ChannelAdvisor Integration
Topics in this part: The following topics describe the integration between Order Administration and ChannelAdvisor.
ChannelAdvisor Integration Overview provides an overview of the various components of the integration.
ChannelAdvisor Setup provides information on the setup required within Order Administration to support the integration.
Working with ChannelAdvisor Accounts (WCAA) describes the screens you use to up accounts, marketplaces, and offers for integration with ChannelAdvisor.
Purpose: Order Administration’s integration with ChannelAdvisor enables you to fulfill orders through the Amazon marketplace. This integration includes:
Sending items/SKUs and their available quantities to ChannelAdvisor: A periodic function creates a file to send all items/SKUs in your company to ChannelAdvisor, indicating the current available quantity of each. A system control value indicates the available quantity to include for non-inventory items, drop ship items, and other items without an inventory requirement, such as virtual gift cards and memberships. Each item/SKU is identified by a cross-reference code, if you have set it up; otherwise, the short SKU code is used. See Sending Current Inventory Information to ChannelAdvisor for details.
The information sent to ChannelAdvisor includes only the short SKU or cross-reference code and the available quantity. It does not include item descriptions, images, or any other information. -
Sending current pricing to ChannelAdvisor: A periodic function creates a file to send item/SKU pricing to ChannelAdvisor. Prices are from the Original retail $ and List price from the SKU record; you can also include a third price from your ChannelAdvisor offer. Only items/SKUs that are associated with your ChannelAdvisor offer are included. See Sending Current Prices to ChannelAdvisor for details.
Receiving orders from ChannelAdvisor: A periodic function sends a message requesting a list of orders from ChannelAdvisor and then uses the information in the response message to create each order in Order Administration, using a predefined order type as well as mapped values such as source code, ship via, and pay type. See Importing Orders from ChannelAdvisor for details.
Sending shipment confirmations to ChannelAdvisor: A periodic function sends a shipment confirmation message to ChannelAdvisor for each shipment of a ChannelAdvisor order. See Sending Shipment Confirmations to ChannelAdvisor for details.
Sending refund notifications to ChannelAdvisor: The Process Refunds function sends a message to ChannelAdvisor for each refund generated for a ChannelAdvisor order. When the function receives a confirmation response from ChannelAdvisor, it sets the refund to a processed status but does not actually generate the refund. See Submitting Refunds for ChannelAdvisor Orders for details.
The ChannelAdvisor integration has been designed and tested to work for the Amazon Marketplace. To use the ChannelAdvisor integration with a marketplace other than Amazon, contact your Order Administration project manager.
Troubleshooting the ChannelAdvisor integration:
Setup issues? See ChannelAdvisor Setup for details on the setup required for the integration. Also, each of the process overviews that follow include a summary of related setup.
In this topic:
See also: ChannelAdvisor Setup.
Purpose: You send current inventory information to ChannelAdvisor through a periodic function that generates a file and transfers it through a web service request so that the ChannelAdvisor account can apply the inventory updates. The steps are described below.
The periodic function does not include any additional information about the items/SKUs, such as descriptions or images.A. Run the CAINV periodic function. The CAINV periodic function:
1. Creates a file: Creates a comma-separated value file in the CA_INVENTORY_FILE_LOCAL_FOLDER, using the CA_INVENTORY_FILE_NAME.
If there is already a file of that name in the folder, the function overwrites it.
If the file size exceeds 125MB, splits the file into smaller files.
Which items included? Includes all items and SKUs in the company, except for any items that are sold out or flagged as restricted. Items do not need to have records in your current ChannelAdvisor offer. The items are in alphanumeric order based on their original item code.
