Working with Error Order Batches
- Introducing Order Batches describes the process of working with batched orders from a high-level point of view.
- Working with an Order Batch describes how to review, correct, and accept orders received from an external system that are in error.
- Performing Batch Order Entry describes how to work with the individual orders in the batch.
- Accepting or Rejecting the Order Batch describes how to release the individual orders in a batch on the system once the batch is in balance or how to reject the entire batch, if necessary.
You can work with the following types of order batches.
Batch Orders and Web Orders
Web orders that fail the order edit: If an order received through the Generic Order Interface (Order API) does not pass the order edit, or if it does not include payment information, it is retained in the Default Batch for E-Commerce Orders in Error (G41). However:
- If the order_channel is P and the order is not part of a batch, the system places the order in the Batch Number for Retail Channel Orders (I78) if it has errors.
- If a retail pickup or delivery order does not pass the order edit, it is retained in the Order Broker Error Batch Number (K90). If this system control value is blank, retail pickup and delivery orders in error are assigned to the same batch as e-commerce orders in error. See Retail Pickup (including Ship-for-Pickup) or Delivery Orders for background.
For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
To correct web orders in error: You can use batch orders to review, work with, and approve web orders that failed the order edit. Select Edit/Accept on the Work with Error Orders Batches Screen to edit the order batch. The system runs the same order edit that is performed when you receive orders through the Generic Order Interface (Order API). When an order passes the order edit, the system removes the batch number from the order, updates its status to open, performs pick slip preparation, and makes it available in regular order maintenance and inquiry. If an order fails the order edit, the system includes the order on the Print Remote Order Errors Report and retains the order in an error status in the order batch.
Batch Orders and Membership Orders
Membership orders that fail the order edit: If a membership order generated through Generating Membership Orders (EGMO) does not pass the order edit, the order remains in a suspended status and is placed in a generated order batch, using the next number in the Order Batch (A01) number assignment wheel.
To correct membership orders in error: You can use batch orders to review, work with, and approve membership orders that failed the order edit. Select Edit/Accept on the Work with Error Orders Batches Screen to edit the order batch. The system runs the same order edit that is performed when you receive orders through the Generic Order Interface (Order API). When an order passes the order edit, the system removes the batch number from the order, updates its status to open, performs pick slip preparation, and makes it available in regular order maintenance and inquiry. If an order fails the order edit, the system includes the order on the Print Remote Order Errors Report and retains the order in an error status in the order batch.
Order batching allows you to review, correct, and accept orders received from an external system that are in error.
Web orders: If an order received through the Generic Order Interface (Order API) does not pass the order edit, or if it does not include payment information, the system places the order in an order batch; see Batch Orders and Web Orders. Select Edit/Accept on the Work with Error Orders Batches Screen to edit and approve the batch. Even if the batch is error-free, you will still need to approve it manually.
In this topic:
- Default Values for Orders Screen (Selecting Error Order Batches)
- Work with Error Orders Batches Screen
- Work with Orders within a Batch Screen
Purpose: Use this screen to advance to the Work with Error Order Batches screen.
About this screen: Each field on this screen is described in Setting Defaults in Order Entry; however, you must select the Error order batches field to select to work with orders in error. Entries to the other fields on this screen are optional.
Purpose: This screen displays the order batches in the system that contain orders in error. The value in the Assigned to user field controls which batches display. If blank, this screen lists all the order batches in the system.
Threshold: The Suspended Batches threshold value controls the length of time in which a suspended order batch remains on the system. Any order batches beyond this threshold are deleted automatically during a periodic process.
User ID: This screen also displays the user ID of the person currently working with an order batch. Only one person can work on a batch.
Screen use: Use this screen to:
- Work with an order batch. Orders in the batch remain in a suspended
status until you accept the batch. For each order batch, you can:
- Edit and accept the orders in the order batch.
- Reject an order batch.
- Add, delete, or work with an order in the batch at the Work with Orders within a Batch Screen.
- Review, work with, and edit orders received through the Generic
Order Interface (Order API) that did not pass the order edit or
do not include payment information; see Batch Orders and Web Orders.
- You can select Edit/Accept to edit the order batch. The system
How to display this screen:
- Select Error order batches on the Default Values for Orders Screen (Selecting Error Order Batches).
