4 REST Web Services
Web services are intended for integration to allow a system using those services to control the flow and processing of data within EICS. There are multiple types of data involved in this integration. Data that is managed by other systems and needs to get into our system, but that EICS does not manage. This includes such concepts as item, stores, and point-of-sale transaction. Data that is managed by EICS includes such ideas as inventory adjustments, transfers, deliveries, and stock counts. Some services will provide ability for external data to get into EICS, some are intended to be used real time such as approving, picking, and dispatching shipments.
REST WEB Services Security Considerations
The REST web services provided by EICS are secured using OAuth2 tokens and require SSL.
The supported OAuth2 security requires a token requested for the client_credentials grant with the EICS integration scope (for example, rgbu:siocs:integration).
Note that the scope name differs for each environment.
REST Web Service OAuth2 Requests
This section will describe how to call an EICS web service using the OAuth2 protocol. The target audience is developers who are looking to write code that calls the web service.
Using the OAuth Protocol
The OAuth protocol is relatively straightforward:
Get an access token from the authentication provider
Pass the access token along with the web service request
In this case, the authentication provider is Oracle Identity Cloud Service (IDCS). Every customer who purchases a subscription to EICS gets a subscription to IDCS as part of their purchase.
Obtaining a Token
REST APIs use OAuth2.0 for authorization.
To generate a token from IDCS, an IDCS application client will need to be created for you to use.
The Customer Administration users must create their own client credential IDCS application using the Oracle Retail Home Cloud Service. For additional details, refer to Oracle® Retail Home Administration Guide- Chapter: Oauth Application Configuration chapter – Section: Creating OAuth Client Applications.
The App name and scope that should be used for IDCS application creation should be environment specific using the format :
App Name- RGBU_SIOCS_<ENV>_EICS_INT
Scope 1 - rgbu:siocs:integration-<ENV>
Scope 2 - rgbu:siocs:security-<ENV>
Please note that the integration scope is the default and other scopes are needed when specified.
Example:
App Name- RGBU_SIOCS_STG1_ EICS_INT
Scope 1 - rgbu:siocs:integration-STG1
Scope 2 - rgbu:siocs:security-STG1
You will need the following information about the IDCS application client to request a token:
IDCS URL
Client Id
Client Secret
Scope Name
the application client must be assigned the scope from the EICS IDCS cloud service in order to request the token. This assignment is performed when the application client is created.
The scope name will differ for each environment. Please ensure the correct value is used for your environment.
To generate a token, you will need to invoke the appropriate IDCS REST API. The curl command in Linux that describes the POST that will return a token is as follows:
curl -H 'Authorization: Basic <base64(clientId:clientSecret)>'
-H 'Content-Type: application/x-www-form-urlencoded;charset=UTF-8'
--request POST <IDCS URL>/oauth2/v1/token -d 'grant_type=client_credentials&scope=<EICS
Scope>'
In Windows, use double-quotes, as follows:
curl -H "Authorization: Basic <base64(clientId:clientSecret)>"
-H "Content-Type: application/x-www-form-urlencoded;charset=UTF-8"
--request POST <IDCS URL>/oauth2/v1/token -d "grant_type=client_credentials&scope=<EICS
Scope>"
This is a standard REST POST, with the following details:
<IDCS URL> is the IDCS URL the retailer provided
Include the Client Id and Client Secret as a Basic Authentication header
Specify the Content Type as application/x-www-form-urlencoded;charset=UTF-8
Specify the body as grant_type=client_credentials&scope=<EICS Scope>
The service will respond with the following JSON message:
"access_token": "<TOKEN>",
"token_type": "Bearer",
"expires_in": 3600
Note that the response will return how long the token is valid for. You should reuse the same token until it expires in order to minimize calls to IDCS to get a token.
If the token request fails, you will receive the following JSON response:
"error":"<error>",
"error_description":"<error description>",
"ecid":"u….."
The most common errors are:
Invalid Client. This means that the client information you send in is not correct. The error description will expand on the reason:
Client Authentication Failed means that the client is valid, but the client secret is incorrect.
Invalid OAuth Client <CLIENT> means that the client id is not valid, and the invalid client will be listed in the error message.
Invalid Request. Some part of the inbound request is not valid. The error description is usually descriptive about what the actual error condition is
Calling the EICS Web Service
To invoke the web service with an OAuth2 token, you must add an Authorization header to the request. The value of the Authorization header must be Bearer <token>, that is:
The word Bearer
A space
A valid token
For a REST service call, the request might look something like this:
curl -X POST -H 'Content-Type: application/json' -H 'Authorization:
Bearer <TOKEN>' -i https://CloudServiceURL --data '{PAYLOAD}'
Remember that the token will expire after a specific amount time, and to be more efficient you should always use a token so long as it's valid. It is your responsibility to make sure that you are keeping track of whether the token is still valid. Your pattern should be:
Check to see if you have a valid token that has not expired.
If not, call to IDCS and get a new token. Store it and its expiration time.
Send the request into the web service with the token in the Authorization header as a Bearer token.
REST WEB Services Basic Design Principles
Requests and Responses
When making requests and processing responses from REST web services it is important for the client to handle headers correctly.
The client should always use Accept for the appropriate content type when making requests.
The client should always check the response status code and Content-Type header before processing a response body.
When reading a payload from the response body, the Content-Length header must be used safely and securely along with the Content-Type.
This is important even for error responses. It is possible for errors to occur outside of the REST API layer, which may produce different content for the error. In these cases, it is common to get text or HTML content for the response body.
API Versioning
Accept-Version
The REST end points have an optional API versioning feature allowing the client to specify an API version to be accepted.
This may be used by the client to ensure that no calls may be made to a web service that uses an incorrect version number.
For example: Accept-Version: 22.1.301
If the web service does not support this API version, then the server will produce a 400 Bad Request error response.
Content-Type
application/json
The content type of both REST input and returned output is application/json.
In the case that no content is included, a content type may not be assigned.
When handling REST service responses, the client must always check the returned Content-Type and Content-Length before processing the payload.
JSON Validation
When consuming a REST service end point that requires a request payload as JSON, the client is responsible for verifying that the JSON is valid. If invalid data is sent in a request, there may be a server error processing the JSON or it may ignore some fields if the JSON is valid but does not map correctly to the API payload definition.
Always make sure that the client sends valid JSON that is designed to satisfy the API payload definition.
Synchronous vs Asynchronous
Each service API will be defined as synchronous or asynchronous. Both perform JSON validation as described above. If the API is synchronous, the remaining data validation and live updating of the data will take place immediately and the call will be rejected if any business errors occur. If the API is asynchronous, the data is set aside to be processed later and the REST service is successfully returned noting that the data has been accepted. In the case of asynchronous processing, business error and failed data recovery is monitored and the dealt with outside of the REST web service.
Online Documentation
EICS has exposed Swagger JSON files for customers to download and use with the Swagger application as online documentation. The table below contains the files name for access. The file can be retrieved from on the server at:
https://<external_load_balancer>/<cust_env>/siocs-int-services/public/api/filename.json|
activitylock |
address |
adhoccount |
allocation |
batch |
differentiator |
finisher |
fts |
fulfillmentorder |
fulfillmentorderdelivery |
fulfillmentorderpick |
fulfillmentorderreversepick |
inventoryadjustment |
item |
itembasket |
iteminquiry |
iteminventory |
itemisn |
itemprice |
itemuda |
itemuin |
manifest |
notification |
postransaction |
productarea |
productgroup |
productgroupschedule |
purchaseorder |
reasoncode |
rfid |
security |
shelfadjustment |
shelfreplenishment |
shelfreplenishmentgap |
shipping |
stockcount |
store |
storeitem |
storeorder |
storesequence |
supplier |
ticket |
transfer |
transferdelivery |
transfershipment |
translation |
vendordelivery |
vendorreturn |
vendorshipment |
warehouse |
For external APIs that must be implemented by the customer for EICS to access, the files can be accessed on the server at:
https://<external_load_balancer>/<cust_env>/siocs-int-services/public/api-external/file.json|
fulfillmentorderaddress-external |
fulfillmentorderstatus-external |
inventoryadjustment-external |
manifest-external |
notification-external |
preshipmentnotice-external |
shipment-external |
stockcountschedule-external |
storeorder-external |
ticketprint-external |
transferdeliverreceipt-external |
transferstatus-external |
vendordeliveryreceipt-external |
vendorreturn-external |
Configured System Options In EICS
Web services apply system configuration to the request that are coming in through a web service but assumes that all in-put validation that requires user interaction to confirm has been completed by the third party system prior to accessing the service. It operates as if the user confirmed any activity. However, if a system option is a fixed restriction that does not require user interaction, and the input fails the restriction, this is always considered an error.
Examples of configurations being applied include:
Shipping inventory when inventory is less than 0 can be allowed by a user of EICS. The web services assumes that the application accessing the service did prompt the user or that their business always allows the user to this activity.
Adding a non-ranged item requires both a system configuration option to be enabled and the user to confirm the addition of the item. If the system configuration does not allow it, the web service will block the transaction and return an error (un-less processing asynchronously). If the system configuration does allow adding non-ranged items, it will automatically assume that a user confirmed this addition and processing will allow the addition of the item.
Allowing Receiver Unit Adjustments is dependent on a period of time. If a receiver unit adjustment were to come into EICS after that period of time, it would automatically be rejected, and the web service would return an error regardless of presentation or confirmation of user done by the external system.
External vs Internal Attributes
EICS web services are EICS centric and track information from an internal application point-of-view. This has ramifications on three types of data: identifiers, dates, and users.
Almost all paths and information will contain an identifier. In almost all cases, this will be an EICS internal identifier generated within our system. If external identifiers also exist for the date, they will be defined as such in the information. For example, you might encounter transferId and externalTransferId as attributes. In some cases, an API only takes an internal identifier, and you may need to use lookup APIs to retrieve an internal identifier using an external identifier as search criteria.
Timestamps are captured at the time an event occurs within EICS as part of EICS's internal tracking and state management. For example, we capture the timestamp when a shipment is created, last updated, and when it is dispatched. These timestamps occur at the time this occurred within EICS. When a REST service is called to create a transaction, such as a shipment, the create timestamp of the shipment will be the moment that service is called. If the shipment is dispatched using the web service, the dispatch date will be the moment that service is called. So if an external system dispatched a shipment two days earlier, and is just now calling the web service, it will not capture the external dispatch time. In some places, you will encounter a date that can be entered as part of the input information (for example, an externalDispatchDate, or simple a transactionTimestamp). If it is part of the input information, then it will be captured as that attribute defined in the API.
The user responsible for actions is often captured as part of transaction information with EICS. Some examples might be the user that created the data, the user the last updated it, or perhaps the user that approved it. In these cases, the user is considered an internal user as is assigned the current session user at the time the activity takes place. When accessing the REST service, the user will be fiwed as an “External User” to indicate it came from an external system, and not the user that manipulated the information in an external system. If external users are to be captured by the data, there will be independent attribute fields such as externalCreateUser that capture the identity of a user in an external system.
Activity Locking
An activity lock is a record indicating that a user is currently actively working on a transaction. When using REST services, the accessing application is responsible for the management of activity locks. The Activity Lock REST service allows the finding, creating, and deleting of activity locks.
Developers should create a lock on transactional information prior to performing updating calls and delete those locks when the update is finished. For example, to update Inventory Adjustment 123, the first step is to create an activity lock for Inventory Adjustment 123 using the Activity Lock REST service. The next step is to update the inventory adjustment. Once the inventory adjustment is finished, you can then delete the activity lock for Inventory Adjustment 123. Note that an activity lock is not obtained, then an error may occur when updating the transaction indicating that the update can not happen due to a user currently holding the lock.
An alternate method to handling activity locks is to assume that REST service calls should override any current work a user is performing. Under this design, a delete lock call can be issued just prior to the update. For example, for Inventory Adjustment 123, you can simply delete locks for that transaction just prior to calling the update and this will remove the lock and terminate any work other users are doing on that transaction prior to your update.
Dates In Content
Dates included as part of raw JSON data content (most often as part of a POST) must match the following format example: 2022-04-19T23:59:59-05:00.
The content includes year (4 digit), month, day, hour, minute, second, and timezone offset and allows formatting.
Dates included as a query parameter within the main URL must be in the following format example: 220227152543-0700
The content includes year (2 digit), month, day, hour, minute, second, and timezone offset without any formatting.
Due to URL encoding standards, the query parameter cannot directly contain a “+” symbol for positive shift from UTC timezones and this character will need to replace by its URL encoding. The URL encoding for a “+” symbol is “%2B”, so the actual query parameter for 220227152543+0700 would instead be 220227152543%2B0700.
After the format permissible length, any additional trailing characters will be ignored and the date will still be processed.Links In Content
JSON information for a data object may include links. These are self-referential APIs that defined other APIs that are available with the information. In the example below, when reading an activity lock, the following links were included that define a path to accomplish other calls. HRef lists the basic reference and the “rel” the remainder of the path. So, when you read activity lock (1), you get a delete reference that maps to /activitylock/1/delete, defining the REST path to delete that lock.
"links" : [ {
"href" : "/activitylocks/1",
"rel" : "self"
"rel" : "delete"
Hypertext Transfer Protocol Status Codes
The following information documents the HTTP status codes that Oracle returns via web services calls.
Success Codes
Successful codes are returned whenever the accessing client call was made without any error in the form or content.
| Code | Description |
200 OK |
The information supplied by the customer was in a correct form. This code is returned when reading a resource or querying information about an existing resource or schema. This response code is used when the access is synchronous. |
202 Accepted |
The information supplied by the customer as in a correct form. This code is returned when access is asynchronous. |
204 No Content |
The information supplied by the customer was in a correct form. The request was successful but the API itself never provides information as a response. |
Client Failure Codes
Client failure codes indicate the client made an error in their service access and must correct their code or its content to fix the failure.