Identifying items and SKUs: Identifies the item/SKU in the file with:
the SKU Cross Reference record, if any, set up through Maintaining SKU Cross Reference Codes (MSKR) for the item/SKU and the ChannelAdvisor SKU X-Ref Offer (L92); otherwise,
the short SKU for the item, if there is no SKU Cross Reference record for the item/SKU and ChannelAdvisor SKU X-Ref Offer (L92), or if that system control value is blank. If some but not all items/SKUs in your company have SKU Cross Reference records, then the file includes a combination of cross references and short SKUs.
Calculating the available quantity:
Standard calculation: Uses the standard availability calculation to determine the quantity to report to ChannelAdvisor (On hand - reserved - protected - reserve transfer quantity - backorder quantity), and indicates a quantity of zero if the result of this calculation is a negative number.
Set items: Based on the set component with the lowest availability. For example, a set includes one unit of a teapot with 75 units available, and four units of a teacup with 100 units available. The available quantity of the set is calculated as 25, since there are enough units of the teacup to make 25 tea sets.
Include non-allocatable warehouses? Uses the Include Non-Allocatable Warehouses (I34) system control value to determine whether to include inventory in warehouses that are not flagged as Allocatable when calculating the available quantity in the inventory download file.
Non-inventory? Uses the ChannelAdvisor Inventory Level Default (L91) as the available quantity for:
items flagged for drop ship, regardless of whether they have an available quantity in the warehouse. A drop ship item might have a quantity in the warehouse if, for example, you received a return.
non-inventory items, including virtual stored value cards, membership items, and subscription items
A quantity of zero is always indicated for variable sets. As a result, you cannot sell these items through ChannelAdvisor.Sample file contents: In the sample lines below, 1234619 is a short SKU, CACIN12345 is a SKU cross
reference set up through Maintaining SKU Cross Reference Codes (MSKR),
and the Quantity indicated for each (the last
column) is the available quantity. The text UNSHIPPED is included as the Quantity Update Type for
each item/SKU in the file.
Inventory Number,Quantity Update Type,Quantity
1234619,UNSHIPPED,13
CACIN12345,UNSHIPPED,53
2. Sending the file to ChannelAdvisor: The function uses a web service request to transmit the file to ChannelAdvisor at the URL from the CA_SERVICES_URL_PREFIX concatenated with the CA_PRODUCT_SERVICE_SUFFIX.
3. Backing up successful and failed files: The function renames
files using a unique sequence number, for example: inventory_123456.txt, where the CA_INVENTORY_FILE_NAME is inventory and 123456 is the job ID, and:
If the file creation and transmission was successful, the function saves a copy of the file in the
inventory/archivesubfolder of the CA_INVENTORY_FILE_LOCAL_FOLDER. -
If the file creation and transmission was unsuccessful, the function saves a copy of the file in the
inventory/failedsubfolder of the CA_INVENTORY_FILE_LOCAL_FOLDER.
4. Deleting backed up files: The function deletes any existing
files in the inventory subfolder of the CA_INVENTORY_FILE_LOCAL_FOLDER that are
older than the CA_MAXBACKUP_DAYS defined in Working with Admin Properties (CPRP).
Setup summary: To support the inventory upload to ChannelAdvisor, you need to complete the following setup:
Create the CAINV periodic function and assign it to a scheduled periodic process.
Specify the CA_INVENTORY_FILE_NAME.
Use the Working with ChannelAdvisor Accounts (WCAA) option to specify your ChannelAdvisor account settings, including information on authentication in ChannelAdvisor.
To identify items/SKUs using cross references rather than short SKU numbers in ChannelAdvisor:
Create a ChannelAdvisor offer and assign it to the ChannelAdvisor SKU X-Ref Offer (L92 ) system control value.
Use the Maintaining SKU Cross Reference Codes (MSKR) option to assign cross reference codes.
To control the availability calculation:
Use the Include Non-Allocatable Warehouses (I34) system control value to determine whether to include inventory in warehouses that are not flagged as Allocatable when calculating the available quantity in the inventory download file.
Use the ChannelAdvisor Inventory Level Default (L91) as the available quantity for drop ship and non-inventory items.
