2 Implementation Considerations
IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment is part of the Retail Analytics Platform (RAP) and imports the forecast generated by AI Foundation (AIF). The IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment application is tailored towards the workflow of a Forecast Analyst. Whereas the data scientist would interact with the AIF UI to set low level forecast tuning parameters. The following sections describe the overall implementation flow and whether it is configured on the IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment side or AIF side.
The following information must be considered before configuring Inventory Planning Optimization Cloud Service-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment:
Configuration Considerations
Before implementing IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment, an implementor should first answer the following questions listed in Table 2-1
Table 2-1 Configuration Considerations and Applications
| Consideration | Applications |
Is my forecasted item Long Lifecycle (LLC) or Short Lifecycle (SLC)? |
AIF |
What is the purpose of my forecast? To drive replenishment, allocation, or others? |
Do I need to enable the Lifecyle module to generate the Allocation and Replenishment plans ? Does the retailer have inventory data ? |
Are there any promotions that impact my forecast? If yes, how can I define the promotions? |
AIF |
Based on the purpose of my forecasting, which level should the forecast be generated on (sku/stor/week)? How many escalation levels are needed for the forecasting? Which level should the forecast be exported to? |
IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment, AIF |
What data is available to use for forecasting: rsal, psal, csal, Promotions, or Price? |
What kind of preprocessing is needed: Outage, Outlier, Depromote, or Deseasonalize Smooth? |
AIF |
Do I need the Lifecyle Allocation and Replenishment solution? |
How do I want to handle New Items? Is there any product attribute information? |
IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment |
Do I want to integrate IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment with other Applications? |
If I want to use grouping in my escalation levels, how do I group my item/stores? |
AIF |
Do I need to generate daily forecast, and/or both weekly and daily forecasts? |
Do I have a foundation system to provide foundation (hierarchy) data? |
Depending on the answers to the previous questions, the implementor can use the IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment plug-in to generate IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment configurations. For details about how to generate IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment configuration, refer to IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Configuration. The generated IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment configuration can be customized to satisfy client specific requirement. For details about how to customize IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment configuration, refer to IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Extensibility.
In order to implement planning applications on RAP, you should ensure their foundation data such as Product and Organization hierarchies, align with RMFCS (Merchandising Systems) so that the foundation and transactional data can be used by all applications in RAP. They can have additional alternate dimensions than available in RMFCS (Merchandising Systems), if it is needed for their planning solution.
Customers can use the flex fields available in RAP Foundation files to interface this additional data. Also, if multiple planning applications like MFPCS, APCS, or IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment reside in the same PDS, then the common hierarchies should have the same dimension names to share the data interfaced from RAP. However additional non-shared dimensions can be present in each application.
IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Hierarchies
There are four type of hierarchies in IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment:
Standard RPASCE Hierarchies Files
This is the foundation data to build any RPASCE solution. Inventory Planning Optimization Cloud Service-Demand Forecasting Inventory Planning Optimization Cloud Service-Lifecycle Allocation and Replenishment requires the standard three hierarchy files, Calendar, Product, and Location. Additional sets of hierarchy files specific to different solutions may also be needed. The standard hierarchy files for Calendar, Product, Location and Product Attributes need to be loaded into the RI interface. Refer to the Data Requirements section in the Oracle Retail Analytics Platform Implementation Guide.
The following format only shows the hierarchy structure used by IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment. The file to be loaded needs to conform to the RI interface. The user provides standard RPASCE hierarchy files.
