3 XML Messages
Overview on XML Messages
Overview: The following table presents the XML messages processed through Order Management System. It also includes links to the DTD and schema for each message, and a link to a sample XML file illustrating the appearance of the message with every element and attribute populated with character strings.
Opening the files: When you click on the link to a file, it opens in the default program associated with the file. See Integration Layer Processes and Web Services for background and troubleshooting information.
List of Messages with Links to DTDs and Schemas
| Message | Process(es) | In/Out | DTD (in DTD subfolder) | Schema (in schemas subfolder) |
IJCT Processes and Generic Web Services Any of the following XML messages that are processed through the Working with Integration Layer Processes (IJCT) menu option are indicated below. |
N/A |
N/A |
N/A |
N/A |
Authorization Request XML Message (CWAuthorizationRequest) This message is not currently used by any base integration. |
N/A |
out |
Authorization Response XML Message (CWAuthorizationResponse) This message is not currently used by any base integration. |
N/A |
in |
CWAuthorizationResponse_1_0.dtd |
CWAuthorizationResponse_1_0.xsd |
Deposit Request XML Message (CWDepositRequest) This message is not currently used by any base integration. |
N/A |
out |
Deposit Response XML Message (CWDepositResponse) This message is not currently used by any base integration. |
N/A |
in |
Inbound Customer Message (CWCustomerIn) Use this message to: Create or change a customer record. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
CWCustomer web service; can also use CWMessageIn Web Service For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
Outbound Customer Response Message (CWCustomerOut) Use this message to: Indicate whether the create, change, or delete request from the CWCustomerIn message succeeded. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
out |
Customer Download XML Message (CWCustomerDownload) Use this message to: Send information on an existing customer to an external system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
CUST_OUT |
out |
Mass Customer Download XML Message (CWCustomerDownload) Use this message to: Send information on an existing customer to an external system. Note: This message is a subset of the Customer Download message and only includes the Message, CustSoldTo, CustSoldToCrossReferences, CustSoldtoCrossReference, CustTaxes and CustTax elements For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
N/A |
out |
Inbound Customer Search Message (CWCustomerInqRequest) Use this message to: Search for a customer in Order Management System from an external system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
CUST_SRCH; can also use CWMessageIn Web Service For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
Outbound Customer Search Response (CWCustomerInqResponse) Use this message to: Provide one or more customers who match the search criteria submitted by an external system in the CWCustomerInqRequest. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
out |
Customer History Request XML Message (CWCustHistIn) Use this message to: Receive a request for customer history or details on a particular order from an external system. Xstore integration: The CWCustHistIn message is used as part of the Xstore integration. Contact your Oracle support representative for formatting details and configuration requirements for integration with Xstore. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
CUST_HIST; can also use CWMessageIn Web Service For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
Customer History Response XML Message (CWCustHistOut)For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). Use this message to: Provide a list of orders for a customer to an external system. |
out |
Detailed Order XML Response (CWORDEROUT) or Summary Order Inquiry Response XML Message (CWORDEROUT) and Order Acknowledgement XML Message (CWORDEROUT)) Use this message to: Send information on an order to an external system, either in response to a customer history inquiry or to the CWOrderIn message (order API). For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
CUST_HIST ORDER_IN |
out |
Email XML Message (CWEmail) Use this message to: Send emails to Order Management System for correspondence history purposes. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
EMAIL; can also use CWMessageIn Web Service For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
Email Request Message (CWEmailRequest) Use this message to: Generate the store pickup email, notifying the customer that a store pickup order is ready at the selected store. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
Outbound Email XML Message (CWEmailOut) Use this message to: Send email notifications to an external system in order to generate a reformatted email, possibly including promotional information. Note: Version 7.0 or later of the CWEmailOut message is required to generate all possible email notification types. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
EMAIL_OUT |
out |
Inventory Download XML Message (CWInventoryDownload) Use this message to: Send inventory updates to an external system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
INV_ DOWNLD |
out |
Inventory Inquiry Request XML Message (CWInventoryInquiry) Use this message to: Receive an inventory inquiry on a particular item. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
INV_INQURY; can also use CWMessageIn Web Service For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
Inventory Inquiry Response XML Message (CWInventoryInquiryResponse) Use this message to: Send inventory information on a particular item to an external system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
out |
Item Availability Request XML Message (CWItemAvailabilityWeb) Use this message to: Receive an inventory inquiry on a particular item or group of items. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
CWServiceIn Web Service For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
Item Availability Response XML Message (CWItemAvailabilityResponseWeb) Use this message to: Send inventory information on a particular item or group of items to an external system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
out |
E-Commerce Availability Web Request XML Message (AvailabilityWebRequest) Use this message to: Receive an inventory inquiry on the items in a specified company and optionally offer. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