- Select OK to display the Work with Error Order Batches screen.
Field | Description |
Assigned to user |
The user ID of the person who created the order batch. All order batches display if this field is blank. The system assigns your default user to orders received through the Generic Order Interface (Order API) that contain errors. For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).Alphanumeric, 10 positions; optional, assigned by the system. |
Batch suspended |
Indicates whether the screen lists only suspended batches or all batches. The system suspends a batch if the keyed cash and/or order controls do not match the actual cash and/or order controls. Valid values include:
The system default is to display only the unbalanced batches because these batches need to be worked on. You must enter (or continue to enter) orders for the batch, adjust the cash or order controls for the batch or correct the orders in the batch to bring the batch into balance. If you select this field, every batch currently on the system is listed. Note: A threshold value controls the length of time in which an order batch remains on the system. After this period, the system deletes order batches automatically during a periodic process. |
Batch # |
The number assigned by the system to a group of orders within an order batch. Web orders: If an order received through the Generic Order Interface (Order API) does not pass the order edit, or if it does not include payment information, it is retained in the Default Batch for E-Commerce Orders in Error (G41). However:
Numeric, 5 positions; display-only, assigned by the system. |
Date |
The date on which the order batch was created. Numeric, 6 positions (in user date format); display-only, assigned by the system. |
# orders |
The number of individual orders assigned to the order batch, regardless of order status and including orders that have been processed and no longer display in the batch. The system includes all orders whose Batch # field in the Order Header table matches the order batch number. Numeric, 5 positions; display-only. |
$ value |
The total dollar amount of orders entered for this batch during Order Entry. The system updates this field as you enter and accept each order in the batch. Numeric, 13 positions with a 2-place decimal. |
In use by |
The user ID of the person currently working with the batch. Only one person at a time can access a batch. If the batch is locked by another user because, for example, the user’s session ended unexpectedly, you can use Unlocking a Stranded Order or Batch (MULO) to unlock the batch. Alphanumeric, 10 positions; display-only, updated by the system. |
Screen Option | Procedure |
Review, delete or enter orders for the batch |
Select Work with Orders for a batch to display the Work with Orders within a Batch Screen. |
Reject and remove the entire batch |
Select Reject for a batch to reject and delete the batch. Select OK at the Confirm Reject Window to perform this action. See Accepting or Rejecting the Order Batch. |
Run the order edit batch program and print the Print Remote Order Errors report for an order batch |
Select Edit/Accept for an order batch to run the order batch edit and print the Print Remote Order Errors Report. See Accepting or Rejecting the Order Batch for the updates that occur. |
Purpose: Use this option to:
- Review the orders assigned to the batch
- Delete an order from the batch
- Work with an order in the batch
- Review the order totals for an order in the batch
- Add an order to the batch
How to display this screen: Select Work with Orders for an order batch at the Work with Error Orders Batches Screen.
Batch# |
The number assigned by the system to a group of orders within an order batch. Numeric, 5 positions; display-only, assigned by the system. |
Sts Order status |
The status of the order, as assigned by the system. Batched orders may have a Suspended, Open or Quote status. Suspended/Error Batched orders are suspended in an error status until the errors are corrected. When you correct the errors on an order, the status of the order in the batch changes to Open. Open Pick slips may be printed for orders in an open status. Additionally, these orders are available for maintenance and inquiry. Quote If the Quote field for the order type on the order is selected, the system considers the order a pre-order quote and not a standard order. Quotes in a batch are entered in a Quote status and remain in a Quote status until you convert the quote to an order in Quote Maintenance. See Entering Pre-Order Quotes for an overview. Other status codes are: Held, Cancelled or Closed. Alphanumeric, display-only, updated by the system. |
Order # |
A unique number assigned by the system to identify an order. Numeric, 8 positions; display-only. |
Ord date |
The date the order was created. Numeric, 6 positions (in user date format); display-only. |
Sold to |
The last name, first name and initial or the company name of the customer who placed the order. Alphanumeric, 41 positions; display-only. |
#Rcp |
The number of recipients for this order, which indicates the number of different shipping addresses associated with the order number. The system assigns a sequential ship-to number to every order, even if the shipping address and the sold-to address are the same. Numeric, 3 positions; display-only. |
Total paid |
The dollar amount you received from the customer on all prepaid (cash/check payments) for the order. Numeric, 20 positions with a 2-place decimal; display-only. |
Pmt |
Indicates whether a payment method exists on the order.
