Mobile Device Quick Config
Mobile Device Quick Config allows you to generate a QR code for a mobile device to connect to the Xstore Mobile server.
Select System Admin from the Main Menu.
Click Mobile Device Quick Config in the System Admin menu.
For the mobile device you want to configure, enter the register ID it should have.
Xstore generates a QR code containing the configuration information.
On the mobile device you want to configure, go into the Configuration screen. Swiping the screen from the left to the right on the mobile device gains access to the Configuration screen. Select Scan to Configure to scan the generated barcode.
Scan the QR code. The mobile device is added.
