Accessing Oracle Retail Xstore Office
Oracle Retail Xstore Office is a web-based application that you can access through an internet browser.
Open an internet browser.
Enter the server address in the Address field and press [Enter].
The login page opens.
Figure 1-1 Oracle Retail Xstore Office Login Page
The Forgot Password link is not available in a manually reset password environment and when using LDAP Authentication. You can only request a forgotten password reset in static and algorithm password environments. See Requesting a Forgotten Password for more information about resetting your password.
The Xstore Office Login page is displayed in the Default Locale language when you log on for the first time or when you use a new browser. For more information on how to configure the language (default locale code) for Xstore Office, see theGeneral Category General Category section in theSystem Management chapter.
Type your user name in the User ID field.
Type your password in the Password field.
Click the Sign In button.
The first time you log in to Oracle Retail Xstore Office you will be prompted to change your password. Complete the fields as required, then click Submit.
You are prompted for an organization. Select an organization from the list and click OK.
If only one organization is assigned to your user account, the organization selection is not available.
If you select Cancel you are logged out of Xstore Office.
The Oracle Retail Xstore Office Home page displays. Select a menu option from the menu bar, or click a link in one of the Oracle Retail Xstore Office Panels to continue.
Figure 1-2 Oracle Retail Xstore Office Home Page
Home Page Layout:
Menu Bar
The top of the page contains the menu bar.
Breadcrumbs Bar
The breadcrumbs bar is right below the menu bar.
Organization ID, Organization Name (if available) and Logged In User ID
The selected organization ID and organization name (if available) as well as the logged in user ID are displayed in the top right corner of the page.
Panels
In the center of the page the available panels are displayed. Possible available panels are:
Configuration Manager
Data Manager
Deployment Manager
Support Tools
Reports
System
More Arrow (when applicable)
Drop-down menu
Select the logged in profile name in top right section of the page. A drop down menu is displayed. The following options are available:
Log Out
Select the Log Out option.
Confirm that you want to log out. The system returns to the login page.
Change Organization
Use the Change Organization option to switch between organizations.
If the user has only access to one organization, the Change Organization option is not displayed.
About Xadmin
Use this feature to view the Oracle Retail Xstore Office version the system is currently running on. This is a view-only window.
To view the versions of Oracle Retail Xstore Point of Service running in the field, see Support Tools.
The following information is shown:
The application version number
Copyright information
Oracle license information
To close the window, click the Close icon.
Navigation:
To return to the Oracle Retail Xstore Office Home page at any time, click the Home bread crumb.
To display more panels (when applicable), click the More arrow.
Initial Access Setup Instructions
A default administrator security role account has been set up in the database to allow first-time access to Oracle Retail Xstore Office.
Using this default user account to log in, click the Xadmin Users link in the System panel or select Xadmin Users in the System menu to set up additional Oracle Retail Xstore Office user accounts.
Oracle recommends that you set up at least one ADMINISTRATOR security user account.
Once this Administrator security user has been set up, delete the initial (default) administrator user account for security purposes.
See Roles, Users, and Security Access for detailed instructions.
