4 RESTful APIs
The following RESTful APIs are available:
UserRestService: Users
SupplierRestService: Suppliers
SiteRestService: Sites
ContactRestService: Supplier/Site Contacts
TaskRestService: Users' Tasks
UrgentItemsRestService: Users' Urgent Items
ArtworkRestService: Artwork Activities
BusinessCategoryService: Business Categories
AuditRestService: Audits and Visits
DataPrivacyService: Data Privacy Requests
AttachmentRestService: Attachment Files
ScorecardRestService: Assessments
ProjectRestService: Processes
ActivityRestService: Process Activities
- ProductRecordRestService: Product Records
Figure 4-1 Overview of RESTful APIs
Only minimal business logic and validation is applied by the Supplier Evaluation REST APIs.
When creating or updating records, all values must be included. If a value or element is omitted from the XML, the field contents will be cleared when updating the record.
Generally, only the validation necessary to ensure the system's referential integrity is applied when updating records through the APIs. It is therefore possible to set the contents of some fields with values that are rejected when the user manually edits or validates the record through the UI. In some cases, it may be necessary to regress these records back to a prior status in order to edit and correct values that have been set incorrectly through the UI.
Parameters and Filtering
Various parameters can be included in calls to the APIs, generally to define what data is to be returned, but can also control how records are returned. The following table lists some commonly used parameters.
Common Parameters
| Parameter | Type | Description |
offset |
int |
Used with pageSize to control the paging of a returned list of records. Specifies the starting point for the retrieval of records. If not specified, zero is assumed. For example, to retrieve 150 records:
pageSize batchSize |
int |
Used with offset to control the paging of a returned list of records. Specifies the number of entries in each page of returned list of records. If not specified, 30 is assumed. The maximum is 100. |
isActive |
Boolean |
Used to only return records that are flagged as being active (TRUE). |
modifiedSince |
string |
Used to locate records that have been created or updated since a specific date/time. |
modifiedUntil |
string |
Used to locate records that have been updated or created until a specific date/time. |
When a list of records is returned, it may include a previousPage and nextPage element. These elements provide URI links to the previous or next pages of records respectively. A totalRecords element is included that shows the total number of records available for retrieval.
For example, using the List of Values function to retrieve a list of User records, where there are 150 records to be retrieved, with the pageSize parameter set to 50 returns the first 50 records within entity elements, along with a nextPage element containing a URI link to the next 50 records which can be used to retrieve the next 50 records. When the second page of 50 records are returned, the XML includes a nextPage URI link to the final 50 records, along with a previousPage URI link to the first 50. The following graphic illustrates this example.
Figure 4-2 Example of Retrieving a List of Users
The totalRecords element shows the total number of retrievable records. The previousPage and nextPage elements are only present if there are previous and/or next pages to be retrieved.
Date/Time parameters must be provided in the YYYY-MM-DD hh:mm:ss format.
When retrieving records, the returned XML only includes elements that actually contain data; empty elements are omitted.
The details of the returned records are contained in an entities element, and repeated in an entryArray element. The entryArray element is a representation from the Java objects and can be ignored.
Where a date/time is passed in as a parameter to an endpoint, such as fromDate and toDate, validation checks for a valid date/time. If not valid, an HTTP 417 is returned, along with an XML error message detailing the exact issue with the date/time.
Error Messages
The Supplier Evaluation APIs use standard web services messaging protocols to notify the success or failure of a call to the service. Where an API handles a specific error condition, details of the returned message can be found in the following sections. The following table lists various generic error messages that may be returned by calls to any of the APIs.
Generic Error Messages
| Element | Message | Meaning |
userId |
HTTP Status 401 - Bad credentials |
User ID or password is invalid |
Password |
Disabled |
HTTP Status 401 - User is disabled |
External System account is not enabled in Supplier Evaluation |
offset |
HTTP 417 IllegalStateException: Offset must be a positive integer |
Invalid offset value - must be between zero and 2,147,483,647 |
offset |
HTTP 404 Not Found |
Not numeric or an integer |
pageSize |
HTTP 417 IllegalStateException: The Page Size must be between 1 and 100 |
Invalid page size value |
Record cannot be located due to an invalid key or ID |
HTTP 417 Expectation Failed |
Record cannot be located due to an invalid ID |
HTTP Status 500 - Internal Server Error |
Unspecified internal error occurred |
Non-numeric value in numeric parameters |
modifiedSince |
HTTP 417 <errorMessage> |
Not a valid date, whereby <errorMessage> will identify the issue For example: IllegalInstantException: Cannot parse "2018-03-25 01:00:00": Illegal instant due to time zone offset transition (Europe/London) In this example, due to the clocks moving forward (in the server's time-zone), the passed in date is invalid |
modifiedUntil |
Not a valid date, whereby <errorMessage> will identify the issue (see example above) |
HTTP 400 Bad Request |
Malformed XML, or general error in content of the XML |
Wildcard Searches
The % character can be used as a wildcard filter when locating the records.
Using the % at the start of the string will search for matches where the given string ends with the text being searched for, for example, %smith could be used to search for all users with a surname of smith.
Using the % at the end of the string will look for matches where the given string begins with the text being searched for, for example, mark% could be used to search for all users with the name mark.
The following table shows which APIs and functions support the use of wildcards.
Wildcard Searches
| API | Function |
User |
List of Values |
Supplier |
List of Values |
Site |
List of Values |
Contact |
List of Values Retrieve Supplier Contact Record by Business Key Retrieve Site Contact Record by Business Key |
Business Category |
List of Values |
Task |
List of Values |
Urgent Items |
Number of Urgent Items |
Notes:
Wildcard searches are not case sensitive so, for example, searching a name field for John Smith or john smith will return the same matches.
When searching glossary parameters, be aware that they relate to the code (not the description) of the glossary entry.
Wildcard searches can typically be applied to parameters that are string type. See the Wildcard Search Supported column in the APIs’ List of Values functions for which URL parameters support it.
Deleted Records
By default, soft deleted records are returned by the APIs (the XML contains a deleted element, which is set to true). To exclude soft deleted records, it is necessary to use a softDelete=false parameter when calling the API. For example:
/creations-core/services/rest/site?softDelete=false
UserRestService
This section describes the API for managing retailer and supplier users. The following functions are available:
List of Values: retrieves a list of users
Retrieve Record by ID: retrieves a User record using its unique identifier
Retrieve Record by Business Key: retrieves a User record using its business key
Check Record Modification Timestamp: retrieves the timestamp when a User record was last updated
Create Record: creates a new User record
Update Record: updates an existing User record
List of Values
Description
Retrieves a list of users in a paged list. Use this function to retrieve a simple list of user names and IDs, or to locate User record IDs prior to a retrieve or update operation. Parameters are available to apply specific selection criteria for filtering the returned records.
Endpoint address: /services/rest/user HTTP method: GET
Request Details
Parameters are passed as URI parameters.
URI Parameters
| Parameter Name | Mandatory/ Optional | Value Type | Multiple Value Separator (~) Supported? | Wildcard Search Supported? | Example |
| offset | Optional | int | No | No | 60 |
| pageSize | Optional | int | No | No | 30 |
| name | Optional | string | No | Yes | John Smith |
| jobTitle | Optional | string | No | Yes | Process Manager |
| language | Optional | string | No | Yes | en_GB |
| country | Optional | string | No | Yes | UK |
| userRoles | Optional | string | No | Yes | PROCESS ADMINISTRATOR |
| userType | Optional | string | Yes | No | RETAILER |
| authorityProfiles | Optional | string | No | Yes | PROCESS MANAGER |
| siteStatus | Optional | string | Yes | No | ACTIVE~INACTIVE |
| supplierActive | Optional | string | No | No |
true returns active users no value returns both active and inactive users |
| modifiedSince | Optional | string | No | No | 2015-05-19 13:30:39 |
| modifiedUntil | Optional | string | No | No | 2015-05-19 13:30:39 |
Example URLs
…/services/rest/user/?offset=2&pageSize=20 …/services/rest/user/?siteStatus=Active …/services/rest/user/?name=Frank%
Response Details
For a successful response, XML is returned with a UserLinkList root element containing an entries element for each matched user. The entries element consists of the elements shown in the following table.
Returned Elements
| Element | Type | Description |
recordId |
long |
User record's internal ID |
recordLink |
string |
URI to the UserRestService Retrieve record service for this user |
loginId |
string |
Login ID / business key to the User record |
name |
string |
User's name |
The returned XML also contains a totalRecords element, which states the total number of retrievable records that match the filter parameters.
Error Messages
In the event that an error occurs, an HTTP 500 response is sent.
Description
Retrieves a single User record's details using the record's internal unique ID (which is not visible in the UI). Use this function to retrieve the full details of an individual user.
Endpoint address: /services/rest/user/{id} HTTP method: GET
Request Details
The URL contains the {id} parameter that determines the record to retrieve.
URI Parameters
| Parameter Name | Mandatory/Optional | Value Type | Multiple Value Separator (~) Supported? | Example |
locale |
Optional |
string |
Yes |
en_GB~fr Locale country code. If used, fields that have language translations have a localeData element returned for the specified locales if data is present. |
Example URL
…/services/rest/user/105
Response Details
For a successful response, an HTTP 301 message is returned, which is automatically acted upon to retrieve XML consisting of a userFullDTO root element containing the individual attributes of the requested User record. If an ID is not specified, a list of all users is returned (per the List of Values function).
See the associated WADL for a full list of the attributes, and the Oracle Retail Supplier Evaluation Cloud Service Data Dictionary, Volume 1 - Framework for details of their mapping to the fields within the Supplier Evaluation UI.
Error Messages
id |
HTTP 404 Not found |
Invalid {id} - not numeric |
id |
HTTP 417 IllegalStateException: Cannot find the User to return with id:<###> |
Invalid {id} - not found |
Description
Retrieves a single User record's details using its business key (login ID). Use this function to retrieve the full details of an individual user using its Supplier Evaluation login ID.
Endpoint address: /services/rest/byKey/{loginId} HTTP method: GET
Request Details
There are no request parameters, but the URL contains the {loginId} parameter that determines the record to retrieve.
Example URL
…/services/rest/user/byKey/Frank Jones
Response Details
If successful, an HTTP 301 redirect response is sent containing a header Location with the URI of the document requested.
The returned URI represents the call to be made to the Retrieve Record by ID function (with the id substituted with the relevant value), which will return a userFullDTO root element containing the individual attributes of the requested User record.
If your method of calling the API is configured to automatically follow HTTP 301 redirects, the call may automatically return a userFullDTO root element containing the individual attributes of the requested User record.
Error Messages
loginId |
Invalid {loginId} - blank or not found |
loginId |
Invalid {loginId} - not found |
Description
Retrieves the last modification date and time of a User record. Use this function to determine when a user's details were last updated.
Endpoint address: /services/rest/user/{id} HTTP method: HEAD
Request Details
There are no request parameters, but the URL contains the {id} parameter that determines the record to retrieve.
Example URL
Response Details
If successful, an HTTP 200 response is sent containing the Last-Modified header showing the date and time of the last update of the requested User record. For example:
HTTP/1.1 200 OK Date: Wed, 13 Jul 2016 07:52:14 GMT Last-Modified: Fri, 08 Jul 2016 06:44:46 GMT Content-Type: application/xml Content-Length: 0
Error Messages
id |
id |
Create Record
Description
Creates a new User record. Use this function to create a new user in Supplier Evaluation based on data sourced from the external system.
Dependencies: If creating a supplier user, the Supplier must be present in the application and its record ID obtained. For more information, see Dependencies.
Endpoint address: /services/rest/user HTTP method: POST
Request Details
The body of the request contains a UserFullDTO to specify the details of the user to create. Compared to retrieving a user (which uses the same UserFullDTO type), this request is much shorter. Only the attributes that are to be populated on the created User record need to be included. As a minimum, this must include the fields shown in the following table:
Supplier User Mandatory Fields
| Field Name | Element Name |
Name |
person / name |
person / email |
Login Id |
code |
User Role |
role / code |
Supplier Code |
person / supplier / code supplier / code |
User Type |
userType (Fixed value SUPPLIER) |
Deleted Record |
deleted (Set to false) |
Login Id Disabled |
disabled (Set to false) |
Login Permitted |
loginPermitted (Set to true) |
Language |
language / code |
Example Request XML
This example shows the minimum requirement to be able to create a supplier user.
<ns0:userFullDTO xmlns:ns1="http://www.micros.com/creations/core/domain/dto/v1p0/simple" xmlns:ns0="http://www.micros.com/creations/core/domain/dto/v1p0/full">
<ns0:code>jphillips</ns0:code>
<ns0:person>
<ns0:email>jphillips@supplier.co.uk</ns0:email>
<ns0:name>Jane Phillips</ns0:name>
<ns0:supplier>
<ns1:code>A0174</ns1:code>
</ns0:supplier>
</ns0:person>
<ns0:role>
<ns1:code>SUPPLIER ADMINISTRATOR</ns1:code>
</ns0:role>
<ns0:supplier>
</ns0:supplier>
<ns0:userType>SUPPLIER</ns0:userType>
<ns0:deleted>false</ns0:deleted>
<ns0:disabled>false</ns0:disabled>
<ns0:loginPermitted>true</ns0:loginPermitted>
</ns0:userFullDTO>Note:
When creating a supplier user, the user type must be set to SUPPLIER. The supplier code must be set to match the required supplier from Supplier Evaluation.
Site User Mandatory Fields
Name |
person / name |
person / email |
Login Id |
code |
User Role |
role / code |
Supplier Code |
Sites |
sites / code sites/ supplierCode |
User Type |
userType (Fixed value SITE) |
Deleted Record |
Login Id Disabled |
Login Permitted |
Language |
language / code |
Example Request XML
This example shows the minimum requirement to be able to create a site user.
<ns0:person>
<ns0:email>sphillips@supplier.co.uk</ns0:email>
<ns0:name>Sean Phillips</ns0:name>
<ns0:supplier>
<ns1:code>WS0001</ns1:code>
<ns1:id>22</ns1:id>
</ns0:supplier>
</ns0:person>
<ns0:role>
<ns1:code>SITE USER</ns1:code>
</ns0:role>
<ns0:sites>
<ns1:code>WS0001-0001</ns1:code>
<ns1:id>26</ns1:id>
<ns1:supplierCode>WS0001</ns1:supplierCode>
<ns1:id>22</ns1:id>
</ns0:sites>
<ns0:supplier>
<ns1:id>22</ns1:id>
</ns0:supplier>
<ns0:userType>SITE</ns0:userType>
When creating a site user the user type must be set to SITE. The supplier code must be set to match the required supplier from Supplier Evaluation. The site codes must be set to match the required site from Supplier Evaluation.
Retailer User Mandatory Fields
Name |
person / name |
person / email |
Login Id |
code |
User Role |
role / code |
Supplier Code |
person / supplier / code supplier / code (Fixed value RETAILER) |
User Type |
userType (Fixed value RETAILER) |
Deleted Record |
Login Id Disabled |
Login Permitted |
Language |
language / code |
Example Request XML
This example shows the minimum requirement to be able to create a retailer/portal owner user.
<ns0:code>james howard</ns0:code>
<ns0:person>
<ns0:email>james.howard@example.com</ns0:email>
<ns0:name>James Howard</ns0:name>
<ns0:supplier>
<ns1:code>RETAILER</ns1:code>
</ns0:supplier>
</ns0:person>
<ns0:role>
<ns1:code>POWER USER</ns1:code>
</ns0:role>
<ns0:supplier>
</ns0:supplier>
<ns0:userType>RETAILER</ns0:userType>
When creating a retailer/portal owner user, the user type must be set to RETAILER. The supplier code must be set to RETAILER.
Enabling User Accounts
Where the record is linked to another record, such as the Role in these cases, the business key must be provided (not the description) in order to form the link between the records. In general, the business key will be the code attribute of the linked record.
Set loginPermitted to true to ensure a corresponding IDCS or OCI IAM profile is automatically created for the user. If an IDCS or OCI IAM profile is not required, setting the loginPermitted attribute to false will skip the IDCS or OCI IAM profile creation.
Set the deleted attribute to false to ensure the record can be seen in the UI. If omitted, or set to true, it will exist, but will not be visible.
When a new record is created in Supplier Evaluation, a corresponding IDCS or OCI IAM profile is automatically created to manage login authentication. If an IDCS or OCI IAM profile is not required, setting the loginPermitted attribute to false will skip the IDCS or OCI IAM profile creation.
Response Details
For a successful response, an HTTP 200 response is sent with a body containing a UserLink root element. The root element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Newly created User record's internal ID |
recordLink |
string |
URI to the newly created User record, for use in a GET request |
loginId |
string |
Login ID / business key to the newly created User record |
name |
string |
User's name |
Error Responses
If the supplied data does not result in a valid User (such as a missing mandatory field), an HTTP 417 response is sent with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
code |
ERROR: class com.micros.creations.core.domain.User.code - The condition is invalid |
Code not provided |
ERROR: class com.micros.creations.core.domain.User.person.email - The condition is invalid |
Email not provided |
name |
ERROR: class com.micros.creations.core.domain.User.person.name - The condition is invalid |
Name not provided |
role |
ERROR: class com.micros.creations.core.domain.User.role - A user must have an active authority profile from either roles or additional authority profiles |
Role or authority profiles not provided |
Update Record
Description
Updates an existing User record. Use this function to update a user's details in Supplier Evaluation based on data sourced from the external system.
Endpoint address: /services/rest/{id} HTTP method: PUT
Request Details
The body of the request contains a UserFullDTO to specify the updates to the User record. Compared to retrieving a user (which uses the same UserFullDTO type), this request is much shorter. As a minimum, the values specified as mandatory for the Create Record function (see above) must be included.
The request content is similar to that for creating a user. After the call, the User record is updated to match the request.
When updating records, all values must be included. If a value or element is omitted from the request, the field contents will be cleared on the User record.
Any values passed for Login Id or Email Address are ignored, as they cannot be updated once the record has been created.
Process for Disabling User Accounts
A user's account can be disabled using the Update Record function as follows:
Call the Retrieve Record by Business Key GET function or the Retrieve Record by Id function, passing the login id or the record id respectively, to retrieve the full XML for the user.
Amend the returned XML as follows:
Set the account to disabled with <ns0:disabled>true<ns0:disabled> and <ns0:loginPermitted>false<ns0:loginPermitted
Remove the localeData and activeAuthorityProfiles elements.
Call the Update Record PUT function, passing the full amended XML to disable the account.
Response Details
If successful, an HTTP 200 response is sent with a body containing a UserLink element. The UserLink element consists of the returned elements shown in the following table.
Returned Elements
recordId |
long |
recordLink |
string |
URI to the User record, for use in a GET request |
loginId |
string |
Login ID/business key to the User record |
name |
string |
User's name |
Error Responses
If the supplied data does not result in a valid user (such as a missing mandatory field), an HTTP 417 response is sent with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
SupplierRestService
This section describes the API for managing suppliers. The following functions are available:
List of Values: retrieves a list of suppliers
Retrieve Record by ID: retrieves a Supplier record using its unique identifier
Retrieve Record by Business Key: retrieves a Supplier record using its business key
Check Record Modification Timestamp: retrieves the timestamp when a Supplier record was last updated
Create Record: creates a new Supplier record
Update Record: updates an existing Supplier record
When integrated with Merchandising, using the SupplierRestAPI to make changes that affect the Billing Details table can have an impact on the integration.
List of Values
Description
Retrieves a list of suppliers in a paged list. Use this function to retrieve a simple list of supplier names and IDs, or to locate Supplier record IDs prior to a retrieve or update operation. Parameters are available to apply specific selection criteria for filtering the returned records.