400 Bad Request |
If this code is returned, it indicates the customer made a call with invalid syntax or violated the defined properties of the input information. Detailed information may be returned that further identifies the error. |
401 Unauthorized 403 Forbidden |
If either of these codes are returned, it indicates the access to service was denied. This may occur if no OAuth2 token was provided, or the token had expired, or the identity the token was generated for did not have sufficient access. |
404 Not Found |
If this code is returned, it indicates the customer made an erroneous access call against a resource or schema that is not defined. |
405 Method Not Allowed |
If this code is returned, it indicates that the wrong HTTP method was used to make the call. Please check the API. |
406 Not Acceptable |
If this code is returned, it indicates the wrong Accept header value was used to make the call. Please check the API. |
409 Too Many Requests |
If this code is returned, it indicates that the web service has received too many service requests recently. This may indicate a cloud issue requiring support to address or the client is making too many calls too frequently and a solution may be required to avoid the issue. |
System Failure Codes
System failure codes are returned whenever the processing server encounters an unexpected or severe failure.
500 Internal Server Code |
A server error occurred that did not allow the operation to complete. |
502 Bad Gateway 503 Service Unavailable 504 Gateway Timeout |
If any of these codes are returned, it indicates an issue with the network or cloud services, which may occur due to either client or cloud networking or infrastructure issues, such as outages. |
JSON Error Element and Error Codes
If an error occurs in the form of the content, or during processing of the content, an HTTP response code (400 Bad Request) will be returned along with JSON structure defined by the ErrorList schema.
Schema — ErrorList
This section describes the ErrorList schema.
Table 4-1 ErrorList — Object
| Element Name | Required | Data Type | Description |
| errors | NA | object |
Information about the errors. |
The table below describes the information about the error. See the Oracle Retail Enterprise Inventory Cloud Service Administration Guide for further information.
Table 4-2 Error — Object
code |
NA |
number example: 1 |
The code error type. |
description |
NA |
string example: AN_ERROR_TOOK_PLACE |
A brief description of the error type (an error key). |
dataElement |
NA |
string example: item |
The attribute or element that caused the failure. |
dataValue |
NA |
string example: 1234 |
The value of the attribute or element that failed, or a piece of information about that element. |
referenceElement |
NA |
string example: inventory adjustment |
An attribute or element that may help further identify the error. Most often this is a containing element one level above the failed element. |
referenceValue |
NA |
string example: 123 |
The value of the reference attribute or element, often something to identify the specific reference element. |
Example Value
"errors": [
"code": 1,
"description": "AN_ERROR_TOOK_PLACE",
"dataElement": "item",
"dataValue": "1234",
"referenceElement": "inventory adjustment",
"referenceValue": "123"
]Error Attribute Definitions
| Attribute | Definition |
Code |
A numeric code indicates the issue. See Integration Error Codes table. |
Description |
The name of the error or issue. |
DataElement |
The name of an attribute or element of the JSON structure that failed. |
DataValue |
The value of the attribute or element that failed, or a piece of information about the element that failed (such as a maximum value). |
ReferenceElement |
The name of an attribute or element that will help further identify the data element. Most often the containing element one level above the failed elements (such as a transaction header). |
ReferenceValue |
The value of the attribute or element that will help further identify the data element. |
The following table contains a listing of the error codes that can be found within returned error information.
| Code | Name | Issue |
1 |
Business Error |
A business processing error prevent the service from completing. |
2 |
Date Range Error |
The date range has a problem (usually indicates end date is earlier than start date in a date range. |
3 |
Duplicate Error |
Indicates duplicate element within the data is not permitted. |
4 |
Forbidden |
Access is not allowed to the service. |
5 |
Internal Server Error |
A severe error occurred with the service attempting to process the request. |
6 |
Invalid Input |
Most often this indicates that input was included that is not allowed or not needed, however it also doubles a kind of catch-all category. |
7 |
Invalid Format |
An input was in an invalid format (most often a date string in a query parameter not being in a valid date format). |
8 |
Invalid Status |
A transaction or entity is not in a valid status to proceed with the request. |
9 |
Missing Path Element |
A path element defining the path of the resource URL was not present. |
10 |
Missing Attribute |
A required attribute was missing on the input to the service. |
11 |
Not Found |
A data element in the input could not be found in the system (most often an invalid identifier). |
12 |
No Data Input |
No input exists for a service that requires input. |
13 |
No Query Input |
No query input exists at all for a query that requires at least one input. |
14 |
Element Too Large |
An input was too large (exceeded maximum count or maximum size). |
15 |
Results Too Large |
The results of the service were too large to return. |
Error Code Data Elements
The following table contains a listing of likely or possible data elements that would be matched with a code. Data element and value may not be returned in all cases.
| Code | Name | Data Element | Data Value |
1 |
Business Error |
Business exception name/key |
Data Value |
2 |
Date Range Error |
Date element name |
Value of date |
3 |
Duplicate Error |
Duplicate element name |
Duplicated Value |
4 |
Forbidden |
N/A |
5 |
N/A |
6 |
Invalid Input |
Element name |
Value of element |
7 |
Invalid Format |
Element name |
Value of element |
8 |
Invalid Status |
Element name |
Status of element |
9 |
Missing element |
10 |
Missing Attribute |
Required element name |
11 |
Not Found |
Element not found |
Value of element not found |
12 |
No Data Input |
Missing element |
13 |
No Query Input |
N/A |
14 |
Element Too Large |
Element name |
Allowed size limit |
15 |
Results Too Large |
N/A |
REST Service: Activity Lock
This service allows the creation, removal, and finding of activity locks.
An activity lock is a record indicating the user, time, and apiece of information (a transaction) that should be considered "locked". All server processing validates that the accessing user has a lock on the information before updating, notifying the current user if someone else has modified the information while they were locked and preventing a stale update.
Find Activity Lock
This section describes the Find Activity Lokc API. The Find Activity Lock API searches for up to 10,000 locks based on input criteria. At least one input criteria should be provided.
Request
Table 4-3 Find Activtiy Lock — Request Parameters
| Name | Required | Data Type/Example | Description |
| activityType | NA | integer($int2) (query) |
Include only activity locks with this activity type. Valid devices types are: 1 - Bill of Lading 2 - Direct Delivery Invoice 3 - Fulfillment Order 4 - Fulfillment Order Delivery 5 - Fulfillment Order Pick 6 - Fulfillment Order Reverse Pick 7 - Invnetory Adjustment 8 - Inventory Adjustment Reason 9 - Item Basket 10 - Item Request 11 - POS Transaction Resolution 12 - Price Change 13 - Product Basket 14 - Product Group 15 - Product Group Schedule 16 - Replenishment Gap 17 - Shelf Adjustment 18 - Shelf Replenishment 19 - Shipment Reason 20 - Stock Count Child 21 - Store Order 22 - Ticket 23 - Ticket Format Basket 24 - Transaction Event 25 - Transfer 26 - Transfer Delivery Carton 27 - Transfer Shipment Carton 28 - Vendor Delivery Carton 29 - Vendor Shipment Carton 30 - Vendor Return Available values : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30 |
| sessionId | NA | string($text128) (query) | Include only activity locks with this session identifier. |
| deviceType | NA | integer($int4) (query) |
Include only activity locks with this device type. Valid devices types are:
1 - Client 2 - Server 3 - Integration Service Available values : 1, 2, 3 |
| userName | NA | string($text128) (query) | Include only activity locks with this user name. |
| lockDateFrom | NA | string($date-time) (query) | Include only activity locks created on or after this date. |
| lockDateTo | NA | string($date-time) (query) | Include only activity locks created on or before this date. |
Responses
This section describes the responses of the Find Activity Lock API.
Response Code: 200
The request has been successful.
The media type is application/json.
Example Value
"lockId": 1111111,
"sessionId": "1234",
"activityId": "5555",
"activityType": 1,
"deviceType": 1,
"userName": "userAbc",
"lockDate": "2025-02-27T13:15:22.775Z"
Schema — ActivityLockIdo
Table 4-4 ActivityLockIdo —Object
| Element Name: | Required | Data Type/Example | Description |
| lockId | NA | number($int15) example: 1111111 | The identifier of an activity lock. |
| sessionId | NA | string($text128) example: 1234 | The identifier of the session that owns the lock. |
| activityId | NA | string($text128) example: 5555 | The identifier of the activity that is locked. |
| activityType | NA | integer($int4) example: 1 |
The type of activity that is locked. Valid devices types are: 1 - Bill of Lading 2 - Direct Delivery Invoice 3 - Fulfillment Order 4 - Fulfillment Order Delivery 5 - Fulfillment Order Pick 6 - Fulfillment Order Reverse Pick 7 - Inventory Adjustment 8 - Inventory Adjustment Reason 9 - Item Basket 10 - Item Request 11 - POS Transaction Resolution 12 - Price Change 13 - Product Basket 14 - Product Group 15 - Product Group Schedule 16 - Replenishment Gap 17 - Shelf Adjustment 18 - Shelf Replenishment 19 - Shipment Reason 20 - Stock Count Child 21 - Store Order 22 - Ticket 23 - Ticket Format Basket 24 - Transaction Event 25 - Transfer 26 - Transfer Delivery Carton 27 - Transfer Shipment Carton 28 - Vendor Delivery Carton 29 - Vendor Shipment Carton 30 - Vendor Return Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30 ] |
| deviceType | NA | integer($int4) example: 1 |
The device type that holds the activity lock. Valid types are: 1 - Client 2 - Server 3 - Integration Service Enum: [ 1, 2, 3 ] |
| userName | NA | string($text128) example: userAbc | The unique identifier of the user that owns the lock. |
| lockDate | NA | string($date-time) | The date the activity was locked. |
Read Activity Lock
The Read Activity Lock API retrieves information about an activity lock.
Request
Table 4-5 Read Activity Lock — Request Parameter
activityLockId |
Yes |
integer($int15) (path) |
The activity lock identifier. |
Responses
This section describes the responses of the Read Activity Lock API.
Response Code: 200
Example Value
"lockId": 1111111,
"activityType": 1,
"deviceType": 1,
"lockDate": "2025-02-27T13:47:12.359Z"
}Schema — ActivityLockIdo
Table 4-6 ActivityLockIdo —Object
Create Activity Lock
The Create Activity Lock API creates a new user transaction activity lock. This prevents two users from simultaneously changing the data.
Request
There are no request parameters.
The request body is appliaction/json.
The activity lock to create.
Schema — ActivityLockCreateIdo
Table 4-7 ActivityLockCreateIdo —Object
| Element Name | Required | Data Type/Example | Description |
sessionId |
Yes |
activityId |
Yes |
The identifier of the activity that is locked (this is often a primary identifier of a transaction). |
activityType |
Yes |
The type of activity that is locked. Valid devices types are 1 - Bill of Lading 2 - Direct Delivery Invoice 3 - Fulfillment Order 4 - Fulfillment Order Delivery 5 - Fulfillment Order Pick 6 - Fulfillment Order Reverse Pick 7 - Invnetory Adjustment 8 - Inventory Adjustment Reason 9 - Item Basket 10 - Item Request 11 - POS Transaction Resolution 12 - Price Change 13 - Product Basket 14 - Product Group 15 - Product Group Schedule 16 - Replenishment Gap 17 - Shelf Adjustment 18 - Shelf Replenishment 19 - Shipment Reason 20 - Stock Count Child 21 - Store Order 22 - Ticket 23 - Ticket Format Basket 24 - Transaction Event 25 - Transfer 26 - Transfer Delivery Carton 27 - Transfer Shipment Carton 28 - Vendor Delivery Carton 29 - Vendor Shipment Carton 30 - Vendor Return Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30 ] |
Delete Activity Lock
This section describes the Delete Activity Lock API. This API removes an activity lock and indicates the activity should no longer be restricted and another user can now being activity on that data. It will remove the lock if it exists and perform no action at all if the lock does not exist. In either case, it returns 204 code.
Request Parameters
Table 4-9 Delete Activity Lock — Request Parameters
| Parameter | Required | Data Type | Description |
activityLockId |
yes |
REST Service: Address
This service integrates address foundation data. Asychronous address integration is processed through staged messages and is controlled by the MPS Work Type: DcsStore.
Read Address
The Read Address API retrieves information about a single address.
Request
Table 4-10 Read Address — Request Parameter
addressId |
Yes |
The address identifier. |
Responses
This section describes the responses of the Read Address API.
Response Code: 200
Example Value
"addressId": 1111111,
"entityType": 1,
"entityId": 5555,
"addressType": 1,
"primary": true,
"addressLine1": "This is line 1.",
"addressLine2": "This is line 2.",
"addressLine3": "This is line 3.",
"city": "City name",
"state": "ST",
"countryCode": "USA",
"postalCode": "10000",
"county": "County",
"companyName": "Company name",
"contactName": "Contact Name",
"contactPhone": "123-456-7890",
"contactFax": "123-456-7890",
"contactEmail": "email@service.com",
"firstName": "John",
"lastName": "Smith",
"phoneticFirstName": "jon",
"phoneticLastName": "smith",
"supplierLocation": "Location"
}Schema — AddressIdo
Table 4-11 AddressIdo —Object
| addressId | NA | number($int25) example: 1111111 | The identifier of the address in an external system. |
| entityType | NA | integer($int4) example: 1 |
Denotes the type of location of the entity. Valid values are: 1 - Bill Of Lading 2 - Direct Delivery Invoice 3 - Fulfillment Order Enum: [ 1, 2, 3 ] |
| entityId | NA | integer($int10) example: 5555 | The external identifier of the entity the address belongs to. |
| addressType | NA | integer($int4) example: 1 |
The type of address. Value values are: 1 - Business 2 - Postal 3 - Return 4 - Order 5 - Invoice 6 - Remittance 7 - Billing 8 - Delivery 9 - External Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9 ] |
| primary | NA | boolean example: true | True if this is the primary address of the entity. |
| addressLine1 | NA | string($text240) example: This is line 1. | The first line of the address. |
| addressLine2 | NA | string($text240) example: This is line 2. | The second line of the address. |
| addressLine3 | NA | string($text240) example: This is line 3. | The third line of the address. |
| city | NA | string($text120) example: City name | The city of the address. |
| state | NA | string($text3) example: ST | The state abbreviation of the address. |
| countryCode | NA | string($text3) example: USA | The country code of the address (used by supplier).) |
| postalCode | NA | string($text30) example: 10000 | The postal code of the address. |
| county | NA | string($text250) example: County | The county name of the address. |
| companyName | NA | string($text120) example: Company name | A company name associated to the address. |
| contactName | NA | string($text120) example: Contact Name | A contact name for the address. |
| contactPhone | NA | string($text20) example: 123-456-7890 | A contact phone number for the address. |
| contactFax | NA | string($text20) example: 123-456-7890 | A contact fax number for the address. |
| contactEmail | NA | string($text100) example: email@service.com | A contact email for the address. |
| firstName | NA | string($text120) example: John | The first name of the contact for the address. |
| lastName | NA | string($text120) example: Smith | The last name of the contact for the address. |
| phoneticFirstName | NA | string($text120) example: jon | A phonetic spelling of the first name of a contact for the address. |
| phoneticLastName | NA | string($text120) example: smith | A phonetic spelling of the last name of a contact for the address. |
| supplierLocation | NA | string($text120) example: Location | Supplier location information |
Import Address
Imports a series of addresses. This allows up to 1,000 addresses. A forbidden response will occurs if the application is integrated with MFCS or RMS..
