4 Users, Roles and Privileges
LPO enforces two independent layers of access control: role-based security, which governs what actions a user can perform, and data-level security, which governs which merchandise and location data a user can see and act on. Both must be configured correctly before a user can work with Rules Based Regular Pricing runs and recommendations.
Role-Based Security
Role-based security in LPO is managed through Oracle Identity Cloud Service (IDCS) role assignments. Each LPO role grants a defined set of privileges: the actions a user is permitted to perform within the application. A user may hold multiple roles simultaneously, and their effective privileges are the union of all privileges across their assigned roles. Role assignments are managed by the Pricing Administrator.
Data-Level Security
Data-level security restricts which merchandise hierarchy nodes and locations a user can view and act on, independent of role-based privileges. For example, a Pricing Analyst may have the privilege to accept recommendations but can only accept recommendations for the departments and zones assigned to them in data-level security. Data-level security is configured per user by the Pricing Administrator.
End-to-End Workflow and Role Context
Rules Based Regular Pricing follows a six-stage workflow. Understanding this flow helps users see where their role, privileges, and responsibilities fit in the overall pricing process.
Figure 4-1 Workflow Stages
User Roles and Responsibilities
For Rules Based Regular Pricing, the following roles are typically involved.
Table 4-1 User Login Roles
Role IDCS Role Responsibility
Pricing Analyst PRICING_ANALYST_JOB PRICING_ANALYST_JOB_PREPROD Primary day-to-day user. Creates ad hoc runs, runs the recommendation process, reviews recommendations, and accepts, rejects, or overrides prices on the Manage Recommendations workspace.
Regular Price User REGULAR_PRICE_JOBREGULAR_PRICE_JOB_PREPROD Application role required to access and manage Rules Based Regular Pricing recommendations. This role is typically assigned together with the Pricing Analyst or Pricing Manager role.
Pricing Manager(Analytical Super User) PRICING_MANAGER_JOB PRICING_MANAGER_JOB_PREPROD Configures and maintains N/F rules and strategies in the Control and Tactical Center. Reviews run diagnostics. Creates and evaluates What-If runs to test alternate rule configurations.
Buyer BUYER_JOB BUYER_JOB_PREPROD Owns merchandise departments. Takes final action on reviewed recommendations: Submit or Approve. Both actions trigger export to downstream systems. Can also reject recommendations.
Pricing Administrator ADMINISTRATOR_JOB ADMINISTRATOR_JOB_PREPROD Manages application configuration including Rules Based Regular Pricing enablement using PRO_LPO_REGULAR_LITE_ENABLED_FLG flag, auto-approval criteria, and export frequency rules.
Run and Recommendation Privileges
LPO privileges govern what actions each role can perform on runs and recommendations. The tables below define each privilege and show which roles hold them.
Table 4-2 Privileges on LPO Runs and Recommendations
Privilege Description
Create new LPO run Set up and execute optimization runs, including copying existing runs.
View existing LPO run View run data at each stage. Can search and filter but cannot edit.
Optimize a LPO run Trigger optimization or re-optimization, including for failed runs.
Modify recommendations Accept, reject, or override regular price recommendations.
Review / Undo Review Transition recommendations to Reviewed status, a prerequisite for Submit or Approve.
Submit recommendations Send final recommendations to the export interface for execution by the downstream system.
Approve recommendations Approve recommendations for export. May bypass the Submit step depending on configuration.
Finalize What-If run Promote a finalized What-If run result to replace the current batch recommendations.
Delete a run Remove a run and its recommendations, subject to status restrictions.
Role Based Privileges
Table 4-3 Privileges Based on Data Access and User Role
Privilege Data Scope Pricing Analyst / Regular Price User Pricing Manager Buyer Pricing Administrator
Create/Copy Run All runs ✕ ✓ ✕ ✕
View Run All runs ✓ ✓ ✓ ✕
Modify Run Runs owned by user ✓ ✓ ✕ ✕
Run / Re-run Runs owned by user ✓ ✓ ✕ ✕
Delete saved LPO run Runs owned by user ✓ ✓ ✕ ✕
Modify recommendations Runs owned / batch ✓ ✓ ✓ ✕
Recalculate recommendations Runs owned / batch ✓ ✓ ✕ ✕
Review recommendations Runs owned / batch ✓ ✓ ✓ ✕
Submit recommendations All runs ✕ ✕ ✓ ✕
Approve recommendations All runs ✕ ✕ ✓ ✕
Optimize all technical failures All runs with technical failures ✕ ✕ ✓ ✓
Action Restrictions By Status
Table 4-4 Action Restrictions by Status
Who Object
Auto Approved Cannot be selected for price override, date override, accept/reject, review/submit/approve, undo review, or undo approve actions. These recommendations are processed automatically by the export workflow and cannot be modified manually.
Export Success Must not be pushed again to the downstream pricing system.
Export Failed Can be picked up again by the batch or ad hoc integration push process after the failure is investigated.
Rejected Excluded from downstream export.
