Browse Attribute Definitions
Purpose: Use the Browse Attribute Definitions window to review information about an attribute definition.
Used for the Routing Engine module.
For more information: See Using Attribute Rules for Delivery and Pickup Orders and Using Attribute Rules for Ship-for-Pickup Orders for background.
How to display this window: Highlight an attribute definition at the Attribute Definitions screen.
Only users with Attribute Definitions authority can display this window. See the Role Wizard for more information.Fields at this window
All fields are display-only.
| Field | Description |
| Organization |
See organization. |
| Attribute Code |
The Code identifying an attribute you can apply to locations, products, or both. Attribute codes can be 1 to 40 positions in length and must be unique within the organization. |
| Description |
The description of the attribute. Can be up to 100 positions. |
| Attribute Type |
Indicates how you can apply the attribute:
| Ship For Pickup Matching Type |
Indicates whether to filter a location based on its role in fulfilling a ship-for-pickup order:
Note: This setting does not control routing of delivery or pickup orders, and is used only if ship-for-pickup orders are enabled. |
| Allow Multiple |
Set to Yes if multiple values for the attribute can be assigned to the same product or location; otherwise, set to No. Boolean attributes do not support allowing multiples. Also, multiple attribute values cannot be applied to a location when the attribute’s Location Use for the location is set to Originating Location. |
| Data Type |
Indicates the type of data that can be defined through the attribute. Possible data types are:
| Values |
Displays each value that can be applied for a list attribute. Each value can be up to 50 positions. Not displayed for a text, number, or Boolean attribute. |
| Last Updated |
The most recent date and time when the attribute definition was updated. |
Scroll up or down: Click the next arrow (
) to display the next active
schedule, if any. Similarly, click the previous arrow (
) to
display the previous active schedule, if any.