Endpoint address: /services/rest/supplier HTTP method: GET
Request Details
URI Parameters
| supplierStatus | Optional | string | Yes | No | AWAITING REGISTRATION |
| supplierCode | Optional | string | Yes | Yes | A0001 |
| supplierName | Optional | string | Yes | Yes | West Road Site |
| supplierType | Optional | string | Yes | Yes | AGENT |
| country | Optional | string | Yes | Yes | UK |
| leadBusinessUnit | Optional | string | Yes | Yes | UK |
| isActive | Optional | string | No | No |
true returns active suppliers no value returns both active and inactive suppliers |
| invoicingRef | Optional | string | No | Yes | ABC123 |
Example URLs
…/services/rest/supplier/?offset=2&pageSize=20 …/services/rest/supplier/?supplierStatus=AWAITING REGISTRATION …/services/rest/supplier/?supplierName=API%
Response Details
For a successful response, XML is returned with a SupplierLinkList root element containing an entries element for each matched supplier. The entries element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Supplier record's internal ID |
recordLink |
string |
URI to the SupplierRestService Retrieve record service for this supplier |
code |
string |
Supplier code business key to the Supplier record |
name |
string |
Supplier's name |
localName |
string |
Supplier's name in business language (if used) |
Error Messages
supplierStatus |
HTTP 417 IllegalStateException: The Supplier Status <###> does not exist |
Invalid supplier status |
supplierStatus |
HTTP 417 IllegalStateException: The Supplier Statuses <###~###~###> do not exist |
supplierType |
HTTP 417 IllegalStateException: The Supplier Type <###> does not exist |
Invalid supplier type |
supplierType |
HTTP 417 IllegalStateException: The Supplier Types <###~###> do not exist |
country |
HTTP 417 IllegalStateException: The Country <###> does not exist |
Invalid country |
country |
HTTP 417 IllegalStateException: The Countries <###~###> do not exist |
Invalid country |
leadBusinessUnit |
HTTP 417 IllegalStateException: The Business Unit <###> does not exist |
Invalid business unit |
leadBusinessUnit |
HTTP 417 IllegalStateException: The Business Units <###~###> do not exist |
pageSize |
Error Code: INVALIDRESTSERVICEPAGESIZE |
offset |
Error Code: INVALIDOFFSET |
supplierStatus |
Error Code: INVALIDSUPPLIERSTATUS |
Invalid Supplier Status |
supplierType |
Error Code: INVALIDSUPPLIERTYPE |
Invalid Supplier Type |
country |
Error Code: INVALIDCOUNTRY |
Invalid Country |
leadBusinessUnit |
Error Code: INVALIDBUSINESSUNIT |
Invalid Business Unit |
isActive |
Error Code: INVALIDBOOLEAN |
Invalid isActive value Permitted values (not case-sensitive) are: true; yes; 1; false; no; 0 |
Description
Retrieves a single Supplier record's details using the record's internal ID (which is not visible in the UI). Use this function to retrieve the full details of an individual supplier.
Endpoint address: /services/rest/supplier/{id} HTTP method: GET
Request Details
URI Parameters
locale |
Optional |
string |
Yes |
Example URL
…/services/rest/supplier/9
Response Details
For a successful response, an HTTP 301 message is returned, which is automatically acted upon to retrieve XML consisting of a supplierFullDTO root element containing the individual attributes of the requested Supplier record. If an ID is not specified, a list of all suppliers is returned (per the List of Values function).
See the associated WADL for a full list of the attributes, and the Oracle Retail Supplier Evaluation Cloud Service Data Dictionary, Volume 2 - Supplier for details of their mapping to the fields within the Supplier Evaluation UI.
Error Messages
id |
id |
HTTP 417 IllegalStateException: Cannot find the Supplier to return with id:<###> |
Description
Retrieves a single Supplier record's details using its business key (supplier code). Use this function to retrieve the full details of an individual supplier using the Supplier Evaluation supplier code.
Endpoint address: /services/rest/supplier/byKey/{code} HTTP method: GET
Request Details
There are no request parameters, but the URL contains the {code} parameter that determines the record to retrieve.
Example URL
…/services/rest/supplier/byKey/A0901
Response Details
The returned URI represents the call to be made to the Retrieve Record by ID function (with the id substituted with the relevant value), which will return a supplierFullDTO root element containing the individual attributes of the requested Supplier record.
If your method of calling the API is configured to automatically follow HTTP 301 redirects, the call may automatically return a supplierFullDTO root element containing the individual attributes of the requested Supplier record.
Error Messages
code |
Invalid {code} - blank |
code |
Invalid {code} |
Description
Retrieves the last modification date and time of a Supplier record. Use this function to determine when a supplier's details were last updated.
Endpoint address: /services/rest/supplier/{id} HTTP method: HEAD
Request Details
Example URL
Response Details
If successful, an HTTP 200 response is sent containing the Last-Modified header showing the date and time of the last update of the requested Supplier record.
Error Responses
id |
id |
Create Record
Description
Creates a new Supplier record. Use this function to create new suppliers in Supplier Evaluation based on data sourced from the external system.
Dependencies: Create sites and contacts after creating the supplier. For more information, see Dependencies.
Endpoint address: /services/rest/supplier HTTP method: POST
Request Details
The body of the request contains a SupplierFullDTO to specify the detail of the supplier to create. Compared to retrieving a supplier (which uses the same SupplierFullDTO type), this request is much shorter. Only the attributes that are to be populated on the created Supplier record need to be included. As a minimum, this must include the fields shown in the following table.
Supplier Mandatory Fields
Supplier Name |
name |
Contact Name |
supplierContactName |
Supplier Type |
supplierType/code |
Lead Business Unit |
businessUnit/code |
Billing Code |
billingCode/code |
Status |
Status |
Supplier Code Confirmed Flag |
supplierCodeConfirmed |
Deleted Record |
Created On |
createdOn (set to current date using format YYYY-MM-DD or to current date and time using format YYYY-MM-DDThh:mm:ss) |
Is Active |
isActive - see below |
Potential Supplier |
potentialSupplier (Set to false) |
Example Request XML
This example shows the minimum requirement to be able to create a supplier.
<ns1:supplierFullDTO
xmlns:ns2="http://www.micros.com/creations/core/domain/dto/v1p0/simple"
xmlns:ns1="http://www.micros.com/creations/core/domain/dto/v1p0/full">
<ns1:billingCode>
<ns2:code>SMALL</ns2:code>
</ns1:billingCode>
<ns1:businessUnit>
<ns2:code>UK</ns2:code>
</ns1:businessUnit>
<ns1:email>supplier.contactemail@supplier.co.uk</ns1:email>
<ns1:name>Name of Supplier</ns1:name>
<ns1:status>AWAITING REGISTRATION</ns1:status>
<ns1:supplierContactName>Supplier Contact Name</ns1:supplierContactName>
<ns1:supplierCodeConfirmed>false</ns1:supplierCodeConfirmed>
<ns1:supplierType>
<ns2:code>SUPPLIER_TYPE</ns2:code>
</ns1:supplierType>
<ns1:deleted>false</ns1:deleted>
<ns1:createdOn>2020-09-29T09:00:00</ns1:createdOn>
<ns1:isActive>false</ns1:isActive>
<ns1:potentialSupplier>false</ns1:potentialSupplier>
</ns1:supplierFullDTO>
Set the deleted attribute to false to ensure the record can be seen in the UI. If omitted or set to true, it will exist, but will not be visible.
The Supplier API only creates the Supplier record, just as the Site API only creates the Site record. The same goes for the User API; it only creates the User record, and similarly the Contact API only creates the Contacts records. Each Supplier record must also have at least one Site record created for it.
Supplier Contacts and their User records must be created using the respective APIs, and linked to the supplier/site with their record IDs. When a new Supplier is created through the API, the process does not automatically create the initial Supplier user.
Use of the isActive and supplierCodeConfirmed Flags
The isActive and supplierCodeConfirmed flags on the Supplier record are used to control the Registration process within the application UI.
isActive is a Boolean TRUE/FALSE value. It is always FALSE when a Supplier is created in the application UI. If set to FALSE in the API, when the supplier user first logs in to the system, the Supplier Registration wizard runs (as it does if the Supplier has been created through the application UI). Successful completion of the Registration wizard sets the isActive flag to TRUE, thus ensuring it only runs once. Therefore, if set to TRUE in the API, when the Supplier user first logs in to the system, the Registration wizard will not run.
supplierCodeConfirmed is a Boolean TRUE/FALSE value. It is always FALSE when a Supplier is created through the application UI. It is a security measure for the supplier user logging in for the first time, where they are prompted to enter their Supplier Code. The application changes the value to TRUE if there is a successful match.
Setting both isActive and supplierCodeConfirmed as FALSE will trigger the Registration wizard process when the supplier user first logs in, prompting for the entry of the Supplier Code.
Setting both isActive and supplierCodeConfirmed as TRUE indicates that the information captured during the Registration wizard process has effectively been provided, and therefore the wizard will not run.
Setting isActive as FALSE and supplierCodeConfirmed as TRUE indicates that part of the information captured during the Registration wizard process is present, but the wizard will run to allow the user to complete the data entry.
If a Supplier is created with a status of AWAITING AUTHORISATION, but with isActive set as TRUE, the Supplier status is changed to REGISTERED, thus bypassing the Registration process.
When a new supplier is created manually within the application, the system sends an email to the supplier requesting they complete the registration process. When creating a new supplier through the API, the email is not generated.
Where the record is linked to another record, such as the Supplier Type in this case, the business key must be provided (not the description) in order to form the link between the records. In general, the business key will be the code attribute of the linked record.
Response Details
If successful, an HTTP 200 response is sent with a body containing a SupplierLink root element. The root element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Newly created Supplier record's internal ID |
recordLink |
string |
URI to the newly created Supplier record, for use in a GET request |
code |
string |
Supplier code business key to the newly created Supplier record |
name |
string |
Supplier's name |
localName |
string |
Error Messages
If the supplied data does not result in a valid Supplier (such as a missing mandatory field), an HTTP 417 response is sent with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
billingCode |
ERROR: class <<hostname>>.Supplier.billingCode - The condition is invalid |
No tag provided |
billingCode |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>.BillingCode using code:null |
No <ns1:code> tag |
billingCode |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>..BillingCode using code:<###> |
Invalid <ns1:code> |
businessUnit |
ERROR: class <<hostname>>..Supplier.businessUnit - The condition is invalid |
No tag provided |
businessUnit |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>..domain.BusinessUnit using code:null |
No <ns1:code> tag |
businessUnit |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>..BusinessUnit using code:<###> |
code |
ERROR: class com.micros.creations.core.domain.Supplier.code - ??Another object exists with this value?? |
Supplier code already exists |
ERROR: class com.micros.creations.core.domain.Supplier.email - The condition is invalid |
No tag provided |
ERROR: class <<hostname>>.Supplier.email - The attribute is invalid |
Malformed email address |
ERROR: class <<hostname>>.Supplier.supplierContactName - The condition is invalid |
No tag provided |
No value provided |
name (supplier name) |
ERROR: class <<hostname>>.Supplier.name - The condition is invalid |
No tag provided |
No value provided |
supplierType |
ERROR: class <<hostname>>.Supplier.supplierType - The condition is invalid |
No tag provided |
supplierType |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>.SupplierType using code:null |
No <ns1:code> tag |
supplierType |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>.SupplierType using code:<###> |
Update Record
Description
Updates an existing Supplier record. Use this function to update a supplier's details in Supplier Evaluation based on data sourced from the external system.
Endpoint address: /services/rest/supplier/{id} HTTP method: PUT
Request Details
The body of the request contains a SupplierUpdateDTO to specify the updates to the Supplier record. Compared to retrieving a supplier (which uses the SupplierFullDTO type), this request is much shorter. As a minimum, the values specified as mandatory for the Create Record function (see above) must be included.
The request content is similar to that for creating a supplier, but crucially, the links to other top-level records (Sites, SiteContact, SupplierContact) are omitted. The omission of those ensures that when updating a supplier, only the supplier details need to be specified, and not the details for the related records that may not require updating (and which should be updated to calls to their respective services). After the call, the Supplier record is updated to match the request.
When updating records, all values must be included. If a value or element is omitted from the request, the field contents will be cleared on the Supplier record (except for the Sites, SiteContacts, and SupplierContacts).
Response Details
If successful, an HTTP 200 response is sent with a body containing a SupplierLink element. The SupplierLink element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
recordLink |
string |
URI to the Supplier record, for use in a GET request |
code |
string |
name |
string |
Supplier's name |
localName |
string |
Error Messages
billingCode |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>.BillingCode using code:<###> |
businessUnit |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>domain.BusinessUnit using code:<###> |
code |
MySQLIntegrityConstraintViolationException: Duplicate entry <###> for key 'c_code' |
Supplier code provided that already exists for another supplier |
name |
PropertyValueException: not-null property references a null or transient value: <<hostname>>.domain.Supplier.name |
No tag provided |
status |
NullPointerException: |
No status tag provided |
status |
IllegalArgumentException: Empty string is not allowed, should be null on method: <<hostname>>.domain.Supplier@1df35f3[id=<###>,code=<###>] |
No status code provided |
SiteRestService
This section describes the API for managing sites. The following functions are available:
List of Values: retrieves a list of sites
Retrieve Record by ID: retrieves a Site record using its unique identifier
Retrieve Record by Business Key: retrieves a Site record using its business key
Check Record Modification Timestamp: retrieves the timestamp when a Site record was last updated
Create Record: creates a new Site record
Update Record: updates an existing Site record
When integrated with Merchandising, using the SiteRestAPI to make changes that affect the Billing Details table can have an impact on the integration.
List of Values
Description
Retrieves a list of sites in a paged list. Use this function to retrieve a simple list of supplier names and IDs, or to locate Site record IDs prior to a retrieve or update operation. Parameters are available to apply specific selection criteria for filtering the returned records.
Endpoint address: /services/rest/site HTTP method: GET
Request Details
URI Parameters
| Parameter Name | Mandatory/ Optional | Value Type | Multiple Value Separator (~) Supported? | Wildcard Search Supported? | Example | Validation |
| offset | Optional | int | No | No | 60 | |
| pageSize | Optional | int | No | No | 30 | |
| siteStatus | Optional | string | Yes | No | AWAITING REGISTRATION | |
| siteCode | Optional | string | Yes | Yes | A0001-0001 | |
| siteName | Optional | string | Yes | Yes | West Road Site | |
| siteType | Optional | string | Yes | Yes | CANNERY | |
| country | Optional | string | Yes | Yes | UK | |
| businessCategory | Optional | string | Yes | Yes | CHEESE_DAIRY |
Code in the Business Categories glossary at any level of the hierarchy. Applies the filter to Business Category and Lead Business Category (if used). Returns a result if any of the values match any of the specification's business categories. |
| businessUnit | Optional | string | Yes | Yes | UK | |
| supplierName | Optional | string | Yes | Yes | ABC Ltd | |
| supplierActive | Optional | String | No | No |
true (otherwise will return active and inactive suppliers) |
| modifiedSince | Optional | string | No | No | 2015-05-19 13:30:39 | |
| modifiedUntil | Optional | string | No | No | 2015-05-19 13:30:39 | |
| statusChangedFrom | Optional | string | No | No | 2015-06-10 09:00:00 |
If From and Until are both used, then the Until date must be greater than or equal to the From date. |
| statusChangedUntil | Optional | string | No | No | 2015-06-10 09:00:00 | |
| statusChangedTo | Optional | string | Yes | No | ACTIVE | |
| leadTechnologist | Optional | string | Yes | Yes | John Smith | The user's Login Id. |
Example URLs
…/services/rest/site/?offset=2&pageSize=20 …/services/rest/site/?siteStatus=ACTIVE …/services/rest/site/?supplierName=API%
Response Details
For a successful response, XML is returned with a SiteLinkList root element containing an entries element for each matched site. The entries element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Site record's internal ID |
recordLink |
string |
URI to the SiteRestService Retrieve record for this site |
code |
string |
Site code business key to the Site record |
name |
string |
Site's name |
localName |
string |
Site's name in business language (if used) |
Error Messages
siteStatus |
Invalid site status |
siteStatus |
siteType |
siteType |
country |
Invalid country |
country |
Invalid country |
businessCategory |
HTTP 417 IllegalStateException: The Business Category <###> does not exist |
Invalid business category |
businessCategory |
HTTP 417 IllegalStateException: The Business Categories <###~###> do not exist |
businessUnit |
businessUnit |
modifiedSince |
Invalid dates cause stack trace to come back to "response" |
modifiedUntil |
pageSize |
Error Code: INVALIDRESTSERVICEPAGESIZE INVALIDPAGESIZE |
offset |
siteStatus |
Error Code: INVALIDSITESTATUS INVALIDSITESTATUSES |
Invalid Site Status |
siteType |
Error Code: INVALIDSITETYPE |
Invalid Site Type |
country |
Invalid Country |
businessCategory |
Error Code: INVALIDBUSINESSCATEGORY |
Invalid Business Category |
businessUnit |
supplierActive |
Invalid supplierActive value Permitted values (not case-sensitive) are: true; yes; 1; false; no; 0 |
leadTechnologist |
Error Code: INVALIDUSER |
Invalid Lead Technologist |
statusChangedFrom |
Error Code: INVALIDDATEFORMAT |
Invalid Status Changed From Must be a valid date/time format: Year-Month-DayOfMonth Hour:Minute:Seconds such as 2016-12-30 09:59:59 |
Invalid Status Changed Until Must be a valid date/time format: Year-Month-DayOfMonth Hour:Minute:Seconds such as 2016-12-30 09:59:59 |
statusChangedTo |
Error Code: INVALIDSTATUSCHANGEDTO |
Either Status Changed From or Status Changed Until must be specified if filtering on Status Changed To |
Description
Retrieves a Site record's details using the record's internal unique ID (which is not visible in the UI). Use this function to retrieve the full details of an individual site.
Endpoint address: /services/rest/site/{id} HTTP method: GET
Request Details
URI Parameters
locale |
Optional |
string |
Yes |
Example URL
…/services/rest/site/87
Response Details
For a successful response, an HTTP 301 message is returned, which is automatically acted upon to retrieve XML consisting of a siteFullDTO root element containing the individual attributes of the requested Site record. If an ID is not specified, a list of all sites is returned (per the List of Values function).
Error Messages
id |
id |
HTTP 417 IllegalStateException: Cannot find the Site to return with id:<###> |
Description
Retrieves a single Site record's details using its business key (supplier and codes). Use this function to retrieve the full details of an individual site using the combination of the Supplier Evaluation supplier and site codes.
Endpoint address: /services/rest/site/byKey/{supplierCode}/{siteCode} HTTP method: GET
Request Details
There are no request parameters, but the URL contains the {supplierCode} and {siteCode} parameters that determine the record to retrieve.
Example URL
…/services/rest/site/byKey/A0001/A0001-0001
Response Details
The returned URI represents the call to be made to the Retrieve Record by ID function (with the id substituted with the relevant value), which will return a siteFullDTO root element containing the individual attributes of the requested Site record.
If your method of calling the API is configured to automatically follow HTTP 301 redirects, the call may automatically return a siteFullDTO root element containing the individual attributes of the requested Site record.
Error Messages
supplierCode |
Invalid {supplierCode} - blank |
siteCode |
Invalid {siteCode} |
Description
Retrieves the last modification date and time of a Site record. Use this function to determine when a site's details were last updated.
Endpoint address: /services/rest/site/{id} HTTP method: HEAD
Request Details
Example URL
Response Details
If successful, an HTTP 200 response is sent containing the Last-Modified header showing the date and time of the last update of the requested Site record.
Error Messages
id |
id |
Create Record
Description
Creates a new Site record. Use this function to create new sites in Supplier Evaluation based on data sourced from the external system.
Dependencies: The Supplier must be present in the application and its record ID obtained. If assigning a Business Category or Technologist, the record must be present in the application and its record ID obtained. Create Contacts after creating the Site. For more information, see Dependencies.
Endpoint address: /services/rest/site HTTP method: POST
Request Details
The body of the request contains a SiteFullDTO element to specifying the details of the site to create. Compared to retrieving a site (which uses the same SiteFullDTO type), this request is much shorter. Only the attributes that are to be populated on the created Site record need to be included. As a minimum, this must include the fields shown in the following table.
Site Mandatory Fields
Site Name |
name |
Site Type |
siteType/code |
Categories |
businessCategories |
Lead Technologist |
leadTechnicalManager |
Supplier |
supplier/code |
Site Status |
siteStatus |
Deleted Record |
Example Request XML
This example shows the minimum requirement to be able to create a site against a supplier.
<ns1:siteFullDTO
<ns0:businessCategories>
<ns1:code>CATEGORY2A</ns1:code>
</ns0:businessCategories>
<ns0:leadTechnicalManager>
<ns1:code>techadmin</ns1:code>
</ns0:leadTechnicalManager>
<ns0:name>Site Name</ns0:name>
<ns0:siteType>
<ns1:code>SITE_TYPE_EXAMPLE</ns1:code>
</ns0:siteType>
<ns0:siteStatus>
<ns1:status>ACTIVE</ns1:status>
</ns0:siteStatus>
<ns0:supplier>
</ns0:supplier>
</ns1:siteFullDTO>
Where the record is linked to another record, such as the Site Type in this case, the business key must be provided (not the description) in order to form the link between the records. In general, the business key will be the code attribute of the linked record.