Request Parameters
Threr are no request parameters.
The request body is application/json.
A list of addresses to import.
Example Value
"addresses": [
"entityType": 1,
"entityId": 5555,
"addressType": 1,
"primary": true,
"state": "ST",
"county": "County",
}Schema - AddressImportListIdo
Table 4-12 AddressImportListIdo —Object
| addresses | NA | object | Addresses |
Table 4-13 AddressImportIdo —Object
Denotes the type of location of the entity. Valid values are: 1 - Bill of Lading 2 - Direct Delivery Invoice 3 - Fulfillment Order Enum: [ 1, 2, 3 ] |
REST Service: Adhoc Count
An Adhoc Count is a stock count created and counted on the fly without previous sheduling or determination of what is going to be counted. All stock counts are broken down into child counts. An adhoc count is broken down into a single child count for processing.
Find Counts
Finds up to a maximum of 1,000 adhoc counts for the input criteria.
Request
Table 4-15 Find Counts — Request Parameters
| storeId | NA | integer($int10) (query) | Include only stock counts for this store. |
| scheduleDate | NA | string($date-time) (query) | Include only stock counts that are scheduled to be executed on this date. |
| phase | NA | integer($int4) (query) |
Include only stock counts in this phase. Valid values are: 1 - Count 2 - Authorize Available values : 1, 2 --12 |
| status | NA | integer($int4)(query) |
Include only stock counts in this status. Valid values are: 1 - New 2 - Count Scheduled 3 - Count In Progress 4 - Count Complete 5 - Approval Scheduled 6 - Approval In Progress 7 - Approval Processing 8 - Approval Authorized 9 - Approval Complete 10 - Canceled Available values : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 --12345678910 |
| departmentId | NA | number($int12) (query) | Include only stock counts associated to this department. |
| classId | NA | number($int12) (query) | Include only stock counts associated to this class. A department is required if this attribute is used. |
| subclassId | NA | number($int12) (query) | Include only stock counts associated to this subclass. A class is required if this attribute is used. |
Responses
This section describes the responses of the Find Counts API.
Response Code: 200
Example Value
"stockCountId": 11111,
"storeId": 5000,
"description": "Weekly Department Count",
"status": 1,
"phase": 1,
"totalItemsOnCount": 120,
"scheduleDate": "2025-07-14T11:17:07.440Z",
"startDateTime": "2025-07-14T11:17:07.440Z",
"updateDateTime": "2025-07-14T11:17:07.440Z"
]Schema — AdhocCountHeaderIdo
Table 4-16 AdhocCountHeaderIdo —Object
| stockCountId | NA | number($int12) example: 11111 |
The unique identifier of the adhoc count. |
| storeId | NA | number($int10) example: 5000 |
The identifier of the store. |
| description | NA | string($text255) example: Weekly Department Count |
A description of the adhoc count. |
| status | NA | integer($int4) example: 1 |
The current status of the adhoc count. Valid values are 1 - New 2 - Count Scheduled 3 - Count In Progress 4 - Count Complete 5 - Approval Scheduled 6 - Approval In Progress 7 - Approval Processing 8 - Approval Authorized 9 - Approval Complete 10 - Canceled Enum:[ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 ] |
| phase | NA | integer($int4) example: 1 | integer($int4)example: 1 The current phase of the adhoc count. Valid values are 1 - Count 2 - Authorize Enum:[ 1, 2 ] |
| totalItemsOnCount | NA | number($int12) example: 120 |
The total number of items on the adhoc count. |
| scheduleDate | NA | string($date-time) |
The date the adhoc count is being counted. |
| startDateTime | NA | string($date-time) |
The time stamp when the adhoc count was started. |
| updateDateTime | NA | string($date-time) |
The time stamp when the adhoc count was last updated. |
Create Count
The Create Count API creates a new adhoc stock count.
Request
Details to create the adhoc count with.
Example Value
"storeId": 11111,
"scheduleDate": "2025-07-14T11:47:12.274Z",
"timeframe": 1
}Schema — AdhocCountCreateIdo
Table 4-17 AdhocCountCreateIdo —Object
| storeId | Yes | integer($int10)example: 11111 |
The store where the count is taking place. |
| description | NA | string($text255)example: Weekly Department Count |
| timeframe | number($int2) example: 1 |
The timeframe of the processing. If daily sales, only before store open and after store close are allowed. For not daily sales, only None is allowed. If daily sales and not included, default configuration will be used instead. Valid values are 1 - Before Store Open 2 - After Store Close 3 - None Enum:[ 1, 2, 3 ] |
Responses
This section describes the responses of the Create Count API.
Response Code: 200
Example Value
"storeId": 5000,
"status": 1,
"phase": 1,
Table 4-18 AdhocCountHeaderIdo —Object
Read Count
The Read Cound API retrieves all the details about an adhoc count.
Request
Table 4-19 Read Count— Request Parameter
adhocCountId |
Yes |
number($int12)(path) |
Responses
This section describes the responses of the Read Count API.
Response Code: 200
Example Value
"storeId": 5000,
"status": 1,
"phase": 1,
"scheduleDate": "2025-07-14T13:07:06.824Z",
"startDateTime": "2025-07-14T13:07:06.824Z",
"updateDateTime": "2025-07-14T13:07:06.824Z",
"adhocItemLock": true,
"childCounts": [
"childCountId": 11111,
"status": 1,
"phase": 1,
"countUser": "jsmith",
"authorizeUser": "jsmith",
"authorizedDate": "2025-07-14T13:07:06.824Z",
"lineItems": [
"lineId": 1223465,
"itemId": "20045673",
"departmentId": 2000,
"classId": 3000,
"subclassId": 4000,
"primaryLocation": true,
"multiLocated": false,
"discrepant": true,
"breakableComponent": false,
"countSnapshot": 100,
"quantityCounted": 99,
"quantityAuthorized": 101,
"quantityCountedTotal": 99,
"countedDateTime": "2025-07-14T13:07:06.824Z",
"authorizedDateTime": "2025-07-14T13:07:06.824Z",
"snapshotDateTime": "2025-07-14T13:07:06.824Z",
"priceType": 1,
"priceCurrency": "USD",
"priceValue": 12.99,
"uins": [
"uin": "200456734823",
"uinId": 1223465,
"snapshotStatus": 1
]Schema — AdhocCountIdo
Table 4-20 AdhocCountdo —Object
| stockCountId | NA | number($int12) example: 11111 | The unique identifier of the adhoc count. |
| adhocItemLock | NA | boolean |
True indicates that items can no longer be added. |
| childCounts | NA | objects | child counts |
Table 4-21 AdhocCountChildIdo —Object
| childCountId | NA | number($int12) example: 11111 |
The unique identifier of the adhoc child count. |
| phase | NA | integer($int4)example: 1 |
| countUser | NA | string($text128) example: jsmith |
The last user to count the adhoc count child. |
| authorizeUser | NA | string($text128) example: jsmith |
The user that authorized this adhoc count child. |
| authorizedDate | NA | string($date-time) |
The date the adhoc count child was authorized. |
| lineItems | NA | object | line items |
Table 4-22 AdhocCountLineItemIdo —Object
| lineId | NA | number($int12) example: 1223465 |
The unique identifier of the line item record. |
| itemId | NA | string($text128) example: 20045673 |
The unique identifier of the item. |
| departmentId | NA | number($int12) example: 2000 |
The unique identifier of the department. |
| classId | NA | number($int12) example: 3000 |
The unique identifier of the class. |
| subclassId | NA | number($int12) example: 4000 |
The unique identifier of the subclass. |
| primaryLocation | NA | boolean example: true |
True indicates this is the primary stock count child for the item. |
| multiLocated | NA | boolean example: false |
True indicates this item is located within multiple stock count child records. |
| discrepant | NA | boolean example: true |
True indicates the item count is discrepant. |
| breakableComponent | NA | boolean example: false |
True indicates this is a component of a breakable (notional) pack. |
| countSnapshot | NA | number($decimal(12,4)) example: 100 |
The stock on hand at the time the count snapshot was executed. |
| quantityCounted | NA | number($decimal(12,4)) example: 99 |
The amount in standard unit of measure counted during the initial stock counting phase. |
| quantityAuthorized | NA | number($decimal(12,4)) example: 101 |
The amount in standard unit of measure to be approved during authorization. |
| quantityCountedTotal | NA | number($decimal(12,4)) example: 99 |
The amount in standard unit of measure counted during the initial stock counting phase for this item across all children in which it appears. |
| countedDateTime | NA | string($date-time) |
The time stamp when counting began for the item. |
| authorizedDateTime | NA |
The time stamp when the item was authorized. |
| snapshotDateTime | NA | string($date-time) | string($date-time)
The time stamp when the snapshot was last taken for this item. |
| priceType | NA | integer($int3) example: 1 |
The price type of the price value and currency. Valid values are 1 - Permanent 2 - Promotional 3 - Clearance Enum:[ 1, 2, 3 ] |
| priceCurrency | NA | string($text3) example: USD |
The price currency at the time of the snapshot. |
| priceValue | NA | number($decimal(20,4)) example: 12.99 |
The price amount at the time of the snapshot. |
| uins | NA | object | UINS |
Table 4-23 AdhocCountLineItemUinIdo - Object
| uin | NA | string($text128) example: 200456734823 |
The unique identifier number. |
| uinId | NA | number($int12) example: 1223465 |
The record identifier of the UIN. |
| snapshotStatus | NA | number($int2) example: 1 |
The status of the UIN at the time of the snapshot. Valid values are 1 - In Stock 2 - Sold 3 - Shipped To Warehouse 4 - Shipped To Store 5 - Reserved For Shipping 6 - Shipped To Vendor 7 - Remove From Inventory 8 - Unavailable 9 - Missing 10 - In Receiving 11 - Customer Reserved 12 - Customer Fulfilled 13 - Shipped To Finisher 99 - Unconfirmed Enum:[ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 99 ] |
Update Count
The Update Count API adds or updates the counted quantities of items on the adhoc stock count.
Request
Table 4-24 Update Count— Request Parameter
adhocCountId |
Yes |
Item details to update on the adhoc count.
Example Value
"lineItems": [
"itemId": "55001234",
"quantity": 2,
"timestamp": "2025-07-24T16:07:12.174Z",
"uins": [
111222333,
444555666
Schema — AdhocCountUpdateIdo
Table 4-25 AdhocCountUpdateIdo —Object
Table 4-26 AdhocCountUpdateLineItemIdo —Object
| itemId | Yes |
string($text25) example: 55001234 |
The SKU level item identifier. |
| quantity | Yes |
number($decimal(20,4)) example: 2 |
The quantity of the item counted. |
| timestamp | NA |
The date and time that the item was counted. |
| uins | NA | string($text128)]
[example: List [ 111222333, 444555666 ] |
The UINs to attach to this line item. If UINs are included, the total number of UINs must match the quantity. |
Complete Count
The Complete Count API completes the counting phase of the adhoc stock count moving it to authorization phase.
Request
Table 4-27 Complete Count— Request Parameter
adhocCountId |
Yes |
Cancel Count
The Cancel Count API cancels the adhoc stock count that is currently in progress.
Request
Table 4-28 Cancel Count— Request Parameter
adhocCountId |
Yes |
REST Service: Allocation
Allocation documents defined the intent to ship goods from a warehouse to a store. Allocations may be managed by Oracle Merchandising, and if so, then some operations within this service will be blocked.
Service Base URL
The Cloud service base URL follows the format:
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Allocation
This section describes the Find Allocation API. This API finds up to 5,000 purchase orders headers for the input criteria. No item information is returned.
Request Parameters
Table 4-29 Find Allocation — Request Parameters
allocationId |
NA |
integer($int12) (query) |
Include only allocations with this allocation identifier. |
itemId |
NA |
string($text25) (query) |
Include only allocations for this item. |
storeId |
NA |
Include only allocations for this store. |
warehouseId |
NA |
Include only allocations for this warehouse. |
deliveryDateFrom |
NA |
Include only allocations where the delivery date is on or after this date. |
deliveryDateTo |
NA |
Include only allocations where the delivery date is on or before this date. |
status |
NA |
Include only allocations in this status. Valid values are: 1 - Approved 2 - Completed 3 - Canceled Available values : 1, 2, 3 |
Responses
This section describes the responses of the Find Allocation API.
