Propose Changes to Purchase Orders
When the Purchase Order is in Approved status, the supplier can propose changes to the Purchase Order:
- From the side menu, choose Procure to Pay.
- In the Purchase Orders tab, select the PO that requires changes.
- In the Create or Edit PO screen, click Edit.
- Make the changes required to the PO. The following actions are supported:
- Add items.
- Remove items.
- Amend dates, quantities, and unit cost.
- Change deliveries.
- Add new deliveries.
- Split deliveries.
- Remove deliveries.
- After the changes are completed, click Submit.
- In the Reason dialog box, complete the Reason Code, Due Date, and Comments. Then click Submit.