Response Details
If successful, an HTTP 200 response is sent with a body containing a SiteLink root element containing the site data, and a SupplierLink element, consisting of the parent supplier data. The returned elements are shown in the following table.
Returned Elements
recordId |
long |
Newly created Site record's internal ID |
recordLink |
string |
URI to the newly created Site record, for use in a GET request |
code |
string |
Supplier and site code business key to the newly created Site record |
name |
string |
Site's name |
localName |
string |
supplierLink/recordId |
long |
Newly created site's Supplier record internal ID |
supplierLink/recordLink |
string |
URI to the newly created site's Supplier record, for use in a GET request |
recordLink/code |
string |
Supplier code business key to the newly created site's Supplier record |
recordLink/name |
string |
Supplier's name |
recordLink/localName |
string |
Error Messages
If the supplied data does not result in a valid Site (such as a missing mandatory field), an HTTP 417 response is sent with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
supplier/id |
Null Pointer Exception |
Supplier ID not provided |
supplier/id |
No row with the given identifier exists: [com.micros.creations.core.domain.Supplier#<###>] |
Supplier not found |
siteStatus |
Site Status not provided |
siteStatus |
Cannot locate keyword for class com.micros.creations.core.domain.SiteStatus using status:<###> |
Site Status not found |
siteType |
ERROR: class com.micros.creations.core.domain.Site.siteType - The condition is invalid |
Site Type not provided |
siteType |
Cannot locate keyword for class com.micros.creations.core.domain.SiteType using code:<###> |
Site Type not found |
name |
class com.micros.creations.core.domain.Site.name - The condition is invalid |
Site name not provided |
ERROR: class com.micros.creations.core.domain.Site.leadTechnicalManager - The condition is invalid |
Lead Technical Manager not provided |
HTTP 417 IllegalStateException: Cannot locate keyword for class com.micros.creations.core.domain.User using code:<###> |
Lead Technical Manager not found |
ERROR: class com.micros.creations.core.domain.Site.businessCategories - The condition is invalid |
Business Category not provided |
Cannot locate keyword for class com.micros.creations.core.domain.BusinessCategory using code:<###> |
Business Category not found |
code |
Duplicate site code |
The site already exists for this supplier |
Update Record
Description
Updates an existing Site record. Use this function to update a site's details in Supplier Evaluation based on data sourced from the external system.
Endpoint address: /services/rest/site/{id} HTTP method: PUT
Request Details
The body of the request contains a SiteUpdateDTO to specify the updates to the Site record. Compared to retrieving a site (which uses the SiteFullDTO type), this request is much shorter. As a minimum, the values specified as mandatory for the Create Record function (see above) must be included.
The request content is similar to that for creating a site, but crucially, the links to other top-level records (SiteContact) are omitted. The omission of those ensures that when updating a site, only the site details need to be specified, and not the details for the related records that may not require updating (and which should be updated with calls to their respective services). After the call, the Site record is updated to match the request
When updating records, all values must be included. If a value or element is omitted from the request, the field contents will be cleared on the Site record (except for the SiteContacts).
Response Details
Returned Elements
recordId |
long |
Updated Site record's internal ID |
recordLink |
string |
URI to the updated Site record, for use in a GET request |
code |
string |
Site code business key to the updated Site record |
name |
string |
Site's name |
localName |
string |
long |
Updated site's Supplier record internal ID |
string |
URI to the updated site's Supplier record, for use in a GET request |
recordLink/code |
string |
Supplier code business key to the updated site's Supplier record |
recordLink/name |
string |
Supplier's name |
string |
Error Responses
If the supplied data does not result in a valid Site (such as a missing mandatory field), an HTTP 417 response is sent an with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
ContactRestService
This section describes the API for managing supplier and site contacts. The following functions are available:
List of Values: retrieves a list of contacts
Retrieve Record by ID: retrieves a Contact record using its unique identifier
Retrieve Supplier Contact Record by Business Key: retrieves a Supplier Contact record using its business key
Retrieve Site Contact Record by Business Key: retrieves a Site Contact record using its business key
Check Record Modification Timestamp: retrieves the timestamp when a Contact record was last updated
Create Record: creates a new Contact record
Update Record: updates an existing Contact record
List of Values
Description
Retrieves a list of contacts in a paged list. Use this function to retrieve a simple list of contact names and IDs, or to locate Contact record IDs prior to a retrieve or update operation. Parameters are available to apply specific selection criteria for filtering the returned records.
Endpoint address: /services/rest/contact HTTP method: GET
Request Details
URI Parameters
| name | Optional | string | Yes | Yes | John Smith |
| supplierContactRoles | Optional | string | Yes | Yes | HEAD OF MANUFACTURING |
| siteContactRoles | Optional | string | Yes | Yes | HEAD OF MANUFACTURING |
| selectedSites | Optional | string | No | No | A0001-0001 |
| supplierName | Optional | string | Yes | Yes | ABC Ltd. |
true returns active contacts no value returns both active and inactive contacts |
Example URLs
…/services/rest/contact/?offset=2&pageSize=20 …/services/rest/contact/?siteStatus=ACTIVE …/services/rest/contact/?supplierName=API%
Response Details
For a successful response, XML is returned with a ContactLinkList root element containing an entries element for each matched contact. The entries element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Contact record's internal ID |
recordLink |
string |
URI to the ContactRestService Retrieve record service for this contact |
string |
Contact's email address |
name |
string |
Contact's name |
siteContact |
Boolean |
Indicates if a contact for the site (true), else false |
supplierContact |
Boolean |
Indicates if a contact for the supplier (true), else false |
Error Messages
HTTP 417 IllegalStateException: The Supplier Contact Role <###> does not exist |
Invalid supplier contact role |
HTTP 417 IllegalStateException: The Supplier Contact Roles <###~###> do not exist |
siteContactRoles |
HTTP 417 IllegalStateException: The Site Contact Role <###> does not exist |
Invalid site contact role |
siteContactRoles |
HTTP 417 IllegalStateException: The Site Contact Roles <###~###> do not exist |
country |
Invalid country code |
country |
siteStatus |
Invalid supplier status code |
pageSize |
offset |
supplierContactRole |
Error Code: INVALIDCONTACTROLE |
Invalid Supplier Contact Role |
siteContactRole |
Invalid Site Contact Role |
country |
Invalid Country |
selectedSite |
Error Code: INVALIDSITE |
Invalid Site |
supplierCode |
Error Code: INVALIDSUPPLIER |
Invalid Supplier |
siteStatus |
Error Code: INVALIDSITESTATUS |
supplierActive |
Description
Retrieves a single Contact record's details using the record's unique ID. Use this function to retrieve the full details of an individual supplier or site contact.
Endpoint address: /services/rest/contact/{id} HTTP method: GET
Request Details
URI Parameters
locale |
Optional |
string |
Yes |
Example URL
…/services/rest/contact/405
Response Details
For a successful response, an HTTP 301 message is returned, which is automatically acted upon to retrieve XML consisting of a contactAndPersonDTO root element containing the individual attributes of the requested Contact record and the person it associates to.
Error Messages
id |
id |
HTTP 417 IllegalStateException: Cannot find the Contact to return with id:<###> |
Description
Retrieves a single Supplier Contact record's details using its business key (supplier code, contact name, and email address). Use this function to retrieve the full details of an individual supplier contact using the combination of the Supplier Evaluation supplier codes, name of the contact, and the contact's email address.
Endpoint address: /services/rest/contact/byKey/supplier/{supplierCode}/{name}/{email} HTTP method: GET
Request Details
URI Parameters
supplierCode |
Mandatory |
string |
No |
A0001 |
name |
Mandatory |
string |
No |
John Doe |
Mandatory |
string |
No |
john.doe@email.com |
Example URL
…/services/rest/contact/byKey/supplier/A0001/John Doe/john.doe@email.com
Response Details
The returned URI represents the call to be made to the Retrieve Record by ID function (with the id substituted with the relevant value), which will return a contactAndPersonDTO root element containing the individual attributes of the requested Contact record.
If your method of calling the API is configured to automatically follow HTTP 301 redirects, the call may automatically return a contactAndPersonDTO root element containing the individual attributes of the requested Contact record.
Error Responses
In the document cannot be located, an HTTP 404 response is sent.
Description
Retrieves a single Site Contact record's details using its business key (supplier code, site code, contact name, and contact email). Use this function to retrieve the full details of an individual site contact using the combination of the Supplier Evaluation supplier and site codes, name of the contact, and the contact's email address.
Endpoint address: /services/rest/contact/byKey/site/{supplierCode}/{siteCode}/{name}/{email} HTTP method: GET
Request Details
URI Parameters
supplierCode |
Mandatory |
string |
No |
A0001 |
siteCode |
Mandatory |
string |
No |
A0001-0001 |
name |
Mandatory |
string |
No |
John Doe |
Mandatory |
string |
No |
Example URL
…/services/rest/contact/byKey/site/A0001/A0001-0001/ John Doe/john.doe@email.com
Response Details
For a successful response, XML is returned with a contactAndPersonDTO root element containing the individual attributes of the requested Contact record and the person it associates to.
Error Responses
Description
Retrieves the last modification date and time of a Contact record. Use this function to determine when a supplier or site contact's details were last updated.
Endpoint address: /services/rest/contact/{id} HTTP method: HEAD
Request Details
Example URL
Response Details
If successful, an HTTP 200 response is sent containing the Last-Modified header to show the last modification date and time of the last update of the requested Contact record.
Error Messages
id |
id |
Create Record
Description
Creates a new Contact record (and the associated Person record). Use this function to create new supplier or site contacts in Supplier Evaluation based on data sourced from the external system.
Dependencies: The Supplier (and Site, if a site contact) must be present in the application and its record ID obtained. Omit the Site element if not a site contact. The User/Person must be present in the application and its record ID obtained. For more information, see Dependencies.
Endpoint address: /services/rest/contact HTTP method: POST
Request Details
The body of the request contains a ContactAndPersonDTO to specify the details of the contact to create. Compared to the retrieving a contact (which uses the same ContactAndPersonDTO type), this request is much shorter. Only the attributes that are to be populated on the created Contact record need to be included. As a minimum, this must include the fields shown in the following table.
Contact Mandatory Fields
Name |
contactFullDTO/person/name personFullDTO/name |
User Id |
contactFullDTO/person/id |
Supplier |
contactFullDTO/person/supplier/id contactFullDTO/company/code personFullDTO/supplier/code personFullDTO/supplier/id |
contactFullDTO/person/email personFullDTO/email |
Phone |
contactFullDTO/contactDetails/phoneNumber |
Supplier Contact Roles |
contactFullDTO/supplierContactRole/code |
Contact Type |
contactFullDTO/dtype |
Site Contact Flag |
contactFullDTO/siteContact |
Supplier Contact Flag |
contactFullDTO/supplierContact |
Deleted Record |
Example Request XML
This example shows the minimum requirement to be able to create a contact against a supplier.
<ns0:ContactAndPersonDTO xmlns:ns4="http://www.oracle.com/orsecs/service/rest/model" xmlns:ns0="http://www.micros.com/creations/core/domain/dto/v1p0/full" xmlns:ns1="http://www.micros.com/creations/core/domain/dto/v1p0/simple">
<ns0:contactFullDTO>
<ns0:contactDetails>
<ns0:phoneNumber>01234 56789</ns0:phoneNumber>
</ns0:contactDetails>
<ns0:dtype>SupplierContact</ns0:dtype>
<ns0:person>
<ns1:email>jphillips@example.com</ns1:email>
<ns1:name>Jane Phillips</ns1:name>
<ns1:supplier>
<ns1:code>A0001</ns1:code>
</ns1:supplier>
</ns0:person>
<ns0:siteContact>false</ns0:siteContact>
<ns0:supplierContact>true</ns0:supplierContact>
<ns0:supplierContactRole>
<ns1:code>ACCOUNT MANAGER</ns1:code>
</ns0:supplierContactRole>
<ns0:company>
</ns0:company>
</ns0:contactFullDTO>
<ns0:personFullDTO>
<ns0:email>jphillips@example.com</ns0:email>
<ns0:supplier>
</ns0:supplier>
</ns0:personFullDTO>
</ns0:ContactAndPersonDTO>
If a contact has multiple supplier or site contact roles, they should be separate entries as follows:
<ns1:code>AUDITS AND VISITS CONTACT</ns1:code>
<ns1:code>EMERGENCY CONTACT</ns1:code>
Where the record is linked to another record, such as the Contact Role in this case, the business key must be provided (not the description) in order to form the link between the records. In general, the business key will be the code attribute of the linked record.
Response Details
If successful, an HTTP 200 response is sent with a body containing a ContactLink root element. The root element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Newly created Contact record's internal ID |
recordLink |
string |
URI to the newly created Contact record, for use in a GET request |
string |
Email address of the newly created contact |
name |
string |
Contact's name |
siteContact |
Boolean |
supplierContact |
Boolean |
Error Messages
phoneNumber |
phoneNumber - The condition is invalid |
Missing tag |
dtype |
IllegalArgumentException: Invalid value for dtype:<###> |
Invalid value SupplierContact; SiteContact |
name & email |
HTTP 417 IllegalStateException: Cannot locate Person record with name: <###> and email: <###> |
A valid user must be found with matching name and email address |
company |
HTTP 417 IllegalStateException: Cannot locate keyword for class com.micros.creations.core.domain.Company using code:<###> |
Invalid company/supplier code |
Update Record
Description
Updates an existing Contact record. Use this function to update a supplier or site contact's details in Supplier Evaluation based on data sourced from the external system.
Endpoint address: /services/rest/contact/{id} HTTP method: PUT
Request Details
The body of the request contains a ContactAndPersonDTO element to specify the updates to the Contact record. As a minimum, the values specified as mandatory for the Create Record function (see above) must be included.
The request content is the same as that for creating a contact. After the call, the Contact record is updated to match the request.
When updating records, all values must be included. If a value or element is omitted from the request, the field contents will be cleared on the Contact record.
Response Details
If successful, an HTTP 200 response is sent with a body containing a ContactLink element. The ContactLink element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
recordLink |
string |
URI to the Contact record, for use in a GET request |
string |
name |
string |
Contact's name |
siteContact |
Boolean |
supplierContact |
Boolean |
Error Messages
If the supplied data does not result in a valid Contact (such as a missing mandatory field), an HTTP 417 response is sent with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
TaskRestService
This section describes the API for managing user tasks. The following function is available:
List of Tasks: Retrieves a list of user tasks
List of Tasks
Description
Retrieves a list of tasks for a user in the given language. Use this function to retrieve a list of a specific user's entries in their Supplier Evaluation Task Manager app. Parameters are used to specify the name of the user, and the language of the returned task details.
Endpoint address: /services/rest/task HTTP method: GET
Request Details
URI Parameters
| userId | Mandatory | string | No | No | John Smith |
| language | Mandatory | string | No | No | en_GB |
Example URL
…/services/task/?language=en_GB
The userId parameter is the login ID of the user for which the tasks list is to be retrieved. The language parameter is the code of the language record/locale in which to retrieve the task details.
Response Details
For a successful response, XML is returned with a TaskDTOList root element containing a tasks element for each matched task. The root element consists of the elements in the following table.
Returned Elements
message |
string |
Name of the task, in the language specified |
messageId |
string |
A language-agnostic identifier for the task |
myCreationsLink |
string |
A URI to the Supplier Evaluation system, which will open the list of items for that task |
taskItemCount |
int |
The number of items in the task |
Error Messages
| Element | Message | Meaning |
userId |
userId required |
User not provided |
userId |
Cannot find user with login id <###> |
User not found |
language |
language required |
Language not provided |
language |
Invalid locale format: <###> |
Language not found |
UrgentItemsRestService
This section describes the API for retrieving a count of a user's urgent items. The following function is available:
Number of Urgent Items: retrieves the number of urgent items pending for a user
Description
Retrieves a count of the number of Urgent Item tasks for a user. Use this function to determine the number of pending urgent tasks a specific user has in their Supplier Evaluation Urgent Item Manager app. A parameter is passed to specify the name of the user.
Endpoint address: /services/rest/urgentItems HTTP method: GET
Request Details
URI Parameters
The userId parameter is the login ID of the user for which the number of pending urgent items are to be retrieved.
Response Details
For a successful response, XML is returned with an UrgentItemsModel root element containing an itemCount element that specifies the number of Urgent Items.
Error Messages
userId |
User not provided: userId required |
User not provided |
userId |
User not found |
ArtworkRestService
This section describes the API for Artwork integration. The following functions are available:
Started Activities: retrieves a list of Artwork Activities that have started
Update Record: updates existing Artwork Activities
Started Activities
Description
Retrieves a list of Project Activities that have their useMyArtwork flag set, and their status has changed to Started within the specified date range. This function is used for the integration of Supplier Evaluation with an external Artwork Management system.
Endpoint address: /services/rest/artwork/started HTTP method: GET
Request Details
URI Parameters
| fromDate | Mandatory | string | No | No | 2014-12-30 23:59:59 |
| toDate | Mandatory | string | No | No | 2015-12-30 23:59:59 |
Response Details
For a successful response, XML is returned with a CreateArtworkRequestList root element containing an entries element for each matching Artwork project activity. A totalRecords element identifies the number of records returned. Separate activityDetails and project elements group the returned activity and project data. The elements consist of the elements in the following tables.
Returned Elements - activityDetails
activityName |
string |
Project activity's title |
activityRecordId |
long |
Project activity record's internal ID |
actualStartDate |
string |
Actual start date of the project activity |
checkpointOnly |
Boolean |
Is the project activity a checkpoint only type |
criticalPath |
Boolean |
Is the project activity a critical path type |
duration |
int |
Duration of the project activity |
isAutoGate |
string |
Project's type of auto gate |
isGate |
Boolean |
Is the project activity a gate type |
isKey |
Boolean |
Is the project activity a key type |
projectId |
long |
Project record's internal ID |
projectTitle |
string |
Project's title |
proposedEndDate |
string |
Proposed end date of the project activity |
proposedStartDate |
string |
Proposed start date of the project activity |
responsibleUserRoles |
string |
Role names of the responsible users |
sequenceNumber |
string |
Project activity's sequence number |
statusCode |
string |
Code of the project activity's status |
subStatusCode |
string |
Code of the project activity's sub-status |
Returned Elements - projects
brand |
string |
Name of the project's brand |
categories |
string |
Names of the project's categories (the lowest level of the selected category - may be multiples) |
masterProject |
Boolean |
If the project is a master type |
newCategoryComments |
string |
Category comments |
packaging |
string |
Packaging details |
productRangeInformation |
string |
Project’s product range details |
projectConcept |
string |
Project's business key ID |
projectId |
string |
projectManager |
string |
Name of the project's project manager |
projectRecordId |
long |
projectTitle |
string |
Project's title |
projectType |
string |
Type of project |
proposedProducts |
string |
Project's proposed products |
specType |
string |
Type of project's product specification |
status |
string |
Status of the project |
subBrand |
string |
Name of the project's sub-brand |
supplier |
string |
Name of the supplier associated to the project |
site |
string |
Name of the site associated with the project |
targetConsumer |
string |
Project's target consumer details |
teamDetails/role |
string |
Name of the team role |
teamDetails/users |
string |
Name of the team users |
templateFolder |
string |
Name of the project template folder |
templateType |
string |
Type of the project's template |
templateUsed |
string |
Name of the project's template |
Error Messages
fromDate |
fromDate parameter required |
From date not provided |
toDate |
toDate parameter required |
To date not provided |
fromDate |
fromDate and toDate parameters are required |
From and To dates not provided |
toDate |
From date must be before or equal to To date |
From date is after To date |
fromDate |
HTTP 417 <errorMessage> |
Not a valid date, whereby <errorMessage> will identify the issue For example: IllegalInstantException: Cannot parse "2018-03-25 01:00:00": Illegal instant due to time zone offset transition (Europe/London) In this example, due to the clocks In this example, due to the clocks moving forward (in the server's time-zone), the passed in date is invalid |
toDate |
Not a valid date, whereby <errorMessage> will identify the issue (see example above) |
Update Record
Description
Updates the sub-status of existing Artwork Project Activities. This function is used for the integration of Supplier Evaluation with an external Artwork Management system, to update the status of an Artwork activity from the external system.