Response Code: 200
Example Value
"allocationId": 11111,
"itemId": "100637121",
"storeId": 5000,
"warehouseId": 7000,
"scheduleDate": "2025-01-02T12:38:48.481Z",
"status": 1,
"contextId": 14562,
"contextValue": "Season End",
"distributionParentId": "19384731",
"deliverySlotId": 134143,
"quantityExpected": 20,
"quantityReceived": 10,
"quantityDamaged": 10
]Schema — AllocationIdo
Table 4-30 AllocationIdo— Object
allocationId |
NA |
The unique identifier of the allocation. |
itemId |
NA |
string($text25) example: 100637121 |
The identifier of the item. |
storeId |
NA |
The identifier of the store receiving the goods. |
warehouseId |
NA |
number($int10) example: 7000 |
The identifier of the warehouse shipping the goods. |
scheduleDate |
NA |
The date the allocation is expected to be delivered. |
status |
NA |
The current status of the allocation. Valid values are: 1 - Approved 2 - Completed 3 - Canceled Enum: [ 1, 2, 3 ] |
contextId |
NA |
number($int18) example: 14562 |
The identifier of a context associated to the allocation. |
contextValue |
NA |
string($text25) example: Season End |
A value associated to the context. |
distributionParentId |
NA |
string($text25) example: 19384731 |
A unique identifier of a parent allocation document. |
deliverySlotId |
NA |
number($int15) example: 134143 |
The identifier of the delivery slot of the expected delivery time. |
quantityExpected |
NA |
number($decimal(20,4)) example: 20 |
The quantity expected to be delivered. |
quantityReceived |
NA |
number($decimal(20,4)) example: 10 |
The quantity of the allocation that has been received. |
quantityDamaged |
NA |
The quantity of the allocation that has been received as damaged. |
Import Allocation
This API imports an allocation order approved in an external system through an asynchronous process. These allocations will be staged as a message for later processing in the MPS queue (DcsAllocation).
Request Parameters
The allocation details of the allocation to import.
Example Value
"distributionParentId": 19384731,
"contextId": 14562,
"details": [
"storeId": 5000,
"deliveryDate": "2025-01-02T13:18:14.085Z",
"quantity": 20
}Schema — AllocationImportIdo
Table 4-31 AllocationImportIdo — Object
allocationId |
Yes |
itemId |
Yes |
warehouseId |
Yes |
The unique identifier of the warehouse shipping the goods. |
NA |
number($int15) example: 19384731 |
contextId |
NA |
contextValue |
NA |
details |
Yes |
object |
A set of stores and quantities for delivery. |
Table 4-32 AllocationImportDetailIdo — Object
storeId |
Yes |
deliveryDate |
NA |
quantity |
Yes |
The quantity to be delivered. |
Complete Allocation
This section describes the Complete Allocation API. This API completes an allocation. This operation will return a forbidden response if the application is integrated with Oracle Merchandising.
Request Parameters
Table 4-33 Complete Allocation — Request Parameters
allocationId |
yes |
integer($int12) (path) |
The allocation identifier. |
Cancel Allocation
This section describes the Cancel Allocation API. This API cancels an allocation. This operation will return a forbidden response if the application is integrated with Oracle Merchandising.
Request Parameters
Table 4-34 Cancel Allocation — Request Parameters
allocationId |
yes |
REST Service: Batch
This service allows an external system to schedule an adhoc batch job for execution.
Service Base URL
Find Batch
This section describes the Find Batch API. The Find Batch API finds all the batch jobs available to schedule.
Responses
This section describes the responses of the Find Batch API.
Response Code: 200
Example Value
"jobName": "ShelfReplenishmentClosure_OpsJob",
"shortDescription": "opsJob.shelfReplenishmentClosure",
"longDescription": "opsJob.shelfReplenishmentClosure.desc",
"jobParamHint": "Transaction identifier",
"jobInterval": 9,
"batchType": 2,
"storeRelated": true,
"enabled": true,
"lastExecutionTime": "2025-03-04T14:46:45.738Z",
"updateDate": "2025-03-04T14:46:45.738Z"
Schema — BatchJobIdo
Table 4-35 BatchJobIdo —Object
| jobName | NA | string($text256) example: ShelfReplenishmentClosure_OpsJob | The job name used to execute the batch. |
| shortDescription | NA | string($text256) example: opsJob.shelfReplenishmentClosure | A short description of the batch job. |
| longDescription | NA | string($text2000) example: opsJob.shelfReplenishmentClosure.desc | A long description of the batch job. |
| jobParamHint | NA | string($text1000) example: Transaction identifier | Some hint text for what parameter values might be. |
| jobInterval | NA | integer($int2) example: 9 |
The execution interval of the batch job. Valid values are: 1 - 30 Minutes 2 - 1 Hour 3 - 2 Hours 4 - 3 Hours 5 - 4 Hours 6 - 6 Hours 7 - 8 Hours 8 - 12 Hours 9 - 24 Hours 10 - Monthly Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 ] |
| batchType | NA | integer($int4) example: 2 |
1 - Cleanup 2 - Operation 3 - System 4 - System Cleanup 5 - Data Seed 6 - Archive Enum: [ 1, 2, 3, 4, 5, 6 ] |
| storeRelated | NA | boolean example: true | True indicates the batch job requires store level processing. |
| enabled | NA | boolean example: true | True indicates the batch job is currently enabled and scheduled. This will not prevent batch execution via this service. |
| lastExecutionTime | NA | string($date-time) | The timestamp of the last execution of the batch job. |
| updateDate | NA | string($date-time) | The last time this record was updated. |
Successful
The media type appliction/json.
Execute Batch Job
Schedules the specific batch job for immediate execution. If parameter date and/or parameter identifier are entered, they are passed as parameters to the batch job identified by the batch name.
Request
There are no parameters.
The batch job requested.
Example Value
"batchName": "11111",
"storeId": 1234,
"parameterDate": "2025-03-27T09:32:56.299Z",
"parameterId": "123"
Schema - BatchRequestIdo
Table 4-36 BatchRequestIdo - Object
| batchName | NA | string($text120) example: 11111 | The name of the batch job to execute. |
| storeId | NA | number($int10) example: 1234 | A store identifier of a store to run the batch for. If included, it will run for this specific store. If not included, it will function for all stores (based on the individual batch functionality description). |
| parameterDate | NA | string($date-time) | A parameter date passed to the batch job (see adhoc batch documentation). |
| parameterId | NA | string($text120) example: 123 | A parameter identifier passed to the batch job (see adhoc batch documentation); |
REST Service: Differentiator
This service integrates differentiator foundation data. Asychronous differentiator integration is processed through staged messages and is controlled by the MPS Work Type: DcsDiff.
Service Base URL
Import Differentiator Type
Imports up to 1,000 differentiator types by writing a staged message and processing asynchronously through the MPS system. A forbidden response will occur if the application is integrated with MFCS or RMS.
Request
A list of differentiator types to import.
Schema - DifferentiatorTypeImportListIdo
Table 4-37 DifferentiatorTypeImportListIdo —Object
| differentiatorTypes | NA | object | Differentiator Types |
Table 4-38 DifferentiatorTypeImportIdo —Object
| differentiatorTypeId | NA | string($text10) example: S | The differentiator type identifier. |
| description | NA | string($text255) example: Size | The differentiator type description. |
Delete Differentiator Type
Deletes a differentiator type. The processing occurs asynchronously through a MPS staged message.
Request
Table 4-39 Delete Differentiator Type — Request Parameters
| differentiatorTypeId | Yes | string($text10)(path) |
Differentiator Type ID |
Imports up to 1,000 differentiators by writing a s staged message and processing asynchronously through the MPS system. A forbidden response will occur if the application is integrated with MFCS or RMS.
Request
The request body is applicattion/json.
A list of differentiators to import.
Example Value
"differentiatorTypes": [
"differentiatorId": "Color 00",
"differentiatorTypeId": "C",
"description": "Assorted Color Pack"
}Schema - DifferentiatorImportListIdo
Table 4-40 DifferentiatorImportListIdo - Object
| differentiatorTypes | NA | object | Differentiator types |
Table 4-41 DifferentiatorImportIdo - Object
| differentiatorId | NA | string($text10) example: Color 00 | The differentiator identifier. |
| differentiatorTypeId | NA | string($text10) example: C | The differentiator type identifier. |
| description | NA | string($text255) example: Assorted Color Pack | The differentiator description. |
Deletes a differentiator. The processing occurs asynchronously through a MPS staged message.
Request
Table 4-42 Delete Differentiator — Request Parameters
| differentiatorId | Yes | string($text10)(path) |
Differentiator ID |
REST Service: Finisher
This service integrates finisher and finisher item foundation data. Asychronous finisher integration is processed through staged messages and is controlled by the MPS Work Type: DcsPartner. Asynchronous finisher item integration is processed through staged messages and is controlled by the MPS Work Type: DcsItemLocation.
Service Base URL
Import Finisher
Imports a series of up to 500 finishers. A forbidden response will occurs if the application is integrated with MFCS or RMS.
Request
A list of finishers to import.
Example Value
"finishers": [
"finisherId": 1111111,
"name": "Egravers, Inc.",
"status": 1,
"currencyCode": "USD",
"languageCode": "en",
"contactName": "John Smith",
"contactFax": "123-456-7891",
"contactTelex": "123-456-7892",
"contactEmail": "address@service.com",
"manufacturerId": "4321",
"taxId": "67890",
"transferEntityId": "88888",
"paymentTerms": "30 Days",
"importCountryCode": "USD",
"importPrimary": false
Schema - FinisherImportListIdo
Table 4-43 FinisherImportListIdo - Object
| finishers | NA | object | finishers |
Table 4-44 FinisherImportIdo - Object
| finisherId | Yes | number($int10) example: 1111111 | The identifier of the finisher. |
| name | NA | string($text240) example: Egravers, Inc. | The name of the finisher. |
The current status of the finisher. Valid values are: 1 - Active 2 - Inactive Enum: [ 1, 2 ] |
| currencyCode | NA | string($text3) example: USD | ISO currency code assigned to the finisher. |
| countryCode | NA | string($text3) example: USA | ISO country code assigned to the finisher. |
| languageCode | NA | string($text6) example: en | ISO language code assigned to the finisher. |
| contactName | NA | string($text120) example: John Smith | Name of the finisher's representative contact. |
| contactPhone | NA | string($text20) example: 123-456-7890 | Phone number of the finisher's representative contact. |
| contactFax | NA | string($text20) example: 123-456-7891 | Fax number of the finisher's representative contact. |
| contactTelex | NA | string($text20) example: 123-456-7892 | Telex number of the finisher's representative contact. |
| contactEmail | NA | string($text100) example:address@service.com | Email address of the finisher's representative contact. |
| manufacturerId | NA | string($text18) example: 4321 | Manufacturer's identification number. |
| taxId | NA | string($text18) example: 67890 | Tax identifier number of the finisher. |
| transferEntityId | NA | string($text20) example: 88888 | Identifier of the transfer entity that the finisher belongs to. |
| paymentTerms | NA | string($text20) example: 30 Days | Payment terms for the partner. |
| importCountryCode | NA | string($text3) example: USD | The ISO country code of the import authority. |
| importPrimary | NA | boolean example: false | True indicates the code is the primary import authority of the import country. |
Delete Finisher
Deletes a finisher. A forbidden response will occur if the application is integrated with Oracle merchandising.
Request
Table 4-45 Delete Finisher — Request Parameter
finisherId |
Yes |
The finisher identifier. |
Import Finisher Item
Imports up to 5,000 finisher items. A forbidden response will occurs if the application is integrated with MFCS or RMS.
Request
Table 4-46 Import Finisher Item — Request Parameter
finisherId |
Yes |
A list of finisher items to import.
Schema - FinisherItemImportListIdo
Table 4-47 FinisherItemImportListIdo - Object
| items | NA | object | items |
Table 4-48 FinisherItemImportIdo - Object
| itemId | Yes | string($int25) example: 1111111 | The identifier of the item. |
| status | Yes | integer($int4) example: 1 |
The status of the item. Valid values are: 1 - Active 2 - Discontinued 3 - Inactive Enum: [ 1, 2, 3 ] |
Delete Finisher Item
Marks up to 5,000 finisher items for later deletion. A forbidden response will occurs if the application is integrated with MFCS or RMS.
Request
Table 4-49 Delete Finisher Item — Request Parameter
finisherId |
Yes |
A list of finisher items to remove.
REST Service: Customer Fulfillment Order
This service defines operations to manage customer fulfillment order information by integration with an external system. A fulfillment order the portion of a customer order to be fulfilled at a particular store. There can be many fulfillment orders for the same customer order.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Fulfillment Order
This section describes the Find Fulfillment Order API. This API finds up to a maximum of 3,0000 fulfillment order headers based on input search criteria.
Request Parameters
Table 4-51 Find Fulfillment Order — Request Parameters
fulfillmentOrderNumber |
NA |
Include only fulfillment orders with this external fulfillment order number. |
customerOrderNumber |
NA |
Include only fulfillment orders with this external customer order number. |
storeId |
NA |
Include only fulfillment orders for this store. |
orderType |
NA |
Include only fulfillment orders with this order type. Valid values are: 1 - Layaway 2 - Pickup and Delivery 3 - Customer Order 4 - Pending Purchase 5 - Special Order 6 - Web Order 7 - On Hold Available values : 1, 2, 3, 4, 5, 6, 7 |
status |
NA |
Include only fulfillment orders with this status. Value values are: 1 - New 2 - In Progress 3 - Completed 4 - Canceled 5 - Reverse Pick 6 - Pick In Progress 7 - Delivery In Progress 8 - Ready To Ship 9 - Ready For Pickup 10 - Picking Required 11 - Under Review Available values : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 |
releaseDateFrom |
NA |
Include only fulfillment orders with an release date on or after this date. |
releaseDateTo |
NA |
Include only fulfillment orders with an release date on or before this date. |
updateDateFrom |
NA |
Include only fulfillment orders with an update date on or after this date. |
updateDateTo |
NA |
Include only fulfillment orders with an update date on or before this date. |
itemId |
NA |
Include only fulfillment orders containing this item. |
Responses
This section describes the responses of the Find Fulfillment Order API.