For information on the hierarchy files, see the following sections:
Calendar Hierarchy File (CLND)
| Name | Label | Hierarchy Type | Parent |
DAY |
Day |
Main |
None |
WEEK |
Week |
Main |
DAY |
MNTH |
Month |
Main |
WEEK |
QRTR |
Quarter |
Main |
MNTH |
HALF |
Half |
Main |
QRTR |
YEAR |
Year |
Main |
HALF |
DOW |
DAY OF WEEK |
Alternate |
DAY |
WOYR |
Week of Year |
Alternate |
WEEK |
Product Hierarchy File (PROD)
SKU |
Item |
Main |
None |
SKUP |
Style/Color |
Main |
SKU |
SKUG |
Style |
Main |
SKUP |
SCLS |
Sub-Category |
Main |
SKUG |
CLSS |
Category |
Main |
SCLS |
DEPT |
Department |
Main |
CLSS |
PGRP |
Group |
Main |
DEPT |
DVSN |
Division |
Main |
PGRP |
CMPP |
Company |
Main |
DVSN |
VNDR |
Vendor |
ALT |
SKU |
Location Hierarchy File (LOC)
STOR |
Location |
Main |
None |
DSTR |
District |
Main |
STOR |
REGN |
Region |
Main |
DSTR |
CHNL |
Area |
Main |
REGN |
CHAN |
Chain |
Main |
CHNL |
COMP |
Company |
Main |
CHAN |
SFMT |
Store Format |
Alternate |
STOR |
STCL |
Store Class |
Alternate |
STOR |
PHWH |
Physical Warehouse |
Alternate |
STOR |
STRC |
Location Cluster |
Alternate |
STOR |
CHNC |
Channel |
Alternate |
STRC |
CCTY |
Channel Country |
Alternate |
CHNC |
LOCT |
Location Type |
Alternate |
STOR |
The Store Cluster dimension (STRC) is not used in IPOCS, but is included so as to align with other planning apps (MFPCS, APCS). Currently it is mapped same as the store dimension. It can be customized to bring in clusters from another source field.
Products Attributes Hierarchy File (PATR)
The product attributes hierarchy represents attributes associated with products. These attributes are used to group products within categories.
This hierarchy is intended to capture all product attributes for all product types. The attributes are then assigned to individual products. This assignment is used to calculate similarity scores between items.
The retailer needs to load the Product Attributes into the RI interface. Refer to the Attribute Files section of the Oracle Retail Analytics Platform Implementation Guide.
In IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment, the Product Attribute hierarchy structure is described in this section.
| Name | Label | Hierarchy Type | Aggs |
PATV |
Prod Attribute Value |
Main |
None |
PATT |
Prod Attribute |
Main |
PATV |
The following table describes the fields in this file.
| Field | Description |
The various values that an attribute might have. For example, the package type attribute might take the values bag, box, or convenience. |
Prod Attribute |
The name of a product attribute, such as brand, family type, flavor, grain, package type, size, or temperature. |
In RAP, the product attributes would flow from RI to RDX to PDS. When imported this way into PDS, the product attribute name is concatenated with the product attribute values using ‘_’ to make the product attribute values unique. The Product Attribute name for Supplier (W_PDS_SUPPLIER_D) is used as ‘supp’ and Brand (W_PDS_BRAND_D) is used as ‘brnd’.User Managed IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Hierarchies
The implementor or retailer can update these IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment hierarchy files. The GA IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment package contains these hierarchy files.
These hierarchies can be classified into two categories:
Hierarchies that are configured in AIF and IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment:
Hierarchies that are configured only in IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment:
Offer Hierarchy (OFFH)
This hierarchy represents the offer/promo fields. If promo has been enabled in AIF this hierarchy will be imported during the batch. Refer to the RAP Integration for detailed information. If promo is not enabled in AIF, then the retailer can upload the GA offer hierarchy file. Note that the offer hierarchy needs to be populated for the Forecast Review workbook to build.
File name: offh.hdr.csv.dat
File format: comma-separated values file
offd |
Offer |
Main |
None |
prmd |
Promo |
Main |
offd |
camd |
Campaign |
Main |
prmd |
offa |
Offer Alias |
ALT |
offd |
cama |
Campaign Alias |
ALT |
camd |
Reward Type Hierarchy (RDTH)
This hierarchy represents the reward type that can be associated per offer. If promo has been enabled in AIF this hierarchy will be imported during the batch. Refer to the RAP Integration for detailed information. This hierarchy is needed to build the Offer Analysis workbook. This workbook is useful only if promo is enabled.
File name: rdth.hdr.csv.dat
rdtp |
Reward Type |
Main |
None |
Supplier Hierarchy (SUP)
This hierarchy represents the list of suppliers. This hierarchy is imported during the batch. Refer to the RAP Integration chapter for detailed information.
File name: sup.hdr.csv.dat
supp |
Supplier |
Main |
None |
Example:
supp,supp_label
v1001,Supplier 1
v1002,Supplier 2
v1003,Supplier 3
Alert Hierarchy (ALT)
Alert hierarchy contains alerts for Inventory Planning Optimization Cloud Service-Lifecycle (IPOCS-Lifecycle). Alerts can be defined during implementation time.