Endpoint address: /services/rest/artwork/update HTTP method: POST
Request Details
The body of the request contains an activityUpdateRequest element consisting of the elements shown in the following table.
Request Elements
| Element | Type | Description |
activityName |
string |
Project activity's name |
activityRecordId |
long |
projectId |
string |
ID business key to the Project record |
projectRecordId |
long |
subStatusCode |
string |
Code business key to the activity's sub-status |
After the call, the Project Activity record's sub-status is updated to match the request.
See the associated WADL for a full list of the attributes, and the Oracle Retail Supplier Evaluation Cloud Service Data Dictionary, Volume 3 - Process for details of their mapping to the fields within the Supplier Evaluation UI.
Response Details
If successful, an HTTP 200 response is sent with a body containing an ArtworkActivityLink element. The ArtworkActivityLink element consists of the elements shown in the following table.
Returned Elements
If successful, an HTTP 200 response is sent.
recordId |
long |
Project activity's internal ID |
recordLink |
string |
URI to the Product Activity record, for use in a GET request |
code |
string |
Code business key to the Project Activity record |
title |
string |
Error Messages
In the event that an error occurs, an HTTP 500 response is sent.
The following conditions may prevent a successful update:
An invalid project record id or activity record id.
The activity sub-statuses not being configured in Supplier Evaluation (including the general sub-statuses COMPLETED, MESSAGE SENT, MESSAGE ACCEPTED, and MESSAGE FAILED).
The activity's template not being flagged as an artwork type, or having the permitted activity sub-statuses assigned, prior to the activity being created (a snapshot of the template settings is stored on the Activity record on creation).
BusinessCategoryService
This section describes the API for managing Business Categories. The following functions are available:
List of Values: retrieves a list of categories
Retrieve Record by ID: retrieves a Business Category record using its unique identifier
Check Record Modification Timestamp: retrieves the timestamp when a Business Category record was last updated
Create Record: creates a new Business Category record
Update Record: updates an existing Business Category record
Delete Record: deletes an existing Business Category record
List of Values
Description
Retrieves a list of categories in a paged list. Use this function to retrieve a simple list of categories and IDs, or to locate Business Category record IDs prior to a retrieve or update operation. Parameters are available to apply specific selection criteria for filtering the returned records.
Endpoint address: /services/rest/businessCategory HTTP method: GET
Request Details
Parameters are passed as URI parameters.
URI Parameters
| code | Optional | string | Yes | Yes | POTATOES_LOOSE |
| parentCode | Optional | string | Yes | Yes | POTATOES |
| entityDescription | Optional | string | Yes | Yes | Loose Potatoes |
| specificationType | Optional | string | Yes | No | FOOD~PRODUCE |
| topLevelCategory | Optional | Boolean | No | No | TRUE |
Example URLs
…/services/rest/businessCategory/?offset=2&pageSize=20 …/services/rest/businessCategory/?code=POTATOES_LOOSE …/services/rest/businessCategory/?entityDescription=Potato%
The code parameter will attempt to find a single category with a matching code. The parentCode parameter will find any categories whose parent has the given code.
The entityDescription matches any category whose description (irrespective of language) matches the value given; this is just the description of the category in question and does not include those of parents.
The specificationType parameter is a tilde (~) separated list of types.
Including a value in the specificationType filter will exclude any categories for which no specification type has been selected.
The topLevelCategory parameter determines whether only top-level categories (those with no parent) will be included in the results.
Response Details
For a successful response, XML is returned with a BusinessCategoryLinkList root element containing an entries element for each matched category. The entries element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Business Category record's internal ID |
recordLink |
string |
URI to the BusinessCategoryService Retrieve record service for this category |
code |
string |
Code business key to the Business Category record |
entityDescription |
string |
Category's name |
path |
string |
Category's full path (including parent levels - separated by '/') |
Error Messages
specificationType |
<###> is not a valid Specification Type |
Specification type not found |
pageSize |
Error Code: INVALIDPAGESIZE |
Page Size must be between 1 and 100 |
offset |
Offset must be a positive integer |
code |
parentCode |
specificationType |
Error Code: INVALIDSPECIFICATIONTYPE |
Invalid SpecificationType |
topLevelCategory |
Invalid topLevelCategory value Permitted values (not case-sensitive) are: true; yes; 1; false; no; 0 |
Description
Retrieves a single Business Category record's details using the record's unique ID. Use this function to retrieve the full details of an individual category.
Endpoint address: /services/rest/businessCategory/{id} HTTP method: GET
Request Details
There are no request parameters, but the URL contains the {id} parameter that determines the record to retrieve.
Example URL
…/services/rest/businessCategory/105
Response Details
For a successful response, an HTTP 301 message is returned, which is automatically acted upon to retrieve XML consisting of a BusinessCategoryFullDTO root element containing the individual attributes of the requested Business Category record. If an ID is not specified, a list of all categories is returned (per the List of Values function).
See the associated WADL for a full list of the attributes, and the Oracle Retail Supplier Evaluation Cloud Service Data Dictionary, Volume 1 - Framework for details of their mapping to the fields within the Supplier Evaluation UI.
Error Messages
id |
HTTP 404 Not found |
Invalid {id} - not numeric |
id |
Invalid record id |
Invalid {id} - not found |
Description
Retrieves the last modification date and time of a Business Category record. Use this function to determine when a category's details were last updated.
Endpoint address: /services/rest/businessCategory/{id} HTTP method: HEAD
Request Details
Example URL
Response Details
If successful, an HTTP 200 response is sent containing the Last-Modified header showing the date and time of the last update of the requested Business Category record. For example:
HTTP/1.1 200 OK Date: Wed, 13 Jul 2016 07:52:14 GMT Last-Modified: Fri, 08 Jul 2016 06:44:46 GMT Content-Type: application/xml Content-Length: 0
Error Messages
id |
HTTP 417 Expectation Failed |
id |
Create Record
Description
Creates a new Business Category record. Use this function to create a new category in Supplier Evaluation based on data sourced from the external system.
Dependencies: If a lower-level category, the parent Business Category must be present in the application and its record ID obtained. For more information, see Dependencies.
Endpoint address: /services/rest/businessCategory HTTP method: POST
Request Details
The body of the request contains a BusinessCategoryFullDTO to specify the details of the category to create. Compared to retrieving a user (which uses the same BusinessCategoryFullDTO type), this request is much shorter. Only the attributes that are to be populated on the created Business Category record need to be included. As a minimum, this must include the fields shown in the following table:
Business Category Mandatory Fields
| Field Name | Element Name |
Code |
code |
Description |
description |
Parent Code |
parentCode |
Parent or Child level |
topLevelCategory |
Deleted Record |
deleted (Set to false) |
Path |
path (The category's full path descriptions, concatenated and separated by /) |
If creating a top level category, topLevelCategory must be set to true; if creating a lower level category, topLevelCategory must be set to false, and parentCode becomes mandatory (the parent category's code).
Example Request XML
<ns0:businessCategoryFullDTO xmlns:ns0="http://www.micros.com/creations/core/domain/dto/v1p0/full" xmlns:ns1="http://www.micros.com/creations/core/domain/dto/v1p0/simple">
<ns0:code>X1</ns0:code>
<ns0:localeData>
<ns0:description>Category X - Level 1</ns0:description>
<ns0:path>Category X - Level 1</ns0:path>
</ns0:localeData>
<ns0:topLevelCategory>true</ns0:topLevelCategory>
<ns0:deleted>false</ns0:deleted>
</ns0:businessCategoryFullDTO>
The following example adds a second level category to the above top-level parent category:
<ns0:code>X2</ns0:code>
<ns0:localeData>
<ns0:description>Category X - Level 2</ns0:description>
<ns0:path>Category X - Level 1 / Category X - Level 2</ns0:path>
</ns0:localeData>
<ns0:parentCode>X1</ns0:parentCode>
<ns0:topLevelCategory>false</ns0:topLevelCategory>
The value of the code element must be unique.
The description and path elements are locale-dependent, so are contained within a localeData element, with a locale element supported language code, for example:
<ns0:localeData>
<ns0:description>Cheese</ns0:description>
<ns0:locale>en_GB</ns0:locale>
</ns0:localeData>
<ns0:localeData>
<ns0:description>Fromage</ns0:description>
<ns0:locale>fr</ns0:locale>
</ns0:localeData>
The hierarchy of category levels is maintained through the parent code, linking a category to its immediate parent. All levels except the top level must therefore have a valid parent code specified.
The number of levels in the hierarchy is defined in the Supplier Evaluation Admin area.
Categories may be assigned to specific product specifications, or available for use by all; if specified, the specification type must be match those assigned to its parent categories.
Where the record is linked to another record, such as the Locale in this case, the business key must be provided (not the description) in order to form the link between the records. In general, the business key will be the code attribute of the linked record.
Response Details
For a successful response, an HTTP 200 response is sent with a body containing a BusinessCategoryLink root element. The root element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Newly created Business Category record's internal ID |
recordLink |
string |
URI to the newly created Business Category record, for use in a GET request |
code |
string |
Code ID business key to the newly created Business Category record |
entityDescription |
string |
Category's description |
Error Responses
If the supplied data does not result in a valid Business Category (such as a missing mandatory field), an HTTP 417 response is sent with an XML body message stating the validation errors. The request should not be reattempted with the same content.
Error Messages
code |
Code {0} has already been used |
Codes must be unique |
parent |
The Parent Code cannot be blank when the Top Level Category flag is false |
A parent code must be specified unless the category is a top level category |
topLevelCategory |
The Top Level Category flag cannot be true when the Parent Code has a value |
A category cannot be a top level category and have a parent |
description |
Description must be provided |
Descriptions are mandatory |
code |
The parent Business Category with code {0} cannot be found |
The parent category must exist |
parent |
A new Business Category cannot be added to the Business Category with the code{0} because it will fall outside of the Business Category Hierarchy |
Categories can only be added within the bounds of the Business Category Hierarchy as defined in Supplier Evaluation's Admin/System Control/Business Category Configuration |
specificationType |
{0} is not a valid Specification Type(s) |
The specification type or types must be valid |
specificationType |
The Specification Types must be a subset of the parent Business Category's Specification Types: {0} |
This message is issued when no specification types are specified on a child, but there are specification types assigned to the parent It lists the specification types selected on the parent |
specificationType |
The Business Category Specification Types {0} are not a subset of the parent Business Category Specification Types {1} |
This message is issued when the category's specification types have not all be selected on the parent The child's specification types are listed in {0} and the parent's specification types are listed in {1} |
Update Record
Description
Updates an existing Business Category record. Use this function to update a category's details in Supplier Evaluation based on data sourced from the external system, or to move a category to appear beneath a different parent category.
Endpoint address: /services/rest/businessCategory/{id} HTTP method: PUT
Request Details
The body of the request contains a BusinessCategoryUpdateDTO to specify the updates to the Business Category record.
The request content is similar to that for creating a category, but does not include the child categories link. If children are to be managed, then a separate call is required for each child. As a minimum, the values specified as mandatory for the Create Record function (see above) must be included.
After the call, the Business Category record is updated to match the request.
When updating records, all values must be included. If a value or element is omitted from the request, the field contents will be cleared on the Business Category record.
The id element is used to locate the category to update.
Categories may be moved to the same level within another part of the hierarchy. When a category is moved, its children are automatically moved.
The body of the request contains a BusinessCategoryUpdateDTO element to specify how the category should appear after the update.
Response Details
If successful, an HTTP 200 response is sent with a body containing a BusinessCategoryLink element. The BusinessCategoryLink element consists of the returned elements shown in the following table.
Returned Elements
recordId |
long |
recordLink |
string |
URI to the Business Category record, for use in a GET request |
code |
string |
Code ID business key to the Business Category record |
entityDescription |
string |
path |
string |
Error Responses
If the supplied data does not result in a valid Business Category (such as a missing mandatory field), an HTTP 417 response is sent with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
Error Messages
recordId |
Invalid record id |
The ID used to call the PUT process does not relate to an existing record |
parent |
topLevelCategory |
code |
code |
parent |
Business Category cannot be moved from a parent at level {0} to a parent at level {1} |
Categories can only be moved between parent categories at the same level in the hierarchy |
specificationType |
The specification type(s) must be valid |
specificationType |
This message is issued when no specification types are specified on a child but there are specification types assigned to the parent It lists the specification types selected on the parent |
specificationType |
Delete Record
Description
Deletes an existing Business Category record, along with any associated child categories. Use this function to remove a single category or a category and all its lower level categories.
Endpoint address: /services/rest/businessCategory/{id} HTTP method: DELETE
Request Details
There are no request parameters, but the URL contains the {id} parameter that determines the record to delete.
Response Details
If the Business Category is deleted successfully, an HTTP 200 response is sent.
Error Responses
If a Business Category cannot be deleted due to it being referenced by another record (or a child of the category being referenced by another record), an HTTP 417 response is sent with an ErrorMessage/Message XML body containing the message: "Could not delete: with a URI link to the category."
Error Messages
id |
HTTP 417 Could not delete: {URI} |
Category is referenced by another record |
id |
id |
Invalid record id for deletion |
AuditRestService
This section describes the API for managing audit and visits. The following functions are available:
List of Values (Audit): retrieves a list of audits and visits
Retrieve Record by ID (Audit): retrieves an Audit or Visit record using its unique identifier
Retrieve Record by Business Key (Audit): retrieves an Audit or Visit record using its business key
Check Record Modification Timestamp (Audit): retrieves the timestamp when an Audit or Visit record was last updated
Create Record (Audit): creates a new Audit or Visit record
Update Record (Audit): updates an existing Audit or Visit record
List of Values (Checklist): retrieves a list of checklists
Retrieve Record by ID (Checklist): retrieves a Checklist record using its unique identifier
Retrieve Record by Business Key (Checklist): retrieves a Checklist record using its business key
Create Record (Checklist): creates a new Checklist record
Update Record (Checklist): updates an existing Checklist record
Delete Record (Checklist): deletes an existing Checklist record
Description
Retrieves a list of Audits or Visits in a paged list. Use this function to locate Audit or Visit record IDs prior to a retrieve or update operation. Parameters are available to apply specific selection criteria for filtering the returned records.
Endpoint address: /services/rest/audit HTTP method: GET
Request Details
URI Parameters
| status | Optional | string | Yes | No | Scheduled~In Progress |
| softDelete | Optional | string | No | No | true |
Example URL
…/services/rest/audit/?offset=2&pageSize=20
Response Details
For a successful response, XML is returned with an AuditVisitLinkList root element containing an entries element for each matched audit or visit. The entries element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Audit/Visit record's internal ID |
recordLink |
string |
URI to the AuditRestService Retrieve record service for this audit/visit |
code |
string |
Audit/Visit's code business key |
dueDate |
string |
Audit/Visit's due date |
siteCode |
string |
Audit/Visit's site code |
supplierCode |
string |
Audit/Visit's supplier code |
templateCode |
string |
Audit/Visit's template code |
Error Messages
pageSize |
Description
Retrieves a single Audit or Visit record's details using the record's internal unique ID (which is not visible in the UI). Use this function to retrieve the full details of an individual audit or visit.
Endpoint address: /services/rest/audit/{id} HTTP method: GET
Request Details
The URL contains the {id} parameter that determines the record to retrieve.
URI Parameters
| Parameter Name | Mandatory/Optional | Value Type | Multiple Value Separator (~) Supported? | Example |
locale |
Optional |
string |
Yes |
en_GB~fr Locale country code. If used, fields that have language translations have a localeData element returned for the specified locales if data is present. |
Example URL
…/services/rest/audit/105
Response Details
For a successful response, an HTTP 301 message is returned, which is automatically acted upon to retrieve XML consisting of an AuditFullDTO root element containing the individual attributes of the requested Audit or Visit record. If an ID is not specified, a list of all audits/visits is returned (per the List of Values function).
File Structure:
The main elements of the auditFullDTO root element:
auditTemplateSnapshot and Template - the settings from the associated template.
nonConformances - If the audit/visit has any non conformances/issues raised against it, they appear within a nonConformances element - a separate element for each.
supplier and site - details of the supplier and site that the audit/visit is related to.
udfData - the contents of any user-defined custom fields associated to the Audit/Visit record. nonConformances may also contain udfData elements, if the Non Conformance record has user-defined custom fields configured.
See the associated WADL for a full list of the attributes, and the Oracle Retail Supplier Evaluation Cloud Service Data Dictionary, Volume 2 - Supplier for details of their mapping to the fields within the Supplier Evaluation UI.
Error Messages
id |
HTTP 404 Not Found |
id |
HTTP 417 IllegalStateException: Cannot find the Audit to return with id:<###> |
Description
Retrieves a single Audit or Visit record's details using its business key (code). Use this function to retrieve the full details of an individual audit or visit using its key code.
Endpoint address: /services/rest/audit/byKey/{code} HTTP method: GET
Request Details
There are no request parameters, but the URL contains the {code} parameter that determines the record to retrieve.
Example URL
…/services/rest/audit/byKey/110
Response Details
If successful, an HTTP 301 redirect response is sent containing a header Location with the URI of the document requested.
The returned URI represents the call to be made to the Retrieve Record by ID function (with the id substituted with the relevant value), which will return an AuditFullDTO Element Message containing the individual attributes of the requested Audit or Visit record.
If your method of calling the API is configured to automatically follow HTTP 301 redirects, the call may automatically return a AuditFullDTO root element containing the individual attributes of the requested Audit or Visit record.
File Structure:
Error Messages
code |
Invalid {code} - blank or not found |
code |
Invalid {code} - not found |
Description
Retrieves the last modification date and time of an Audit or Visit record. Use this function to determine when the audit or visit was last updated.
Endpoint address: /services/rest/audit/{id} HTTP method: HEAD
Request Details
Example URL
Response
If successful, an HTTP 200 response is sent containing the Last-Modified header to show the last modification date and time of the last update of the requested Audit or Visit record.
Error Messages
id |
id |
Description
Creates a new Audit or Visit record. Use this function to create a new audit or visit in Supplier Evaluation based on data sourced from the external system.
Dependencies: The Supplier and Site must be present in the application and its record ID obtained. If assigning a Business Category, the ID of the Business Category record must be present in the application and its record ID obtained. If assigning a Technologist or People Present, the users must be present in the application and the record IDs of the User record obtained. If non conformances/issues are to be included, and they are associated to a specific user of the application, the record IDs of the User record must be obtained. An audit/visit must be associated to an audit/visit template. For more information, see Dependencies.
Endpoint address: /services/rest/audit HTTP method: POST
Request Details
The body of the request contains an AuditFullDTO element to specify the detail of the audit or visit to create, which is based on the AuditFullDTO element returned when retrieving an audit/visit. As a minimum, the fields shown in the following table must be populated.
Audit/Visit Mandatory Fields
Audit/Visit Template |
template / id (or code) auditTemplateSnapshot |
Audit/Visit Code |
code |
Lead Technologist |
leadTechnicalManager / code |
Supplier |
supplier / id |
Site |
site / id |
Due Date |
dueDate |
Record Type |
recordType |
Status |
status / id |
From Date |
fromDate |
To Date |
toDate |
People Present |
peoplePresent / name |
Deleted Record |
If the status is Scheduled, fromDate, toDate, and peoplePresent are not mandatory.
To ensure a valid unique business key code is automatically assigned to the record being created, a value of zero must be passed in the <code> element of the XML when submitting the POST request.
People Present Table:
This table is used to identify the people present during the audit or visit. The options for completing the table depend on the settings in the audit/visit's template:
The table must contain at least one entry (whether an audit or a visit).
If a visit or an internal audit, the entry should be a user of the system who has a Technologist role and is set as an approved auditor. The template may have been set to just allow specific auditors.
If a third-party audit, the entry should be a Certification Body. The template may have been set to just allow specific auditors.
Rows of free text may be added to the table.
File Structure:
The main elements of the AuditFullDTO root element are shown in the following table:
Summary of AuditFullDTO Elements
| Element Name | Description |
announced costChargedToSupplier auditTemplateSnapshot |
Values from the audit/visit template, required to control the record's behavior when it is progressed within Supplier Evaluation. |
code |
The audit/visit's business key. |
dueDate fromDate toDate leadTechnical Manager recordType |
Values that may be mandatory for the audit/visit to be created. |
nonConformances |
Container for the non conformance data - a separate element for each non conformance/issue. |
supplier |
ID of the supplier that the audit/visit is associated to. |
site |
ID of the site that the audit/visit is associated to. |
status |
The audit/visit's status. |
template |
ID of the audit/visit template that the audit/visit is associated to. |
Example Request XML
This example shows the minimum requirement to be able to create an In Progress audit or visit.