Response Code: 200
Example Value
"orderId": 11111,
"customerOrderId": "222345666",
"fulfillmentOrderId": "76544400",
"storeId": 1234,
"orderType": 1,
"deliveryType": 1,
"status": 1,
"holdLocation": "Pickup Desk"
]Schema — FulfillmentOrderHeaderIdo
Table 4-52 FulfillmentOrderHeaderIdo— Object
orderId |
NA |
The unique identifier of the fulfillment order. |
customerOrderId |
NA |
string($text128) example: 222345666 |
The customer order number (from the external ordering system). |
fulfillmentOrderId |
NA |
string($text128) example: 76544400 |
The fulfillment order number (from the external ordering system). |
storeId |
NA |
The identifier of the store at which this order will be fulfilled. |
orderType |
NA |
The current status of the inventory adjustment. Valid values are: 1 - Layaway 2 - Pickup and Delivery 3 - Customer Order 4 - Pending Purchase 5 - Special Order 6 - Web Order 7 - On Hold Enum: [ 1, 2, 3, 4, 5, 6, 7 ] |
deliveryType |
NA |
The delivery type of the customer order. Valid values are: 1 - Customer Pickup 2 - Ship To Store Enum: [ 1, 2 ] |
status |
NA |
The current status of the customer order. Value values are: 1 - New 2 - In Progress 3 - Completed 4 - Canceled 5 - Reverse Pick 6 - Pick In Progress 7 - Delivery In Progress 8 - Ready To Ship 9 - Ready For Pickup 10 - Picking Required 11 - Under Review Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 ] |
holdLocation |
NA |
string($text128) example: Pickup Desk |
Descripton of where the order is being held for pickup or delivery. |
Read Fulfillment Order
This section describes the Read Fulfillment Order API. This API retrieves all the details about a fulfillment order.
Request Parameters
Table 4-53 Read Fulfillment Order — Request Parameters
orderId |
Yes |
number($int12) (path) |
The unique SIOCS internal identifier of the fulfillment order. |
Responses
This section describes the responses of the Read Fulfillment Order API.
Response Code: 200
Example Value
"orderId": 11111,
"storeId": 1234,
"customerId": "JXA244443",
"orderType": 1,
"deliveryType": 1,
"status": 1,
"orderDate": "2025-01-15T12:53:31.299Z",
"releaseDate": "2025-01-15T12:53:31.299Z",
"deliveryDate": "2025-01-15T12:53:31.299Z",
"carrierId": 4500674,
"carrierServiceId": 4500222,
"allowPartialDelivery": true,
"deliveryCharge": 12.5,
"deliveryChargeCurrency": "USD",
"holdLocation": "Pickup Desk",
"orderComments": "Customer will arrive by 2pm.",
"underReview": false,
"fullFlow": true,
"deliveryComments1": "First line.",
"deliveryComments2": "Second line.",
"deliveryComments3": "Third line.",
"customerArrivalDate": "2025-01-15T12:53:31.299Z",
"createDate": "2025-01-15T12:53:31.299Z",
"updateDate": "2025-01-15T12:53:31.299Z",
"lineItems": [
"lineId": 333444,
"substituteLineId": 5600043,
"lineNumber": 2,
"preferredUom": "KG",
"comments": "Item packaging slightly damaged.",
"quantityOrdered": 10,
"quantityPicked": 6,
"quantityDelivered": 2,
"quantityCanceled": 2,
"quantityReserved": 8,
"allowSubstitution": true,
"price": 4500674,
]Schema — FulfillmentOrderIdo
Table 4-54 FulfillmentOrderIdo— Object
orderId |
NA |
customerOrderId |
NA |
NA |
storeId |
NA |
customerId |
NA |
string($text14) example: JXA244443 |
The identifier of the customer for this fulfillment order. |
orderType |
NA |
The order type of the customer order. Valid values are: 1 - Layaway 2 - Pickup and Delivery 3 - Customer Order 4 - Pending Purchase 5 - Special Order 6 - Web Order 7 - On Hold Enum: [ 1, 2, 3, 4, 5, 6, 7 ] |
deliveryType |
NA |
status |
NA |
orderDate |
NA |
The date the customer placed the order. |
releaseDate |
NA |
The date in which the order must be shipped by the store or picked up in the store. |
deliveryDate |
NA |
The date in which the order is to be delivered. |
carrierId |
NA |
integer($int10) example: 4500674 |
The identifier of the carrier who will deliver the order. |
carrierServiceId |
NA |
integer($int10) example: 4500222 |
The identifier of the carrier service used for the delivery. |
allowPartialDelivery |
NA |
True indicates delivery can occur without all items being available and ready. False indicates all items must be shipped in the delivery. |
deliveryCharge |
NA |
number($decimal(12,4)) example: 12.5 |
The cost of shipment of this order. |
deliveryChargeCurrency |
NA |
The current of the delivery charge value. |
holdLocation |
NA |
orderComments |
NA |
string($text2000) example: Customer will arrive by 2pm. |
Comments entered in the external system for the order. |
underReview |
NA |
True indicates that the fulfilling system needs to delay either shipping or fulfilling the order until this flag is cleared. |
fullFlow |
NA |
True indicates this customer order can only be fulfilled using SOCS. If false, it must be fulfilled using JET mobile. |
deliveryComments1 |
NA |
string($text128) example: First line. |
The first line of delivery comments. |
deliveryComments2 |
NA |
string($text128) example: Second line. |
The second line of delivery comments. |
deliveryComments3 |
NA |
string($text128) example: Third line. |
The third line of delivery comments. |
customerArrivalDate |
NA |
The date that the customer arrived for pickup. |
createDate |
NA |
The date the fulfillment order was created in SIOCS. |
updateDate |
NA |
The date the fulfillment order was last updated in SIOCS. |
lineItems |
NA |
object |
A collection of line items on the fulfillment order |
Table 4-55 FulfillmentOrderLineItemIdo— Object
lineId |
NA |
number($int12) example: 333444 |
The unique identifier of the line item. |
itemId |
NA |
substituteLineId |
NA |
number($int12) example: 5600043 |
The identifier of a line item that this item has been substituted for. |
lineNumber |
NA |
number($int10) example: 2 |
The line number of the fulfillment order this item is fulfilling. |
preferredUom |
NA |
string($text4) example: KG |
The preferred unit of measure the item quantities should be processed or displayed in. |
comments |
NA |
string($text2000) example: Item packaging slightly damaged. |
Comments from an external system associated to this item. |
quantityOrdered |
NA |
number($decimal(12,4)) example: 10 |
The quantity ordered on this line item. |
quantityPicked |
NA |
number($decimal(12,4)) example: 6 |
The quantity picked for this line item. |
quantityDelivered |
NA |
number($decimal(12,4)) example: 2 |
The quantity delivered to date on this line item. |
quantityCanceled |
NA |
The quantity canceled on this line item. |
quantityReserved |
NA |
number($decimal(12,4)) example: 8 |
The quantity reserved for this line item. |
allowSubstitution |
NA |
True indicates a substitution is allowed for this item, false indicates it is not. |
price |
NA |
number($decimal(20,4)) example: 4500674 |
The amount of the price of the item. |
priceCurrency |
NA |
The currency of the price of the item. |
createDate |
NA |
The date the order item was created in SIOCS. |
updateDate |
NA |
The date the order item was last updated in SIOCS. |
Import Fulfillment Order
This section describes the Import Fulfillment Order API. This service operation takes a request to import a collection of new fulfillment orders. All orders passed in must be new orders. The sent will be processed asynchronously. A notification of accepted or rejected status will be published out after the processing is finished to a fulfillment order status service. Duplicate fulfillment orders in a single access will immediately return a bad request error. Duplicate fulfillment orders seperated into different requests will cause the second or later orders to be rejected at a later time with a duplicate order error.
Request Parameters
Table 4-56 Update Delivery - Request Parameters
| deliveryId | Yes | number($int12)(path) | The unique identifier of the fulfillment order delivery. |
Details about the fulfillment orders to import.
Example Value
"fulfillmentOrders": [
"storeId": 1234,
"deliveryType": 1,
"deliveryDate": "2025-01-15T13:25:05.331Z",
"carrierServiceId": 4500674,
"deliveryCharge": 4500674,
"lineItems": [
"lineNumber": 2,
"price": 4500674,
}Schema — FulfillmentOrderImportListIdo
Table 4-57 FulfillmentOrderImportListIdo — Object
fulfillmentOrders |
yes |
object |
A collection of fulfillment orders to import |
FulfillmentOrderImportIdo{Jump to path
Table 4-58 FulfillmentOrderImportIdo — Object
customerOrderId |
yes |
The customer order number (from the external ordering system). The combination of customer order number and fulfillment order number will determine if the order is treated a new or existing. |
NA |
The fulfillment order number (from the external ordering system). The combination of customer order number and fulfillment order number will determine if the order is treated a new or existing. |
storeId |
yes |
The identifier of the store at which this order will be fulfilled. This value is required but will be ignored if the order already exists. |
customerId |
yes |
The identifier of the customer for this fulfillment order. The value is required but will be ignored if the order already exists. |
deliveryType |
yes |
The delivery type of the fulfillment order. This value is required but will be ignored if the order already exists. Valid values are: 1 - Customer Pickup 2 - Ship To Store Enum: [ 1, 2 ] |
deliveryDate |
NA |
The date in which the order is to be delivered. This value will be ignored if the order already exists. |
carrierId |
NA |
The identifier of the carrier who will deliver the order. This value will be ignored if the order already exists. |
carrierServiceId |
NA |
The identifier of the carrier service used for the delivery. This value will be ignored if the order already exists. |
NA |
True indicates delivery can occur without all items being available and ready. False indicates all items must be shipped in the delivery. This value will be ignored if the order already exists. |
deliveryCharge |
NA |
number($decimal(12,4)) example: 4500674 |
The cost of shipment of this order. This value will be ignored if the order already exists. |
NA |
The currency of the delivery charge value. This value will be ignored if the order already exists. |
holdLocation |
NA |
Description of where the order is being held for pickup or delivery. |
orderComments |
NA |
lineItems |
yes |
object |
A collection of line items on the fulfillment order. |
Table 4-59 FulfillmentOrderImporLineItemtIdo — Object
itemId |
yes |
lineNumber |
NA |
preferredUom |
NA |
comments |
NA |
quantityOrdered |
yes |
The quantity ordered on this line itemm. |
allowSubstitution |
NA |
price |
NA |
priceCurrency |
NA |
Pickup Fulfillment Order
This section describes the Pickup Fulfillment Order API. This service will update an order to indicate a customer is arriving (or has arrived) to pickup the order.
Request Parameters
Details about the fulfillment order for pickup.
Example Value
"storeId": 1234,
"customerArrivalDate": "2025-01-15T14:20:01.431Z"
}Schema — FulfillmentOrderPickupIdo
Table 4-60 FulfillmentOrderPickupIdo — Object
customerOrderId |
Yes |
NA |
storeId |
Yes |
deliveryComments1 |
NA |
deliveryComments2 |
NA |
deliveryComments3 |
NA |
Yes |
Reject Fulfillment Order
This section describes the Reject Fulfillment Order API. This will cause the store to reject the fulfillment order specified notifying external systems that the fulfillment order has been rejected.
Request Parameters
Details about the fulfillment order to reject.
Schema — FulfillmentOrderRejectIdo
Table 4-61 FulfillmentOrderRejectIdo— Object
customerOrderId |
Yes |
NA |
storeId |
Yes |
Cancel Fulfillment Order
This section describes the Cancel Fulfillment Order API. This API will cancel all remaining ordered quantities on the fulfillment order.
Request Parameters
Details about the fulfillment order to cancel.
Schema — FulfillmentOrderCancelIdo
Table 4-62 FulfillmentOrderCancelIdo— Object
customerOrderId |
Yes |
NA |
storeId |
Yes |
Responses
Response Code: 200
Example Value
"storeId": 1234,
"lineItems": [
"lineNumber": 2,
"standardUom": "KG",
]Schema — FulfillmentOrderCancelStatusIdo
Table 4-63 FulfillmentOrderCancelStatusIdo— Object
customerOrderId |
NA |
NA |
storeId |
NA |
lineItems |
NA |
object |
A collection of line items with the quantities that were cancelled. |
Table 4-64 FulfillmentOrderCancelStatusItemIdo— Object
itemId |
NA |
lineNumber |
NA |
preferredUom |
NA |
standardUom |
NA |
The standard unit of measure for the item. |
quantityCanceled |
NA |
The quantity canceled on this line itemm. |
Cancel Fulfillment Order Quantities
This section describes the Cancel Fulfillment Order Quantities API. This API will cancel quantities on specific line items of a fulfillment order.
Request Parameters
Details about the fulfillment order items to cancel.
Example Value
"storeId": 1234,
"lineItems": [
"lineNumber": 2,
}Schema — FulfillmentOrderItemCancelIdo
Table 4-65 FulfillmentOrderItemCancelIdo— Object
customerOrderId |
Yes |
NA |
storeId |
Yes |
lineItems |
NA |
object |
Table 4-66 FulfillmentOrderItemCancelLineIdo— Object
itemId |
Yes |
lineNumber |
NA |
preferredUom |
NA |
standardUom |
NA |
quantityCanceled |
Yes |
Responses
This section describes the responses of the Cancel Fulfillment Order Quantities API.
Response Code: 200
Example Value
"storeId": 1234,
"lineItems": [
"lineNumber": 2,
Table 4-67 FulfillmentOrderCancelStatusIdo— Object
customerOrderId |
NA |
NA |
storeId |
NA |
lineItems |
NA |
object |
Table 4-68 FulfillmentOrderCancelStatusItemIdo— Object
itemId |
NA |
lineNumber |
NA |
preferredUom |
NA |
standardUom |
NA |
quantityCanceled |
NA |
REST Service: Fulfillment Order Delivery
Delivering of a customer order consists of collecting the items that have been picked and then getting them to the customer (shipment or pickup). This might be for a customer pickup or shipping them to the customer.This service integrations a fulfillment order delivery with an external application.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Delivery
Finds up to a maximum of 500 fulfillment order delivery headers based on input search criteria.
Request Parameters
Table 4-69 Find Delivery - Request Parameters
| storeId | NA | integer($int10) (query) | Include only customer deliveries from this store. |
| orderId | NA | number($int12) (query) | Include only customer deliveries for this SIOCS fulfillment order id. |
| externalDeliveryId | NA | string($text25) (query) | Included only customer deliveries with this external identifier. |
| status | NA | integer($int4) (query) |
Include only customer deliveries this status. Valid values are 1 - In Progress 2 - Submitted 3 - Completed 4 - Canceled Available values: 1, 2, 3, 4 |
| updateDateFrom | NA | string($date-time) (query) | Include only customer deliveries with an update date on or after this date. |
| updateDateTo | NA | string($date-time) (query) | Include only customer deliveries with an update date on or before this date. |
Responses
This section describes the responses of the Find Delivery API.
