Edit RTVs
To edit an RTV:
- On the Return to Vendor screen, the user can edit the RTV details by selecting the RTV Order number.
- The Create and Edit RTV page is displayed.
- Click Edit to change the screen into Edit Mode.
- Update the RTV Details.
In Edit mode, Supplier and Location are not editable. If these need to be changed, a new RTV needs to be created. During Edit Mode on the RTV header, the user can always see the RTV History, Add/Remove and/or View Attachments, View RTV Errors, and start and/or reply to Queries. These top buttons are not visible in Create mode.
