Add a Translation
To add a translation, follow the steps below:
- Select Actions > Translate or use the Translate button, if available. The Translations drawer appears as an overlay on top of the screen.
Click the Create Translation button. The New Translation drawer appears.
Figure 3-2 New Translation
- The system’s primary language and your current language are displayed at the top of the page along with the primary language values for the fields that can be translated.
- In the Language field, select the desired language from the list. This is a required field.
- In the Translated fields, enter the desired translation or click the Generate button to obtain an AI-generated translation. Depending on the entity being translated, there may be more than one translatable field. For example, stores have two translatable fields, store name and secondary name.
- If the translation was generated, review and refine the translation as desired.
- Then choose one of the following options.
- Click Create to add the translation to the table and close the page.
- Click Create and Add Another to add translations in additional languages.
- Click Cancel to reject all entries and close the page.
- To exit the Translations drawer, click the X at the top of the drawer.
