Display Order History Screen
Purpose: Use this option to review any type of activity that occurred since the order was entered, including order activity received through the Generic Order Transaction History API. The system logs all order history automatically for inquiry purposes, including when the order was:
For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
- Authorized, reauthorized, or declined
- Canceled
- Held
- Maintained
- Released
- Logged as a sale (when the invoice was generated)
- Shipped
- Sold out
The system records these activities against the order on the Display Order History screen. The system can record up to 999 transactions for each order. This information remains on the system for inquiry purposes until the order is purged.
Subscriptions: The system also records order history for each subscription generation. This occurs when you are Generating the Subscription Extract Table (WGSE) for items identified as subscriptions (if the Subscription field for the Item is selected). For example, six entries would be logged to the Order History for a 6-month subscription, reflecting each time another issue of the subscription item is included in the Subscription Extract file.
Information captured: The system captures the following information on the Display Order History screen:
- Date and time of activity
- Type of activity
- Transaction note
- Amount
- User ID
Tracking packages: Use the Package Info option to advance to the Display Package Information Screen, where you can review shipment tracking numbers and, depending on the ship via, advance to the shipper’s web site to review tracking history. The Package Info option is available if you have received any tracking numbers related to shipments on the order.
Streamlined order inquiry: As an alternative to standard order inquiry, the Streamlined Order Inquiry (DORI) option provides a consolidated, one-page view of the order, including a pop-up window displaying order history.
Special characters? If there are any special characters in the Order Transaction History message, the system replaces the first special character, excluding any underscores, with a space when you advance to this screen.
How to display this screen: Select Order History at the:
- Work with Order Lines Screen in order maintenance
- Order Inquiry Header Screen or Order Inquiry Detail Screen
| Field | Description |
| Order # |
A unique number to identify an order. Numeric, 9 positions; display-only, assigned by the system. |
| Sold to (Sold to customer name) |
The name of the customer who placed the order. Last nameThe customer's last name. Alphanumeric, 25 positions; display-only. First nameThe customer's first name. Alphanumeric, 15 positions; display-only. InitialThe initial of the customer's middle name. Alphanumeric, 1 position; display-only. |
| Ship to (Ship to customer name) |
The name of the customer to receive the order. These fields are blank if the Sold To Customer receives the order. Last nameThe customer's last name. Alphanumeric, 25 positions; display-only. First nameThe customer's first name. Alphanumeric, 15 positions; display-only. InitialThe initial of the customer's middle name. Alphanumeric, 1 position; display-only. |
| Date |
The date when the order activity occurred. Numeric, 6 positions (in user date format); display-only, updated by the system. |
| Type |
A code for a type of update against the order. The OTH_TRANSACTION_TYPE code in the ORDER_TRANSACTION_HISTORY table is indicated in parentheses. Valid values are described below. Related Transaction Notes are also described if they add additional information. If an Amount is specified for the entry, it is mentioned below as well; otherwise, the Amount is blank.
For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1). Narvar notices: When you use the Narvar Integration, the Letter notification type for a shipment email can be:
For more information: See Narvar Troubleshooting.
For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1). Note: Starting with release 18.0, the system no longer creates Maintenance records for activity updates from Order Orchestration. See above for the individual records created when an order is accepted, shipped, picked, or picked up.Note: A separate Order Canceled record is created when an order is canceled in maintenance only if no items have shipped for the order.
Note: Starting with release 18.0, the system no longer creates a Pick Gen (P) record when a stock allocation error occurs.
Note: If the quote was canceled during maintenance, a maintenance (M) record is also created, indicating the cancel reason.
For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1). |
Note: Contact Center does not display the ROL Error under Order Activity.
Display-only, updated by the system. |
| Transaction note |
The description of the activity related to the transaction, such as:
Alphanumeric, 40 positions; display-only, updated by the system. |
| Amount |
The total order amount following the order activity, including merchandise, freight, tax, handling, etc. No amount is associated with issuing a subscription, as the system bills the customer for the entire amount of the subscription when billing the order. For an order cancellation (before any items have shipped), the dollar amount listed includes freight, regardless of whether the Recalculate freight option was selected at order cancellation. Numeric, 20 positions with a 2-place decimal; display-only, updated by the system. |
| User |
The user ID of the person who performed this activity against the order.
For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1). Alphanumeric, 10 positions; display-only, updated by the system. |
| Option | Procedure |
Display the time when the order activity occurred |
Select Display Time for an order activity to advance to a window that displays the Transaction note, Date, and time, in HH:MM:SS format, when the order activity occurred. |
Track packages or display carton contents |
Select Package Info to advance to the Display Package Information Screen, where you can review shipment tracking numbers and, depending on the ship via, advance to the shipper’s web site to review tracking history. The Package Info option is available if you have received tracking numbers or carton contents information through the Generic Pick In API (Shipments, Voids, and Backorders). For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1). |