E-Commerce Availability Web Response XML Message (AvailabilityWebResponse) Use this message to: Indicate to the external system whether the request was successful. Note: The actual inventory information is included in the E-Commerce Availability Web XML File (AvailabilityWeb). For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
out |
Invoice Download XML Message (CWInvoiceOut) Use this message to: Send information on an invoice for a shipment or return to an external system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
INVOICE_ OUT |
out |
Inventory Transaction Upload XML Message (inCreateInvXaction) Use this message to: Process inventory transactions and update inventory. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
INVTRANS_ IN; can also use CWMessageIn Web Service For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
Item Download XML Message (CWItemOut) For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). Use this message to: Send information on an existing item to an external system. Message version: The message version of the ITEM_OUT process should be set to 2.0, as version 1.0 of the CWItemOut message includes tags that are not currently supported. See XML Versions for a discussion on setting outbound message versions. |
ITEM_OUT |
out |
| Note: The CWMerchLocRequest and CWMerchLocResponse messages are used only to support processing the LocateItems request and response messages and the Merchandise Locator API, and are not themselves generic API messages. |
NA |
NA |
NA |
NA |
Inbound Order XML Message (CWORDERIN) Use this message to: Create an order that originated at the web storefront or in an external system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
CWOrderIn web service; can also use ORDER_IN IJCT job or CWMessageIn Web Service For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
Order Reject Request Message (CWORDERREJECT) This is a variation on the CWORDERIN message and does not have a separate DTD or schema. Use this message to: Reject an order. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
NA |
NA |
N/A |
N/A |
Order Line History In Message (CWOrdLnHstIn) Use this message to: Create order line history records for a specified line on an order. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
Order Transaction History Message (CWOrderTransactionHistory) Use this message to: Create order transaction history records for a specified order. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
CWPickIn XML Message Use this message to: Receive updates about pick slips from a warehouse management system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
CWPickIn web service |
in |
Pick Message from Order Management System (CWPickOut) Use this message to: Send information on pick slip to an external system. Message version: The message version of the PICK_OUT process should be set to 5.0 or higher, as versions 1.0 through 4.0 of the CW message includes tags that are not currently supported. See XML Versions for a discussion on setting outbound message versions. |
PICK_OUT |
out |
CWProcessIn Message Use this message to: Submit a periodic process. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
See Using the CWProcessIn Message to Start a Periodic Process in the Web Services Guide on My Oracle Support (ID 2149144.1) for more information. | ||
PO Download XML Message (CWPurchaseOrderOut) Use this message to: Send information on a purchase order to an external system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
PO_OUT |
out |
PO Receipt In XML Message (CWReceiptIn) Use this message to: Process purchase order receipts based on information received from an external system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
CWReceiptIn web service |
in |
Return Request Message (CWReturnIn) Use this message to: Create, receive, and credit a return against an order line. Xstore integration: The CWReturnIn message is used as part of the Xstore integration. Contact your Oracle support representative for formatting details and configuration requirements for integration with Xstore For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
RETURN_IN; can also use CWMessageIn Web Service For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
Return Response Message (CWReturnOut) Use this message to: Indicate whether the CWReturnIn message was processed successfully. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
out |
Return Authorization Outbound XML Message (CWReturnRAOut) Use this message to: Send a return authorization request to an external system. |
RETURN_OUT |
out |
Tax Request Message (CWTaxRequest) Use this message to: Send tax information to an external tax system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
TAX_INT |
out |
Tax Response Message (CWTaxResponse) For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). Use this message to: Receive calculated tax from an external tax system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
TAX_INT |
in |
Vendor Download XML Message (CWVendorOut) Use this message to: Send vendor information to an external system. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). Message version: The message version of the VENDOR_OUT process should be set to 2.0, as version 1.0 of the CWVendorOut message includes tags that are not currently supported. See XML Versions for a discussion on setting outbound message versions. |
VENDOR_ OUT |
out |
Generic Workflow XML Message (CWWorkflow) Use this message to: Create a WF workflow event. |
WORKFLOW; can also use CWMessageIn Web Service For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
E-Commerce Product Web XML File (ProductWeb) Use this message to: Send item offer information to an external web storefront. |
Downloading E-Commerce Offer Files (EOFR) if the Generate E-Commerce Offer Tables (M29) system control value is unselected |
out |
E-Commerce Cancel Request Message (CWCancel) For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). Use this message to: Cancel an order or order line. |
in |
E-Commerce Catalog Request Message (CWCatRequest) Use this message to: Create a catalog request. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
in |
E-Commerce Catalog Request Response Message (CWCatreqResponse) Use this message to: Respond to a catalog request. For more information see the Web Services Guide on My Oracle Support (ID 2149144.1). |
out |
E-Commerce Customer Merge Web XML File (CustomerMergeWeb) Use this message to: Send customer sold to merge records to an external web storefront. |
Working with Merge/Purge Sold-to Names (MMCS) if the Generate E-Commerce Customer Merge Staging Files (H86) system control value is selected |
out |
