22 Shelf Labels
You can print shelf labels for any item in the
current item file. Shelf labels can be printed to a laser report printer
if the report printer supports printing multiple labels per page,
or to a label printer if using ZPL II communication. In addition to
scanning/entering items in order to print labels, the system also
provides an option to print shelf labels for all of the items on an
entire receiving document at once, and from previously saved batches
You must load the appropriate label stock into the printer for each label printing job. The system does not perform a check for the correct stock before printing.
