30 Price Inquiry
If you want to look up the price of an item, select Price Inquiry from the Home Screen. You can look up the price for an item when you are logged out.
To look up the price of an item, follow the steps below.
Select Price Inquiry from the Home Menu.
Figure 30-1 Home Screen Menu - Price Inquiry
You are prompted for the item. Scan, or enter the item and select OK.
Figure 30-2 Price Inquiry Item Prompt
The item description, item ID and the corresponding price are displayed.
Figure 30-3 Price Inquiry Result
If the displayed price is a deal price, the system marks the price with the text Sale.
Select Back to close the screen.