Delete an order from the batch |
Select Delete for the order to delete it. The system writes a record in the Deleted Order Table for the order. |
Go into an order in the batch to change or verify order information before you accept the entire batch |
Select Ship To’s for an order listed for the batch to advance to Order Entry (in “review” mode). You must accept or reject the order when you are through. |
Review the order totals for the order |
Select Display order totals for the order to display the Display Order Totals Window. |
Enter another order for the batch |
Select Create. See Performing Batch Order Entry for more information about the batching process during Order Entry. See also Entering Orders for details on how to enter an order. |
Purpose: This topic describes the differences you see during Order Entry when you work with an order in an order batch. This topic identifies the screen differences on each major Order Entry screen during Batch Order Entry. The screens display this way only if you select the Error order batches field at the Default Values for Orders Screen (Selecting Error Order Batches).
Only the fields and command keys that apply to Batch Order Entry are described in this topic.
Refer to Entering Orders for field-by-field descriptions and instructions for performing Order Entry. Whether entering batched or unbatched orders, this process remains the same.
When you complete the Batch Order Entry process, which means that you update and accept each order in the batch, you must accept the entire batch to release these orders on the system. See Accepting or Rejecting the Order Batch if you have completed the orders in the batch and wish to process or delete the batch.
In this topic:
- Select Customer Sold To For Order Screen
- Work with Order Screen (Batch Order Entry)
- Completing Order Entry
Purpose: Use this screen to specify the customer for the order in the order batch, by:
- Entering the customer number, if you know it, or
- Entering information in any of the scan fields to obtain a list of customers who closely match this information, or
- Selecting Create to enter an order for a new customer.
How to display this screen: Select Create at the Work with Orders within a Batch Screen.
If the ORCE Customer Integration (L37) system control value is set to INTERACT, you advance instead to the Customer Scan Screen.About this screen: This screen is described fully in Selecting Customers in Order Entry; however, in batch order entry the Batch # field is listed at the top of the screen to indicate that you are entering orders for a batch.
Batch # |
The batch number for which you are entering the current order. The batch number is a number assigned by the system to a group of orders. Numeric, 5 positions; display-only, assigned by the system. |
Review or update defaults for several Order Entry fields |
Select Change Defaults to display the Change Defaults pop-up window. See Setting Defaults in Order Entry. |
Enter an order for a new customer |
Select Create to advance to the Work with Order screen. See Entering Orders. |
Review the orders already entered in the batch |
Select Maintain to display the Work with Orders within a Batch Screen. |
Purpose: The following screens identify the differences in the Order Entry screens when batching orders. See Entering Orders for a complete discussion and a sample of these screens.
Batch# |
Purpose: You return to the Work with Orders within a Batch Screen when you accept or reject each order in the batch.
Select one of the following options on the Work with Error Orders Batches Screen when you finish working with the orders in the batch:
- Select Edit/Accept to accept all the orders in the batch.
- Select Reject to reject and delete the entire batch.
See Accepting or Rejecting the Order Batch if you are through entering the entire batch.
Purpose: This topic describes the processes that the system performs when you select Edit/Accept for a batch to accept the entire batch or you select Reject Batch for a batch to reject and delete the batch.
In this topic:
- Rejecting the Batch
- Accepting the Batch
- Performing Online Credit Card Authorizations
- Accepting an Order in the Batch
- Accepting the Entire Batch
When to accept or reject: You accept or reject a batch of orders when you finish entering the individual orders in a batch; see Performing Batch Order Entry.
Rejecting the Batch
You may want to reject an order batch if the order batch contains orders that you wish to delete.
Select Reject Batch to reject and delete the batch. You advance to the Confirm Reject Window. Select OK to reject the batch.
The system prints the Rejected Batch Listing, deletes the orders from the system, and deletes the batch itself.
Deleted Order table: The system writes a record in the Deleted Order Table for each purged order.