File name:alt.hdr.csv.dat
altr |
Alert |
Main |
None |
altt |
Alert Type |
Alternate |
altr |
altp |
Alert Priority |
Alternate |
altr |
altc |
Alert Class |
Alternate |
altr |
alth |
Alert Hierarcy |
Alternate |
altr |
Example:
altr,altr_label,altt,altt_label,altp,altp_label,altc,altc_label,alth,alth_label
alert.c01,C01 Permanent,com,Common,3_l,3 Low,filter,Filter,prod-loc,PROD-LOC
alert.c02,C02 Seasonal,com,Common,3_l,3 Low,filter,Filter,prod-loc,PROD-LOC
Business Rule Attribute Hierarchy File (ATTH)
This is attribute hierarchy used in the Business Rule Engine functionality. Note that this is different from the PATR (Product Attribute) hierarchy. This hierarchy file is a hybrid between user-loaded attributes and IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment GA calculated attributes generated by the plug-in. Refer to the Appendix: IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Business Rule Engine for detailed information on Business Rule Engine.
File name: atth.hdr.csv.dat
ATTD |
Attribute |
Main |
None |
ATDT |
Attribute Data Type |
Alternate |
ATTD |
ATSC |
Attribute Source |
Main |
ATTD |
ATST |
Attribute Source Type |
Main |
ATSC |
ATTP |
Attribute Type |
Alternate |
ATTD |
Example:
attd,attd_label,atdt,atdt_label,atsc,atsc_label,atst,atst_label,attp,attp_labelbrand,Brand,3,String,ldprdattstr01,loaded Product Attribute 01,load,Loaded Attribute,prod,Product Attributeregn,Region,3,String,regn,region of location Hierarchy,hier,Hierarchy Attribute,loc,Location Attribute
Business Rule Hierarchy File (RULH)
This hierarchy structure is used to associate Business Rules within a Business Rule Group in the Business Rule Engine functionality. The GA hierarchy file loads five placeholder Business Rules per Rule Group. The implementor can customize this file, based on the maximum number of rules the retailer would like to define per Business Rule Group. Refer to the Appendix: IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Business Rule Engine for detailed information on Business Rule Engine.
File name: rulh.hdr.csv.dat
RULD |
Business Rule |
Main |
None |
RULG |
Business Rule Group |
Main |
RULD |
Example:
ruld,ruld_label,rulg,rulg_labelr001,Rule 1,g001,Rule Group 1r002,Rule 2,g001,Rule Group 1 r003,Rule 3,g001,Rule Group 1 r004,Rule 4,g001,Rule Group 1 r005,Rule 5,g001,Rule Group 1
Condition Hierarchy File (CONH)
This is the Condition hierarchy used to organize the strategies (conditions) in defining a business rule. Refer to the Appendix: IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Business Rule Engine for detailed information on Business Rule Engine.
File name: conh.hdr.csv.dat
COND |
Rule Condition |
Main |
None |
Example:
cond,cond_labelcond01, condition 01cond02, condition 02cond03, condition 03cond04, condition 04
Constraint Group Hierarchy (CSG)
Constraint Group Hierarchy is used for the constraint functionality framework.
File name: csg.hdr.csv.dat
cstg |
Constraint Group |
Main |
None |
Example:
cstg,cstg_label
csg.01,Constraint Group 01
csg.02,Constraint Group 02
Constraint Object Hierarchy (CSO)
Constraint Object Hierarchy is used for the constraint functionality framework.
File name: cso.hdr.csv.dat
csto |
Constraint Object |
Main |
None |
Example:
csto,csto_label
csto.0001,C.0001
csto.0002,C.0002
csto.0003,C.0003
csto.0004,C.0004
Databag Hierarchy (DTB)
Databag Hierarchy allows the grouping of data for planning in IPOCS-Lifecycle Allocation and Replenishment.
File name:dtb.hdr.csv.dat
dtbg |
Databag |
Main |
None |
dtbp |
Databag Partition |
Main |
dtbg |
Example:
dtbg,dtbg_label,dtbp,dtbp_label
dtb.01.01,Fashion.Replenishment.All,dp.01,Databag Partition Fashion 01
dtb.01.02,Fashion.Replenishment,dp.01,Databag Partition Fashion 01
Lifecycle Program Hierarchy (LPR)
Lifecycle Program Hierarchy contains phases of the lifecycle.