<ns0:auditFullDTO xmlns:ns0="http://www.micros.com/creations/core/domain/dto/v1p0/full" xmlns:ns1="http://www.micros.com/creations/core/domain/dto/v1p0/simple">
<ns0:announced>true</ns0:announced>
<ns0:costChargedToSupplier>false</ns0:costChargedToSupplier>
<ns0:auditTemplateSnapshot>
<ns0:allowWorkingOffline>false</ns0:allowWorkingOffline>
<ns0:allowableScoreOptions>
<ns1:code>AMBER</ns1:code>
</ns0:allowableScoreOptions>
<ns1:code>GREEN</ns1:code>
<ns0:auditType>INTERNAL</ns0:auditType>
<ns0:auditVisibility>OPTIONAL</ns0:auditVisibility>
<ns0:autoSchedule>false</ns0:autoSchedule>
<ns0:buyerInformationRequired>true</ns0:buyerInformationRequired>
<ns0:categoriesRequired>2</ns0:categoriesRequired>
<ns0:categoryRequired>false</ns0:categoryRequired>
<ns0:certificationBodiesSelectable>ALL</ns0:certificationBodiesSelectable>
<ns0:closureDeadline>56</ns0:closureDeadline>
<ns0:closureDeadlineNoOfDays>0</ns0:closureDeadlineNoOfDays>
<ns0:commentsNotVisibleToOrganisationRequired>true
</ns0:commentsNotVisibleToOrganisationRequired>
<ns0:defaultFrequency>12</ns0:defaultFrequency>
<ns0:defaultIssueCompletion>28</ns0:defaultIssueCompletion>
<ns0:extendedDeadline>56</ns0:extendedDeadline>
<ns0:extendedDeadlineNoOfDays>0</ns0:extendedDeadlineNoOfDays>
<ns0:internalAuditorsSelectable>ALL</ns0:internalAuditorsSelectable>
<ns0:isActive>true</ns0:isActive>
<ns0:localeData>
<ns0:name>Checklist Audit</ns0:name>
<ns0:id>49</ns0:id>
</ns0:localeData>
<ns0:mayExternalManagersEditConfig>MAY_NOT_EDIT
</ns0:mayExternalManagersEditConfig>
<ns0:nonConformanceCreationMethod>VIA_CHECKLISTS
</ns0:nonConformanceCreationMethod>
<ns0:organisationType>SITE</ns0:organisationType>
<ns0:recordType>AUDIT</ns0:recordType>
<ns0:scoreAudit>true</ns0:scoreAudit>
<ns0:scoreRequired>true</ns0:scoreRequired>
<ns0:stampOrgWithLastAuditDate>true</ns0:stampOrgWithLastAuditDate>
<ns0:supplierGenerated>false</ns0:supplierGenerated>
<ns0:useAuditVisitStandards>false</ns0:useAuditVisitStandards>
<ns0:id>6</ns0:id>
</ns0:auditTemplateSnapshot>
<ns0:dueDate>2017-04-27</ns0:dueDate>
<ns0:fromDate>2017-04-27</ns0:fromDate>
<ns1:code>PROD-TECH</ns1:code>
<ns1:disabled>false</ns1:disabled>
<ns1:externalAuthenticationUser>false</ns1:externalAuthenticationUser>
<ns1:timeZone>Europe/London</ns1:timeZone>
<ns1:userType>RETAILER</ns1:userType>
<ns1:id>12</ns1:id>
<ns0:nonConformances>
<ns0:description><p>Test</p></ns0:description>
<ns0:reference>AR01</ns0:reference>
<ns0:status>
<ns1:status>OPEN</ns1:status>
</ns0:status>
<ns0:type>
<ns1:code>MAJOR</ns1:code>
</ns0:type>
<ns0:code>AR01-11</ns0:code>
</ns0:nonConformances>
<ns0:site>
<ns1:id>27</ns1:id>
</ns0:site>
<ns0:status>
<ns1:status>IN PROGRESS</ns1:status>
</ns0:status>
<ns0:supplier>
<ns1:id>21</ns1:id>
</ns0:supplier>
<ns0:template>
<ns1:id>8</ns1:id>
</ns0:template>
<ns0:toDate>2017-04-27</ns0:toDate>
<ns0:code>AR1</ns0:code>
</ns0:auditFullDTO>
Set the deleted attribute to false to ensure the record can be seen in the UI. If omitted or set to true, it will exist, but will not be visible.
Where the record is linked to another record, such as the Template, the business key or ID must be provided (not the description) in order to form the link between the records. In general, the business key will be the code attribute of the linked record. The supplier and site elements can contain just the ID of the respective record links.
A unique code for the audit/visit must be assigned.
Templates:
The audit/visit is linked to its template using the template and auditTemplateSnapshot elements. The template element can contain just the code or ID of the associated Template record.
The auditTemplateSnapshot element must be completed to provide the parameters that control the audit/visits' behavior as it progresses through its Supplier Evaluation workflow. If scoring is used, the allowable options can be specified using the code or ID of the glossary record; if none are specified, all options will be available when the user selects the score.
Non Conformances:
If the audit/visit is to be created with non conformances/issues already raised against it, they can be added within a nonConformances element - a separate element for each. A unique code must be assigned to each. The status can be set using its code or ID.
For further information about the process for creating audit, non conformances and checklists, see Dependencies.
Response Details
If successful, an HTTP 200 response is sent with a body containing a AuditVisitLink root element. The root element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Newly created Audit/Visit record's internal ID |
recordLink |
string |
URI to the newly created Audit/Visit record, for use in a GET request |
code |
string |
dueDate |
string |
siteCode |
string |
supplierCode |
string |
templateCode |
string |
Error Responses
If the supplied data does not result in a valid Audit or Visit (such as a missing mandatory field), an HTTP 417 response is sent with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
Error Messages
peoplePresent |
WARNING: class com.micros.creations.core.domain.Audit.peoplePresent - There must be at least one entry in the People Present table |
People Present not provided |
recordType |
IllegalArgumentException: No enum constant com.micros.creations.core.type.AuditRecordType. <###> |
Record Type not found |
supplier/id code site/id code supplierId supplierCode |
HTTP 417 IllegalStateException: Cannot locate keyword for class com.micros.creations.core.domain.Site using id: <###>, code:<###>, supplierCode:<###> and supplierId:<###> |
Site Id not found Site Code not found Supplier Id not found Supplier Code not found |
template |
EntityNotFoundException: Unable to find com.micros.creations.core.domain.AuditTemplate with id <###> |
Template not found |
fromDate |
ERROR: class com.micros.creations.core.domain.Audit.fromDate - The condition is invalid |
From Date not provided |
code |
ERROR: class com.micros.creations.core.domain.Audit.code - The condition is invalid |
Audit/Visit code not provided |
code |
ERROR: class com.micros.creations.core.domain.Audit.code - Another object exists with this value |
Audit/Visit code already exists |
Description
Updates an existing Audit or Visit record. Use this function to update an audit or visit's details in Supplier Evaluation based on data sourced from the external system.
Endpoint address: /services/rest/audit/{id} HTTP method: PUT
Request Details
The body of the request contains an AuditFullDTO element to specify the updates to the Audit or Visit record, which is based on the AuditFullDTO type returned when retrieving an audit/visit.
The request content is similar to that for creating an audit or visit.
As a minimum, the values specified as mandatory for the Create Record function (see above) must be included. However, when updating records, all values must be included.
If a value or element is omitted from the request, the field contents will be cleared on the Audit/Visit record.
If the audit/visit has any non conformances/issues raised against it, they appear within a nonConformances element - a separate element for each. The non conformances/issues can be updated or created when updating the audit/visit. If creating a new Non Conformance record, assign a unique code and omit the id element.
Response Details
If successful, an HTTP 200 response is sent with a body containing an AuditVisitLink element. The AuditVisitLink element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
recordLink |
string |
URI to the Audit/Visit record, for use in a GET request |
code |
string |
dueDate |
string |
siteCode |
string |
supplierCode |
string |
templateCode |
string |
Error Responses
Description
Retrieves a list of Checklists in a paged list. Use this function to locate Checklist record IDs prior to a retrieve or update operation. Parameters are available to apply specific selection criteria for filtering the returned records.
Endpoint address: /services/rest/audit/{auditId}/checklist HTTP method: GET
Request Details
URI Parameters
| Parameter Name | Mandatory/ Optional | Value Type | Multiple Value Separator (~) Supported? | Wildcard Search Supported? | Example |
| auditId | Optional | long | No | No | 105 |
| offset | Optional | int | No | No | 60 |
| pageSize | Optional | int | No | No | 30 |
Example URL
…/services/rest/audit/105/checklist/?offset=2&pageSize=20
Response Details
For a successful response, XML is returned with an AuditChecklistLinkList root element containing an entries element for each matched audit or visit. The entries element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Checklist record's internal ID |
recordLink |
string |
URI to the AuditRestService Retrieve record service for this checklist |
parentId |
string |
The parent Audit/Visit's internal ID |
auditCode |
string |
The parent Audit/Visit's code business key |
globalId |
string |
Checklist's code business key |
Error Messages
Description
Retrieves a single Checklist record's details using the record's internal unique ID (which is not visible in the UI) and its parent audit/visit's internal unique Id. Use this function to retrieve the full details of an individual audit or visit.
Endpoint address: /services/rest/audit/{auditId}/checklist/{id} HTTP method: GET
Request Details
The URL contains the {auditId} parameter that identifies the parent Audit/Visit record, and the {id} parameter that determines the record to retrieve.
URI Parameters
locale |
Optional |
string |
Yes |
Example URL
…/services/rest/audit/105/checklist/7
Response Details
For a successful response, an HTTP 301 message is returned, which is automatically acted upon to retrieve XML consisting of an auditChecklistFullDTO root element containing the individual attributes of the requested Checklist record. If a Checklist ID is not specified, a list of all the audit/visit's checklists is returned (as per the List of Values function).
Error Messages
auditId |
Invalid {auditId} - not numeric |
auditId |
Invalid {auditId} - not found |
id |
id |
Description
Retrieves a single Checklist record's details using its business key (code) and its parent audit/visit's code. Use this function to retrieve the full details of an individual checklist using its key code.
Endpoint address: /services/rest/audit/byKey/{auditCode}/checklist/{checklistCode} HTTP method: GET
Request Details
There are no request parameters, but the URL contains the {auditCode} parameter that identifies the parent Audit/Visit record, and the {checklistCode} parameter that determines the record to retrieve.
Example URL
…/services/rest/audit/byKey/110/checklist/7374be1e-2a6c-11e7-8fda-0021f60dd918
Response Details
The returned URI represents the call to be made to the Retrieve Record by ID function (with the id substituted with the relevant value), which will return an auditChecklistFullDTO root element containing the individual attributes of the requested Checklist record.
If your method of calling the API is configured to automatically follow HTTP 301 redirects, the call may automatically return a auditChecklistFullDTO root element containing the individual attributes of the requested Checklist record.
Error Messages
auditCode |
Invalid {auditCode} - blank or not found |
checklistCode |
Invalid {checklistCode} - blank or not found |
Description
Creates a new Checklist record. Use this function to create a new checklist in Supplier Evaluation based on data sourced from the external system.
Dependencies: To create an audit with a checklist, the parent Audit record must be created using the Create Record (Audit/Visit) function, before creating the associated Checklist records.
Therefore, when creating the checklist, the parent Audit/Visit record must be present in the application and its record ID obtained. A checklist's questions and the permitted answers are determined by the checklist template that has been assigned to the audit/visit's template. The IDs of the Checklist Template record must also be provided when creating a template. For more information, see Dependencies.
Endpoint address: /services/rest/audit{auditId}/checklist HTTP method: POST
Request Details
The body of the request contains an auditChecklistFullDTO element to specify the detail of the checklist to create, which is based on the auditChecklistFullDTO element returned when retrieving a checklist. As a minimum, the fields shown in the following table must be populated.
Checklist Mandatory Fields
Audit/Visit Id |
audit / id See note 1. |
Audit/Visit Code |
audit /code See note 1. |
Checklist Template |
localeData / id |
Checklist Comments Allowed |
commentsAllowed |
Questionnaire Questions |
questionnaire / questionnaireQuestion / questionDetails |
Question Answers |
questionnaire / questionnaireQuestion / questionnaireAnswer questionnaire / questionnaireQuestion / quesAvailAnsFull |
Deleted Record |
Notes:
Either code or ID may be specified to identify the audit/visit.
File Structure:
The following diagram shows the structure of the auditChecklistFullDTO request file structure:
Figure 4-3 RESTful Checklist Request
Summary of AuditChecklistFullDTO Elements
audit |
Identifies the parent audit record by code or id. |
commentsAllowed |
A value from the checklist template, required to control the record's behavior when it is progressed within Supplier Evaluation. |
localeName |
Identifies the checklist template by name and id. |
questionnaire |
Groups the questions and their answers. |
questionnaireQuestion |
Groups the checklist questions and their answers - repeated for each question in the checklist. reference is the question reference. |
questionDetails |
Individual questions. question is the question text. answerComment is the answer's comments (if configured). answerFieldType is code of answer type (MULTI_SELECTION, TEXT, or SINGLE_SELECTION). commentAllowed is whether comments are allowed. |
questionnaireAnswer |
Groups the answer details. |
questionnaireAvailableAnswer |
Answers for the individual questions. code is the question's unique key. commentMandatory is whether comments are mandatory or not. generateNonConformance is whether an answer will generate an issue. |
quesAvailAnsFull |
The available answers - repeated for each answer. code is the question's unique key. commentMandatory is whether comments are mandatory or not. id and keywordTypeEnum are the keys to the Issues glossary. |
Process for Creating Checklist Audits
The general process for creating checklist audits:
Create the Audit/Visit. While it is possible to create a checklist audit using the Create Audit function, it is recommended that they be created within the Supplier Evaluation application.
A method of creating a new audit:
Retrieve an existing audit using a GET function.
Omit the id and statusChangeHistory elements from the retrieved file.
Omit localData elements from status and allowableAuditStandards.
Assign a new unique code.
Link to the Supplier, Site, and Audit Template records using the relevant IDs.
Change other content to reflect the new audit.
Submit using the POST function.
If non conformances are to be created at the time of creating the audit/visit, include them as nonConformances elements.
The API does not automatically create a non conformance based on the answer of a checklist question. Non conformances must be assigned when either creating or updating the Audit/Visit record.
Retrieve the code or ID of the newly created Audit, and its template detail using a GET function.
Create the checklist using the POST function (repeat for each checklist):
Identify the parent audit/visit by setting the code or id within audit element.
Can retrieve an existing checklist using a GET function, in which case the id and questionnaireQuestionAvailableAnswer elements must be omitted. Also omit any id elements within the questionnaire element, except those that relate to the auditNonConformance element.
Example Request XML
This example shows the minimum requirement to be able to create an audit checklist. This example contains three questions, each with the available answers of Yes, No, or Not Applicable.
Figure 4-4 Checklist Questions
<ns0:auditChecklistFullDTO xmlns:ns1="http://www.micros.com/creations/core/domain/dto/v1p0/simple" xmlns:ns0="http://www.micros.com/creations/core/domain/dto/v1p0/full">
<ns0:audit>
<ns1:code>AUD09</ns1:code>
<ns1:id>132</ns1:id>
</ns0:audit>
<ns0:commentsAllowed>false</ns0:commentsAllowed>
<ns0:localeData>
<ns0:name>
<![CDATA[ API Test Template ]]>
</ns0:name>
<ns0:id>563</ns0:id>
</ns0:localeData>
<ns0:questionnaire>
<ns0:questionnaireQuestion>
<ns0:localeData>
<ns0:reference>
<![CDATA[Ref1]]>
</ns0:reference>
</ns0:localeData>
<ns0:questionDetails>
<ns0:answerComment>
<![CDATA[Yes comment]]>
</ns0:answerComment>
<ns0:answerFieldType>SINGLE_SELECTION</ns0:answerFieldType>
<ns0:commentAllowed>true</ns0:commentAllowed>
<ns0:localeData>
<ns0:question>
<![CDATA[Question 1]]>
</ns0:question>
</ns0:localeData>
</ns0:questionDetails>
<ns0:questionnaireAnswer>
<ns0:questionnaireAvailableAnswer>
<ns1:code>QQAA7236</ns1:code>
<ns1:commentMandatory>false</ns1:commentMandatory>
<ns1:generateNonConformance>false
</ns1:generateNonConformance>
<ns1:localeData>
<ns0:answer>Yes</ns0:answer>
</ns1:localeData>
</ns0:questionnaireAvailableAnswer>
<ns1:localeData>
<ns0:reference>
<![CDATA[Ref1]]>
</ns0:reference>
</ns1:localeData>
</ns0:questionnaireQuestion>
</ns0:questionnaireAnswer>
<ns0:quesAvailAnsFull>
<ns0:code>QQAA7236</ns0:code>
<ns0:commentMandatory>false</ns0:commentMandatory>
<ns0:generateNonConformance>false</ns0:generateNonConformance>
<ns0:localeData>
</ns0:localeData>
</ns0:quesAvailAnsFull>
<ns0:code>QQAA7237</ns0:code>
<ns0:commentMandatory>true</ns0:commentMandatory>
<ns0:generateNonConformance>true</ns0:generateNonConformance>
<ns0:localeData>
<ns0:answer>No</ns0:answer>
</ns0:localeData>
<ns0:code>QQAA7238</ns0:code>
<ns0:localeData>
<ns0:answer>Not Applicable</ns0:answer>
</ns0:localeData>
<ns0:localeData>
<ns0:reference>
<![CDATA[Ref2]]>
</ns0:reference>
</ns0:localeData>
<ns0:answerComment>
<![CDATA[No comment]]>
<ns0:localeData>
<ns0:question>
<![CDATA[Question 2]]>
</ns0:question>
</ns0:localeData>
<ns1:code>QQAA7240</ns1:code>
<ns1:commentMandatory>true</ns1:commentMandatory>
<ns1:generateNonConformance>true</ns1:generateNonConformance>
<ns1:localeData>
</ns1:localeData>
<ns1:localeData>
<ns0:reference>
<![CDATA[Ref2]]>
</ns0:reference>
</ns1:localeData>
<ns0:code>QQAA7239</ns0:code>
<ns0:localeData>
</ns0:localeData>
<ns0:code>QQAA7240</ns0:code>
<ns0:localeData>
</ns0:localeData>
<ns0:code>QQAA7241</ns0:code>
<ns0:localeData>
</ns0:localeData>
<ns0:localeData>
<ns0:reference>
<![CDATA[Ref3]]>
</ns0:reference>
</ns0:localeData>
<ns0:answerComment>
<![CDATA[N/A comment]]>
<ns0:localeData>
<ns0:question>
<![CDATA[Question 3]]>
</ns0:question>
</ns0:localeData>
<ns1:code>QQAA7244</ns1:code>
<ns1:generateNonConformance>false</ns1:generateNonConformance>
<ns1:localeData>
</ns1:localeData>
<ns1:localeData>
<ns0:reference>
<![CDATA[Ref3]]>
</ns0:reference>
</ns1:localeData>
<ns0:code>QQAA7242</ns0:code>
<ns0:localeData>
</ns0:localeData>
<ns0:code>QQAA7243</ns0:code>
<ns0:localeData>
</ns0:localeData>
<ns0:code>QQAA7244</ns0:code>
<ns0:localeData>
</ns0:localeData>
</ns0:questionnaire>
<ns0:globalId>7470e250-36cc-4dea-a0f1-eb6040185865</ns0:globalId>
</ns0:auditChecklistFullDTO>
For further information about the process for creating audit, non conformances, and checklists, see Dependencies.