If the batch includes a retail pickup or delivery order from Order Orchestration, the BROKER process sends a status update rejecting the order; also, it deletes the related Order Orchestration and Order Orchestration History records. See Retail Pickup (including Ship-for-Pickup) or Delivery Orders for an overview.
Accepting the Batch
Select Edit/Accept on the Work with Error Orders Batches Screen to edit the order batch. The system runs the same order edit that is performed when you receive orders through the Generic Order Interface (Order API) and includes any orders in error on the Print Remote Order Errors Report.
If an order fails the order edit, the system includes the order on the Print Remote Order Errors Report and retains the order in an error status in the order batch. Select Work with Orders for the order batch to advance to the Work with Error Orders Batches Screen where you can review and correct the errors on each order. When you have finished updating each order, select Edit/Accept again to edit and accept the remaining orders in the order batch.
Online credit card authorization allows you to send and receive electronically the information required to authorize a credit card at the time the order is placed instead of at the time the pick slip is generated for the order.
The system performs online authorization when you accept an order batch after determining if any order in the batch should go on hold.
If an order in the batch is eligible to receive a credit card authorization during batch order entry, the system sends the amount requiring authorization to the authorization service and waits for a response.
There are 3 types of responses you can receive from the authorization service.
- R = an authorization response was received, such as declined or approved.
- T = the program timed out before an authorization response was received.
- U = an undefined response was received.
Additionally, if an authorization response is received, the authorization service sends back an authorization response code, AVS response code (if performing address verification), card security response code (if performing credit card security identification), authorization code, and date.
If a hold reason code has been defined for the vendor response, AVS response, or CID response received, the system places the order on hold.
Credit cards requiring authorizations less than $1.00: If the credit card amount to authorize is less than $1.00 and you have defined an authorization number in the Authorization Number for Authorizations Under $1.00 (I08) system control value, the system does not send the credit card to the service bureau for authorization and instead assigns the authorization number from the system control value to the credit card. If an authorization number is not defined in this system control value, the system sends the credit card to the service bureau for authorization, regardless of the amount that requires authorization.
Performing Online Verification Only: If the Online Auth Verification Only (I96) system control value is selected, the system processes online authorizations for $1.00 for the purpose of validating the card. During batch authorizations, the system authorizes the card for the shippable dollar amount and voids the online authorization for $1.00.
For more information: See Performing Online Credit Card Authorizations for an overview of the online credit card authorization process and the required setup.
Purpose: The system performs updates to a number of tables to reflect the addition of a new order to the batch. The updates occur:
- Immediately, as you enter an order to the batch.
- When you accept the order or accept the order and add a recipient order.
- During a background processing job (ORDR_ASYNC).
Immediate Updates
The system updates the SKU and Item/Warehouse tables immediately as you enter a new order to the batch.
Process | Table | Field |
Update the Item/Warehouse record for each item ordered |
Item/ Warehouse |
On hand qty (if express-billed order) ITW B/O qty Reserve qty S/H reserve qty ITW On order qty |
Update the SKU record |
SKU |
SKU Orders avail pick gen SKU Open qty SKU On hold qty |
Additionally, the system updates the following tables as you enter a new order:
- Customer Sold To
- Customer Sold To Extended Address
- Customer Sold To Phone #
- Customer Bill To
- Customer Bill To Extended Address
- Customer Bill To Phone #
- Customer Ship To
- Customer Ship To Extended
- Customer Ship To Phone #
- Customer Action Notes
- Order Additional Charges
- Order Detail
- Order Detail Data Queue
- Order Free Gift
- Order Header
- Order I/T Lines
- Order Information
- Order Line History
- Order Line Messages
- Order Messages
- Order Payment Method
- Order Pending Checks
- Order Selected Item
- Order Ship To
- Order Ship To Address
- Order Ship To Data Queue
- Order Special Handling
- Order Transaction History
- Reserved Order Lines
Updates at Accept
The system performs these table updates when you accept each order in the batch.
