26 Message Maintenance
Select this tab to create and maintain associate messages.
Messages can be viewed by selecting Messages.
Figure 26-1 Home Screen - Messages
Creating and Maintaining Messages
Messages are for information purposes only and require no action by the associate. Messages may be downloaded from the corporate office, and messages can also be created and maintained at the store level using the outside of sale mode Message Maintenance menu option.
Messages can be store-based or register-based and provide the ability for both the corporate office and the store managers to share information with all associates.
Messages can be maintained at the corporate office or using these functions. Only store-created messages can be edited at the store level. Messages from the corporate office cannot be changed or deleted.
Perform the following steps to create and maintain messages:
  1. After logging in, select Associate from Global Navigation.
    Figure 26-2 Associate Menu
    Associate Menu
  2. At the Associate menu, select Message Maintenance.
Creating a New Message
Messages can be displayed on all registers, or only a specific register. However, all associates can see the messages. Messages cannot be directed to specific associates or associate groups. Any messages created are automatically flagged as Store Created.
  1. At the Message Maintenance list, select New Message.
  2. Enter data as required to create a new message:
    Figure 26-3 Message Details- New Message Form
    Message Details - New Message Form
    • Start Date: The date the message is to be displayed.
    • End Date: The date the message is to be removed from the message list.
    • Priority: The message importance: High, Medium, Low.
    • Register Specific/Register #:
      • Register Specific: Yes or No - If No, the message is displayed on all registers. If Yes, the message is only displayed on a specific register.
      • Register #: If Register Specific is set to Yes, this is the register on which the message is displayed.
    • Message URL: If applicable, enter a URL address. The URL will appear as an attachment to the message.
    • Message: The message text.
    • Select Save Changes to create the new message.
Editing a Message
Only messages created at the store level can be edited or deleted. For this reason, any messages downloaded from the corporate office are not displayed in the list of messages returned from a message search.
To find and display the list of store-created messages, refer to Creating and Maintaining Messages, or see Message Maintenance to display the list.
  1. Select the Row Overflow Menu for the desired message.
    Figure 26-4 Message Maintenance
    Associate Messages List
  2. Select Edit Message to make the fields active and available for editing.
    Figure 26-5 Associate Messages Maintenance
  3. At the active Associate Messages maintenance form, make your changes as needed:
    • Store Created: Any message that is created automatically.
      • Register #: The register on which the message is displayed. This only applies if Register Specific is set to Yes.
  4. After making your changes, select OK to apply your edits to the message.
Deleting a Message
Only messages created at the store level can be deleted.
  1. At the Message Maintenance list (Figure 26-4) select the Row Overflow Menu.
  2. Select Delete Message to delete the message.
  3. At the Delete Message confirmation prompt, select Yes to remove the message. If you do not want to delete the message, select No to return to Message Maintenance.