Complete inventory (pull) setup in ChannelAdvisor as described above.
For more information: See ChannelAdvisor Setup for background on setup.
Purpose: You send current pricing information to ChannelAdvisor through a periodic function that generates a file and transfers it to ChannelAdvisor to apply the pricing updates. The steps are described below.
A. Run the CAPRICE periodic function. The CAPRICE periodic function:
1. Creates a file: Creates a comma-separated value file in the Local Price Folder using the Price Filename. Both of these settings are from your ChannelAdvisor account in the Working with ChannelAdvisor Accounts (WCAA) option.
Which items included? The price file includes only items and SKUs in that are included in your current ChannelAdvisor offer. If the item has SKUs, and:
if there is an Item Offer record and an Item Price record, but no SKU Offer or SKU Price records for any SKUs, then all SKUs are included.
if there are any SKU Offer and SKU Price records for any SKUs, then only the SKUs with SKU Offer and SKU Price records are included.
To prevent a situation in which some SKU’s might be included in the file without prices, do not create an Item Offer without also creating an Item Price.
Identifying items and SKUs: The function identifies the item/SKU in the file with:
the SKU Cross Reference record, if any, set up through the Maintaining SKU Cross Reference Codes (MSKR) for the item/SKU and the ChannelAdvisor SKU X-Ref Offer (L92); otherwise,
the short SKU for the item, if there is no SKU Cross Reference record for the ChannelAdvisor SKU X-Ref Offer (L92), or if the system control value is blank.
Which prices are included? The file includes:
Buy It Now Price: from the Original retail $ in the SKU table.
Retail Price: from the List price in the SKU table.
Additional price: from the most current SKU Price (based on Effective date), if any, for your ChannelAdvisor offer; otherwise, from the most current Item Price. The label of this price field is from the Price output name specified for the ChannelAdvisor offer through the Work with ChannelAdvisor Offers Screen option.
1234619is a short SKU, andCACIN12345is a SKU cross reference set up through the Maintaining SKU Cross Reference Codes (MSKR). The prices are derived as described above.Inventory Number,Buy It Now Price,Retail Price,second chance offer priceCACIN12345,11.11,13.13,7.771234619,1.99,1.5,1.11Note:
If you clear out one of these price fields after it was previously populated, the next time you send the price file the field is passed as blank. When this occurs, ChannelAdvisor does not clear out the current value for the price. For example, the Buy It Now Price is currently set to 12.34, and you delete the price. The next time the CAPRICE function runs, it includes a blank Buy It Now Price, but ChannelAdvisor skips this entry and leaves the Buy It Now Price set to 12.34. -
files using a unique sequence number, for example: caprice_123456.txt, where caprice is the Price Filename and 123456 is the job ID, and:
pricing/archivesubfolder of the CA_INVENTORY_FILE_LOCAL_FOLDER. -
pricing/failedsubfolder of the CA_INVENTORY_FILE_LOCAL_FOLDER.
files in the pricing subfolder of the CA_INVENTORY_FILE_LOCAL_FOLDER that are
Setup summary: To support the price upload to ChannelAdvisor, you need to complete the following setup:
Create the CAPRICE periodic function and assign it to a scheduled periodic process.
Use the Working with ChannelAdvisor Accounts (WCAA) option to specify your ChannelAdvisor account settings, including ChannelAdvisor authentication information.
Create a ChannelAdvisor offer, and assign it to the ChannelAdvisor SKU X-Ref Offer (L92) system control value.
Use the Work with ChannelAdvisor Offers Screen option to set up your ChannelAdvisor offer, including the Price output field name.
Specify the Original retail $ and the List price in the SKU table.
Optionally, set up Item Offer and Price Records and/or SKU Offer and Price Records for each item/SKU you sell through a ChannelAdvisor marketplace to include a third price in the price file, using the Price output name.