File name: lpr.hdr.csv.dat
lprg |
Lifecycle Prog |
Main |
None |
Example:
lprg,lprg_label
lprg_id_1,Phase 1
lprg_id_2,Phase 2
lprg_id_3,Phase 3
List Hierarchy (LST)
List Hierarchy contains lists for rule conditions.
File name: lst.hdr.csv.dat
list |
List |
Main |
None |
Example:
list,list_label
l.01,L.01
l.02,L.02
Rule Hierarchy (RUL)
Rule Hierarchy is for the definition of rules of Lifecycle and Replenishment.
File name:rul.hdr.csv.dat
rull |
Rule |
Main |
None |
rulg |
Rule Group |
Main |
rull |
Example:
rull,rull_label,rulg,rulg_label R.01.01,R.01.01,RG.01,Rule Group Fashion 01
R.01.02,R.01.02,RG.01,Rule Group Fashion 01
Batch Generated Hierarchies
The IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment batch generates this hierarchy file using the Location and Supplier hierarchies:
The IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment batch generates the following hierarchy files using purchase order and transfer order numbers retrieved from RMS:
Source Location Hierarchy File
This hierarchy file defines the locations that can be a source of a product.
File name: slc.hdr.csv.dat
SL0L |
Source Location Main |
Main |
None |
SL01 |
Source District |
Main |
SL0L |
SL0G |
Source Region |
Main |
SL01 |
SL03 |
Source Channel |
Main |
SL0G |
SL0P |
Source Chain |
Main |
SL03 |
SL05 |
Source Company |
Main |
SL0P |
SL11 |
Source Store |
Alternate |
SL0L |
SL21 |
Source Class |
Alternate |
SL0L |
SLTY |
Source Location Type |
Alternate |
SL0L |
Example:
sl0l,sl0l_label,sl01,sl01_label,sl0g,sl0g_label,sl03,sl03_label,sl0p,sl0p_label,sl05,sl05_label,sl11,sl11_label,sl21,sl21_label,slty,slty_label 1000,New York City,1000,US,1000,North America,1000,The Americas,1000,Bricks & Mortar,100,JCB Trading Company,4,4,A,A,s,Store w1001,w1001 Regional Warehouse 1,none,None,none,None,none,None,none,None,1,Retailer Ltd,none,None,none,None,w,Warehouse v1001,Supplier 1,supplier,Supplier,supplier,Supplier,supplier,Supplier,supplier,Supplier,100,JCB Trading Company,supplier,Supplier,supplier,Supplier,v,Supplier
Purchase Order Number Hierarchy File
This hierarchy file defines purchase order number positions.
File name: ponh.hdr.csv.dat
pon |
pon_label |
Main |
None |
Example:
pon,pon_label 12345678,12345678
Transfer Order Number Hierarchy File
This hierarchy file defines transfer order number positions.
File name: tfnh.hdr.csv.dat
tfn |
tfn_label |
Main |
None |
Example:
tfn,tfn_label 123456789123,123456789123
Plug-in Generated IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Hierarchies
The IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment plug-in generates this hierarchy files based on the IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment configuration:
Final Level Hierarchy File
This hierarchy file defines the Business Rule Group Types associated with a Final Level. Refer to the Appendix: IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Business Rule Engine for detailed information on Business Rule Engine.
File name: flvh.hdr.csv.dat
RGTP |
Business Rule Group Type |
Main |
None |
FLVL |
Final Level |
Main |
RGTP |
Example:
rgtp,rgtp_label,flvl,flvl_labelaprv01,approve 01,01,01 Weekly Units Forecastnavi01,navigation 01,01,01 Weekly Units Forecast
RHS Hierarchies
The PROR and LOCR internal hierarchies are mirrored hierarchies of the PROD and LOC hierarchies. They are also referred as PROD RHS and LOC RHS. In the RPAS Cloud Edition versions 19.0 and later, PROR and LOCR are considered as virtual hierarchies. Refer to the Oracle Retail Predictive Application Server Cloud Edition Configuration Tools User Guide for information on Virtual Hierarchies.