Response Code: 200
Example Value
"deliveryId": 11111,
"orderId": 11111,
"storeId": 1234,
"status": 1,
"submitDate": "2025-04-11T10:06:38.846Z",
"submitUser": "smith123",
"dispatchDate": "2025-04-11T10:06:38.846Z",
"dispatchUser": "smith123",
"createDate": "2025-04-11T10:06:38.846Z",
"createUser": "smith123",
"updateDate": "2025-04-11T10:06:38.846Z",
"updateUser": "smith123"
]Schema — FulfillmentOrderDeliveryHeaderIdo
Table 4-70 FulfillmentOrderDeliveryHeaderIdo— Object
| deliveryId | NA | number (int12) example 11111 | The unique identifier of the fulfillment order delivery. |
| orderId | NA | number (int12) example 11111 | The unique SIOCS identifier of the fulfillment order. |
| storeId | NA | number (int10) example 1234 | The identifier of the store at which this order will be fulfilled. |
| status | NA | integer (int4) example 1 |
The current status of the customer delivery. Valid values are: 1 - In Progress 2 – Submitted 3 – Completed 4 - Canceled Enum: 1,2,3, 4 |
| submitDate | NA | string (date-time) | The date the delivery was submitted. |
| submitUser | NA | string (text128) example: smith123 | The user that submitted the delivery. |
| dispatchDate | NA | string (date-time) | The date the delivery was dispatched. |
| dispatchUser | NA | string (text128) example: smith123 | The user that dispatched the delivery. |
| createDate | NA | string (date-time) | The date the delivery was created |
| createUser | NA | string (text128) example: smith123 | The user that created the delivery |
| updateDate | NA | string (date-time) | The date the delivery was updated. |
| updateUser | NA | string (text128) example: smith123 | The user that last updated the delivery. |
Create Delivery
Creatures a fulfillment order delivery from an order (and responds with the newly created delivery).
Request Parameters
The fulfillment order delivery to create.
Example Value
"orderId": 11111,
"carrierRole": 1,
"carrierId": 112233,
"carrierServiceId": 445566,
"alternateAddress": "PO Box 28, Apple Street, Nowhereville",
"alternateCarrierName": "Speedy Delivery",
"alternateCarrierAddress": "200 Box Street, Nowhereville",
"motiveId": 874297,
"trackingNumber": "ANV343255",
"cartonSizeId": 9375834,
"cartonWeight": 12.1,
"cartonWeightUom": "KG",
"requestedPickupDate": "2025-04-11T10:16:03.960Z",
"lineItems": [
"orderLineId": 11111,
"quantity": 11111,
"uins": [
11111,
22222
}Schema —FulfillmentOrderDeliveryCreateIdo
Table 4-71 FulfillmentOrderDeliveryCreateIdo — Object
| orderId | Yes | number (int12) example: 11111 | The unique SIOCS identifier of the fulfillment |
| carrierRole | NA | number (int2) example: 1 |
The type of carrier. Valid values are: 1 – Sender 2 – Received 3 - Third Party Enum: 1, 2, 3 |
| carrierId | NA | number (int10) example:112233 | The unique identifier of the carrier. |
| carrierServiceId | NA | number (int10) example:445566 | The unique identifier of the carrier service being used. |
| alternateAddress | NA | string (text2000) example: PO Box 28, Apple Street, Nowhereville |
An alternate destination address for the delivery.
| alternateCarrierName | NA | string (text240) example: Speedy Delivery |
Name of the carrier responsible for the delivery.
| alternateCarrierAddress | NA | string (text2000) example: 200 Box Street, Nowhereville | Address of the carrier responsible for the delivery. |
| motiveId | NA | number (int18) example:874297 | The unique identifier of the motive. |
| trackingNumber | NA | string (text128) example: ANV343255 | A tracking number for the shipment |
| cartonSizeId | NA | number (int12) example: 9375834 | The unique identifier of a carton size (dimension) for that store. |
| cartonWeight | NA | number (decimal(12,4)) example: 12.1 | The weight of the shipment. |
| cartonWeightUom | NA | string (text4) example KG | The unit of measure of the shipment weight. |
| requestedPickupDate | NA | string (date-time) | The date that this delivery will be picked up |
| lineItems | Yes | object | A collection of up to 500 line items on the fulfillment order delivery. |
Table 4-72 FulfillmentOrderDeliveryCreateItemIdo - Object
| orderLineId | Yes | number($int12) example: 11111 | The unique identifier of the fulfillment order line item being delivered. |
| quantity | Yes | number($decimal(20,4)) example: 11111 | The quantity being delivered. |
| uins | NA | string ($text128) example: List [ 11111, 22222 ] | A list of uins (must match the quantity) if serial numbers are being delivered. |
Responses
This section describes the responses of the Create Delivery API.
Response Code: 200
Example Value
"orderId": 11111,
"storeId": 1234,
"status": 1,
"billOfLadingId": 573804,
"additionalReference": "XDER78393",
"submitDate": "2025-04-11T15:39:51.433Z",
"dispatchDate": "2025-04-11T15:39:51.433Z",
"createDate": "2025-04-11T15:39:51.433Z",
"updateDate": "2025-04-11T15:39:51.433Z",
"updateUser": "smith123",
"lineItems": [
"lineId": 333444,
"orderLineId": 4563,
"quantity": 10,
"caseSize": 6
]Schema - FullfillmentOrderDeliveryIdo
Table 4-73 FulfillmentOrderDeliveryIdo - Object
| deliveryId | NA | number($int12) example: 11111 | The unique identifier of the fulfillment order delivery. |
| orderId | NA | number($int12) example: 11111 | The unique SIOCS identifier of the fulfillment order. |
| storeId | NA | number($int10) example: 1234 | The identifier of the store at which this order will be fulfilled. |
The current status of the customer delivery. Valid values are 1 - In Progress 2 - Submitted 3 - Completed 4 - Canceled Enum: [ 1, 2, 3, 4 ] |
| billOfLadingId | NA | number($int12) example: 573804 | The shipment bill of lading identifier. |
| additionalReference | NA | string($text128) example: XDER78393 | A government reference identifier from an external system. |
| submitDate | NA | string($date-time) | The date the delivery was submitted. |
| submitUser | NA | string($text128) example: smith123 | The user that submitted the delivery. |
| dispatchDate | NA | string($date-time) | The date the delivery was dispatched. |
| dispatchUser | NA | string($text128) example: smith123 | The user that dispatched the delivery. |
| createDate | NA | string($date-time) | The date the delivery was created. |
| createUser | NA | string($text128) example: smith123 | The user that created the delivery. |
| updateDate | NA | string($date-time) | The date the delivery was updated. |
| updateUser | NA | string($text128) example: smith123 | The user that last updated the delivery. |
| lineItems | NA | object | A collection of line items on the fulfillment order delivery. |
Table 4-74 FulfillmentOrderDeliveryLineItemIdo — Object
| lineId | NA | number($int12)example: 333444 | The unique identifier of the line item. |
| orderLineId | NA | number($int12)example: 4563 | The unique identifier of the fulfillment order line item this delivery item is for. |
| quantity | NA | number($decimal(12,4))example: 10 | The quantity to be delivered. |
| caseSize | NA | number($decimal(10,2))example: 6 | The case size of this line item. |
Read Delivery
This API retrieves all the details about a fulfillment order delivery.
Request Parameters
Table 4-75 Read Delivery — Request Parameters
deliveryId |
Yes |
Responses
This section describes the responses of the Read Delivery API.
Response Code: 200
For details about the schema, see the Schema - FullfillmentOrderDeliveryIdo section.
Example Value
"orderId": 11111,
"storeId": 1234,
"status": 1,
"submitDate": "2025-04-14T06:44:40.769Z",
"dispatchDate": "2025-04-14T06:44:40.769Z",
"createDate": "2025-04-14T06:44:40.769Z",
"updateDate": "2025-04-14T06:44:40.769Z",
"lineItems": [
"lineId": 333444,
"quantity": 10,
"caseSize": 6
]Update Delivery
This section describes the Update Delivery API. This API updates the details of an order delivery that is currently "In Progress". Detailed information left blank using this service will remove this information from the delivery.
Request Parameters
Table 4-76 Update Delivery — Request Parameters
The fulfillment order delivery to update.
Example Value
"carrierRole": 1,
"motiveId": 874297,
"requestedPickupDate": "2025-04-14T08:49:44.110Z",
"lineItems": [
"quantity": 2,
"uins": [
11111,
22222
}Schema — FulfillmentOrderDeliveryUpdateIdo
Table 4-77 FulfillmentOrderDeliveryUpdateIdo - Object
| carrierRole | NA | number($int2) example: 1 |
The type of carrier. Valid values are: 1 - Sender 2 - Received 3 - Third Party Enum: [ 1, 2, 3 ] |
| carrierId | NA | number($int10) example: 112233 | The unique identifier of the carrier. |
| carrierServiceId | NA | number($int10) example: 445566 | The unique identifier of the carrier service being used. |
| alternateAddress | NA | string($text2000) example: PO Box 28, Apple Street, Nowhereville | An alternate destination address for the delivery. |
| alternateCarrierName | NA | string($text240) example: Speedy Delivery | Name of the carrier responsible for the delivery. |
| alternateCarrierAddress | NA | string($text2000) example: 200 Box Street, Nowhereville | Address of the carrier responsible for the delivery. |
| motiveId | NA | number($int18) example: 874297 | The unique identifier of the motive. |
| trackingNumber | NA | string($text128) example: ANV343255 | A tracking number for the shipment. |
| cartonSizeId | NA | number($int12) example: 9375834 | The unique identifier of a carton size (dimension) for that store. |
| cartonWeight | NA | number($decimal(12,4)) example: 12.1 | The weight of the shipment. |
| cartonWeightUom | NA | string($text4) example: KG | The unit of measure of the shipment weight. |
| requestedPickupDate | NA | string($date-time) | The date that this delivery will be picked up. |
| lineItems | NA | object | A collection of up to 500 line items on the fulfillment order delivery. |
Table 4-78 FulfillmentOrderDeliveryUpdateItemIdo - Object
| quantity | Yes | number($decimal(20,4)) example: 2 | The quantity being delivered. If the quantity is reduced to 0, this item will be removed from the delivery. |
| uins | NA | string($text128) example: List [ 11111, 22222 ] | A list of uins (must match the quantity) if serial numbers are being delivered. |
Submit Delivery
This section describes the Submit Delivery API.This API will submit the delivery and set it to Submitted status. Submit is only available when store configured for Dispatch Validate to Ship Submit. Submitting will set the delivery to a Submitted status and not allow for edits, since there are no updates to inventory at this point. The only step possible will be to cancel Submit or Dispatch.
Request Parameters
Table 4-79 Submit Delivery — Request Parameters
Cancel Submit Delivery
This section describes the Cancel Submit Delivery API. This API cancels a fulfillment order delivery submission.
Request Parameters
Table 4-80 Cancel Submit Delivery — Request Parameters
Dispatch Delivery
This section describes the Dispatch Delivery API. Dispatch will check if Allow Partial Indicator is set to No, it will validate that the entire order is being delivered together. If not, the system will restrict the user from dispatching. Those users with certain privileges will be able to override this and it will be a warning. If Allow Partial Indicator is set to Yes, the customer order can be delivered partially. If system parameter 'Customer Order Fulfillment Restriction' is set to 'Line Controlled' and Allow Partial Indicator is set to Yes, if an item is getting delivered then it has to be delivered fully. Partial delivery of an item is not allowed. Also, if the store parameter Manifest Customer Order Deliveries is set to No and system parameter Tracking ID Required is set to Yes, the system should check if the Tracking ID has been captured or not, if not captured, an error message will be displayed. Upon dispatch of the delivery the delivery will move to Completed status, and user returns to the Delivery List screen. The stock on hand and customer order reserved quantities will be decremented by the delivered quantities. The customer order fulfillment order will have the delivered and remaining quantity updated. If the entire customer order has been fulfilled, meaning there is no remaining quantity, the customer order will be set to Completed status. If the system is enabled to obtain Fiscal Doc ID/E-way bill ID as part of the shipping process, the delivery cannot be dispatched until the Fiscal Doc ID/E-way bill ID is available. The exception is when the user has ‘Allow dispatch without Fiscal Document ID’ security permission.
Request Parameters
Table 4-81 Dispatch Delivery — Request Parameters
REST Service: Fulfillment Order Pick
The Picking process is a formal process of the system telling the user what items need to be picked and the user going out, physically picking the items, and setting them aside. Once the items are set aside, they will then be used during the fulfillment process for shipping to, or pick up by the customer.The service integrates a fulfillment order pick with an external application.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Pick
Finds up to a maximum of 3,0000 fulfillment order picks based on input search criteria.
Request Parameters
Table 4-82 Find Pick — Request Parameters
| Name | Required | Data Type/Example | Description |
| storeId | NA | integer($int10) (query) | Include only order picks for this store. |
| orderId | NA | integer($int12) (query) | Include only order picks with this fulfillment order identifier. |
| itemId | NA | string($text25) (query) | Include only order picks orders containing this item. |
1 - New 2 - In Progress 3 - Completed 4 - Canceled 99 - Active Available values : 1, 2, 3, 4, 99 |
| createDateFrom | NA | string($date-time) (query) | Include only order picks with an create date on or after this date. |
| createDateTo | NA | string($date-time) (query) | Include only order picks with an create date on or before this date. |
Responses
This section describes the responses of the Find Pick API.
Response Code: 200
The request has been successful.
The media type is application/json.