Response Details
If successful, an HTTP 200 response is sent with a body containing an AuditChecklistLink root element. The root element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
recordLink |
string |
URI to the newly created Checklist record, for use in a GET request |
parentId |
long |
auditCode |
string |
globalId |
string |
Error Responses
If the supplied data does not result in a valid Checklist (such as a missing mandatory field), an HTTP 417 response is sent with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
Error Messages
audit / id audit / code |
HTTP 417 IllegalStateException: The checklists audit cannot be located |
Audit/Visit id/code not found |
id |
HTTP 417 IllegalStateException: Cannot find matching relation to update on <###> looking for <###> |
Invalid link to related record |
Description
Updates an existing Checklist record. Use this function to update a checklist's details in Supplier Evaluation based on data sourced from the external system.
Endpoint address: /services/rest/audit/{auditId}/checklist/{id} HTTP method: PUT
Request Details
The body of the request contains an auditChecklistFullDTO element to specify the updates to the Audit or Visit record, which is based on the auditChecklistFullDTO type which is returned when retrieving an audit/visit.
The request content is similar to that for creating a checklist.
If a value or element is omitted from the request, the field contents will be cleared on the Checklist record.
The link to the parent Audit/Visit record is defined by the code or ID within the audit element.
Response Details
If successful, an HTTP 200 response is sent with a body containing an auditChecklistLink element. The auditChecklistLink element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
recordLink |
string |
URI to the Checklist record, for use in a GET request |
parentId |
long |
auditCode |
string |
globalId |
string |
Error Messages
Deletes an existing Checklist record. Use this function to delete a checklist that has been created in error from the external system
Endpoint address: /services/rest/audit/{auditId}/checklist/{id} HTTP method: DELETE
Request Details
There are no request parameters, but the URL contains the {auditId} parameter that identifies the parent Audit/Visit record, and the {id} parameter that determines the record to delete.
It is not possible to manually delete checklists from an audit/visit within the application; this delete function has been provided solely for the deletion of checklists that have been created in error by the API.
To delete a checklist, the external system must be granted access to the AUDIT_CHECKLIST_DELETE endpoint.
Example URL
Response Details
Error Messages
auditId |
auditId |
id |
id |
HTTP 417 IllegalStateException: Cannot find the Audit Checklist to return with id:<###> |
DataPrivacyService
This section describes the API for executing Data Privacy requests. The following functions are available:
Right to Access: retrieves personal data from the system relating to the name of an individual
Right to be Forgotten: erases personal data from the system for an individual
Although minimal personal data is held in Supplier Evaluation, it does include the names and contact details of retailer/portal owner, supplier, and third-party users. The Data Privacy API provides a means for the retailer/portal owner to:
Request details of personal data relating to an individual be held within the system.
Request that the personal data relating to the individual be removed from the system.
For additional detail on using the Data Privacy API, including examples, see Appendix: Using the Data Privacy API.
The Supplier Evaluation and Supply Chain Hub modules have separate APIs for managing data privacy requests, such as GDPR right to access and right to be forgotten requests. For more details, see the Oracle Retail Supply Chain Collaboration Cloud Service Integration User Guide.
Right to Access
Description
Retrieves a set of personal data that relates to the name of an individual. Use this function to perform Right to Access requests for the following scenarios:
An employee of the retailer/portal owner requests an electronic copy of their personal data that is held within the system.
An employee of one of the retailer/portal owner's suppliers requests an electronic copy of their personal data that is held within the system.
An employee of the retailer/portal owner's partner organizations requests an electronic copy of their personal data that is held within the system.
The API's access function allows the name of the individual to be passed, with an XML message being returned containing any personal data found for that name. The XML message is a structured text format, which is both machine and human readable.
Figure 4-5 Right to Access Process
The steps for completing a Right to Access request are as follows (for further details, see Appendix: Using the Data Privacy API):
Submit a POST call, passing the name of the individual.
A batch job is submitted within Supplier Evaluation to search the system for personal data for the presence of the name (for which records and fields are searched, see Appendix: Using the Data Privacy API). On completion, a Data Privacy record containing the retrieved personal data is created within Supplier Evaluation.
A link to the Data Privacy record is returned as the response to the POST call.
On receipt of the response to the POST call, submit a GET call, passing the returned URI link.
If the GET call is submitted before the batch job has finished compiling the personal data, just a header will be returned, and the GET call should be retried.
A message containing the personal data is returned. The XML data is structured within a dataprivRequestDTO root element (for details of the message structure, see Appendix: Using the Data Privacy API).
Just the personal data fields and values to identify the record are returned, not the full record contents.
Addresses may contain multiple localeData elements for the language translation of countries.
XML elements will only be present if they contain data.
Assess whether the returned data relates to the individual who made the request, editing and/or reformatting it if necessary, before passing it to the requestor.
Endpoint address: /services/rest/datapriv/access HTTP methods: POST, GET
Request Details
For the POST method, a name parameter is passed in the payload.
For the GET method, an id parameter is passed as a URI parameter.
URI Parameters
Example URL (POST method): …/services/rest/access/
Example URL (GET method): …/services/rest/access/?id=16
Response Details
For a successful response to the POST method, a link to the Data Privacy record is returned.
For a successful response to the GET method, XML is returned with a dataprivRequestDTO root element containing an element for each record where the personal data has been found.
Error Responses
Description
Erases a set of personal data that relates to an individual. Use this function to perform Right to be Forgotten requests for the following scenarios:
An employee of the retailer/portal owner requests their personal data be erased from the system.
An employee of one of the retailer/portal owner's suppliers requests their personal data be erased from the system.
An employee of a partner organizations requests their personal data be erased from the system.
The retailer/portal owner initiates the purging of an inactive user's personal data from the system.
An erase function allows the XML message returned from a Right to Access request to be used to erase the data.
Figure 4-6 Right to be Forgotten Process
The steps for completing a Right to be Forgotten request are as follows:
The Right to Access service must be used to retrieve the personal data for the individual. For details, see Right to Access
View, and if necessary, edit the XML returned from the Right to Access request.
As there may be any number of users with the same name, it is necessary to decide which data represents the individual who made the request, removing any that is not relevant (for further information on editing the XML message, see Appendix: Using the Data Privacy API).
Optionally submit a POST call to the verify function, passing the login id of the individual (obtained from the XML message returned in Step 2).
This step is used to check whether the erasure of data for the individual will be permitted, before actually submitting the request. The erase will not be permitted if the individual is responsible for the completion of a supplier site's Assessment.
XML is returned with a dataprivVerifyDTO root element containing a status and a message element. If the call is successful the message will contain Success, otherwise it will contain Failure and the reason for the failure will be present in the message element.
Submit a POST call to the erase function, passing the XML retrieved from the Right to Access request (with any edits having been applied).
A batch job is submitted to validate the request, verify that the erasure is permitted (that is, the individual is not responsible for the completion of an Assessment), and obtain locks on the records to be updated.
If the validation fails, or a lock cannot be obtained, the process is terminated and an XML is returned with a dataprivErasureDTO root element containing a message element that contains the reason for the failure, and the status element set to Failure.
If no exceptions are encountered, a Data Privacy record containing the personal data to erase is created and a link to the record is returned as the response to the POST call.
On receipt of the response to the POST call, submit a GET call to the erase function, using the returned URI link.
The update processing replaces the data passed in the XML message with 30 characters of randomly-generated text. Email addresses are changed to x@example.com, where x is 15 characters of randomly-generated text*. GPS coordinate numbers and country selections are blanked.
Some fields have a specific length, in which case the 30 characters of obfuscated text is overridden:
Name 50 characters
Login 20 characters
Address lines 20 characters
Post Code 5 characters
* Email addresses that are stored as free text are fully obfuscated, rather than set to x@example.com.
Only certain fields are permitted to be erased (for details, see Appendix: Using the Data Privacy API).
When updating a user account, the account is set to deactivated, and the password is set to expired.
The erasure of data is not reversible.
Optionally submit another Right to Access request to check that the data has been erased as expected.
Inform the requestor of the outcome of their request.
The Right to be Forgotten facility may also be used for purging user accounts that are no longer active.
Endpoint address: /services/rest/datapriv/erase HTTP methods: POST (verify and erase), GET (erase)
Request Details
For the verify POST method, a loginId parameter is passed in the payload.
For the erase POST method, an XML message is passed in the payload.
For the erase GET method, an id parameter is passed as a URI parameter.
URI Parameters
Example URL (verify POST method): …/services/rest/verify/
Example URL (erase POST method): …/services/rest/erase/
Example URL (erase GET method): …/services/rest/erase/?id=32
Response Details
For a successful response to the verify POST method, XML is returned with a dataprivVerifyDTO root element containing a status of Success.
For a successful response to the erase POST method, a link to the Data Privacy record is returned.
For a successful response to the erase GET method, an HTTP 200 response is sent with a dataprivErasureDTO root element containing a status of Success.
Error Responses
For a failure response to the verify method, XML is returned with a dataprivVerifyDTO root element containing a status of Failure, with the reason in the message element.
For a failure response to the erase method, XML is returned with a dataprivErasureDTO root element containing a status of Failure, with the reason in the message element.
Error Messages
| Element | Message | Meaning |
user |
Only one User can be erased at a time |
More than one User was passed in to the erase function. The XML must only relate to a single user. |
person |
Only one Person can be erased at a time |
More than one Person was passed in to the erase function. The XML must only relate to a single person. |
id |
The User is linked to Person with ID: %id but the Person included has ID: %id |
The wrong Person has been included. %id is the id taken from the XML. |
id |
The Contacts are linked to Person with ID: %id but the Person included has ID: %id |
id |
The Contact with ID %id is linked to a different User than the one being erased |
The Contacts passed do not match the user being erased. %id is replaced with the id from the XML. |
person |
All Contacts being erased must be linked to the same Person |
Where no User is being erased, all Contacts being erased must be for the same person. |
person |
Please include Person with ID: %id |
If User or Contacts are passed, the matching Person must also be included. |
id |
Cannot find entity of type: %rec and ID: %id |
An id is passed that is not found. %rec is the internal name of the record, such as ProductRecord. %id is the id taken from the XML. |
id |
Entity of type: %rec and ID: %id is currently locked, please try again later |
One of the records to be erased is currently locked. %rec is the internal name of the record, such as ProductRecord. %id is the id taken from the XML. Retry the request until the record becomes available. |
id |
Entity of type: %rec with id: %id has been edited during the erase process, please verify data |
One of the records updated has been edited between up front validation and the processing of that particular record. %rec is the internal name of the record, such as ProductRecord. %id is the id taken from the XML. |
user |
The user cannot be erased because they are responsible for the approval of an Assessment |
The user is named as being responsible for completing an assessment, so they cannot be erased. |
login id |
Cannot find User with login ID: %id |
No User account found for the passed login id. %id is the login id. |
The erase has failed due to unexpected internal error |
Other unexpected condition has occurred. |
AttachmentRestService
This section describes the API for retrieving the file attachments from certain records. The following function is available:
Retrieve Report Attachment: retrieves attachment files that have been generated by the system as report outputs
Retrieve Attachment: retrieves files that have been attached to records
Record types that have an attachments element contain a globalId element for each of the record's file attachments. The Retrieve Attachment service can be used to retrieve the actual attachment files by passing globalId as a parameter.
The record types that are capable of returning attachments data are:
Users
Suppliers
Sites
Audits
Audit Issues (Non Conformances)
Scorecards
Projects
Activities
The following attributes are included in the attachment element of the XML:
ID
Record Link (global Id for the attachment file)
File Name/URL
Description
Bytes
Attached by ID
Attached On
The Attachments API is GET (retrieve) only, there is no PUT/POST (update/create) capability.
Retrieving a file returns a fileName element containing the file name, plus the encoded attachment. Retrieving a URL returns a uri element containing the URL.
The following describes the steps for retrieving file attachments:
Figure 4-7 Steps for Retrieving Attachments
Call the List of Values service for the record with appropriate filters to locate the records for which attachments are to be retrieved. Record ids are returned for any records that match search criteria.
Call the Retrieve Record by ID service for each record id returned from the List of Values call. The record's full DTO element is returned, containing the record's data, including an attachments element which has a globalId element for each of the record's file attachments.
Call the Retrieve Attachment service passing the globalId as a parameter. The attachment file's data is returned as a Base 64 text string. Use a suitable decoder to generate the actual attachment file.
Description
Retrieves an attachment file that has been generated as the output of a report. The file types will be PDF, Excel, RTF, or HTML. When a report is generated, the outputs are stored in the Report Outputs area, grouped within a hierarchical folder structure.
The API provides a means of automatically locating reports for further analysis of the data within an external system. The ID of the attachment to be retrieved is sent to the external system's designated email address.
For additional detail on using the Report Attachment API, see Appendix: Using the Report Attachment API.
Endpoint address: /services/rest/attachment/report/{globalId} HTTP method: GET
Request Details
There are no request parameters, but the URL contains the {globalId} parameter that determines the record to retrieve.
Example URL
…/services/rest/attachment/report/f25eebdd-e7c5-4bb2-b61c-f35171438386
Response Details
For a successful response, XML is returned with a data element which contains the actual attachment as a Base64 encoded text string. The string must then be processed by a Base64 decoder to convert it to the actual report file.
Error Messages
globalId |
Invalid {globalId} - not numeric |
globalId |
HTTP 417 IllegalStateException: Cannot find the Attachment to return with id:<###> |
Invalid {globalId} - not found |
Retrieve Attachment
Description
Retrieves a file that has been attached to a record. The files types will typically be documents or images.
Endpoint address: /services/rest/attachment/attachment/{globalId} HTTP method: GET
Request Details
Example URL
…/services/rest/attachment/attachment/RTxy92Ha4lsQE6Bjc-18t1wJ7smbYoCH
Response Details
For a successful response, XML is returned with a data element which contains the actual attachment as a Base64 encoded text string. The string must then be processed by a Base64 decoder to convert it to the actual attachment file.
Error Messages
globalId |
globalId |
ScorecardRestService
This section describes the API for managing assessments. The following functions are available:
List of Values: retrieves a list of assessments
Retrieve Record by ID: retrieves an Assessment record using its unique identifier
Retrieve Record by Business Key: retrieves an Assessment record using its business key
Check Record Modification Timestamp: retrieves the timestamp when an Assessment record was last updated
- Update Record: updates an existing Assessment record
- Update Sub Status: updates the sub status of an existing Assessment record
List of Values
Description
Retrieves a list of assessments in a paged list. Use this function to locate Assessment record IDs prior to a retrieve or update operation. Parameters are available to apply specific selection criteria for filtering the returned records.
Endpoint address: /services/rest/scorecard HTTP method: GET
Request Details
Parameters are passed as URI parameters.
URI Parameters
| status | Optional | string | Yes | Yes | IN PROGRESS~COMPLETE |
| siteStatus | Optional | string | Yes | Yes | AWAITING REGISTRATION |
| siteType | Optional | string | Yes | Yes | PRIMARY |
| siteCode | Optional | string | Yes | Yes | A0001-0001 |
| siteName | Optional | string | Yes | Yes | West Road Site |
| siteNameBusinessLanguage | Optional | string | Yes | Yes | West Road Site |
| supplierCode | Optional | string | Yes | Yes | A0001 |
| supplierName | Optional | string | Yes | Yes | ABC Ltd |
| supplierNameBusinessLanguage | Optional | string | Yes | Yes | ABC Ltd |
| businessCategory | Optional | string | Yes | Yes | POTATOES_LOOSE |
| templateCode | Optional | string | Yes | Yes | ETHICAL_ASSESSMENT |
| dueDate | Optional | string | Yes | No | 2015-05-19 |
| modifiedSince | Optional | string | No | No | 2015-05-19 13:30:39 |
| modifiedUntil | Optional | string | No | No | 2015-05-19 13:30:39 |
Example URLs
…/services/rest/scorecard/?offset=2&pageSize=20 …/services/rest/scorecard/?status=IN PROGRESS~COMPLETE …/services/rest/scorecard/?businessCategory=POTATOES_LOOSE
Response Details
For a successful response, XML is returned with a ScorecardLinkList root element containing an entries element for each matched assessment. The entries element consists of the elements shown in the following table.
Returned Elements
| Element | Type | Description |
recordId |
long |
Assessment record's internal ID |
recordLink |
string |
URI to the ScorecardRestService Retrieve record service for this assessment |
scorecardCode |
string |
Assessment's code business key |
siteCode |
string |
Assessment's site code |
supplierCode |
string |
Assessment's supplier code |
templateCode |
string |
Assessment's template code |
The returned XML also contains a totalRecords element, which states the total number of retrievable records that match the filter parameters.
Error Messages
In the event that an error occurs, an HTTP 500 response is sent.
Description
Retrieves a single Assessment record's details using the record's internal unique ID (which is not visible in the UI). Use this function to retrieve the full details of an individual assessment.
Endpoint address: /services/rest/scorecard/{id} HTTP method: GET
Request Details
URI Parameters
locale |
Optional |
string |
Yes |
Example URL
…/services/rest/scorecard/54
Response Details
For a successful response, an HTTP 301 message is returned, which is automatically acted upon to retrieve XML consisting of a scorecardFullDTO root element containing the individual attributes of the requested Assessment record. If an ID is not specified, a list of all assessments is returned (per the List of Values function).
File Structure
The main elements of the scorecardFullDTO root element:
scorecardTemplateSnapshot and Template - the settings from the associated template.
scorecardQuestions - the assessment's questions and their answers - a separate element for each.
supplier and site - details of the supplier and site that the assessment is related to.
udfData - the contents of any user-defined custom fields associated to the Assessment record.
attachments - a child element containing the ids of any file attachments the assessment has.
Error Messages
id |
HTTP 404 Not found |
Invalid {id} - not numeric |
id |
HTTP 417 IllegalStateException: Cannot find the Assessment to return with id:<###> |
Invalid {id} - not found |
Description
Retrieves a single Assessment record's details using its business key (code). Use this function to retrieve the full details of an individual assessment using its key code.
Endpoint address: /services/rest/scorecard/byKey/{code} HTTP method: GET
Request Details
Example URL
…/services/rest/scorecard/byKey/184
Response Details
File Structure
Error Messages
code |
Description
Retrieves the last modification date and time of an Assessment record. Use this function to determine when a assessment was last updated.
Endpoint address: /services/rest/scorecard/{id} HTTP method: HEAD
Request Details
There are no request parameters, but the URL contains the {id} parameter that determines the record to retrieve.
Example URL
Response Details
If successful, an HTTP 200 response is sent containing the Last-Modified header showing the date and time of the last update of the requested Assessment record. For example:
HTTP/1.1 200 OK Date: Wed, 13 Jul 2016 07:52:14 GMT Last-Modified: Fri, 08 Jul 2016 06:44:46 GMT Content-Type: application/xml Content-Length: 0
Error Messages
id |
HTTP 417 Expectation Failed |
id |
Update Record
Description
Updates an existing Assessment record. Use this function to update an Assessment's details in Supplier Evaluation based on data sourced from the external system..
Endpoint address: /services/rest/scorecard/{id} HTTP method: PUT
Request Details
The body of the request contains a ScorecardFullDTO to specify the updates to the Assessment record, which is based on the ScorecardFullDTO type returned when retrieving an Assessment.
When updating records, all values must be included. If a value or element is omitted from the request, the field contents will be cleared on the Assessment record.See the associated WADL for a full list of the attributes, and the Oracle Retail Supplier Evaluation Cloud Service Data Dictionary, Volume 2 - Supplier for details of their mapping to the fields within the Supplier Evaluation UI.
Response Details
If successful, an HTTP 200 response is sent with a body containing a ScorecardRecordLink element. The ScorecardRecordLink element consists of the elements shown in the following table.
Returned Elements
| recordId | long | Assessment record's internal ID |
| recordLink | string | URI to the Assessment record, for use in a GET request |
| scorecardCode | string | Assessment’s code business key |
| siteCode | string | Assessment’s site code |
| supplierCode | string | Assessment’s supplier code |
| templateCode | string | Assessment’s template code |
Error Responses
If the supplied data does not result in a valid Assessment (such as a missing mandatory field), an HTTP 417 response is sent with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
Assessment Questions & Answers
This section explains the basic structure of the Scorecard API’s payload XML, focussing on the elements which identify the Assessment and contain its Questions and Answers.
The key elements in the parent scorecardFullDTO node which are of relevance when responding to Assessments are as follows.
