2 Product Record
The Product Record is a container for all information about a single Product (SKU), for a particular supplier/product combination.
Separate Product Records are created if the same product is supplied by multiple suppliers, either at once or at different stages in the life of the product. There is one Product Record per supplier/product combination.
The Product Record holds the following information:
  • Basic identifying information: Name, Quantity, Product Number, Brand, and so on.
  • Details of the Supplier and Primary Sites at which the Product is currently manufactured.
  • The Retailer contacts who are responsible for the product.
  • Any product coding cross-references for identifying the item in other systems.
  • Links to Processes and Assessments.
  • Attachments, such as, Artwork and Quality Assurance (QA) information.
  • Links to other Product Records for the same product from other Suppliers.
    Partner suppliers and Partner sites cannot be selected as the primary supplier or primary sites for a Product Record.
To work with Product Records, select Product Records from the Product menu.
Figure 2-1 Product Options List
This figure shows the Product options.
The Product Records tab opens, showing a list of all the Product Records on the system, grouped by the Retailer Technologist responsible for the Product.
A supplier user's ability to create and edit the Product Record can be controlled using system parameters and permissions configuration.
Permissions rules can be configured to prevent supplier users from creating new Product Records, and to control whether they may edit individual fields within the record.
For details of the system parameters and how the Permissions spreadsheet can be configured, see the Oracle Retail Supply Chain Collaboration Cloud Service Administration Guide.
Figure 2-2 Product Record Page
This figure shows the Product Records page.
The following columns are shown:
  • Product Title
  • Quantity
  • Product Number
  • Supplier Name
  • Site Name
Product Records are also listed in the Product Record page within the Supplier Record. The listed records are just the Product Records that apply to that specific Supplier.
Figure 2-3 Product Record within Supplier Record
This figure shows the Product within Supplier Record page.
Here, the following columns are shown:
  • Product Title
  • Site Name
  • Variant Name
  • Quantity
  • Product Number
Product Records are also listed in the Product Record page within the Site Record. The listed records are just the Product Records that apply to that Site.
Figure 2-4 Product Record within Site Record
This figure shows the Product Record within Site page.
  • Product Title
  • Quantity
  • Product Number
  • Variant Name
To open the Product Record in a new tab, double click the entry in the list.
A new Product Record is created from any of these list views by selecting New Product Record from the Actions menu.
A new Product Record may be created by the Supplier or the Retailer. A new tab opens with a blank Product Record that has several pages listed across the top.
The Product Records page and New Product Record action are not available for Partner suppliers or Partner sites.
Figure 2-5 New Product Record page
This figure shows the New Product Record page.
Table 2-1 describes the fields in a product record.
Table 2-1 Product Record Fields
Field Description
Product Title
The Product Title is to be sufficiently precise to enable the Product to be identified by both the Supplier and other Retailer users, and to distinguish it from other similarly-named products.
This is not necessarily the on-pack Product Name.
Process Name
Non-mandatory, but can be used to provide the Development process name, for additional ease of identification.
Status
This is the status of the record. May be any of the following:
  • Draft: Newly created Product Record. The Supplier has not yet been allocated.
  • Active: Automatically set once the Supplier has been allocated and the record saved. The Product Record is now available to the Supplier.
  • Archived: Set for Products which are no longer being produced.
Product Code
Number automatically given by the system.
Status in External System
May be used to cross reference the product in a Retailer's other product management system, if any.
Products Covered
  • Variant Name
    A Product Record may cover a number of variants, such as, different sizes of the same product. This field is used to describe the variant.
  • Quantity
    The quantity of the item being sold, such as, 200g or 6 pack.
  • Product Number
    A unique number usually used by the business.
  • Alt. Product Number
    An optional alternative identifier for the product.
  • Division
    An optional additional categorization for the product.
The portal may be configured to include the Alt. Product Number and Division fields. The alternative product number can be used to hold the product's identifier such as a GTIN code; Division is selected from a glossary of categorizations.
If the Alt. Product No. and Division fields are used, the portal may be further configured to use the fields to control the updating of the Retailer Product Number. This would typically be used where the Retailer Product Number holds the product's identifier from an external system, such as an Article Number.
Supplier Name/Supplier Code
The company or agent that supplies this Product to the Retailer. Only one Supplier may be selected per Product Record. Multi-supplier Products have separate Product Records per product/supplier combination.
The Supplier Code is automatically populated when the Supplier is selected.
Sites
The Site where the product is manufactured and packed. If a product is made at multiple sites, all the sites may be selected and listed here.
Business Category
This is the commercial category in which the product is sold.
Contacts
The Retailer contacts who are responsible for this product.
Brand Details
The brand type, brand, and sub brands, and any other brand details.
Product Codes
This table can be used to build a list of the product’s references in other systems. It is enabled by a system parameter. If adding a reference, the following details should be completed:
  • System: Select the name of the external system.
  • Business Unit: Optionally select a Business Unit.
  • Reference Code: Optionally select a Reference Code.
  • Currency: Optionally select a Currency.
  • Further Information: Enter any supporting information.
Benchmark
Enables a history of the benchmark competitive products to be recorded. The following details should be completed:
Is there a Benchmark for this product?: Yes or No
Brand: Select the Brand Name.
Description: Indicates the name of the Competitive product and any other descriptive details.
Justification: Enter the reason why this Brand or product is chosen as the benchmark. (Must also be completed if there is no benchmark; enter the reason why there is no benchmark.)
Alternative benchmark products and details may be added if the benchmark changes by clicking Add Benchmark.
The details may be completed by the Retailer user only, unless the Supplier Can Edit Benchmark system parameter has been set to also allow the Supplier user to complete the Benchmark Details.
Linked Product Records
This page of the Product Record is only seen by the Retailer users. It shows a list of other Product Records where the Product Number within the Products Covered Table is the same as in this record. These Product Records may be opened in another tab by double clicking on a particular entry.
Assessments
This page shows a list of the Item Assessments linked to the Product Record. The list shows the type of assessment, its due date, details of its due date, and any score. The Assessments can be opened from the list by double clicking on a particular row. See the Item Assessments section for further details.
Process Links
This page shows a list where the product has been linked to a Process. For more details, see the Oracle Retail Supplier Evaluation Process User Guide.
The page shows the following:
  • Process Title
  • Activity Name
  • Process Status
  • Date Link Created
Custom Fields
The system provides a facility for a Retailer to set up a number of customized fields within the Product Record. They appear on this page. If no customized fields are set up, this page is not shown.
Change History
This shows the change history for the Product Record, including the dates of any status changes.
As with most records within the system, there is a page to attach any relevant documents to the Product record, such as Process charts, Nutrition analysis, Artwork files, and so on.