Example Value
"orderId": 11111,
"storeId": 1234,
"status": 1,
]Schema — FulfillmentOrderPickHeaderIdo
Table 4-83 FulfillmentOrderPickHeaderIdo - Object
| Element Name | Required | Data Type/Example | Description |
| pickId | NA | number($int12) example: 11111 | The unique identifier of the fulfillment order pick. |
| storeId | NA | number($int10) example: 1234 | The store this pick will occur at. |
| type | NA | integer($int4) example: 1 |
The type of pick. Valid values are: 1 - Order 2 - Bin Enum: [ 1, 2 ] |
The current status of the order pick. Valid values are: 1 - New 2 - In Progress 3 - Completed 4 - Canceled Enum: [ 1, 2, 3, 4] |
| productBasketId | NA | integer($int12) example: 488552 | The identifier of the product basket associated to the pick. |
| createDate | NA | string($date-time) | The date the order pick was created. |
| createUser | NA | string($text128) example: smith123 | The user that created the order pick. |
| completeDate | NA | string($date-time) | The date the order pick was completed. |
| completeUser | NA | string($text128) example: smith123 | The user the completed the order pick. |
Read Pick
This API retrieves all the details about a fulfillment order pick.
Request Parameters
Table 4-84 Read Pick - Request Parameters
| pickId | Yes | number($int12) (path) | The unique identifier of the fulfillment order pick. |
Responses
This section describes the responses of the Read Pick API.
Response Code: 200
Example Value
"pickId": 11111,
"storeId": 5000,
"type": 1,
"status": 1,
"productBasketId": 488552,
"createDate": "2025-04-14T12:15:59.708Z",
"completeDate": "2025-04-14T12:15:59.708Z",
"completeUser": "smith123",
"lineItems": [
"lineId": 333444,
"orderId": 100,
"orderLineId": 200,
"caseSize": 10,
"quantitySuggested": 2,
"ordinal": 6
]Schema — FulfillmentOrderPickIdo
Table 4-85 FulfillmentOrderPickIdo - Object
| pickId | NA | number($int12) example: 11111 | The unique identifier of the fulfillment order. |
| storeId | NA | number($int10) example: 5000 | The store this pick will occur at. |
The type of pick. Valid values are: 1 - Order 2 - Bin Enum: Array [ 2 ] |
The current status of the order pick. Valid values are: 1 - New 2 - In Progress 3 - Completed 4 - Canceled Enum: [ 1, 2, 3, 4 ] |
| lineItems | NA | object | A collection of line items on the fulfillment order pick. |
Table 4-86 FulfillmentOrderLineItemPickIdo - Object
| lineId | NA | number($int12) example: 333444 | The unique identifier of the line item. |
| itemId | NA | string($text25) example: 55001234 | The SKU level item identifier. |
| orderId | NA | number($int12) example: 100 | The unique SIOCS identifier of the fulfillment order. |
| orderLineId | NA | number($int12) example: 200 | The unique SIOCS identifier of the fulfillment order line item. |
| substituteLineId | NA | number($int12) example: 5600043 | The identifier of another pick line item for which this item is a substitute for. |
| preferredUom | NA | string($text4) example: KG | The preferred unit of measure in which to pick. |
| caseSize | number($decimal(10,2)) example: 10 | The case of this item pick. | |
| quantitySuggested | number($decimal(12,4)) example: 2 | The suggested quantity to pick for this item. | |
| quantityPicked | number($decimal(12,4)) example: 6 | The quantity picked for this line item. | |
| ordinal | integer($int4) example: 6 | The order in which this line should be picked. |
Update Pick
This section describes the Update Pick API. This API updates the fulfillment order pick.
Request Parameters
Table 4-87 Update Pick— Request Parameters
| pickId | Yes | number($int12)(path) | The unique identifier of the fulfillment order pick. |
Details to update the fulfillment order pick from.
Example Value
"lineItems": [
"lineId": 333444,
"quantity": 2,
"substituteItems": [
"itemId": 333444,
"quantity": 2
}Schema — FulfillmentOrderPickUpdateIdo
Table 4-88 FulfillmentOrderPickUpdateIdo - Object
| lineItems | Yes | object | A collection of line items on the fulfillment order pick. |
Table 4-89 FulfillmentOrderPickUpdateItemIdo - Object
| lineId | Yes | number($int12) example: 333444 | The unique identifier of the line item. |
| quantity | Yes | number($decimal(12,4)) example: 2 | The quantity picked for this item. |
| substituteItems | NA | object | A collection of line items on the fulfillment order pick. |
Table 4-90 FulfillmentOrderPickUpdateSubstituteIdo - Object
| itemId | Yes | number($int12) example: 333444 | The SKU number of the item. |
Confirm Pick
This section describes the Confirm Pick API. This API confirms the fulfillment order pick.
Request Parameters
Table 4-91 Confirm Pick — Request Parameters
Cancel Pick
This section describes the Cancel Pick API. This API cancels the fulfillment order pick.
Request Parameters
Table 4-92 Cancel Pick — Request Parameters
Create Pick By Order
Creates new fulfillment order pick within the system by order information. It returns the pick that it created.
Request Parameters
There are no request parameters.
The request body is application/json.
Details to generate the fulfillment order pick from.
Schema - FulfillmentOrderPickByOrderCreateIdo
Table 4-93 FulfillmentOrderPickByOrderCreateIdo - Object
| orderId | Yes | number($int12) example: 11111 | The unique SIOCS identifier of the fulfillment order. |
| productBasketId | NA | integer($int12) example: 488552 | The identifier of the product basket to generate the pick from. |
Responses
This section describes the responses of the Create Pick By Order API.
Response Code: 200
For details about the schema, see the Schema — FulfillmentOrderPickIdo section.
Example Value
"pickId": 11111,
"storeId": 5000,
"type": 1,
"status": 1,
"createDate": "2025-04-14T13:09:21.228Z",
"completeDate": "2025-04-14T13:09:21.228Z",
"lineItems": [
"lineId": 333444,
"orderId": 100,
"orderLineId": 200,
"caseSize": 10,
"ordinal": 6
]Create Pick By Bin
Creates new fulfillment order pick within the system by bin information. It returns the pick that it created.
Request Parameters
Example Value
"storeId": 5000,
"numberOfBins": 2,
"binIds": [
333000,
444001
}Schema - FulfillmentOrderPickByBinCreateIdo
Table 4-94 FulfillmentOrderPickByBinCreateIdo - Object
| storeId | Yes | number($int10) example: 5000 | The unique identifier of the store. |
| numberOfBins | NA | integer($int3) example: 2 | The number of bins being picked. This is required if store generation bin option is system generation. |
| binIds | NA | string($text128) example: List [ 333000, 444001 ] | If manual bin generation is set for the store, this must contain all the bin identifiers. This is required when store generation bin option is manual generation. |
Responses
This section describes the responses of the Create Pick By Bin API.
Response Code: 200
Example Value
"pickId": 11111,
"storeId": 5000,
"type": 1,
"status": 1,
"createDate": "2025-04-14T13:48:55.269Z",
"completeDate": "2025-04-14T13:48:55.269Z",
"lineItems": [
"lineId": 333444,
"orderId": 100,
"orderLineId": 200,
"caseSize": 10,
"ordinal": 6
]REST Service: Fulfillment Order Reverse Pick
Canceling of customer orders can come in from an external system, such as an Order Management System. When this happens, a reverse pick list will be generated. If there are items that physically need to be un-picked, the user will action the reverse pick list which will then take the items that were canceled and move the picked quantities back to the appropriate area in the store. If the items that are being canceled are not picked, then the system generated reverse pick will just be created in a Completed status with no action required through the application.A system-generated reverse pick may get created if the user rejects an open customer order.A manual reverse pick might also be necessary. This happens when the user discovers that something which was picked has to be unpicked, maybe because it has been damaged. The manual reverse pick will reverse the pick quantities.This service integrates a fulfillment order reverse pick with an external application.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Reverse Pick
Finds up to a maximum of 500 order reverse pick headers based on input search criteria.
Request Parameters
Table 4-95 Find Reverse Pick — Request Parameters
| storeId | NA | integer($int10) (query) | Include only reverse picks for this store. |
Include only reverse picks orders with this status. Valid values are: 1 - New 2 - In Progress 3 - Completed 4 - Canceled Available values : 1, 2, 3, 4 |
| orderId | NA | integer($int12) (query) | Include only reverse picks for this fulfillment order identifier. |
| itemId | NA | string($text25) (query) | Include only reverse picks that contain this item. |
| createDateFrom | NA | string($date-time) (query) | Include only reverse picks with a create date on or after this date. |
| createDateTo | NA | string($date-time) (query) | Include only reverse picks with a create date on or before this date. |
Responses
This section describes the responses of the Find Reverse Pick API.
Response Code: 200
Example Value
"reversePickId": 1234,
"storeId": 5000,
"orderId": 11111,
"status": 1,
"createDate": "2025-04-14T14:06:42.816Z"
]Schema — FulfillmentOrderReversePickHeaderIdo
Table 4-96 [FulfillmentOrderReversePickHeaderIdo - Object
| reversePickId | NA | number($int12) example: 1234 | The identifier of the reverse pick. |
| storeId | NA | number($int10) example: 5000 | The identifier of the store for this reverse pick. |
| orderId | NA | number($int12) example: 11111 | The unique identifier of the fulfillment order the reverse pick is for. |
| status | NA | integer($int4) example: 1 |
The current status of the reverse pick. Valid values are: 1 - New 2 - In Progress 3 - Completed 4 - Canceled Enum: [ 1, 2, 3, 4 ]
| createUser | NA | string($text128) example: smith123 | The user that created the reverse pick. |
| createDate | NA | string($date-time) | The date the reverse pick was created in SIOCS. |
Create Reverse Pick
This section describes the Create Reverse Pick API. This API will create a new reverse pick within the system. It responds with the reverse pick that it created.
Request Parameters
Details about the reverse pick to create.
Schema — FulfillmentOrderReversePickCreateIdo
Table 4-97 FulfillmentOrderReversePickCreatedo - Object
| orderID | Yes | number($int12) example: 222345666 | The unique SIOCS identifier of the fulfillment order to be reverse picked. |
| lineItems | Yes | object | A collection of line items to reverse pick. |
Table 4-98 FulfillmentOrderReversePickCreateItemIdo - Object
| orderLineId | Yes | number($int12) example: 55001234 | The unique identifier of the fulfillment order line item to be reverse picked. |
| quantity | Yes | number($decimal(12,4)) example: 2 | The quantity to reverse pick. |
Responses
This section describes the responses of the Create Reverse Pick API.
Response Code: 200
Example Value
"storeId": 5000,
"orderId": 11111,
"status": 1,
"createDate": "2025-04-15T08:14:57.283Z",
"lineItems": [
"lineId": 333444,
"orderLineId": 55001234,
"caseSize": 10,
"quantitySuggested": 6,
"quantityReversePick": 2
Schema — FulfillmentOrderReversePickIdo
Table 4-99 FulfillmentOrderReversePickIdo - Object
The current status of the reverse pick. Valid values are: 1 - New 2 - In Progress 3 - Completed 4 - Canceled Enum: [ 1, 2, 3, 4 |
| lineItems | NA | object | A collection of line items on the fulfillment order reverse pick. |
Table 4-100 FulfillmentOrderReversePickLineItemIdo - Object
| orderLineId | NA | number($int12) example: 55001234 | The unique identifier of the fulfillment order line item to be reverse picked. |
| caseSize | NA | number($decimal(10,2)) example: 10 | The case size of this item reverse pick. |
| quantitySuggested | NA | number($decimal(12,4)) example: 6 | The system suggested reverse pick quantity. |
| quantityReversePick | NA | number($decimal(12,4)) example: 2 | The actual quantity that was reverse picked. |
Read Reverse Pick
This API retrieves all the details about a fulfillment order reverse pick.
Request Parameters
Table 4-101 Read Reverse Pick — Request Parameters
| reversePickId | Yes | number($int12) (path) | The unique identifier of the fulfillment order reverse pick. |
Responses
This section describes the responses of the Read Reverse Pick API.
Response Code: 200
For details about the schema, see the Schema - FulfillmentOrderReversePickIdo section.
Update Reverse Pick
This section describes the Update Reverse Pick API. This API updates the fulfillment order reverse pick.
Request Parameters
Table 4-102 Update Reverse Pick— Request Parameters
| reversePickId | Yes | number($int12)(path) | The unique identifier of the fulfillment order reverse pick. |
Details to update the fulfillment order reverse pick from.
Schema — FulfillmentOrderReversePickUpdateIdo
Table 4-103 FulfillmentOrderReversePickUpdateIdo - Object
| lineItems | Yes | object | A collection of line items to update. |
Table 4-104 FulfillmentOrderReversePickUpdateItemIdo - Object
Confirm Reverse Pick
This section describes the Confirm Reverse Pick API. This API confirms the fulfillment order reverse pick.
Request Parameters
Table 4-105 Confirm Pick— Request Parameters
Cancel Reverse Pick
This section describes the Cancel Reverse Pick API. This API cancels the fulfillment order reverse pick.
Request Parameters
Table 4-106 Cancel Reverse Pick— Request Parameters
REST Service: Inventory Adjustment
Inventory Adjustments allow a user to change the number of units in stock or mark them as non-sellable due to damage. Reason codes are defined on the desktop. When creating a reason code, a disposition is assigned to the reason code and it defines how the stock will be moved. So, adjustments are made to different buckets depending on the reason code's disposition. For example, a reason code of Stock - In has a disposition of + Stock on Hand which moves inventory from Out of the store to Available inventory where as, a Reason if Damaged - Hold has a disposition of + Unavailable that moves inventory from Available to Unavailable. See Reason Codes REST service for the ability to retrieve reason code. The service defines operations to manage inventory adjustment information by integration with an external system.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Inventory Adjustment
This section describes the Find Inventory Adjustment API. This API finds up to a maximum of 10,000 inventory adjustments headers based on input search criteria. No items or detailed information is returned via this search.