<scorecardFullDTO> <autoGenerationEnabled> <businessCategories> <calculatedScore> <code> The Assessment’s business key. <dueDate> The date by which the Assessment is due to be completed. <extraScorecard> <overdue> <period> <personResponsible> <quarterEndDate> <quarterStartDate> <scheduled> <scoreTemplate> The Assessment’s questions & answers - see Questions and Answers below. <scorecardScore> <scorecardValue> <status> The status of the Assessment - see Status and Sub Status below. <statusHistory> <supplierGenerated> <udfData> <week> <year> <id> The Assessment’s record Id. <createdOn> When the Assessment was created. <updatedOn> When the Assessment was last updated. <due> <scorecardTarget> The Assessment’s target supplier & site - see Supplier and Site below. <subStatusText> The sub status of the Assessment. <automaticDisqualificationCount> <scorecardTargetSites> <scorecardTargetSupplier> <createdFromAssessmentRequestWizard>
Supplier and Site
The scorecardTarget element identifies the target supplier and site.
<ns1:scorecardTarget>
<ns1:site>
<ns2:code>A0072-00020</ns2:code>
<ns2:localName>BS Site 123</ns2:localName>
<ns2:name>BS Site 123</ns2:name>
<ns2:id>813</ns2:id>
<ns2:supplierId>490</ns2:supplierId>
<ns2:supplierCode>A0072</ns2:supplierCode>
</ns1:site>
</ns1:scorecardTarget>Additional supplier name and contact information is included in the scorecardTargetSupplier element.
The status element contains the Assessment’s currents status, within the status child element, for example:
<ns1:status>
<ns2:applyTemplateChanges>false</ns2:applyTemplateChanges>
<ns2:localeData>
<ns1:description>En cours</ns1:description>
<ns1:locale>fr</ns1:locale>
<ns1:id>15</ns1:id>
</ns2:localeData>
<ns2:localeData>
<ns1:description>In behandeling</ns1:description>
<ns1:locale>nl</ns1:locale>
<ns1:id>21</ns1:id>
</ns2:localeData>
<ns2:localeData>
<ns1:description>In Progress</ns1:description>
<ns1:id>14</ns1:id>
</ns2:localeData>
<ns2:status>IN PROGRESS</ns2:status>
<ns2:id>2</ns2:id>
</ns1:status>Multiple localeData nodes represent the language translations of the status description. The base language (English) description has no locale node. The status child element contains the status code.
The subStatusText node contains the sub status of the Assessment.
The scoreTemplate element contains the main body of the Assessment, including its questions and answers.
The multiple localeData nodes represent the language translations of the Assessment description, based on its template. The base language (English) description has no locale node. The id node contains the record id of the Assessment’s template.
An Assessment’s questions are represented by universalQuestions, generalQuestions or adHocQuestions elements. The structure of each is the same, the difference being how they were configured within the Assessment’s template: Universal questions appear by default in all templates; General questions are added to the template from a glossary of standard questions; Ad Hoc questions are specific to the template, for that type of Assessment.
A question and its answer are structured as follows:
- Multiple localeData nodes represent the language translations of the Question text. The base language (English) description has no locale node. The questionId node contains the Question’s unique id.
- scorecardAnswerType indicates the type of question. The possible types are TEXT, NUMERIC, DATE, URL, RADIO_BUTTON, CHECKBOX, SINGLE_PICKER, MULTI_PICKER and TABULAR.
- For Text, Numeric, Date and URL answer types, a single scorecardQuestionAnswers element contains the response, within an answerText node.
<ns1:scorecardAnswerType>TEXT</ns1:scorecardAnswerType> <ns1:scorecardQuestionAnswers> <ns1:answerText>text response</ns1:answerText> <ns1:id>25702</ns1:id> <ns1:sequence>0</ns1:sequence> </ns1:scorecardQuestionAnswers>
For Radio Button answer types, a single scorecardQuestionAnswers element contains the response, within an answerText node. Multiple scorecardAvailableAnswers elements represent the available answer options. Also copy the relevant scorecardAvailableAnswers element to scorecardQuestionAnswers
<ns1:scorecardAnswerType>RADIO_BUTTON</ns1:scorecardAnswerType> <ns1:scorecardQuestionAnswers> <ns1:answerText>Yes</ns1:answerText> <ns1:scorecardAvailableAnswer> <ns1:id>25706</ns1:id> <ns1:sequence>0</ns1:sequence> </ns1:scorecardQuestionAnswers> ... <ns1:scorecardAvailableAnswers> <ns1:scorecardAvailableAnswers> -
For Checkbox answer types, one or more scorecardQuestionAnswers elements contain the responses, each within an answerText node. Multiple scorecardAvailableAnswers elements represent the available answer options. Also copy the relevant scorecardAvailableAnswers elements to scorecardQuestionAnswers.
<ns1:scorecardAnswerType>CHECKBOX</ns1:scorecardAnswerType> <ns1:scorecardQuestionAnswers> <ns1:answerText>Fresh</ns1:answerText> <ns1:comment>Locally sourced only</ns1:comment> <ns1:scorecardAvailableAnswer> <ns1:id>25703</ns1:id> <ns1:sequence>0</ns1:sequence> </ns1:scorecardQuestionAnswers> <ns1:scorecardQuestionAnswers> <ns1:answerText>Chilled</ns1:answerText> <ns1:scorecardAvailableAnswer> <ns1:id>25704</ns1:id> <ns1:sequence>0</ns1:sequence> </ns1:scorecardQuestionAnswers> ... <ns1:scorecardAvailableAnswers> <ns1:scorecardAvailableAnswers> <ns1:scorecardAvailableAnswers> -
For Single-select Picker answer types, a single scorecardQuestionAnswers element contains the response, within a single scorecardPicklistSingle child element. Multiple scorecardAnswerOptionDetail elements within scorecardPicklistSnapshot represent the available answer options. Copy the contents of the relevant scorecardAnswerOptionDetail element to scorecardPicklistSingle to populate the response.
<ns1:scorecardAnswerType>SINGLE_PICKER</ns1:scorecardAnswerType> <ns1:scorecardQuestionAnswers> <ns1:id>25707</ns1:id> <ns1:scorecardPicklistSingle> <ns2:mandatoryComments>false</ns2:mandatoryComments> <ns2:localeData> <ns1:description>Frozen</ns1:description> <ns1:id>105522</ns1:id> </ns2:localeData> <ns2:code>FROZEN</ns2:code> ... </ns1:scorecardPicklistSingle> <ns1:sequence>0</ns1:sequence> </ns1:scorecardQuestionAnswers> ... <ns1:scorecardPicklistSnapshot> ... <ns1:scorecardAnswerOptionDetail> <ns1:scorecardAnswerOptionDetail> <ns1:scorecardAnswerOptionDetail> </ns1:scorecardPicklistSnapshot> -
For Multi-select Picker answer types, one or more scorecardPicklistMulti elements contains the responses, within a single scorecardQuestionAnswers element. Multiple scorecardAnswerOptionDetail elements within scorecardPicklistSnapshot represent the available answer options. Copy the contents of the relevant scorecardAnswerOptionDetail elements to scorecardPicklistMulti to populate the responses.
<ns1:scorecardAnswerType>MULTI_PICKER</ns1:scorecardAnswerType> <ns1:scorecardQuestionAnswers> <ns1:id>25708</ns1:id> <ns1:scorecardPicklistMulti> <ns2:mandatoryComments>false</ns2:mandatoryComments> <ns2:localeData> <ns1:description>Frozen</ns1:description> <ns1:id>105524</ns1:id> </ns2:localeData> <ns2:code>FROZEN</ns2:code> ... </ns1:scorecardPicklistMulti> <ns1:scorecardPicklistMulti> <ns2:mandatoryComments>false</ns2:mandatoryComments> <ns2:localeData> <ns1:description>Chilled</ns1:description> <ns1:id>105525</ns1:id> </ns2:localeData> <ns2:code>CHILLED</ns2:code> ... </ns1:scorecardPicklistMulti> <ns1:sequence>0</ns1:sequence> </ns1:scorecardQuestionAnswers> ... <ns1:scorecardPicklistSnapshot> ... <ns1:scorecardAnswerOptionDetail> <ns1:scorecardAnswerOptionDetail> <ns1:scorecardAnswerOptionDetail> </ns1:scorecardPicklistSnapshot> -
For Tabular answer types, a single scorecardQuestionAnswers defines the answer type of each column of the table, and contains the responses.
The column types may be text, numeric, URL or single-select picker, defined in columnxAnswerType nodes, where x is the column number.
The responses are contained within nodes which identify the column and answer type:
- Text answers in a cellAnswerx node, where x is the column number.
- Numeric answers in a numberAnswerx node, where x is the column number.
- URL answers in a urlAnswerx node, where x is the column number.
- Single-select picker answers within a scorecardPicklistx element, where x is the column number. Multiple scorecardAnswerOptionDetail elements within a corresponding picklistSnapshotx element represent the available answer options. Copy the contents of the relevant scorecardAnswerOptionDetail element to scorecardPicklistx to populate the response.
The following example is a table of four columns (text, numeric, URL, single-select picker), populated with one row:
Site Certifications Certification Body Certification Year Product Category Red Tractor rt@example.com 2020 Poultry <ns1:scorecardAnswerType>TABULAR</ns1:scorecardAnswerType> <ns1:scorecardQuestionAnswers> <ns1:id>25709</ns1:id> <ns1:column1AnswerType>TEXT</ns1:column1AnswerType> <ns1:column2AnswerType>URL</ns1:column2AnswerType> <ns1:column3AnswerType>NUMERIC</ns1:column3AnswerType> <ns1:column4AnswerType>SINGLE_PICKER</ns1:column4AnswerType> <ns1:cellAnswer1>Red Tractor</ns1:cellAnswer1> <ns1:numberAnswer3>2020</ns1:numberAnswer3> <ns1:scorecardPicklist4> <ns2:mandatoryComments>false</ns2:mandatoryComments> <ns2:localeData> <ns1:description>Poultry</ns1:description> <ns1:id>105527</ns1:id> </ns2:localeData> <ns2:code>POULTRY</ns2:code> ... </ns1:scorecardPicklist4> <ns1:urlAnswer2>https://rt@example.com</ns1:urlAnswer2> <ns1:sequence>0</ns1:sequence> </ns1:scorecardQuestionAnswers> ... <ns1:picklistSnapshot4> <ns2:code>CATEGORIES</ns2:code> <ns2:localeData> <ns1:description>Product Categories</ns1:description> <ns1:id>58276</ns1:id> </ns2:localeData> <ns2:id>2095</ns2:id> <ns1:scorecardAnswerOptionDetail> <ns2:mandatoryComments>false</ns2:mandatoryComments> <ns2:localeData> <ns1:description>Dairy</ns1:description> <ns1:id>105526</ns1:id> </ns2:localeData> <ns2:code>DAIRY</ns2:code> ... </ns1:scorecardAnswerOptionDetail> <ns1:scorecardAnswerOptionDetail> <ns2:mandatoryComments>false</ns2:mandatoryComments> <ns2:localeData> <ns1:description>Poultry</ns1:description> <ns1:id>105527</ns1:id> </ns2:localeData> <ns2:code>POULTRY</ns2:code> ... </ns1:scorecardAnswerOptionDetail> </ns1:picklistSnapshot4>
- A comment node can be included with the answer for any supporting information. If commentsMandatory is true, a comment is mandatory.
- When an answer has an alternative Summary Attribute label, a summaryLabel node is present with the answer’s description node.
Update Sub Status
Description
Updates the sub status of an existing Assessment record. Use this function to update an Assessment's sub status, such as when being progressed by an Accredited Body as part of third-party integration for the sourcing of data from an external system.
Two alternative endpoints are available, to locate the Assessment either by its record id or by its Code business key. They both return a record link to the Assessment.
Endpoint address: /services/rest/scorecard/{id}/substatus and /services/rest/scorecard/{byKey}/substatus
HTTP method: PUT
Request Details
The body of the request of the request is an assessmentSubStatusDTO message containing the sub status of the Assessment and any comments.
Example Request XML
<ns1:assessmentSubStatusDTO
<ns1:substatus>RETRIEVED</ns1:substatus>
<ns1:comments></ns1:comments>
</ns1:assessmentSubStatusDTO>
An Assessment's sub status is initially ISSUED; once assigned to a third party Accredited Body it becomes PENDING, making it available for the designated third party to retrieve. The workflow requires that before the third party submits their response data they first acknowledge they have retrieved the Assessment by setting the sub status to RETRIEVED.
As the regular Update (PUT) endpoint requires the full Assessment payload to be included, the Update Sub Status endpoint provides a simpler method of just returning the sub status value, locating the Assessment by its record id or business key.
Subsequently, the external system will submit the full Assessment payload with their responses using the existing regular Update (PUT) endpoint, setting the sub status RESPONDED, indicating their response is complete.
When called by the external system of a registered Accredited Body, only Assessments that are assigned to that Accredited Body can be updated.
For additional detail on using the Scorecard API for third party integration, see Appendix: LCA Third-Party Integration
Response Details
Returned Elements
Error Responses
ProjectRestService
This section describes the API for managing processes. The following functions are available:
List of Values: retrieves a list of processes
Retrieve Record by ID: retrieves a Process record using its unique identifier
Retrieve Record by Business Key: retrieves a Process record using its business key
Check Record Modification Timestamp: retrieves the timestamp when a Process record was last updated
Update Record: updates an existing Process record
List of Values
Description
Retrieves a list of processes in a paged list. Use this function to locate Process record IDs prior to a retrieve or update operation. Parameters are available to apply specific selection criteria for filtering the returned records.
Endpoint address: /services/rest/project HTTP method: GET
Request Details
URI Parameters
| projectStatus | Optional | string | Yes | Yes | IN PROGRESS~COMPLETED |
| templateCode | Optional | string | Yes | Yes | NEW_BAKERY_RANGE |
| masterProject | Optional | Boolean | No | No | TRUE |
| parentProject | Optional | string | Yes | Yes | NEW_LINE_DEVELOPMENT |
| projectType | Optional | string | Yes | Yes | CHANGE OF SUPPLIER |
| projectName | Optional | string | Yes | Yes | New Potato Product Launch |
| projectManager | Optional | string | Yes | Yes | John Smith |
| specificationType | Optional | string | Yes | Yes | FOOD |
Example URLs
…/services/rest/user/?offset=2&pageSize=20 …/services/rest/user/?projectStatus=IN PROGRESS~COMPLETED …/services/rest/user/?templateCode=NEW_LINE_DEVELOPMENT
Response Details
For a successful response, XML is returned with a ProjectLinkList root element containing an entries element for each matched process. The entries element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Process record's internal ID |
recordLink |
string |
URI to the ProjectRestService Retrieve record service for this process |
projectId |
string |
Process's business key |
projectName |
string |
Process's name |
parentProjectId |
string |
Parent process's business key |
parentProjectName |
string |
Parent process's name |
Error Messages
Description
Retrieves a single Process record's details using the record's internal unique ID (which is not visible in the UI). Use this function to retrieve the full details of an individual process.
Endpoint address: /services/rest/project/{id} HTTP method: GET
Request Details
The URL contains the {id} parameter that determines the record to retrieve.
URI Parameters
| Parameter Name | Mandatory/Optional | Value Type | Multiple Value Separator (~) Supported? | Example |
locale |
Optional |
string |
Yes |
en_GB~fr Locale country code. If used, fields that have language translations have a localeData element returned for the specified locales if data is present. |
Example URL
…/services/rest/project/20
Response Details
For a successful response, an HTTP 301 message is returned, which is automatically acted upon to retrieve XML consisting of a projectFullDTO root element containing the individual attributes of the requested Process record. If an ID is not specified, a list of all processes is returned (per the List of Values function).
File Structure
The main elements of the projectFullDTO root element:
projectTemplateSnapshot and Template - the settings from the associated template.
briefs - the associated process briefs; a separate element for each.
teams - the users and their roles associated to the process.
linkedRecords - the associated linked records; a separate element for each.
udfData - the contents of any user-defined custom fields associated to the Process record.
attachments - a child element containing the ids of any file attachments the process has.
Processes and their activities can be nested within a hierarchy. In the absence of a function to extract the full hierarchy with a single GET call, to retrieve the hierarchy of a process a number of successive calls is required. The Parent Project field is a Boolean value which will be blank for processes that have no hierarchy, or are at the top level of the hierarchy. Use the id or code of the Parent Project to traverse the levels. Use the Activities endpoints to retrieve the process's activity details. Master processes will not have a parent project id or a process name.
If a process is linked to a record such as an Audit, the linkedRecords element contains a list of the linked records, containing the id and business key of the record (audit code, supplier code, or site code), its type, name and status, and the date it was created.
See the associated WADL for a full list of the attributes, and the Oracle Retail Supplier Evaluation Cloud Service Data Dictionary, Volume 3 - Process for details of their mapping to the fields within the Supplier Evaluation UI.
Error Messages
id |
id |
HTTP 417 IllegalStateException: Cannot find the Process to return with id:<###> |
Description
Retrieves a single Process record's details using its business key (code). Use this function to retrieve the full details of an individual process using its key code.
Endpoint address: /services/rest/project/byKey/{code} HTTP method: GET
Request Details
There are no request parameters, but the URL contains the {code} parameter that determines the record to retrieve.
Example URL
…/services/rest/project/byKey/943
Response Details
File Structure
Error Messages
code |
Invalid {code} - blank or not found |
Description
Retrieves the last modification date and time of a Process record. Use this function to determine when the process was last updated.
Endpoint address: /services/rest/project/{id} HTTP method: HEAD
Request Details
Example URL
Response Details
If successful, an HTTP 200 response is sent containing the Last-Modified header showing the date and time of the last update of the requested Processord. For example:
Error Messages
id |
id |
Update Record
Description
Updates an existing Process record. Use this function to update a Process in Supplier Evaluation based on data sourced from the external system.
Process records can be updated, such as to set start/end dates, process brief details, or other attributes, from an external system. Updates do not trigger any automatic re-scheduling of a Process. Dates and other values are simply updated.
The PATCH method allows for partial updates to a record, to update values without the need to submit the full record. This endpoint supports either an XML or JSON payload. The creation of new records is not supported.
HTTP method: PATCH
Request Details
The body of the request contains a projectFullDTO to specify the updates to the Process record, which is based on the projectFullDTO type returned when retrieving a Process.
See the associated WADL for a full list of the attributes, and the Oracle Retail Supply Chain Collaboration Cloud Service Data Dictionary, Volume 3 - Process for details of their mapping to the fields within the UI. The data dictionary indicates which fields are capable of being updated.
The Process unique id is included in the request URI to identify the Process to be updated. Each transaction will represent a single Process. The payload need only include the mandatory values and the values of elements to be updated. A Process at any status can be updated.
Updating the Process record does not trigger the Process to be re-scheduled, even if the start or end dates are updated. Updates to the Supplier, Site and Process Manager are not supported.
Example JSON Requests
JSON requests consist of the following elements:
op specifies the operation to be performed on a field:
replacea valueadda value to a listremovea value from a listmovea value within a list
path specifies the location of the field to be updated.
value specifies the value to be applied by the update.
Note that JSON indexes are zero based.
Replace an existing value:
{ "op" : "replace", "path" : "/udfData/rtfField001", "value" : "new value" }, -
Remove an item, in this case at the first index:
{ "op" : "remove", "path" : "/sites/0" }, -
Add a new item, in this case at the first index:
{ "op" : "add", "path" : "/sites/0", "value": { "code": "A0006-00001", "supplierCode": "A0006" } }, -
Replacing a value in multiple nested collections, referencing the index of each localeDataMap is keyed by locale, in this case referencing the default locale, but 'en_GB' or 'fr' for example would also be valid:
{ "op" : "replace", "path" : "/briefs/0/sections/0/briefQuestions/1/availableAnswer/1/localeDataMap/null", "value" : { "description": "new value" } },
Example XML Requests
XML requests consist of the following elements:
replacea value -
adda value to a list -
removea value from a list - There is no
moveoperation for XML,removeandaddare used instead.
sel specifies the location of the field to be updated.
Note that XML indexes are 1 based.
