Adding a Process to an Existing Process
A process can be added under an existing process. To add a process, select the parent process in the left pane and then select the Add Process action. A tab opens to enable you to create the process. For information on completing this page, see Creating a New Process. The new process is added to the process hierarchy under the selected parent process.
