Advanced Queuing
Advanced queuing allows you to send messages between Order Administration and other applications using database-integrated message queuing.
Advanced queuing is made up of the following components:
| Component | Description |
Queuing Database |
The Oracle database used for queue processing. |
Queues |
An area where messages are stored so that they can be processed in sequential order (first in, first out). |
Queue Table |
Queues are stored in queue tables in the database. |
Message |
The actual data, such as an XML message, that is inserted into and retrieved from a queue. The message contains:
Message log |
The Message log tracks XML and transactional messages generated or received by Order Administration. |
In this topic:
For more information: See:
See Generic Web Services in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for more information on the web services available for Order Administration.
Working with Web Service Authentication (WWSA) for more information on how to define which Order Administration web service endpoints require authentication and the valid web service authentication users or client IDs for each web service
Logs for more information on the Order Administration application logs.
Working with Integration Layer Processes (IJCT) for more information on the processes that transmit data between Order Administration and an external system.
Advanced Queuing Process
Outbound Process Flow
A user or a process in Order Administration calls an outbound integration layer process to send information to an external system.
If the Communication type setting for the outbound integration layer process (IJCT) is set to Message Queue and the status of the integration layer process is active, the process looks at the queue defined for the process. For an outbound process, the queue indicates:
the name of the outbound queue to which the integration layer process sends the message for transmission to the external system; this must be a valid queue in the database used for queue processing.
the name of the XML message generated and sent to the external system.
The system sends the message to the outbound queue defined for the integration layer process.
An external system uses the JMS RESTful web service to retrieve the message from the queue in order to process the message; see the JMS RESTful Web Service for the correct format of the URL for this web service.
The web service authenticator, JMSQueue, in Work with Web Service Authentication (WWSA), defines the user for basic web service authentication for the JMS RESTful web service when it reads from a queue in the queuing database. In addition to defining the web service authentication user in Work with Web Service Authentication (WWSA), you must also create a corresponding user profile in Oracle Identity Cloud Service and assign the user to the corresponding web service role defined for the Order Management application.
Inbound Process Flow
An external system uses an Order Administration web service to send a message to a queue in the database used for queue processing. Note: The target in the message must match the Inbound job name defined on the Integration Layer Process Queue screen in Work with Integration Layer Processes (IJCT). See Generic Web Services in the Order Administration Web Services Guide on My Oracle Support (ID 2953017.1) for more information on the web services available for Order Administration.
If the Communication type setting for an inbound integration layer process is set to Message Queue and the status of the integration layer process is active, the process monitors the queue defined for the process for new messages. For an inbound process, the queue indicates:
the name of the inbound queue that the integration layer process monitors for new messages to process from an external system; this must be a valid queue in the database used for queue processing.
the name of the job that processes the message from the inbound queue.
If the integration layer process finds a new message to process in the queue, the process picks up the message and processes it using existing functionality.
The web service authenticator, JMSQueue, in Work with Web Service Authentication (WWSA), defines the user for basic web service authentication for the JMS RESTful web service when it reads from a queue in the queuing database. In addition to creating the web service authentication user in Work with Web Service Authentication (WWSA), you must also create a corresponding user profile in Oracle Identify Cloud Service and assign the user to the corresponding web service role defined for the Order Management application.
For more information: See Integration Layer Processes and Web Services for more information on the integration layer processes that use a message queue.
Advanced Queuing Setup
Before you can begin using advanced queuing, you must complete the necessary setup.
