Override Safety Stock Levels for Set of Stores
To override safety stock levels, complete the following steps:
  1. View a plan that contains the desired product, locations, and time frame (see View a Plan).
  2. Click the Aggregate table, in the Stores Tab column header for a week that overlaps the time that you wish to update.
  3. The AO Panel is displayed. The level and location do not require updating (see Advanced Options Panel).
  4. Scroll down until the Optimization Setting policy type is visible.
  5. Click the Override button to the right of the Optimization Settings table (see Policy Tables ).
  6. The Edit Area is displayed.
  7. Update the Min and Max fields as desired, along with the start and end dates for the time period for the changes.
  8. Click Apply to redisplay the policy tables with the updates.
  9. A new row appears in a unpublished table for the optimization settings.
  10. Click the Publish button at the bottom of the AO Panel (see AO Panel Main Buttons).
  11. When the processing is completed, a Publish Completed notification is created (see Notifications).
  12. To see a plan that contains the updates, view a plan that contains the same product, locations, and time frame (see View a Plan).