Purpose: You can periodically request new orders from ChannelAdvisor through a periodic function, which creates the orders in Order Administration. The steps and details on data mapping are described below.
A. Run the CAORDERUP periodic function. The CAORDUP periodic function:
1. Requests new orders: The function sends the GetOrderListRequest
message to ChannelAdvisor, using the CHANNELADVISOR_ORDER_URL specified in the cwdirectcp_interface.properties file and the account
number and credentials specified through the Working with ChannelAdvisor
Maximum orders? Each batch can include a maximum of 50 orders. The CHANNELADVISOR_ PULL_ORDERS_MAX property controls how many orders the function processes. For example, set the property to 100 to have the function process a maximum of two full batches.
2. Receives and creates new orders: The function receives new orders from ChannelAdvisor in the GetOrderListResponse message, mapping data as follows:
company number: From the company number specified for the CAORDUP periodic function.
order type: from the ChannelAdvisor Order Type (L90).
source code: from the Source associated with the marketplace originating the order. The function determines the marketplace from the
ItemSaleSourcepassed for the order, and uses the Source for the matching marketplace, as set up through the Work with ChannelAdvisor Marketplaces Screen. Your marketplace needs to match a ChannelAdvisor Site Token value. -
alternate order number: from the
CartID. -
entered by user: your default user.
order message lines: from:
the ChannelAdvisor client order identifier, preceded by CA; for example,
CA#28839571 -
your ChannelAdvisor account number; for example,
ACCT#cc7bab31-22cc-49d2-a833-be878721520b -
an additional order message line indicating
None
These order message lines are flagged not to print (Print Nowhere).
ship via: from the ship via whose ChannelAdvisor carrier and ChannelAdvisor service class match the
ShippingCarrierandShippingClasspassed for the order. -
customer name and address: from the
ShippingInfoandBillingInfopassed for the order. If noBillingInfois passed, theShippingInfois used as the sold-to customer information; otherwise, theBillingInfois used as the sold-to customer information. Some marketplaces may never passBillingInfo.-
Sold-to different from ship-to? The system searches for a matching sold-to customer using the Include Telephone Number in Customer Search (I20) and Remote Order Values (F70) system control values. If the sold-to customer name and address are different from the ship-to name and address, the periodic function creates an order-level ship-to. The system might change the sold-to customer information to something slightly different from the ship-to name and address passed if it finds a matching customer using your customer search and selection criteria; in this case, an existing sold-to customer who differs somewhat from the ship-to information passed may be assigned to the order. See the Include Telephone Number in Customer Search (I20) and Remote Order Values (F70) system control values for background.
Business or residence? The Delivery code is set to B for the sold-to or ship-to address if there is a company name; otherwise, the Delivery code is set to R.
Opt-in/out: If the
EmailOptInfrom ChannelAdvisor is set toFalse, the customer’s Opt-in/out flag is set to 03; otherwise, if theEmailOptInis set toTrue, the customer’s Opt-in/out flag is set to 01. -
Identifying the country: The periodic function uses the country’s two-position ISO code to map the customer’s country.
email address: from the
BuyerEmailAddresspassed for the order. -
items: mapped from the short SKU or the SKU cross reference, as described under Sending Current Inventory Information to ChannelAdvisor.
shipping and tax: Calculated based on the amounts in the
OrderLineItemItemelement if the CA type for the pay type is set to Item Level (consistent with the Amazon and eBay with premium tax marketplaces); otherwise, calculated from the amounts in theOrderLineItemInvoiceelement and prorated across the lines on the order if the CA type for the pay type is set to Order Level (consistent with the eBay marketplace without premium tax). See Working with Pay Types (WPAY) for background.Note:
Tax on freight is included in the line-level or order-level tax amount. -
price override reason for each order line: uses a reason code of W.
payment method: from the CA cross reference # for a pay type. The function uses the
ItemSaleSourcepassed for an order to identify the marketplace set up through Working with ChannelAdvisor Accounts (WCAA), and assigns the payment method whose CA cross reference # matches the marketplace. Your marketplace needs to match a ChannelAdvisor Site Token value. -
suppress refund flag for the payment method: set to N, so that refunds are not suppressed, and you can use the process described under Submitting Refunds for ChannelAdvisor Orders.
