Sales Order Data Extract Job History
Purpose: Use the Sales Order Data Extract Job History screen to review summary information on the sales order data extracts that have taken place for an organization.
Used for the Routing Engine module.
How to display this screen: Click the history icon (
) for
an organization at the View Active Schedules screen.
- Only users with View Active Schedules authority can display this screen. See the Role Wizard for more information.
- Available only if the Sales Order Data Extract is currently enabled, or if there are any data extract records that have not been purged.
- If the Sales Order Data Extract Job History screen was already open in another tab when you clicked the history icon, you advance to this screen with the order data extract history of the previously-selected organization displayed.
- History is retained for the number of days specified in the Job History retention setting at the Tenant-Admin screen.
Maximum number of orders: The extract fails if the total number of orders to extract exceeds 500,000. If this occurs, use the Extract Orders with Activity From and To at the Schedule Jobs screen to run the extract for smaller segments by specifying date ranges to include each time, rather than including all orders.
For more information: See the Sales Order Data Extract for information on generating the extract, and see Sales Order Data Extract Files for information on the data included in the extract files.
Options at this screen
| Option | Procedure |
| Search for an extract process |
Use the Job Number, Start Date, or Status fields to restrict the displayed extract to those that match your entries and click Search:
| Understand general errors |
If an error occurred for an extract process itself, it is displayed in the Error field. This might occur if, for example, the number of orders to extract exceeded the limit of 500,000. |
Fields at this screen
| Field | Description |
| Summary fields: | |
| Organization |
The code identifying the organization that generated the extract process, and the description of the organization. |
| Search fields: | |
| Job Number |
A unique ID number assigned by Order Broker to identify an export job. Optionally, enter a number and click Search to display this export process only. |
| Start Date |
Optionally, enter a date to display extracts that started on that date. |
| Status |
Optionally, select a status of:
| Results fields: Note: History is retained for the number of days specified in the Job History retention setting at the Tenant-Admin screen. |
| Job Number |
A unique number assigned by Order Broker to identify an export process. |
| Start Date |
The date and time when the export process started. |
| End Date |
The date and time when the export process ended. |
| Duration |
The amount of time it took for the export to run. HH:MM:SS format, but displayed in MM:SS format if the export took less than an hour. |
| Submitted By |
Indicates how the export was submitted. This could be the ID of the user who submitted or scheduled the process, or the client ID used to authenticate the run job API request message. SYSTEM is displayed here if the job ran successfully through a schedule; however, if a scheduled job was rejected, the ID of the user who scheduled the job is displayed. |
| Status |
Indicates whether any errors occurred for the export process:
| Error |
The error that occurred, if any. |
| Order Records |
The total number of order records included in the export process. This total can include both sales orders and purchase orders. |
