Customer Price Group Pricing
Customer price group pricing allows you to price the items on an order based on the customer price group assigned to the sold to customer on the order. The system determines the initial price of the item based on the Price type assigned to the customer price group and applies any qualifying discounts to the order during line-level pricing and end-of-order pricing.
In this topic:
- Customer Price Group Pricing Setup
- Line Level Customer Price Group Pricing
- Examples: Line Level Customer Price Group Pricing
- Customer Price Group Price Code Pricing
- Examples: Customer Price Group Price Code Pricing
- Customer Price Group Best Price Comparison
- Examples: Customer Price Group Best Price Comparison
- Customer Price Group Pricing in Order Maintenance
Before you can use the customer price group pricing method, you must complete the necessary setup.
- Menu Options for Customer Price Group Pricing
- System Control Values for Customer Price Group Pricing
| Menu Option | Description |
Create customer price groups to assign to sold to customers. For each customer price group:
Use the Price group field to assign sold to customers to a customer price group. Note: You can also pass the price group code in the Inbound Order XML Message (CWORDERIN) or the Inbound Customer Message (CWCustomerIn). When you assign the customer price group through the order API, the new order is eligible for any pricing or promotions associated with the price group. If you create an order for a customer that is not assigned to a customer price group, or is assigned to an invalid customer price group code, the system assigns the customer price group code defined in the Customer Price Group Code for CPG Pricing Only (L58) system control value to the customer.For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1). |
For each item/SKU: Define the Original price of the item.
Define the Regular price of the item.
Assign the item/SKU to an offer in order to assign the item/SKU to a price code using the Assigning Price Codes (APCD) menu option. |
Create price codes to offer a special price or discount for an item or group of items. Optionally, use the Work with Qualifying Customer/Price Groups Screen to define the sold to customers and customer price groups that qualify for the price code. Note: If you do not define any sold to customers or customer price groups for a price code, then ALL sold to customers and customer price groups qualify for the price code. Note: Order lines that are assigned to a price code do not qualify for the discount defined for the customer price group assigned to the sold to customer on the order. To apply the customer price group discount to order lines that are assigned to a price code, embed the customer price group discount in the price defined for the price code. Example: If the customer price group provides a 30% discount, create the price code discount so that it includes the 30% discount. |
Define which items are eligible for the special price or discount specified in a price code. You can assign the item to one or more price codes by offer or source code. |
Create the price override reason code to assign to order lines that are priced using a customer price group price and cannot be further discounted. However, you can still apply an order-level coupon to these order lines. |
To perform End of Order Customer Price Group Pricing during repricing, the Price method field for the source code on the order header must be set to Reg Plus Reprice. |
Create promotions to apply a further discount to eligible order lines. |
Entity level override: You can set up pricing value overrides for an entity that should use different pricing logic from your company-wide standard. In order entry, the system checks the entity associated with the source code on the order header to determine if entity-level pricing overrides are in effect. However, if you enter a customer price group in the Customer Price Group Code for CPG Pricing Only (L58) system control value, entity-level pricing overrides are NOT in effect. The system always uses the customer price group pricing method, regardless of the pricing values defined at the entity level.
| System Control Value | Description |
Customer Price Group Code for CPG Pricing Only (L58) |
Enter a customer price group code if you wish to use customer price group pricing. The system uses this customer price group:
Note: If you enter a customer price group code in this system control value:
Enter the price override reason code to assign to order lines that are priced using a customer price group price and cannot be further discounted. However, you can still apply an order-level coupon to these order lines. |