3. Notifies ChannelAdvisor that each order was received: The function sends a status export status update (SetOrderList) to ChannelAdvisor for each received order, indicating that the order was successfully created.
Error? If a new order is in error, it is assigned to the Default Batch for E-Commerce Orders in Error (G41).
Setup summary: In addition to the setup required for the inventory and price uploads, complete the following setup to support the order import:
Create the CAORDUP periodic function and assign it to a scheduled periodic process.
Specify the CHANNELADVISOR_ORDER_URL.
Use the Working with ChannelAdvisor Accounts (WCAA) option to specify your ChannelAdvisor account settings, including your credentials, as well as the marketplaces and their related source codes. Your marketplace needs to match a ChannelAdvisor Site Token value.
Use Establishing Order Types (WOTY) to set up the ChannelAdvisor order type, and assign it to the ChannelAdvisor Order Type (L90) system control value.
Use Establishing Price Override Reason Codes (WPOR) to create a price override reason code of W.
Use Setting Up the Country Table (WCTY) to specify a 2-position ISO country code for each country where you will ship orders.
Use Working with Pay Types (WPAY) to create a pay type for each marketplace, and assign a CA cross reference # to identify the marketplace to each.
Use Working with Ship Via Codes (WVIA) to specify the ChannelAdvisor carrier and ChannelAdvisor service class to map ship vias to carriers that might be used for ChannelAdvisor orders.
Changing orders after creation: A pop-up window opens in order maintenance if you attempt to maintain a ChannelAdvisor order, indicating that any changes must also be made in ChannelAdvisor. There is no mechanism to automatically send changes to ChannelAdvisor except for shipment confirmation or refunds.
Purpose: You can periodically send order shipment notifications to ChannelAdvisor through a periodic function. described below.
A. Confirm shipment. When billing an order whose order type matches the ChannelAdvisor Order Type (L90), the billing async job creates a CAS trigger record. The trigger record identifies the company, order number, and invoice number for the shipment.
B. Run the CASHIPMENT periodic function. For each unprocessed CAS trigger record, the CASHIP periodic function passes a SubmitOrderShipmentList message:
Uses the ChannelAdvisor account number and credentials specified through the Working with ChannelAdvisor Accounts (WCAA) option.
Passes the ChannelAdvisor
clientOrderIdentifierto identify the order. -
Always indicates a
ShipmentTypeofPartial. -
Maps each item using the short SKU or the SKU cross reference, as described under Sending Current Inventory Information to ChannelAdvisor, and indicates the
Quantityshipped of each item. -
Indicates the
trackingNumberfor the shipment, if available in the Manifest Upload Audit table. If there are multiple tracking numbers for a shipment, the tracking number that billed first is included. -
Passes the ChannelAdvisor carrier and ChannelAdvisor service class from the ship via used as the
ShippingCarrierandShippingClass. -
Sends the shipment confirmations to the CHANNELADVISOR_SHIPPING_URL.
The message does not specify any shipping charges or a shipment date if different from the current date.
Setup summary: In addition to the setup required for the inventory and price uploads and order import, complete the following setup to support shipment confirmations:
Create the CASHIP periodic function and assign it to a scheduled periodic process.
Specify the CHANNELADVISOR_SHIPPING_URL.
Purpose: When you use the Processing Refunds (MREF) option, the function submits any pending refunds for ChannelAdvisor orders to ChannelAdvisor, and does not actually generate these refunds. The processing steps are described below.
