Custom Flexible Attributes – Group Sets
Custom Flexible Attributes (CFAS) can be defined at the store level. Each CFAS group set defined at the store level will display as a separate section on the Store page. CFAS Groups will be displayed as sub-sections with the associated attributes displayed as fields within the sub-section. If information has already been entered in the section, it will display in a read-only format upon entering the page. To edit the information, click the Edit button in the upper right corner of the section. This will display the section in an input state where the fields are enabled for entry and edit. After changes are made to return to the read-only state, click the Update button to save changes or the Cancel button to discard all edits.
Figure 3-34 Custom Flexible Attribute – Group Sets
