New Attribute Definition
Purpose: Use the New Attribute Definition screen to complete creation of a new attribute you can assign to products or locations to control order routing.
Used for the Routing Engine module.
For more information: See Using Attribute Rules for Delivery and Pickup Orders and Using Attribute Rules for Ship-for-Pickup Orders for background.
How to display this screen: Begin creation of a new attribute at the Attribute Definitions screen.
- If you click Cancel after advancing to the New Attribute Definition screen, the new attribute is not created.
- Available if Use Routing Engine is selected at the Tenant screen. Only users with Attribute Definitions authority can display this screen. See the Role Wizard for more information.
- If the New Attribute Definition screen was already open in another tab when you clicked the New button, you advance to this screen with the previous new attribute information displayed.
Creating a new attribute
Complete all required fields and, optionally, select the Allow Multiple flag if the Data Type is not Boolean; then click Save. Otherwise, click Cancel. See the field descriptions below for more information.
Update any of the fields described below and click Save, or click Cancel to return to the Attribute Definitions screen without saving the attribute.
| Field | Description |
| Organization |
See organization. Defaults from the Attribute Definitions screen. Required. |
| Attribute Code |
The Code identifying an attribute you can apply to locations, products, or both. Defaults from the Attribute Definitions screen. Attribute codes can be 1 to 40 positions in length and must be unique within the organization. The code can include special characters, but cannot include any spaces. Any lowercase letters entered are automatically converted to uppercase. Required. |
| Description |
The description of the attribute. Defaults from the Attribute Definitions screen. Can be up to 100 positions. Required. |
| Attribute Type |
Note: If an existing attribute definition has an Attribute Type of Location, and Order Broker receives a ProductUpdate JSON request message specifying the attribute, the Attribute Type changes to Product and Location so that the attribute can be applied to a product as well. Similarly, if an existing attribute definition has an Attribute Type of Product, and Order Broker receives a LocationUpdate request message specifying the attribute, the Attribute Type changes to Product and Location so that the attribute can be applied to a location as well. |
| Ship For Pickup Matching Type |
Indicates whether to filter a location based on its role in fulfilling a ship-for-pickup order:
Note: This setting does not control routing of delivery or pickup orders, and is used only if ship-for-pickup orders are enabled. |
| Allow Multiple |
Select if multiple values for the attribute can be assigned to the same product, or to the same location and location use; otherwise, leave blank. For example, select this flag if locations can support pickup of orders with two different brands; in this case, the attribute is assigned to the location for both brands, with a Location Use of Pickup. Boolean attributes do not support allowing multiples. Also, regardless of this setting, multiple values for the attribute cannot be applied to a location with a Location Use of Originating Location. |
| Data Type |
Indicates the type of data that can be defined through the attribute. Defaults from the Attribute Definitions screen. Available data types are:
Required. |
| The following fields are included only when the Data Type is List. | |
| Values |
Use this field to enter each supported value that can be applied for a list attribute. For example, if the attribute is for brand, the values might be the name of each supported brand. Each value can be up to 50 positions. At least one value is required. Click Add Value after entering each new value. Duplicates? If you enter the same value more than once, no error is displayed, and the duplicate value is added to the Current Values area; however, when you save the attribute definition, any duplicates are deleted. Values are case-sensitive. If you enter ABC and abc, both values are saved. |
| Current Values (unlabeled field between the Add Value and Remove Value option) |
The current existing values for the list. You can delete an existing value by highlighting it and then clicking Remove Value. |
