Reinitialize Hardware
Select the Reinitialize Hardware menu option to reset the peripheral hardware devices. The system performs the following process for the hardware devices:
close -->release-->claim-->open
When prompted, select Yes to confirm you want to re-initialize the hardware.
Reinitializing hardware is also used to register a VeriFone device with TransArmor.