The Processing Refunds by Order Number (MRFO) option does not perform ChannelAdvisor refund processing. You need to use the Processing Refunds (MREF) option.Identifying ChannelAdvisor orders: To be included, an order must have an order type matches the ChannelAdvisor Order Type (L90) system control value, and its payment method must have an CA cross reference # that matches a marketplace set up through Working with ChannelAdvisor Accounts (WCAA).
Which activities generate refund requests? Returns generate refund requests, while exchanges do not:
Returns without exchanges: refund request is passed to ChannelAdvisor
Even exchanges (where the exchange item's price is the same as the returned item's price): no refund request is passed to ChannelAdvisor
Uneven exchanges (where the exchange item's price is not the same as the returned item's price): no refund request is passed to ChannelAdvisor; instead, an Order Transaction History message is written:
Refund could not be sent - Ord Has Exchg. You can then process any refund manually through ChannelAdvisor.Note:
When an uneven exchange is made for an order, no subsequent refund requests are sent to ChannelAdvisor.
Item-level or order-level shipping and tax? Based on the setting of the CA type specified for the payment method for the marketplace, the SubmitOrderRefund message includes:
an item-level
RefundItemselement that breaks out theAmount,ShippingAmount, and bothShippingTaxAmountandTaxAmount(both tax amounts including the full tax and tax on freight, if any) in therequestelement of the message if the CA type for the payment method is set to Item Level (consistent with the Amazon and eBay with premium tax marketplaces). -
an order-level
Amount, including merchandise, tax, and shipping, in therequestelement of the message if the CA type for the payment method is set to Order Level (consistent with the eBay marketplace without premium tax).
When you submit the Processing Refunds (MREF) function, it:
A. Submits the refund to ChannelAdvisor: The SubmitOrderRefund message is submitted to the CHANNELADVISOR_ORDER_URL, and includes:
ClientOrderIdentifier: the ChannelAdvisor order number. -
SellerRefundID: identifies the refund in Order Administration; formatted as12345-1.0-2.0where12345is the Order Administration order number,1.0is the ship-to number, and2.0is the refund number. -
AdjustmentReason: set toGeneralAdjustment. -
SKU: the ChannelAdvisor item identifier for the returned item. -
Quantity: the quantity returned. -
Amount: the extended refund amount, if the CA type for the payment method is set to Order Level, or just the merchandise amount if the CA type for the payment method is set to Item Level. See above for a discussion. -
ShippingAmount: the shipping amount refunded. Included only if the CA type for the payment method is set to Item Level; otherwise, the shipping amount is included in theAmountelement. See above for a discussion. -
TaxAmount: The tax amount refunded. Included only if the CA type for the payment method is set to Item Level; otherwise, the tax amount is included in theAmountelement. See above for a discussion.
Each of the amounts described above is passed as an absolute value and not as a negative amount, and includes an explicit decimal
ChannelAdvisor passes tax on freight at the line level in the submit order list message. If the tax amount in the SubmitOrderRefund message does not include tax on freight, then this amount is not refunded.
A credit against an order that does not include the return of a shipped item (for example, if the order line is canceled) does not generate a refund request to ChannelAdvisor.
B. Sets the refund status to I. This status indicates ChannelAdvisor pending.
C. Updates the refund as processed: If ChannelAdvisor accepts the refund, then the system proceeds with standard refund processing and changes the refund’s status to P (processed), performing each standard update, such as credit invoice creation; however, the system does not actually generate the refund, or create records in the Print Check or Bank Reconciliation tables. See Summary of Refund Processing Updates and Reports for background. Otherwise, if ChannelAdvisor does not accept the refund, then the refund status remains I.
Setup summary: See the setup required for the inventory and price uploads, order import, and shipment confirmations, described above, and see ChannelAdvisor Setup for background on setup.
