47 Item Transfer
This chapter describes the procedures for transferring items from one inventory bucket to another.
About This Chapter
This chapter contains the following procedures:
Start Item Transfer
To start the item transfer process:
Figure 47-1 Main Menu - Inventory
  1. Select Inventory in the Main Menu.
    Figure 47-2 Handheld Inventory Menu
    Mobile Handheld Inventory Menu
  2. Select Item Transfer from the Inventory menu.
    Continue with Perform Transfer.
Perform Transfer
To perform an item transfer:
Select the location from which the item will be transferred:
Figure 47-3 Inventory Location Selection - From Location
  1. Select the source location for the item.
  2. Select the source bucket for the item.
  3. Select Process.
    Select the location to which the item will be transferred:
    Figure 47-4 Inventory Location Selection - To Location
  4. Select the destination location for the item.
  5. Select the destination bucket for the item.
  6. Select Process.
    Figure 47-5 List of Reason Codes
  7. Select the reason for the transfer.
    Figure 47-6 Select an Item
    Select an Item
  8. Scan an item or enter an item ID.
  9. Use the Context Menu to:
    Figure 47-7 Item Transfer Context Menu
Adjust Item
This section describes how to adjust an item. Select an item to open the Options menu.
Figure 47-8 Item Transfer Options Menu
Two options are available:
Change Item Quantity
To change the quantity of an item:
  1. Select the item.
  2. Select Change Qty from the Options menu.
    Figure 47-9 Enter Quantity
    Enter Quantity
  3. Enter the quantity.
  4. Select OK.
    The quantity is updated.
    Return to the transfer item list screen.
Void Item
To remove an item from an item transfer:
  1. Select the item.
  2. Select Void Item from the Options menu.
    The quantity is set to zero.
    Note that the item is still listed, only the quantity is changed to zero.
Additional Options
This section describes additional item transfer options.
Save & Exit
To save the transfer and return to the inventory screen:
  1. Select the Context Menu button.
  2. Select Save & Exit.
    Figure 47-10 Confirm Save Transfer
  3. Select Yes.
    The item transfer completes. Return to the inventory menu.
Transfer All Items
To include all the items in the list, setting each item to the maximum quantity:
  2. Select Transfer All.
    Figure 47-11 Confirm Transfer All Items
  3. Select Yes.
    The quantity of every item in the list is set to its maximum value.
    Return to the item transfer list screen.
Print Item List
To print a list of items in the transfer:
  2. Select Print Item List.
    Follow the print procedure for your system.
    The list of items prints.