JMS Server in WebLogic
| # | Step |
1. |
During installation of the application, the JMS server for Order Administration was created and configured in WebLogic. In addition, the OrderManagementNonXADS JDBC data source in WebLogic was created and configured in order to connect to the Order Administration database and advanced queuing database. |
2. |
In Work with Admin Properties (CPRP), the JMS_QUEUE_FACTORY property was set during installation based on the JMS server defined in WebLogic. This property contains the name of the Java Naming and Directory Interface (JNDI) used for queuing; this is the Local JNDI Name as defined in WebLogic. The delivered setting is AqJmsConnectionFactory. Use the following steps to verify the Local JNDI Name in WebLogic:
Queuing Database and Queues Configuration
| # | Step |
1. |
Typical advanced queuing configuration uses the Order Administration database as the queuing database. Make sure the database has open access to use for queue processing. |
2. |
Queues are delivered for the processes in Working with Integration Layer Processes (IJCT); see Delivered Queues. Use the following steps if you wish to create another queue for a job. For each queue you wish to create in the database:
EXEC DBMS_AQADM.CREATE_QUEUE_TABLE (queue_table => 'process_table', queue_payload_type => 'SYS.AQ$_JMS_TEXT_MESSAGE'); where process_table is the name of the queue table you wish to create.
EXEC DBMS_AQADM.CREATE_QUEUE (queue_name => 'process', queue_table => 'process_table'); where process is the name of the queue you wish to create and process_table is the name of the corresponding queue table. Note: the queue name is case-sensitive.
EXEC DBMS_AQADM.START_QUEUE (queue_name => 'process'); where process is the name of the queue you wish to start. The queue must be started in order to enable the queue for processing. Recommended queue naming convention:To easily identify the purpose of a queue, use the following naming convention when creating a queue: PROCESS_DIRECTION where:
Example:
3. |
Queue information is delivered for the processes in Working with Integration Layer Processes (IJCT). Verify the following:
Delivered Queues
The following queues are delivered with the application.
| IJCT Process | Inbound queue | Outbound queue |
CUST_OUT |
CUST_OUT_OUT |
EMAIL_OUT |
EMAIL_OUT_OUT |
INVOIC_OUT |
INVOIC_OUT_OUT |
INVTRAN_IN |
INVTRAN_IN_IN |
INV_DOWNLD_OUT |
INV_DOWNLD_OUT_OUT |
INV_INQURY |
INV_INQURY_IN |
INV_INQURY_OUT |
ITEM_OUT |
ITEMOUT |
PICK_OUT |
PICK_OUT_OUT |
PO_OUT |
PO_OUT_OUT |
RETURN_OUT |
'RETURN_OUT_OUT |
SVC_REVRSL |
SVC_REVRSL_IN |
SVC_REVRSL_OUT |
VENDOR_OUT |
VENDOR_OUT_OUT |
Viewing Messages on a Queue in the Database
Because messages are placed in normal rows in a database table, if you have access to the queuing database, you can query the table using standard SQL.
Use the following SQL command to view existing messages on a queue:
select msgid, enq_time, enq_uid, qt.user_data.text_vc || qt.user_data.text_lob from process_table qt where q_name = 'process'
where process_table is the name of the queue table and process is the name of the queue. Note: the queue name is case-sensitive.
Advanced queuing uses the Java Messaging Service (JMS) as its method to transmit information from the queuing database to an external system. The JMS RESTful web service is used to read from a queue in the queuing database.
The individual URLs for the web service use the following format: http(s)://server:port/SerenadeSeam/sxrs/jms/getFromQueue, where server:port identifies the server where the JMS RESTful web service is located.
In the payload, or message data, include the name of the queue to be read as a JSON string; for example: {"queueName":"process"}, where process is the name of the queue.
Basic Authentication
For security, the RESTful web service endpoint requires basic authentication. In the basic authentication header, you must pass the user ID and password that has access to the queue.
You can define web service authentication using the Work with Web Service Authentication (WWSA) menu option. The web service authenticator, JMSQueue, in Work with Web Service Authentication (WWSA), defines the user for basic web service authentication for the JMS RESTful web service when it reads from a queue in the queuing database.
If the message passes basic authentication, the message will be returned as a JSON string: {"status": "OK", "message": "data"}, where data is the message data.
If there are no more messages to read from the queue, a status of EOF (End Of File) will be returned: {"status": "EOF"}.
If there is a failure, the status will return the error condition; for example: {"status": "JMS-232: An invalid user/password was specified for the JMS connection"}