Since these hierarchies are virtual, you do not have to load the hierarchy files. All of the other operations remain the same. You can register measures on PROR and LOCR and include them in workbooks.
Notes about these virtual hierarchies:
PROR and LOCR hierarchies have been marked as virtual in the GA configuration.
We cannot define security dimension on a virtual hierarchy or make them translatable.
Virtual hierarchies cannot have user defined dimensions.
If a retailer is upgrading from a pre-19.0 IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment version, then IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment will automatically mark them as virtual and conform to the virtual hierarchy requirements.
IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment Input Data
A detailed data set is required to use the capabilities of IPOCS-Demand
Forecasting / IPOCS-Lifecycle Allocation and Replenishment to its
fullest. Some of the data required is relatively easy to obtain, for
example, information about sales. To simplify the data integration,
all measure files are configured to be loaded as one measure per file.
Each measure's data must be present in a separate file and the file
name must be the same as the measure name with the .csv.ovr extension. All files must be in csv format. During the initial domain
build, all data files marked as required are needed with historical
data to build the domain. Some of the Lifecycle measure data that
can be logically grouped together are loaded into the same file.
Measure Name and Intersections
Because many RPASCE measure names and intersections are dynamically generated by IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment plug-in. Tokens are used to represent the IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment level names. The labeled intersection were also listed for measure intersection
Table 2-2 lists the Token names.
Table 2-2 Token Names
| Token Name | Description |
_CF_ |
Forecast Final Level Name, such as 01 |
#LLC_frcst_L_# |
Forecast final level intersection generated by plug-in based on user specified plug-in input parameters |
#LLC_frcstTS_L_# |
Forecast final level timeseries intersection = LLC final level intersection – clnd dim generated by plug-in based on user specified plug-in input parameters |
#SLS_INTX# |
Sales History intersection. This labeled intersection is user defined |
#SLSNC_INTX# |
Sales History intersection -clnd dim This labeled intersection is user defined |
#NIT_ATT_WGT# |
Attribute weight intersection, generated by plug-in based on user specified plug-in input parameters |
#NIT_SKU_ATT# |
Product attribute intersection, generated by plug-in based on user specified plug-in input parameters |
#NIT_SKUSTR_INTX# |
New Item assignment intersection, generated by plug-in based on user specified plug-in input parameters |
#PRESLS_INTX# |
Forecast Preprocessing data source input intersection |
#LP_P0S# |
Lowest level in Product hierarchy foe example, SKU |
#LP_L0L# |
Lowest level in Location hierarchy foe example, stor |
#LP_P0G# |
Product group scope defined in the Lifecycle plugin foe example, clss |
#LP_L0G# |
Location group scope defined in the Lifecycle plugin foe example, regn |
Measure Names and Descriptions
Table 2-3 lists the measure names and descriptions. The measure field descriptions include:
Module Used
This field explains which solution is using the file. The possible values can be:
All
New Item
Forecast
Preprocess
Inventory Planning Optimization Cloud Service-Lifecycle Allocation and Replenishment (IPOCS-Lifecycle Allocation and Replenishment)
Required or Optional Required
This field means the data is necessary. Optional means that during data load and, if not loaded, certain functionality which uses those measures cannot be used. All administration measures are marked as Optional for data load, since those can be directly set in the Admin workbooks as well.
Load Frequency
This specifies the suggested frequency for the data load. It uses the following values:
Daily
Weekly
Anytime as needed or when the values change in source system; it can be weekly, monthly, quarterly, or yearly
Data Source
This specifies the typical data source to get that measure data:
RI - Oracle Retail Insights or equivalent Data Warehouse solutions
Admin - Data can be set by Administrator based on customer data referencing sample data in GA domain.
IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment or equivalent. Can be readily loaded from RMS or derived from data loaded from RMS.
ORASE - Oracle Retail Advanced Science. Those are the derived measure files extracted from ORASE integration files.
RMS - Oracle Retail Merchandising System or equivalent. Can be readily loaded from RMS or derived from data loaded from RMS.
3P - Third-party data aggregator such as Nielsen or Symphony IRI.
Load Intersection
Most of the time, the load intersection of the measure is the same as the base intersection of the measure. When the field is empty, the load intersection is the same as base intersection.
