5 Applications
The Application Navigator menu is populated with the list of applications configured by the Retail Home Administrator. When you click the application, you are taken to the launch URL configured for that application.
You can access the Applications at any time using:
  • Legacy UI: the Applications Menu.
  • HWAO: the Applications tab in the bottom navigation bar.
Figure 5-1 Application Navigator - Legacy UI
Figure 5-2 Applications - HWAO
Applications - HWAO
The Application Name in Application Navigator is the name configured by Retail Home Admin in the Application Navigator Setup page.
Whenever a new application has been added since the last time the user logged in, the user will be able to see the following:
  • A count of new applications near the Application Navigator icon in the left menu bar.
  • A blue indicator beside the new application name inside the menu.
Once the user has viewed the addition of new application, the indicator is cleared. This is applicable only for newly added applications and not for updated or deleted ones.
