Accessing the Gift Registry
From the Back Office Main Menu, select Customer and then press Enter.
Select Gift Registry and then press Enter.
Figure 3-1 Gift Registry
You have the following options at the Gift Registry Search prompt:
Figure 3-2 Gift Registry Search Prompt
To create a new registry, select New. Skip to Creating a New Registry.
To search for a gift registry, enter one or more search criteria and the select Process. You can search by: Registry #, Registry Name, Owner First Name, Owner Last Name, Event Type, or scan a registry id with the handheld scanner. Continue with step 4.
If Xstore retrieves more than one registry, select the registry you wish to view.
Figure 3-3 Multiple Search Results
To create a new registry, select New. See Creating a New Registry.
Choose Select & View to view the Gift Registry options.
Figure 3-4 Gift Registry Options
You have the following options at this screen:
Select Change Qty Desired to update the desired item quantity. See Changing the Quantity.
Select Delete Item to remove the item from the gift registry. See Deleting an Item.
Select View Details to review and edit the gift registry information. See Viewing and Modifying Details.
Select View Owners to view and edit registry owner information. See Viewing and Modifying Owners.
Select View Attributes to see additional attribute information such as wedding date, baby's gender, and so on. See Viewing and Modifying Attributes.
Select View Addresses to view any addresses associated with the registry. Addresses include before event, after event, and vendor's address. See Viewing and Modifying Addresses.