Reprice order if the Pricing method field in the Source Code record is set to a Reg Plus Reprice |
Order Detail |
ODT Price |
Evaluate free gift eligibility, based on the source code or offer; create order detail records for free gift, if applicable |
Order Detail |
All fields |
Calculate the $ Discount, based on Source or Offer; add a record to the Order Additional Charges table |
Order Additional Charges |
All fields |
Sends balance of updates to background processing job (O/P ASYNC) |
Order transaction history: When you accept an order that is part of an order batch, the system writes an order transaction history message with a Type of Maintenance indicating the user that accepted the order. The system writes an order transaction history message each time a user accepts the order so that you can track the users that changed the order in the batch prior to accepting the order batch. You can review order transaction history messages on the Display Order History Screen.
An example of the order transaction history message the system creates when a user accepts an order that is part of an order batch is displayed below. The system includes an amount regardless of whether the change updated the order total.
Date | Type | Transaction Note | Amount | User |
8/14/14 |
MAINT |
Order changed while in unaccepted batch |
45.00 |
SFLYE |
The system does not create an order transaction history message if a user rejects out of an order that is part of an order batch. If a user accepts an order in order maintenance that is no longer part of an order batch, the system writes an order transaction history message indicating:Order was maintained
Additional updates when you accept the entire batch: The system performs these updates to the individual orders in the batch only when you accept the entire batch (see Accepting the Entire Batch):
- Perform the credit check processes
- Evaluate for refund eligibility
- Update the Flash Report
- Evaluate and update the order status based on the detail line status, if necessary
- Update the Online Authorization, Authorization History, and Void Authorization tables if you performed online credit card authorization
- Applies pick slip preparation to each eligible order; see Applying Pick Slip Preparation to an Order
Updates During Background Processing
The system performs the balance of the field and table updates during a background processing job (O/P ASYNC) that runs after you accept each order in the batch.
Update the Price Override Reason table, based on price overrides at detail line level |
Price Override Reason |
POR # of overrides POR Total discount |
SKU |
Date of first order Date of last order |
Update the SKU/Price History record |
SKU Price History |
SPH # orders SPH $ orders |
Update the SKU/Offer Page record for offer page analyses |
SKU/Offer Page |
Dollars ordered CTD Dollars ordered WTD Dollars sold out CTD Dollars sold out WTD Units ordered CTD Units ordered WTD Units sold out CTD Units sold out WTD SOP Dollars upsell CTD SOP Dollars upsell WTD SOP Units upsell CTD SOP Units upsell WTD SOP Units lost CTD SOP Units lost WTD |
Update the Order/Billing History record |
Order/Billing History |
OBH # Orders OBH $ Order total OBH Qty ordered OBH # Orders sold out OBH $ Sold out total OBH Qty sold out |
Add a record to the Soldout Notifications table to generate soldout notifications for sold-out items |
Soldout Notifications |
Update the sold-to customer record |
Customer Sold To Order History |
COH On order $ COH # Orders LTD COH # Sold outs LTD COH $ Orders LTD COH $ Sold outs LTD COH Last Card Number COH Active since date COH Last order date OTY Order type PAY Pay type SRC Source code |
Update the ship-to customer record |
Customer Ship To Order History |
HOH On order $ HOH # Orders LTD HOH # Sold outs LTD HOH $ Orders LTD HOH $ Sold outs LTD HOH Active since date HOH Last order date OTY Order type PAY Pay Type SRC Source code |
Update operator statistics, based on order type |
Order Type/ User |
OTU # Orders TD OTU # Orders LTD OTU $ Value - TD OTU $ Value - LTD OTU # Receipts TD OTU # Recips LTD OTU # Lines TD OTU # Lines LTD |
Update operator statistics by accounting period, based on order type |
Order Type/ User History |
OUH # Orders OUH $ Value OUH # Recips OUH # Lines |
Update the source code record with the accumulated order totals |
Source |
$ Orders $ Soldouts # of Orders # of Soldouts |
Purpose: The system updates several tables:
- When you accept the entire batch
- During a background processing job that runs automatically after you accept a batch or an order in the batch
See Working with the ORDR_ASYNC Job for more information on the background jobs.
Updates at Accept
The system performs these table updates when you accept the batch. See Performing the Release and Introducing Order Hold Reason Codes for more information about the credit check process that evaluates customers, orders, and payment types and performs record updates if any condition on the order fails a credit check.