Table 2-3 RPASCE Measure Names and Intersections
| Measure Name | Measure Description | Base Intersection | Measure Type | Module Used | Required or Optional | Load Frequency | Data Source | Load Intersection |
rsal |
Regular Sales |
#SLS_INTX# |
Real |
all |
Required |
Weekly |
RMS/RI |
#DAYSLS_INTX# |
psal |
Promotion Sales |
#SLS_INTX# |
Real |
all |
Required |
Weekly |
RMS/RI |
#DAYSLS_INTX# |
csal |
Clearance Sales |
#SLS_INTX# |
Real |
all |
Required |
Weekly |
RMS/RI |
#DAYSLS_INTX# |
ldactivefcstitem |
Active Forecast Item Indicator |
#SLSNC_INTX# |
Boolean |
all |
Optional |
Weekly |
prdattT |
Product Attribute |
#NIT_SKU_ATT# |
String |
New Item |
Optional |
Weekly |
RMS/RI |
nitdattwgt |
Attribute Weight |
#NIT_ATT_WGT# |
Real |
New Item |
Optional |
Weekly |
nitfcststovr |
New Item Forecast Start Date |
#NIT_SKUSTR_ INTX# |
Date |
New Item |
Optional |
Weekly |
nisros |
New Item Base Rate of Sales |
Real |
New Item |
Optional |
Weekly |
likeitemexmask |
Like Item Exclusion Mask |
Boolean |
New Item |
Optional |
Weekly |
LPInBookedU |
Input Booked Units |
sku_stor |
Real |
LAR |
Optional |
Daily |
RI |
LPInOnHandU |
Input On Hand Units |
sku_stor |
Real |
LAR |
Required |
Daily |
RI |
LPInCustOrdU |
Input Cust. Order Units |
sku_stor_day |
Real |
LAR |
Optional |
Daily |
RI |
LPInInitFcstPLWkU ext_initfrcst.csv |
Initial Buy Plan Week Units (Pre-Season Forecast) |
sku_stor_week |
Real |
LAR |
Optional |
Daily |
IPO/MFP |
LPInInTrnsU |
Input In Transit Units |
sku_stor_day |
Real |
LAR |
Required |
Daily |
RI |
LPInOnOrdInU |
Input On Order (in) Units |
sku_stor_day |
Real |
LAR |
Required |
Daily |
RI |
LPInOnOrdOutU |
Input On Order (out) Units |
sku_stor_day |
Real |
LAR |
Optional |
Daily |
RI |
LPInOTBV otb.csv |
OTB value |
clss_stor |
Real |
LAR |
Optional |
Daily |
External/AP |
LPInOTBPriceV otb_price.csv |
OTB price |
sku_stor |
Real |
LAR |
Optional |
Daily |
External/AP |
LPInExtAstPLE assortment.csv |
Ext. Asst. Prod-Loc |
sku_stor |
Integer |
LAR |
Optional |
Daily |
LPInExtAstPLEndDt assortment.csv |
Ext. Asst. Prod-Loc End Date |
sku_stor |
Date |
LAR |
Optional |
Daily |
External/AP |
LPInExtAstPLStrDt assortment.csv |
Ext. Asst. Prod-Loc Start Date |
sku_stor |
Date |
LAR |
Optional |
Daily |
External/AP |
LPInDspQU |
Display Qty Units |
sku_stor |
Real |
LAR |
Optional |
Daily |
RI |
LPInFixTS1U init_alloc.csv |
Fixed TS 1 Units |
sku_stor |
Real |
LAR |
Optional |
Daily |
External |
LPInActLocRcpU |
Input Actual Loc. Recpt Units |
sku_stor_week |
Real |
LAR |
Optional |
Daily |
LPInFrcstWkU ext_frcst.csv |
Input Week Forecast Units |
sku_stor_week |
Real |
LAR |
Optional |
Daily |
lppmlfcphsorderi |
Lfc. Phase Order |
lprg |
Integer |
LAR |
Required |
*LAR is an abbreviation for Lifecycle Allocation and Replenishment |
Following is a sample header line for each of the files that are loaded together (if loading flat files):
assortment.csv.*: sku,stor,LPinextastple,LPinextastplstrdt,LPinextastplenddt
* indicates that the file extension could be either .rpl or .ovr.
