Display Order Line History Screen
Purpose: Use this option to review any type of activity that has occurred since this item was entered.
The system logs all item history automatically for inquiry purposes, including order line activity received through the Order Line History In API, and displays this information on the Display Order Line History screen.
For more information see the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1).
Streamlined order inquiry: As an alternative to standard order inquiry, the Streamlined Order Inquiry (DORI) option provides a consolidated, one-page view of the order, including a pop-up window whose contents include order line history.
How to display this screen: Select History for an item at the Order Inquiry Detail Screen or at the Work with Order Lines screen in order entry.
| Field | Description |
| Order # |
A unique number to identify an order. Numeric, 9 positions; display-only, assigned by the system. |
| Ship to number (unlabeled field) |
A hyphen (-) separates this field from the Order# field. Indicates the number of shipping addresses for the order. The system assigns a ship-to suffix of 1 to a single recipient order. Numeric, 3 positions; display-only, assigned by the system. |
| Line # |
The detail line number of this item on the order. Numeric, 3 positions; display-only. |
| Item |
A code for a unit of inventory. Item codes are defined in and validated against the Item table. See Performing Initial Item Entry (MITM). Alphanumeric, 12 positions; display-only. |
| SKU (Stock keeping unit; unlabeled fields to the right of the item number) |
The item's special characteristics, such as its size or color. SKUs are defined in and validated against the SKU table. Alphanumeric, three 4-position fields; display-only. |
| Activity |
Indicates the type of update performed for the order line. Order line activity codes are defined in the Order Line Activity table; see Working with Order Line Activity Codes (WOLA). System Delivered Order Line Activity Codes are:
Note: If the cancel reason code had the Reduce demand flag selected, the activity is listed as a Change rather than as Item Partially Cancelled.
Display-only, updated by the system. |
| Date |
The date when this activity occurred. Numeric, 6 positions (in user date format); display-only, updated by the system. |
| Quantity |
The quantity of the item affected by this activity. For example, 3- indicates that three units of the item were canceled. Activities that do not affect the order quantity, such as changing the pricing of the order line, do not display a quantity here. This quantity is displayed differently depending on how the item was sold out; see Processing Auto Soldout Cancellations (MASO). Also, see each individual Activity, above, for more information. Numeric, 5 positions; display-only, updated by the system. |
| Exc reason (Exchange reason code) |
Represents a reason for the customer to exchange one item for another. Exchange reasons are defined in and validated against the Exchange Reasons table; see Establishing Exchange Reason Codes (WEXR). Numeric, 3 positions; display-only. |
| Can reason (Cancel reason code) |
The reason for canceling the units or reducing the quantity. A cancel reason code is not stored for soldout cancellations, whether you sell out the item by selecting Sold-out in order entry or order maintenance, or through Processing Auto Soldout Cancellations (MASO); however, the Auto Soldout Cancel Reason (C20) is displayed here if a backordered line was canceled at billing because the Canc B/O (Automatically cancel backorders) flag for the order was selected. Cancel reason codes are defined in and validated against the Cancel Reason table; see Establishing Cancel Reason Codes (WCNR). Numeric, 2 positions; display-only. |
| Rtn reason (Return reason code) |
Represents a reason for the customer to return an item. Return reasons are defined in and validated against the Return Reason table; see Establishing Return Reason Codes (WRTR). Numeric, 3 positions; display-only. |
| Add reason (Add reason code) |
Represents a reason for adding an item to the order. The system requires an add reason code if:
Add reason codes are defined in and validated against the Add Reason table; see Establishing Add Reason Codes (WADR). Alphanumeric, 5 positions; display-only. |
| User |
The user ID of the person who performed this activity. Your default user ID defaults for some activities. In most cases, the ID of the user who maintained the order is displayed; however, activities that show the ID of the user who started the async jobs are indicated in the description of the Activity, above. The user ID does not display if you sell out an item through Processing Auto Soldout Cancellations (MASO) rather than order entry or order maintenance. Alphanumeric, 10 positions; display-only, updated by the system. |