<replace sel="ns4:projectFullDTO/ns4:udfData/ns1:rtfField001/text()[2]">new value</replace> -
Remove an item from a collection, in this case the first item:
<remove sel="ns4:projectFullDTO/ns4:sites[1]"/> -
Add two items, in this case two sites:
<add sel="ns4:projectFullDTO"> <ns4:sites> <ns2:code>A0006-00001</ns2:code> <ns2:supplierCode>A0006</ns2:supplierCode> </ns4:sites> <ns4:sites> <ns2:code>A0006-00002</ns2:code> <ns2:supplierCode>A0006</ns2:supplierCode> </ns4:sites> </add> -
Replacing an existing value with a code to a glossary entry:
<replace sel="/ns4:activityFullDTO/ns4:activitySubStatus"> <ns4:activitySubStatus> <ns6:code>ARTWORK</ns6:code> </ns4:activitySubStatus> </replace>This example is updating a code value which is a key to glossary record, in this case the Activity Sub Status. For this aggregation type relationship, the code must be specified as shown above. Specifying the code in the following way will result in an incorrect update:<replace sel="/ns4:activityFullDTO/ns4:activitySubStatus/ns6:code"> <ns6:code>ARTWORK</ns6:code> </replace>
Response Details
The Process record is updated. All updatable values will be replaced with the values in the request.
If successful, an HTTP 200 response is sent with a body containing a ProjectRecordLink element. The ProjectRecordLink element consists of the returned elements shown in the following table.
Returned Elements
| recordId | long | Process record's internal ID |
| recordLink | string | URI to the Process record |
| projectId | string | Code ID business key to the Process record |
| projectName | string | Process record’s description |
Error Responses
If the supplied data does not result in a valid Process, an HTTP 417 response is sent with an ErrorMessage/Message message stating the validation errors. The request should not be reattempted with the same content.
If the validation fails, no updates are made for the request.
Error Messages
| id | Process Record not found in the portal, based on Process ID | Cannot locate the Process record |
| projectType | Process Type with code {0} is not found in the portal | Invalid process type |
ActivityRestService
This section describes the API for managing process activities. The following functions are available:
List of Values: retrieves a list of activities
Retrieve Record by ID: retrieves an Activity record using its unique identifier
Retrieve Record by Business Key: retrieves an Activity record using its business key
Check Record Modification Timestamp: retrieves the timestamp when an Activity record was last updated
Update Record: updates an existing Activity record
Update Status: updates the status of an existing Activity record
List of Values
Description
Retrieves a list of activities in a paged list. Use this function to locate Activity record IDs prior to a retrieve or update operation. Parameters are available to apply specific selection criteria for filtering the returned records.
Endpoint address: /services/rest/activity HTTP method: GET
Request Details
URI Parameters
| Parameter Name | Mandatory/ Optional | Value Type | Multiple Value Separator (~) Supported? | Wildcard Search Supported? | Example |
| offset | Optional | int | No | No | 60 |
| pageSize | Optional | int | No | No | 30 |
| recordId | Optional | string | Yes | Yes | 1 |
| projectId | Optional | string | Yes | Yes | PR0000007 |
| activityName | Optional | string | Yes | Yes | Artwork |
| activityCode | Optional | string | Yes | Yes | 762 |
| activityStatus | Optional | string | Yes | Yes | STARTED~COMPLETED |
| activitySubStatus | Optional | string | Yes | Yes | MESSAGE SENT |
| activityType | Optional | string | Yes | Yes | PRODUCT_ARTWORK |
templateCode |
Optional | string | Yes | Yes | ARTWORK |
| linkedRecord | Optional | string | Yes | No |
Note: Options are: ASSESSMENT SUPPLIER SITE AUDIT PRODUCT_RECORD PRODUCT_SPECIFICATION |
| personResponsibleName | Optional | string | Yes | Yes | John Smith |
| proposedStartDate | Optional | string | No | No | 2015-05-19 |
| proposedEndDate | Optional | string | No | No | 2015-05-19 |
| actualStartDate | Optional | string | No | No | 2015-05-19 |
| actualEndDate | Optional | string | No | No | 2015-05-19 |
sequenceNumber |
Optional | string | Yes | Yes | 1.0 |
Example URLs
…/services/rest/user/?offset=2&pageSize=20 …/services/rest/user/?activityStatus=STARTED~COMPLETED
Response Details
For a successful response, XML is returned with a ProjectActivityLinkList root element containing an entries element for each matched process. The entries element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Process Activity record's internal ID |
recordLink |
string |
URI to the AcitvityRestService Retrieve record service for this activity |
activityCode |
string |
Process Activity's business key |
projectRecordId |
string |
The parent Process's internal ID |
projectId |
string |
The parent Process's business key |
Error Messages
Description
Retrieves a single Activity record's details using the record's internal unique ID (which is not visible in the UI). Use this function to retrieve the full details of an individual process activity.
Endpoint address: /services/rest/activity/{id} HTTP method: GET
Request Details
URI Parameters
locale |
Optional |
string |
Yes |
Example URL
…/services/rest/activity/5
Response Details
For a successful response, an HTTP 301 message is returned, which is automatically acted upon to retrieve XML consisting of a projectActivityFullDTO root element containing the individual attributes of the requested Activity record.
File Structure
The main elements of the projectActivityFullDTO root element:
activityTemplateSnapshot and Template - the settings from the associated template.
udfData - the contents of any user-defined custom fields associated to the Activity record.
attachments - a child element containing the ids of any file attachments the activity has.
If an activity is linked to a record such as an Audit, the linkedRecords element contains a list of the linked records, containing the id and business key of the record (audit code, supplier code, or site code), its type, name and status, and the date it was created.
Error Messages
id |
id |
HTTP 417 IllegalStateException: Cannot find the Activity to return with id:<###> |
Description
Retrieves a single Activity record's details using its business key (code) and its parent process's code. Use this function to retrieve the full details of an individual activity using its key code.
Endpoint address: /services/rest/activity/byKey/{activityCode} HTTP method: GET
Request Details
There are no request parameters, but the URL contains the {activityCode} parameter that determines the record to retrieve.
Example URL
…/services/rest/activity/byKey/762
Response Details
File Structure
Error Messages
activityCode |
Invalid {activityCode} - blank or not found |
Description
Retrieves the last modification date and time of an Activity record. Use this function to determine when the process activity was last updated.
Endpoint address: /services/rest/activity/{id} HTTP method: HEAD
Request Details
Example URL
Response Details
If successful, an HTTP 200 response is sent containing the Last-Modified header showing the date and time of the last update of the requested Activity record. For example:
Error Messages
id |
id |
Update Record
Description
Updates an existing Process Activity record. Use this function to update an Activity in Supplier Evaluation based on data sourced from the external system.
Activity records can be updated, such as to set start/end dates, activity brief details, or other attributes, from an external system. Updates do not trigger any automatic re-scheduling of a Process. Dates and other values are simply updated.
HTTP method: PATCH
Request Details
The body of the request contains an activityFullDTO to specify the updates to the Activity record, which is based on the activityFullDTO type returned when retrieving an Activity.
The Activity unique id is included in the request URI to identify the Activity to be updated. Each transaction will represent a single Activity. The payload need only include the mandatory values and the values of elements to be updated. Can update any updatable value in the Activity record, with the exception of the Activity Status field which can be updated using the Update Status endpoint.
Activities at Not Started, Started or Approval Required status can be updated; Completed Activities cannot be updated.
Duration (Days) is an integer. Completed By can be set to a valid user or to Auto Complete. Brief question answers can be populated by identifying the corresponding question.
Updating the Activity record does not trigger the Process to be re-scheduled, even if the activity durations are updated. Updates to the Supplier, Site and Process Manager are not supported. This means that the overall pattern of activity dates within a Process could appear differently to those generated by the system scheduling tool.
See the Update Record function of the ProjectRestService for examples of XML and JSON requests.
Response Details
The Activity record is updated. All updatable values will be replaced with the values in the request (excluding Activity Status).
If successful, an HTTP 200 response is sent with a body containing an ActivityRecordLink element. The ActivityRecordLink element consists of the returned elements shown in the following table.
Returned Elements
| recordId | long | Activity record's internal ID |
| recordLink | string | URI to the Activity record |
| activityCode | string | Code ID business key to the Activity record |
| projectId | string | Activity record’s description |
Error Response
If the supplied data does not result in a valid Activity, an HTTP 417 response is sent with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
Error Messages
| code | Activity not found in the portal, based on Activity Code | Cannot locate the Activity record |
| status | Activity is at Completed status | Cannot update if already completed |
| subStatus | Sub Status with code {0} is not found in the portal | Invalid sub status |
| completedBy | Completed By User {0} is not found in the portal | Invalid user |
Update Status
Description
Updates the status of an existing Process Activity record. Use this function to update an Activity’s status from the external system, triggering any further updates to the associated Process or to other Activities within the Process.
Two alternative endpoints are available, to locate the Activity either by its record id or by its Code business key. They both return a record link to the Activity. These endpoints support a JSON payload.
Endpoint address: /services/rest/activity/{id}/status and /services/rest/activity/byKey{activityCode}/status
HTTP method: PUT
Request Details
The Activity unique id is included in the request URI to identify the Activity to be updated. Each transaction will represent a single Activity. The payload will only include the Activity Status to be updated.
If completing an Activity the Completed Date and Completed By fields can be updated using the Update Record endpoint.
- Update of keys and gates when the Activity is Completed.
- Auto-completion of Gates.
- If the last Activity in the Process is set to Completed, the Process Status is set to Completed.
Response Details
The Activity Status is updated. All updatable values will be replaced with the values in the request (excluding Activity Status).
Returned Elements
Error Responses
If the supplied data does not result in a valid Activity, an HTTP 417 response is sent with an ErrorMessage/Message message stating the validation errors. The request should not be reattempted with the same content.
Error Messages
| status | Status with code {0} is not found in the portal | Invalid status |
ProductRecordRestService
This section describes the API for managing Product records. The following functions are available:
List of Values: retrieves a list of Product records
Retrieve Record by ID: retrieves a Product record using its unique identifier
Retrieve Record by Business Key: retrieves a Product record using its business key
- Check Record Modification Timestamp: retrieves the timestamp when a Product record was last updated
Create Record: creates a new Product record
Update Record: updates an existing Product record
When integrated with Merchandising, using the ProductRecordRest API to make changes that affect the Product Codes table can have an impact on the integration.List of Values
Description
Retrieves a list of Product records in a paged list. Use this function to retrieve a simple list of product titles and IDs, or to locate Product record IDs prior to a retrieve or update operation. Parameters are available to apply specific selection criteria for filtering the returned records.
Endpoint address: /services/rest/productRecord HTTP method: GET
Request Details
URI Parameters
offset |
Optional |
int |
No |
60 |
pageSize |
Optional |
int |
No |
30 |
modifiedSince |
Optional |
string |
No |
modifiedUntil |
Optional |
string |
No |
productRecordCode |
Optional |
integer |
No |
123456 |
altProductNumber |
Optional |
string |
No |
ABC001 |
division |
Optional |
string |
Yes |
DIV_A~DIV_B Must be the code of an entry in the Divisions glossary |
Example URLs
…/services/rest/productRecord/?offset=2&pageSize=20…/services/rest/productRecord/?productRecordCode=123456
Response Details
For a successful response, XML is returned with a ProductRecordLinkList root element containing an entries element for each matched Product Record. The entries element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Product record's internal ID |
recordLink |
string |
URI to the ProductRecordRestService Retrieve record service for this Product record |
code |
string |
Code business key to the Product record |
title |
string |
Product's title |
Error Messages
modifiedSince |
Invalid dates cause stack trace to come back to "response" |
modifiedUntil |
pageSize |
Error Code: INVALIDPAGESIZE |
Page Size must be between 1 and 100 |
offset |
Error Code: INVALIDOFFSET |
Offset must be a positive integer |
Description
Retrieves a single Product record's details using the record's internal unique ID (which is not visible in the UI). Use this function to retrieve the full details of an individual Product Record.
Endpoint address: /services/rest/productRecord/{id} HTTP method: GET
Request Details
See the associated WADL for a full list of the attributes, and the Oracle Retail Supplier Evaluation Cloud Service Data Dictionary, Volume 5 - Product for details of their mapping to the fields within the Supplier Evaluation UI.
URI Parameters
locale |
Optional |
string |
Yes |
Example URL
…/services/rest/productRecord/99
Response Details
For a successful response, an HTTP 301 message is returned, which is automatically acted upon to retrieve XML consisting of a productRecordFullDTO root element containing the individual attributes of the requested Product record. If an ID is not specified, a list of all Product records is returned (per the List of Values function).
Error Messages
id |
HTTP 404 Not Found |
id |
HTTP 417 IllegalStateException: Cannot find the Product Record to return with id:<###> |
Description
Retrieves a single Product record's details using its business key (code). Use this function to retrieve the full details of an individual Product record using its Supplier Evaluation product code.
The Product record's business key is the product code that is visible in the UI. This an individual number assigned by Supplier Evaluation. It is not the product's traded unit identifier such as a SKU, that is, the product number, which is also visible in the UI.
Endpoint address: /services/rest/productRecord/byKey/{code} HTTP method: GET
Request Details
Example URL
…/services/rest/productRecord/byKey/31
Response Details
If successful, an HTTP 301 redirect response is sent containing a header Location with the URI of the document requested.
The returned URI represents the call to be made to the Retrieve Record by ID function (with the id substituted with the relevant value), which will return a productRecordFullDTO root element containing the individual attributes of the requested Product record.
If your method of calling the API is configured to automatically follow HTTP 301 redirects, the call may automatically return a productRecordFullDTO root element containing the individual attributes of the requested Product record.
Error Messages
code |
Invalid {code} - blank |
code |
Invalid {code} - not found |
code |
NumberFormatException: For input string: <###> |
Invalid {code} - not numeric |
Description
Retrieves the last modification date and time of a Product record. Use this function to determine when a Product record's details were last updated.
Endpoint address: /services/rest/productRecord/{id} HTTP method: HEAD
Request Details
Example URL
Response Details
If successful, an HTTP 200 response is sent containing the Last-Modified header to showing the date and time of the last update of the requested Product record.
Error Messages
id |
id |
Create Record
Description
Creates a new Product record. Use this function to create new Product records in Supplier Evaluation based on data sourced from the external system.
Dependencies: If linked to a supplier or site, the Supplier/Site must be present in the application and its record ID obtained. If assigning a Business Category, Technologist, or Other Contact, the record must be present in the application and its record ID obtained.
Technologist and Other Contacts may be omitted to default to TBC if the TBC user is present in the application. For the status to be Active. the Product record must be linked to a supplier. For more information, see Dependencies.
The Use Alternative Code for Product API system parameter enables a facility for holding alternative supplier codes against Supplier records. This feature is of use if the external system does not hold the Supplier Evaluation supplier codes. If enabled, and the supplier code submitted by the API is not found in Supplier Evaluation, a secondary lookup will be performed to attempt to locate the Supplier using the alternative codes facility.Endpoint address: /services/rest/productRecord HTTP method: POST
Request Details
The body of the request contains a ProductRecordFullDTO to specify the Product record to create. Compared to retrieving a Product record (which uses the same ProductRecordFullDTO type), this request is much shorter. Only the attributes that are to be populated on the created Product record need to be included. As a minimum, this must include the fields shown in the following table.
Product Record Mandatory Fields
| Field Name | Element Name |
Product Title |
title |
Status |
productRecordStatus |
Variant Name |
variantName |
Quantity |
quantity |
Technologist |
technologist |
Other Contacts |
productRecordOtherUser |
Supplier Details |
supplier |
Site Details |
site |
Deleted Record |
deleted (Set to false) |
Language |
labelI18NKey |
To ensure a valid unique business key code is automatically assigned to the record being created, a value of zero must be passed in the <code> element of the XML when submitting the POST request.
Example Request XML
Where the record is linked to another record, such as the Technologist in this case, the business key must be provided (not the description) in order to form the link between the records. In general, the business key will be the code attribute of the linked record.
The API does not apply status-based validation as is applied using the Supplier Evaluation UI when manually progressing a Product record.Single Variant Mode
<productCovered> <productTitle/> <variantName/> <quantity/> <retailerProductNumber/> </productCovered>
Multi Variant Mode
<productCovered>
<productTitle/>
<variantName/>
<quantity/>
</productCovered>
<productCovered>
<productTitle/>
<variantName/>
<quantity/>
</productCovered>
It is therefore possible, using the API, to create a Product record at Active status without the supplier or site being populated.
Response Details
If successful, an HTTP 200 response is sent with a body containing a ProductRecordLink root element. The root element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
Newly created Product record's internal ID |
recordLink |
string |
URI to the newly created Product record, for use in a GET request |
code |
string |
Code business key to the newly created Product record |
title |
string |
Product's title |
Error Messages
If the supplied data does not result in a valid Product record (such as a missing mandatory field), an HTTP 417 response is sent with an ErrorMessage/Message XML body message stating the validation errors. The request should not be reattempted with the same content.
productCoverage |
ERROR: class <<hostname>>.ProductRecord.productCovered - The condition is invalid |
No tag provided |
code |
ERROR: class <<hostname>>.ProductRecord.code - A Product Record's code is mandatory |
No tag provided |
code |
No value provided |
code |
ERROR: class <<hostname>>.ProductRecord.code - A Product Record's code must be unique:<###> |
Code already exists |
code |
HTTP Status 400 - Bad request |
Code is not numeric |
title |
DtoValidationException: title is mandatory |
No tag provided No value provided |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>.PoductRecordStstus using status:<###> |
No tag provided No value provided Status not found |
variantName |
ERROR: class <<hostname>>.ProductRecord.productCovered[###].variantName - Variant name is mandatory |
quantity |
ERROR: class <<hostname>>.ProductRecord.productCovered[###].quantity - Quantity name is mandatory |
technologist |
MySQLIntegrityConstraintViolationException: Cannot add or update a child row: a foreign key constraint fails ('<###>'.'t_prdrcd',CONSTRAINT '<###>' FOREIGN KEY ('fk_technologist') REFERENCES 't_user' ('c_id')) |
technologist |
ObjectNotFoundException: No row with the given identifier exists: [com.micros.creations.core.domain.User#<###>] |
Technologist not found |
productRecordOtherUser/user |
DtoValidationException: ProductRecordOtherUser has no valid user for role:<###> ProductRecordOtherUser Roles are mandatory for the following missing Roles: [<###>] |
No tag provided User not found |
ObjectNotFoundException: No row with the given identifier exists:[<<hostname>>.Usert#<###>] |
No value provided |
productRecordOtherUser/role |
ObjectNotFoundException: No row with the given identifier exists:[<<hostname>>.Role#<###>] |
No value provided |
supplier |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>.Company using code:<###> |
No tag provided |
supplier |
MySQLIntegrityConstraintViolationException: Cannot add or update a child row: a foreign key constraint fails ('<###>'.'t_prdrcd',CONSTRAINT '<###>' FOREIGN KEY ('fk_supplier') REFERENCES 't_company' ('c_id')) |
No value provided Supplier not found |
site |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>.Site using id:<###>, code:<###>, supplierCode:<###> and supplierId:<###> |
No tag provided No value provided Supplier not found |
countryWhereSold |
HTTP 417 IllegalStateException: Cannot locate keyword for class <<hostname>>.CountryWhereSold using code:<###> and spec type:<###> |
No value provided |
countryWhereSold |
ObjectNotFoundException: No row with the given identifier exists:[<<hostname>>.CountryWhereSold#<###>] |
Country not found |
ERROR: class <<hostname>>.ProductRecord.barcode[<###> - Bar Code must be either 8 or 13 characters long |
Invalid code length |
ERROR: class<<hostname>>.ProductRecord.shippingCaseCode[<###> - Shipping Case Code must be either 14 digits long |
Update Record
Description
Updates an existing Product record. Use this function to update a Product record's details in Supplier Evaluation based on data sourced from the external system.
Endpoint address: /services/rest/productRecord/{id} HTTP method: PUT
Request Details
The body of the request contains a ProductRecordFullDTO to specify the updates to the Product record. Compared to retrieving a Product record (which uses the same ProductRecordFullDTO type), this request is much shorter. As a minimum, the values specified as mandatory for the Create Record function (see above) must be included.
The request content is the same as that for creating a Product Record. After the call, the Product Record is updated to match the request.
When updating records, all values must be included. If a value is or element is omitted from the request, the field contents will be cleared on the Product record.See the associated WADL for a full list of the attributes, and the Oracle Retail Supplier Evaluation Cloud Service Data Dictionary, Volume 5 - Product for details of their mapping to the fields within the Supplier Evaluation UI.
Response Details
If successful, an HTTP 200 response is sent with a body containing a ProductRecordLink element. The ProductRecordLink element consists of the elements shown in the following table.
Returned Elements
recordId |
long |
recordLink |
string |
URI to the Product record, for use in a GET request |
code |
string |
title |
string |
Product's title |
Error Responses
