Preface
Audience
This Vendor Portal online help is for vendors who use the Vendor Portal.
Documentation Accessibility
For information
about Oracle's commitment to accessibility, visit the Oracle Accessibility
Program website at https://www.oracle.com/corporate/accessibility/
Access to Oracle Support
Oracle customers that
have purchased support have access to electronic support through My
Oracle Support. For information, visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=info or visit http://www.oracle.com/pls/topic/lookup?ctx=acc&id=trs if you are hearing impaired.
Related Documents
Order Broker Cloud Service Release Readiness Guide
Order Broker Cloud Service Operations Guide
Order Broker Cloud Service Modern View Online Help
Order Broker Cloud Service Vendor Portal Online Help
Order Broker Cloud Service Vendor Integration Guide
Order Broker Cloud Service Store Connect Online Help
Order Broker Cloud Service Administration Guide
See the Order Broker Cloud Service 22.2.301.0 documentation library at the following URL:
Customer Support
To contact Oracle Customer Support, access My Oracle Support at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screen shots of each step you take
Improved Process for Oracle Retail Documentation Corrections
To more quickly address critical corrections to Oracle Retail documentation content, Oracle Retail documentation may be republished whenever a critical correction is needed. For critical corrections, the republication of an Oracle Retail document may at times not be attached to a numbered software release; instead, the Oracle Retail document will simply be replaced on the Oracle Help Center Web site.
This process will prevent delays in making critical corrections available to customers. For the customer, it means that you must verify that you have the most recent version of the Oracle Retail documentation set. Oracle Retail documentation is available on the Oracle Help Center at the following URL:
https://docs.oracle.com/en/industries/retail/index.html
An updated version of the applicable Oracle Retail document is indicated by Oracle part number, as well as print date (month and year). An updated version uses the same part number, with a higher-numbered suffix. For example, part number E12345-02 is an updated version of a document with part number E12345-01.
If a more recent version of a document is available, that version supersedes all previous versions.
Oracle Retail Documentation on the Oracle Help Center
Oracle Retail product documentation is available on the following web site:
Comments and Suggestions
Please give us
feedback about Oracle Retail Help and Guides. You can send an e-mail
to: retail-doc_us@oracle.com
Conventions
The following text conventions are used in this document:
Table - Text Conventions
| Convention | Meaning |
boldface |
Boldface type indicates graphical user interface elements associated with an action, emphasis, screen names, book titles, or terms defined in text or the glossary. |
italic |
Italic type indicates field labels or placeholder variables for which you supply particular values. |
Monospace type indicates commands within a paragraph, URLs, code in examples, text that appears on the screen, or text that you enter. |