Cancellations
The ChannelAdvisor integration does not currently support submitting refunds that are not associated with an item return. As a result, when you cancel an item on a ChannelAdvisor order, you cannot process the refund using the process described above. Instead, you need to cancel the orders manually in ChannelAdvisor.
To identify orders with cancellations: Query
the Order Transaction History table for Transaction note entries
that contain the text Refund could not be sent - no items and a User of CAREFUND. These
are the orders that require manual cancellation in ChannelAdvisor.
Purpose: Order Administration’s integration with ChannelAdvisor requires the setup described below.
In this topic:
Additional required setup:
Working with ChannelAdvisor Accounts (WCAA): See this help topic for information on configuring your ChannelAdvisor accounts in Order Administration.
The ChannelAdvisor integration has been designed and tested to work for the Amazon Marketplace. To use the ChannelAdvisor integration with a marketplace other than Amazon, contact your Order Administration project manager.ChannelAdvisor Properties
Set the integration properties and logging properties, described below, to support the ChannelAdvisor integration.
Integration properties:
| Property | Description |
CA_INVENTORY_FILE_NAME located in Working with Customer Properties (PROP) |
The file name for the CAINV periodic function to use when creating a file of current inventory levels for items. See Sending Current Inventory Information to ChannelAdvisor for background. |
CA_INVENTORY_FILE_LOCAL_FOLDER located in Working with Admin Properties (CPRP) |
The folder on the Order Administration server where the CAINV periodic function writes the inventory file. Note: This setting is defined by Oracle and cannot be changed. |
CA_MAXBACKUP_DAYS located in Working with Admin Properties (CPRP) |
The number of days to store ChannelAdvisor archived or failed price and inventory export files before they are eligible for deletion. The CAINV and CAPRICE periodic functions delete the inventory or price files if they are eligible based on the setting of this property. Defaults to 30. If this property is blank, files are eligible for deletion after 30 days. |
CA_PRODUCT_SERVICE_SUFFIX located in Working with Customer Properties (PROP) |
The suffix to include in the URL used for the ChannelAdvisor price and inventory integration. The CAINV and CAPRICE periodic functions use a web service request to pass the generated price and inventory files to ChannelAdvisor. The URL is composed of the CA_SERVICES_URL_PREFIX concatenated
with the CA_PRODUCT_SERVICE_SUFFIX, for example: Defaults to |
CA_SERVICES_URL_PREFIX located in Working with Customer Properties (PROP) |
The prefix to include in the URL used for the ChannelAdvisor price and inventory integration, as described above under the CA_PRODUCT_SERVICE_SUFFIX. Defaults to |
CHANNELADVISOR_ORDER_URL located in Working with Customer Properties (PROP) |
The URL for:
CHANNELADVISOR_SHIPPING_URL located in Working with Customer Properties (PROP) |
The URL for the CASHIP periodic function to use when sending shipment confirmations to ChannelAdvisor; see Sending Shipment Confirmations to ChannelAdvisor for background. |
CHANNELADVISOR_ PULL_ORDERS_MAX located in Working with Customer Properties (PROP) |
The maximum number of orders that the GetOrderList function processes at once before sending the notification to ChannelAdvisor that the orders were successfully received and created. Each batch can include up to 50 orders. For example, if you set this property to 100, the function imports two batches of 50 orders. If no maximum is specified, a default of 50 orders applies. |
ChannelAdvisor: Related System Control Values
The system control values related to the ChannelAdvisor integration are listed below.
| System Control Value | Setting |
The order type to assign to orders from ChannelAdvisor. |
The available quantity to submit to ChannelAdvisor for drop ship, non-inventory, gift card, subscription, and membership items. |
The offer you use to set up cross references between the ChannelAdvisor item identifier and the Order Administration item/SKU. Must also be set up through the Create ChannelAdvisor Offer Screen. |
Additional system control value requirement: The Tax Included in Price (E70) system control value needs to be unselected for to prevent errors when creating new customers from ChannelAdvisor.
