System Manager
The System Manager menu allows you to manage system management options.
From the Oracle Retail Xstore Office menu, select System Management, then select System Manager.
The System Manager menu displays. The following options are available:
Figure 3-6 System Manager
Credentials Storage
Use this function to submit and store credentials to set up a connection with cloud services. These credentials will allow Xstore Office On-Premise to communicate with Identity Cloud Service (IDCS).
To store and set up the communication with cloud services, follow the steps below.
At the Credentials Storage page, enter the Client ID.
Then enter the Client Secret.
Press Save. The system validates the credentials. If the validation is successful a message is displayed. Then system regenerates the client secret.
If the regeneration was successful, the system saves the client ID and secret to the database.
If the regeneration was not successful, a message is displayed.
This function is only available if you have sufficient security privilege. See Appendix: Enrollment with Cloud Services on how to Enroll Xstore Office On-Premise to communicate with Cloud Service applications.
Additionally see the Oracle Retail Omnichannel Web Service Authentication Configuration Guide (Doc ID 2728265.1) on My Oracle Support, for more information about how to configure web service authentication for the Retail Omnichannel products.