Historical Data
It is recommended that you have at least two full years of historical data for long life cycle forecasting and one full year of historical data for short life cycle forecasting.
Loading and Extracting Data
Data is loaded into IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment using the Online Administration Tools, which in turn use standard RPASCE utilities. For more information on loading and extracting data using Online Administration Tools, see the Oracle Retail Inventory Planning Optimization Cloud Service-Demand Forecasting / Inventory Planning Optimization Cloud Service-Lifecycle Allocation and Replenishment Administration Guide
Loading Image Based Data
IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment is pre-configured to support the display of images for items and product attributes in the Forecast Review and New Item workbooks. Table 2-4 lists the dimension attribute measures used to load images.
Table 2-4 Labeled Intersections
| Measure | Hierarchy | Dimension |
skuimage |
PROD |
sku |
skupimage |
PROD |
skup |
skugimage |
PROD |
skug |
skurimage |
PROR |
skur |
skprimage |
PROR |
skpr |
skgrimage |
PROR |
skgr |
patvimage |
PATR |
patv |
pattimage |
PATR |
patt |
The Content Server exposes the client's image files placed into a particular directory as HTTP URLs. The images must be defined in the load file in an xml format. The images are available at:
http://{content server url}/imgfetch/{sub
directory if defined}
Sample File for skuimage.csv.ovr
The first field represents the SKU ID followed by the required image location. At a minimum, a thumb size image file must be loaded to show in the pivot table. However, both the thumb and full size images can be loaded.
10000010,"<image id=""main"" label=""Front View"">\<url size=""thumb"">http://msp00alq.us.oracle.com:9001/contentserver/imgfetch/sku_10000010_main_thumb.jpg</url></image>"
Example File for skuimage.csv.ovr
10000010,"<image id=""main"" label=""Front View"">\ <url size=""thumb"">http://msp00alq.us.oracle.com:9001/contentserver/imgfetch/sku_10000010_main_thumb.jpg</url> <url size=""full"">http://msp00alq.us.oracle.com:9001/contentserver/imgfetch/ sku_10000010_main_full.jpg</url></image>"
Integration
IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment is part of the Retail Analytics Platform (RAP). The foundation data needs to be loaded into the RI data interface. Any hierarchy or data specific for IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment can be loaded via the File Transfer Service (FTS).
User Roles and Securities
To define workbook template security, the system administrator grants individual users, or user groups, access to specific workbook templates. Granting access to workbook templates provides users the ability to create, modify, save, and commit workbooks for the assigned workbook templates. Users are typically assigned to groups based on their user application (or solution) role. Users in the same group can be given access to workbook templates that belong to that group alone. Users can be assigned to more than one group and granted workbook template access without belonging to the user group that typically uses a specific workbook template. Workbook access is either denied, read-only, or full access. Read-only access allows a user to create a workbook for the template, but the user cannot edit any values or commit the workbook. The read-only workbook can be refreshed.
For more information on security, see the Oracle Retail Predictive Application Server Cloud Edition Administration Guide. For more information on data security in a cloud environment, see the Hosting Policy documents for the cloud solution.
Internationalization
Internationalization is the process of creating software that can be translated more easily. Changes to the code are not specific to any particular market.
Oracle Retail applications have been internationalized to support multiple languages.
The RPASCE platform supports associated solution extensions and solution templates.
A solution extension includes a collection of code and generally available configurations. Typically, solution extensions are implemented by a retailer with minimal configuration.
A solution template does not include code. A solution template is most typically implemented as a retailer configuration.
Oracle Retail releases the translations of the RPASCE server and client, as well as strings from the solution extensions.
Translations of the solution templates are released. All templates have the ability to support multi-byte characters.
For more information on internationalization, see the Oracle Retail Predictive Application Server Cloud Edition Administration Guide.
Translations are available for IPOCS-Demand Forecasting / IPOCS-Lifecycle Allocation and Replenishment for the following languages:
English (United States, Great Britain, Canada, Australia)
Chinese (Simplified)
Chinese (Traditional)
Croatian
Dutch
French
German
Greek
Hungarian
Italian
Japanese
Korean
Polish
Portuguese (Brazilian)
Russian
Spanish
Swedish
Turkish
For information about adding languages for the first time or for translation information in general, see the Oracle Retail Predictive Application Server Cloud Edition Administration.