ChannelAdvisor: Periodic Functions
Build and schedule one or more periodic processes to include the following periodic functions:
| Periodic Function | Purpose | More Information |
Run this periodic function to request access to ChannelAdvisor for the specified AccountID. Before running this periodic function, enter connection information in the Parameter field using the following format:
For example:
Note: This periodic function should be run one time for each account as part of initial setup of the ChannelAdvisor integration.In addition, once you establish a connection with ChannelAdvisor, you can change the Parameter field to the following format:
For example:
Run the periodic function to write information to the Application log about the status of the access to ChannelAdvisor. |
Generates a file of current inventory levels to send ChannelAdvisor. |
Generates a file of current pricing for items sold through the ChannelAdvisor integration. |
Sends ChannelAdvisor a request for new orders and creates orders based on the information in the order response message. |
Sends shipment confirmation messages to Channel Advisor. |
For more information: See Scheduling Jobs for an overview.
Refunds? There is no periodic function to send refunds to ChannelAdvisor; the Processing Refunds (MREF) function sends refunds for ChannelAdvisor orders.
Pricing Setup for ChannelAdvisor
Set up the following prices for the CAPRICE periodic function to extract when building the price file to send to ChannelAdvisor:
Buy It Now Price: from through the Original retail $ in the SKU table
Retail Price: from through the List price in the SKU table
Additional price: the function uses the most current SKU Price (based on Effective date), if any, for your ChannelAdvisor offer, set up through the Create ChannelAdvisor Offer Screen and the ChannelAdvisor SKU X-Ref Offer (L92); otherwise, it uses the most current Item Price. The label of the additional price field is from the Price output name specified for the ChannelAdvisor offer through the Work with ChannelAdvisor Offers Screen option.
Any SKU or Item Prices you set up for the ChannelAdvisor offer should have a quantity of 1.Mapping Data between ChannelAdvisor and Order Administration
Purpose: In order to map data correctly from ChannelAdvisor to Order Administration, you need to set up cross references in Order Administration. This required setup is described briefly below.
| Mapping Data | Menu Option | Used By | Notes |
Sku cross ref for the ChannelAdvisor SKU X-Ref Offer (L92) |
The CAINV, CAPRICE, CAORDUP, and CASHIP periodic functions. See ChannelAdvisor Integration Overview for process overviews. |
The offer needs to match the ChannelAdvisor SKU X-Ref Offer (L92) system control value. |
CA cross reference # and CA type for a pay type Note: Should be a cash/check pay type. |
Working with Pay Types (WPAY) and Working with ChannelAdvisor Accounts (WCAA) |
The CAORDUP periodic function and the Processing Refunds (MREF) option. See Importing Orders from ChannelAdvisor and Submitting Refunds for ChannelAdvisor Orders. |
The function
uses the The CA type indicates whether to calculate tax and shipping at the item level (consistent with the Amazon and eBay with premium tax marketplaces) or the order level (consistent with the eBay marketplace without premium tax). |
ChannelAdvisor carrier and ChannelAdvisor service class for a ship via |
The CAORDUP and CASHIP periodic functions. See Importing Orders from ChannelAdvisor and Sending Shipment Confirmations to ChannelAdvisor. |
ChannelAdvisor Order Type (L90) |
The CAORDUP periodic function. See Importing Orders from ChannelAdvisor. |
This order type also determine which orders to include when sending shipment confirmations and refunds to ChannelAdvisor. See Sending Shipment Confirmations to ChannelAdvisor and Submitting Refunds for ChannelAdvisor Orders. |
Source associated with a marketplace |
Working with Source Codes (WSRC) and Working with ChannelAdvisor Accounts (WCAA) |
The function
uses the the The source code must use a line-level freight method. |
price override reason code of W |
You need to use a price override reason code of W, and cannot change this default. |
ISO country code |
The ISO code must be set to the country’s two-position ISO country code. |
