Customer Price Group SKU Exclusion Upload
Overview: The Customer Price Group SKU Exclusion Upload allows you to upload customer price group SKU exclusion information from an external system to create or update records in the Customer Price Group SKU Exclusion table.
Customer Price Group SKU Exclusion allows you to define the items/SKUs that are not eligible for the customer price group discount applied to an order during Customer Price Group Pricing.
If an item contains SKUs, you can exclude all SKUs for the item or indicate the specific SKUs you wish to exclude from the customer price group discount.
In this topic:
- Customer Price Group Exclusion Upload Setup
- Customer Price Group SKU Exclusion Upload Process
- Customer Price Group Exclusion Upload Errors
- CPG Item/SKU Exclusions Upload Error Records Report
For more information: See Working with Customer Price Groups (WCPG).
The setup required to use the customer price group SKU exclusion upload includes:
Use the following steps to upload Customer Price Group SKU Exclusion records from an external system.
| # | Step |
1. |
Create a customer price group SKU exclusion text file that contains the records to upload. See the Customer Price Group SKU Exclusion Upload Table for details on file contents. |
Populate the Customer Price Group SKU Exclusion Upload Table using the contents of the text file:
2. |
Execute the CPGIXUP Customer Price Group Item Exclusion Upload Periodic Function to submit the Customer Price Group Exclusion Upload process. The system submits the process for the specified company. |
3. |
The system updates the Processed field for each record in the Customer Price Group Exclusion Upload table to blank to include all records in the upload process. |
4. |
The system processes the records in the Customer Price Group Exclusion Upload table in Seq # order. |
5. |
The system validates each record in the Customer Price Group SKU Exclusion Upload Table. The required fields are:
Optionally, you can define:
6. |
If the record in the Customer Price Group SKU Exclusion Upload table does not pass validation, the system:
A record in error remains in the Customer Price Group SKU Exclusion Upload table until you fix or delete it. The system validates the record again the next time you submit the Customer Price Group SKU Exclusion Upload Process. |
7. |
If the record in the Customer Price Group SKU Exclusion Upload table passes validation, the system:
You can review and maintain customer price group SKU exclusions on the Work with Customer Price Group Exclusions Screen in the Working with Customer Price Groups (WCPG) menu option. |
Create records in the Customer Price Group SKU Exclusion Upload table to create or update records in the Customer Price Group SKU Exclusion table.
To populate:
- Create a customer price group SKU exclusion text file that contains the records to upload.
- Upload the records from the file to the Customer Price Group SKU Exclusion Upload table:
- Use the File Storage API to upload the file to the FILE_STORAGE table, and then run the UPCSTPG Upload Customer Price Group Exclusion File (Program name PFR0134, Parameter CUSTPGEUP) periodic function, or
- Use the Work with File Uploads (WUPL) menu option to upload the records in the text file to the Customer Price Group SKU Exclusion Upload table.
You can use the sample data below to create records in the text file for upload.
7|1|CPG|RF123SKU4567|ROSE XSML WMNS||
To leave any field in the upload file blank, pass a space in the field so that the file can be processed without errors. Leaving a field with no space is interpreted as null in the database and causes errors.For more information: See Customer Price Group SKU Exclusion Upload Process for a discussion of the complete upload process.
| Field | Description |
| Company |
Required. A code for the company associated with the Customer Price Group SKU Exclusion Upload record. The system processes only records associated with the company from where the Customer Price Group SKU Exclusion Upload Process was submitted. Company codes are defined in and validated against the Company table. Updates Company in the Customer Price Group SKU Exclusion table. Numeric, 3 positions. |
| Seq # |
Required. A unique number assigned to each Customer Price Group SKU Exclusion Upload record. The system processes the records in the Customer Price Group SKU Exclusion Upload table in ascending sequence number order. Numeric, 9 positions. |
| Customer Price Group |
Required. The code for the customer price group associated with the item/SKU exclusion. Customer price group codes are defined in and validated against the Customer Price Group table. Updates Customer Price Group in the Customer Price Group SKU Exclusion table. Alphanumeric, 4 positions. |
| Item |
Required. A code for the item you wish to exclude from the customer price group discount. Item codes are defined in and validated against the Item table. Updates Excluded Item in the Customer Price Group SKU Exclusion table. Alphanumeric, 12 positions. |
| SKU |
Optional. The SKU of the item you wish to exclude from the customer price group discount.
SKU codes are defined in and validated against the SKU table. Updates Excluded SKU in the Customer Price Group SKU Exclusion table. Alphanumeric, 14 positions. |
| Error Description |
Updated by the system during the Customer Price Group SKU Exclusion Upload Process. The reason why the Customer Price Group Exclusion Upload record has been placed in an error status. See Customer Price Group Exclusion Upload Errors. Alphanumeric, 20 positions. |
| Processed |
Updated by the system during the Customer Price Group SKU Exclusion Upload Process. The status of the Customer Price Group Exclusion Upload record. Valid values:
Alphanumeric, 1 position. |
Use the CPGIXUP periodic function to submit the Customer Price Group SKU Exclusion Upload Process based on the contents of the Customer Price Group SKU Exclusion Upload Table.
| Option | Setting |
| Function: | CPGIXUP |
| Description: | CPG ITEM EXCLUSION UPLOAD |
| Program name: | PFRCPGEXUP |
| Company |
The Company flag must be selected. The Customer Price Group SKU Exclusion Upload process creates, updates, and deletes records in the Customer Price Group SKU Exclusion table based on the records in the Customer Price Group SKU Exclusion Upload Table using the company you entered when you submitted the CPGIXUP periodic function. |
- The CPGIXUP periodic function is delivered with the system; use the Working with Periodic Functions (WPER) menu option to review it.
- Use the Working with Periodic Processes (WPPR) menu option to assign the UPCSTPG and CPGIXUP periodic functions to a periodic process.
- Once you have created the periodic process, you can use the Execute Periodic Process screen (located in the Working with Periodic Processes (WPPR) or Executing Periodic Processes (EPRO)) to define a schedule for the job. See Defining the Job Schedule.
For more information: See Scheduling Jobs for more information on How to Schedule a Job.
The system includes records in the Customer Price Group SKU Exclusion Upload Table that are in error on the CPG Item/SKU Exclusions Upload Error Records Report.
| Error | Reason |
Invalid Company |
The Company is missing, invalid, or inactive. |
Invalid Cust Prc Grp |
The Customer Price Group is missing or invalid. |
Invalid Item |
The Item is missing or invalid. |
Invalid SKU |
The SKU is not valid for the specified item. |