Credit check: sold-to customer unconditional hold |
Order Header SKU |
OHD OHR Sys hold reason SKU On hold qty |
Credit check: sold-to customer fraud |
Order Header Order Header SKU |
OHD Order status OHD OHR Sys hold reason SKU On hold qty |
Credit check: sold-to customer zip code fraud |
Credit check: bill-to customer unconditional hold |
Order Header SKU |
Credit check: bill-to customer zip code fraud |
Order Header SKU |
Credit check: ship-to/ sold-to customer fraud |
Order Ship To Order Header Order Ship To SKU |
OST OHR Hold reason OHD OHR Sys hold reason OST Order status SKU On hold qty |
Credit check: ship-to/ sold-to customer zip code fraud |
Order Ship To Order Header SKU |
OST Order status OHD OHR Sys hold reason SKU On hold qty |
Credit check: ship-to customer fraud |
Credit check: ship-to customer zip code fraud |
Credit check: dollar hold |
Order Header SKU |
Credit check: time hold |
Pay Type Order Header SKU |
OHR Hold reason OHD OHR Sys hold reason SKU On hold qty |
Credit check: check fraud |
Credit check: balance due exceeds the $ amount |
Order Header SKU |
Credit check: pay types |
Order Header SKU |
Credit check: credit card fraud |
Credit check: credit card authorization pending status |
Credit check: outstanding balance due |
Credit check: email address fraud |
Evaluate order for refunds; create refund records for overpayments or balance dues |
Refunds |
All fields |
Update the Operations Control Summary (Flash) Report |
Order Control Summary |
# Orders entered $ Orders entered Quantity ordered # Orders soldout/clsd $ Orders soldout Quantity soldout $ Open backordered Quantity backordered $ Held backordered Qty held backordered |
Update order header and order ship-to status to match status of detail lines if all lines canceled. |
Order Header Order Ship To |
OHD Order status OST Order status |
Approved online credit card authorization: Create an online authorization record, authorization history record, and void authorization record if you performed online credit card authorization for a credit card payment method on the order |
Online Authorization Authorization History Void Authorization |
Online Authorization: company order # seq # auth amount vendor response 1(auth response) vendor response 2 (CID response) auth # auth date status: *UPDT trans seq # card number terminal # AVS result card security value ASV auth service Authorization History: All fields except Amount Deposited Void Authorization: All fields |
Declined online credit card authorization: Create an online authorization record and authorization history record if you performed online credit card authorization for a credit card payment method on the order |
Online Authorization Authorization History |
Online Authorization: company order # seq # auth amount vendor response status: *SENT trans seq # card number terminal # ASV auth service Authorization History: All fields except Amount Deposited, Auth Date, and Auth # |
Undefined online credit card authorization response: Create an online authorization record and authorization history record if you performed online credit card authorization for a credit card payment method on the order |
Online Authorization: company order # seq # auth amount vendor response auth # auth date status: *UPDT trans seq # card number terminal # ASV auth service Authorization History: All fields except Amount Deposited |
Online credit card authorization communication failure: Create an online authorization record and authorization history record if you performed online credit card authorization for a credit card payment method on the order |
Online Authorization: company order # seq # auth amount auth # auth date status: *UPDT trans seq # card number terminal # ASV auth service Authorization History: All fields except Amount Deposited, Auth Date, Auth #, and Vendor Response |
Clear order batch number: If the order is a membership order, an e-commerce order or a retail order, the system clears the order batch number upon acceptance. Determined by:
Order Header |
OBA Batch # |
For a retail pickup or delivery order, sends a status update to Order Orchestration to change the status in Order Orchestration to Accepted. Also, change the status of the Order Orchestration record to In process. See Retail Pickup (including Ship-for-Pickup) or Delivery Orders |
Order Orchestration |
Status |
Create pre-generated picks |
Pick Control Header Pick Control Detail Pick Control Label Pick Stored Value Card |
See Applying Pick Slip Preparation to an Order for the updates that are performed |
The system performs the balance of the field and table updates during a background processing job (ORDR_ASYNC) that runs after you accept the entire batch.
SKU |
SKU Price History |
SKU/Offer Page |
Order Type/ User |
OTU # Orders TD OTU # Orders LTD OTU $ Value - TD OTU $ Value - LTD OTU # Recips TD OTU # Recips LTD OTU # Lines TD OTU # Lines LTD |
Source |
