Creating a New Inventory Replenishment Order
Inventory Replenishment Documents are downloaded from the home office; however, you can also create a Replenishment Document in your store. Use the following process to create a new Inventory Replenishment Document.
At the Document Search form, select the Add New option, or select the Add New option at the Inventory Replenishment Search Results form to create a new Replenishment Document.
Figure 3-29 Document Search Form
Figure 3-30 Document Search Results Form
Xstore Classic displays a blank Replenishment form. Enter the item ID of the item you want added to the document.
Figure 3-31 New Inventory Replenishment Screen
Enter the Quantity and press Enter.
Figure 3-32 Quantity to Order Prompt
If the item has a Pack Size defined, then you must enter a quantity that is a multiple of the pack size. Otherwise Xstore Classic will prompt if you want to round your quantity to the nearest multiple.
Figure 3-33 Quantity Not Multiple of Pack Size Prompt
Figure 3-34 Quantity Less Than Half a Pack Prompt
Select Yes to add the item with the Quantity rounded to the nearest multiple of the Pack Size. For example, you entered a quantity of 1 but the pack size is 5, quantity will be rounded up to 5.
Select No to return to the Item Entry screen without adding the item. Xstore displays the following information for the item entered:
Figure 3-35 Item Entry Screen
Item ID
Description
Quantity
Pack Size (if applicable)
Source Id (if applicable)
Source Name (if applicable)
When you have entered all the information for this new Replenishment Document, select Save & Exit.
To modify the replenishment order before saving, see Inventory Replenishment Options.
Answer the confirmation prompt:
Figure 3-36 Save & Exit Prompt
Select Yes to save the Replenishment Order and return to the document search screen.
Select No to return to the Item Entry screen without saving the document. Your changes are not lost.
