Adding an Activity and Schedule
To schedule or reschedule activities:
  1. Select the processes and then select the Add Activity & Schedule action. The Add Activity dialog box opens.
  2. Select the activities and then click Ok. The Schedule Activities dialog box opens.
  3. Select the scheduling method. The following choices are available:
    • Forwards from the Start Date (with non-critical Activities Starting on same date)
    • Forwards from the Start Date (with non-critical Activities Ending on same date)
    • Backwards from the end date (with non-critical Activities Starting on same date)
    • Backwards from the end date (with non-critical Activities Ending on same date)
    • Forwards from Last Completed Activity Date (with non-critical Activities Starting on same date)
    • Forwards from Last Completed Activity Date (with non-critical Activities Ending on same date)
  4. Click Ok. A Confirmation dialog box appears.
  5. Click Ok. The selected activities are added to the processes. The system calculates the start and end dates for each activity.