Request
Table 4-107 Find Inventory Adjustment — Request Parameters
referenceId |
NA |
number ($int12) (query) |
Include only records with this reference identifier. |
status |
NA |
integer ($int4) (query) |
Include only records with this inventory adjustment status. Valid values are: 1 - In Progress 2 - Completed 3 - Canceled Available values : 1, 2, 3 --123 |
adjustmentDateFrom |
NA |
string ($date-time) (query) |
Include only records with an adjustment date on or after this date. |
adjustmentDateTo |
NA |
Include only records with an adjustment date on or before this date. |
updateDateFrom |
NA |
Include only records with an update date on or after this date. |
updateDateTo |
NA |
Include only records with an update date on or before this date. |
itemId |
NA |
string ($text25) (query) |
Include only records of adjustments containing this item. |
reasonId |
NA |
Include only records of adjustments containing this reason. |
Responses
This section describes responses of the Find Inventory Adjustment API.
Response Code: 200
The response has been successful.
Example Value
"adjustmentId": 11111,
"storeId": 1234,
"referenceId": 7890,
"externalId": "AB87656",
"adjustmentDate": "2024-09-11T13:30:40.820Z",
"status": 1,
"createDate": "2024-09-11T13:30:40.820Z",
"updateDate": "2024-09-11T13:30:40.820Z",
"approveDate": "2024-09-11T13:30:40.820Z"
]Schema — InventoryAdjustmentHeaderIdo
This section describes the InventoryAdjustmentHeaderIdo schema.
Table 4-108 InventoryAdjustmentHeaderIdo — Object
adjustmentId |
NA |
The unique identifier of the inventory adjustment. |
storeId |
NA |
The store identifier of the inventory adjustment. |
referenceId |
NA |
number($int12) example: 7890 |
Identifier of original adjustment it was copied from. |
externalId |
NA |
string($text120) example: AB87656 |
A unique identifier of the adjustment in an external system. |
adjustmentDate |
NA |
The timestamp the inventory if officially considered to have been adjusted. |
status |
NA |
The current status of the inventory adjustment. Valid values are 1 - In Progress 2 - Completed 3 - Canceled Enum: [ 1, 2, 3 ] |
createDate |
NA |
The date the adjustment was created in EICS. |
updateDate |
NA |
The date the adjustment was lasted updated in EICS. |
approveDate |
NA |
The date the adjustment was approved in EICS. |
Create Inventory Adjustment
This section describes the Create Inventory Adjustment API. This API creates a new manual inventory whose status will be "In Progress". If more than 5,000 items are included, an error response will be returned. When adding items to the adjustment a reason code with a disposition associated to it determines stock movement of the item.
Request
The inventory adjustment to create.
Example Value
"storeId": 1234,
"externalUser": "AB87656",
"adjustmentDate": "2024-09-12T13:07:55.023Z",
"comments": "This is a comment.",
"lineItems": [
"itemId": "55001234",
"reasonId": 5678,
"caseSize": 5,
"quantity": 2,
"uins": [
111222333,
444555666
Schema — InventoryAdjustmentCreateIdo
Table 4-109 InventoryAdjustmentCreateIdo — Object
storeId |
Yes |
referenceId |
NA |
externalId |
NA |
string($text128) example: AB87656 |
externalUser |
NA |
A non-EICS user that created the inventory adjustment in an external system. |
adjustmentDate |
NA |
The timestamp the inventory if officially considered to have been adjusted. If left blank, it will default to the creation date of the record. |
comments |
NA |
string($text2000) example: This is a comment. |
Comments associated to the adjustment. Comments will be trimmed down to 2000 characters if the entry is larger. |
lineItems |
Yes |
object |
A collection of line items attached to the adjustment. |
Table 4-110 InventoryAdjustmentCreateLineItemIdo — Object
itemId |
Yes |
reasonId |
Yes |
number($int12) example: 5678 |
The unique identifier of the reason code associated to the adjustment. |
caseSize |
NA |
number($decimal10,2) example: 5 |
quantity |
Yes |
number($decimal20,4) example: 2 |
The quantity of this line item. For UINS, the quantity must match the number of UINs. |
uins |
NA |
string($text128) example: List [ 111222333, 444555666 ] |
The UINs to attach to this line item. |
Read Inventory Adjustment
The Read Inventory Adjustment API retrieves all the details about an inventory adjustment.
Request
Table 4-112 Read Inventory Adjustment — Request Parameters
adjustmentId |
Yes |
Responses
This section describes the responses of the Read Inventory Adjustment API.
Response Code: 200
Example Value
"storeId": 1234,
"adjustmentDate": "2024-09-17T13:47:31.101Z",
"status": 1,
"createDate": "2024-09-17T13:47:31.101Z",
"createUser": "userAbc",
"updateDate": "2024-09-17T13:47:31.101Z",
"updateUser": "userAbc",
"approveDate": "2024-09-17T13:47:31.101Z",
"approveUser": "userAbc",
"externalCreateUser": "userAbc",
"externalUpdateUser": "userAbc",
"lineItems": [
"lineId": 1234,
"reasonId": 5678,
"caseSize": 5,
"quantity": 2,
"uins": [
111222333,
444555666
]Schema — InventoryAdjustmentIdo
This section describes the InventoryAdjustmentIdo schema.
Table 4-113 InventoryAdjustmentIdo — Object
adjustmentId |
NA |
storeId |
NA |
referenceId |
NA |
externalId |
NA |
adjustmentDate |
NA |
status |
NA |
The current status of the inventory adjustment. lid values are: 1 - In Progress 2 – Completed 3 – Canceled Enum: [ 1, 2, 3 ] |
comments |
NA |
Comments associated to the adjustment. |
createDate |
NA |
createUser |
NA |
string($text128) example: userAbc |
The user that created the adjustment in EICS. |
updateDate |
NA |
updateUser |
NA |
The user that last updated the adjustment in EICS. |
approveDate |
NA |
approveUser |
NA |
The user that approved the adjustment in EICS. |
externalCreateUser |
NA |
A non-EICS user that created the adjustment in an external system. |
externalUpdateUser |
NA |
A non-EICS user that last updated the adjustment in an external system. |
lineItems |
NA |
object |
line items |
Table 4-114 InventoryAdjustmentLineItemIdo — Object
lineId |
NA |
itemId |
NA |
reasonId |
NA |
caseSize |
NA |
quantity |
NA |
The quantity of this line item. |
uins |
NA |
The UINs associated to this line item. |
Update Inventory Adjustment
The Update Inventory Adjustment API updates the details of an inventory adjustment that is currently "In Progress".
Request
The inventory adjustment to update.
Table 4-115 Update Inventory Adjustment — Request Parameters
adjustmentId |
Yes |
Example Value
"adjustmentDate": "2024-09-18T08:36:13.027Z",
"lineItems": [
"reasonId": 5678,
"caseSize": 5,
"quantity": 2,
"uins": [
111222333,
444555666
}Schema — InventoryAdjustmentUpdateIdo
This section describes the InventoryAdjustmentUpdateIdo schema.
Table 4-116 InventoryAdjustementUpdateIdo — Object
referenceId |
NA |
externalUser |
NA |
adjustmentDate |
NA |
comments |
NA |
Comments associated to the adjustment. These comments will replace any previous comments Comments will be trimmed down to 2000 characters if the entry is larger. |
lineItems |
Yes |
object |
Table 4-117 InventoryAdjustmentUpdateLineItemIdo — Object
itemId |
Yes |
The SKU level item identifier. If SKU is already present, its line item will be updated. Otherwise, a new line item will be added. |
reasonId |
Yes |
The unique identifier of the reason code associated to the adjustment. The reason code is not modifiable on an update, but it will be used if a new item is added. |
caseSize |
NA |
quantity |
Yes |
The quantity of this line item. For UINS, the quantity must match the number of UINs. If the quantity is set to 0, the system will attempt to remove the line item from the adjustment. |
uins |
NA |
Confirm Inventory Adjustment
This section describes the Confirm Inventory Adjustment API. This API confirms an inventory adjustment, finalizing it and processing the inventory movement.
Request
Table 4-118 Confirm Inventory Adjustment — Request Parameters
adjustmentId |
Yes |
Cancel Inventory Adjustment
This section describes the Cancel Inventory Adjustment API. This API cancels an inventory adjustment.
Request
Table 4-119 Cancel Inventory Adjustment — Request Parameters
adjustmentId |
Yes |
REST Service: Item
This service integrates item foundation data from an external system. For item retrieval or lookup, please see the Item Inquiry REST service..
Service Base URL
The Cloud service base URL follows the format:
Import Item
Imports up to 100 items. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsItem).
Request
A list of items to import.
Example Value
"items": [
"itemId": "1111111",
"transactionLevel": 2,
"itemLevel": 2,
"status": 1,
"departmentId": 1000,
"classId": 2000,
"subclassId": 3000,
"shortDescription": "12p-Water",
"longDescription": "12-Pack of Water",
"differentiator1": "Color 01",
"differentiator2": "Size 06",
"differentiator3": "Flavor 08",
"differentiator4": "Fruit 04",
"parentId": "567000333",
"pack": false,
"simplePack": false,
"sellable": true,
"orderable": true,
"shipAlone": false,
"inventoriable": true,
"notionalPack": false,
"estimatePackInventory": false,
"primaryReferenceItem": false,
"orderAsType": false,
"standardUom": "EA",
"packageUom": "a",
"packageSize": "EA",
"eachToUomFactor": "a",
"barcodeFormat": "a",
"barcodePrefix": "a",
"wastageType": 1,
"wastagePercent": 1.5,
"wastagePercentDefault": 1.5,
"suggestedRetailCurrency": "USD",
"suggestedRetailPrice": 9.99,
"brand": "Brand A",
"brandDescription": "Brand A Full Description",
"components": [
"componentItemId": "1111111",
"quantity": 2
Schema - ItemImportListIdo
Table 4-120 ItemImportListIdo - Object
| Items | Yes | object | items |
Table 4-121 ItemImportIdo - Object
| itemId | Yes | string($text25) example: 1111111 | The unique item identifier (SKU number). |
| transactionLevel | Yes | integer($int1) example: 2 | Number indicating which of the three levels transactions occur for this item. Items may only be used on transactions with inventory tracked if the transaction level and item level match. |
| itemLevel | NA | integer($int1) example: 2 | Number indicating which of the three levels an item resides at. Items may only be used on transactions with inventory tracked if the transaction level and item level match. |
| status | NA | integer($int1) example: 1 |
The status of the item. Value values are: 1 - Active 5 - Auto-Stockable 6 - Non-Ranged Enum: [ 1, 5, 6 N ] |
| departmentId | Yes | number($int12) example: 1000 | The merchandise hierarchy department identifier. |
| classId | NA | number($int12) example: 2000 | The merchandise hierarchy class identifier. |
| subclassId | NA | number($int12) example: 3000 | The merchandise hierarchy subclass identifier. |
| shortDescription | NA | string($text255) example: 12p-Water | A short description of the item. |
| longDescription | NA | string($text400) example: 12-Pack of Water | A long description of the item. |
| differentiator1 | NA | string($text10) example: Color 01 | The first differentiator identifier. |
| differentiator2 | NA | string($text10) example: Size 06 | The second differentiator identifier. |
| differentiator3 | NA | string($text10) example: Flavor 08 | The third differentiator identifier. |
| differentiator4 | NA | string($text10) example: Fruit 04 | The fourth differentiator identifier. |
| parentId | NA | string($text25) example: 567000333 | The unique identifier of the item at the next level about this item. |
| pack | NA | boolean example: false | True if the item is a pack, false otherwise. |
| simplePack | NA | boolean example: false | True if the item is a simple pack, false otherwise. |
| sellable | NA | boolean example: true | True if the item is a sellable, false otherwise. |
| orderable | NA | boolean example: true | True if the item can be ordered from a supplier, false otherwise. |
| shipAlone | NA | boolean example: false | True if the item must be shipped in separated packaging, false otherwise. |
| inventoriable | NA | boolean example: true | True if the item is inventoried, false otherwise. |
| notionalPack | NA | Boolean example: false | True indicates that the inventory is held at the component level, false otherwise. Take special note that all notional packs are automatically marked as invertoriable in SIOCS. |
| estimatePackInventory | NA | boolean example: false | True if the item allows estimating pack inventory from component positions, false otherwise. |
| primaryReferenceItem | NA | boolean example: false | True indicates the item is the primary sub-transaction level item. |
| orderAsType | NA | boolean example: false | True indicates a buyer pack is receivable at the pack level. False indicates it is receivable at the component level. |
| standardUom | NA | string($text4) example: EA | The unit of measure that inventory is tracked in. |
| packageUom | NA | string($text4) example: a | The unit of measure associated with the package size. |
| packageSize | NA | number($text) example: EA | The size of the product printed (or will be printed on the label). |
| eachToUomFactor | NA | number($decimal20,10) example: a | The multiplication factor to convert 1 EA to the equivalent standard unit of measure. |
| barcodeFormat | NA | string($text4) example: a | The format of a barcode (used for Type 2 barcode items). |
| barcodePrefix | NA | number($int9) example: a | The barcode prefix used in association with the Type 2 barcode of this item. |
| wastageType | NA | integer($int4) example: 1 |
The type of wastage. Valid values are: 1 - Sales Wastage 2 - Spoilage Wastage Enum: [ 1, 2 |
| wastagePercent | NA | number($decimal12,4) example: 1.5 | The wastage percent. |
| wastagePercentDefault | NA | number($decimal12,4) example: 1.5 | The default wastage percent. |
| suggestedRetailCurrency | NA | string($text3) example: USD | The currency of the manufacturer suggested retail price. |
| suggestedRetailPrice | NA | number($decimal20,4) example: 9.99 | The manufacturer suggested retail price. |
| brand | NA | string($text30) example: Brand A | Brand name of the brand the item belongs to. |
| brandDescription | NA | string($text120) example: Brand A Full Description | Brand description of the brand the item belongs to. |
| components | NA | object | A list of components if the item is a pack. |
Table 4-122 ItemComponentImportIdo - Object
| componentItemId | Yes | string($text25) example: 1111111 | The item identifier of the component item within the pack. |
| quantity | Yes | number($decimal) example: 2 | The quantity of the component item within the pack. |
Remove Item
Marks items for removal with a non-active status. They are removed later from the system when item cleanup occurs through batch processing. Asychronous item integration is processed through staged messages and is controlled by the MPS Work Type (DcsItem).
Request
A list of items to remove.
Schema - ItemRemoveListIdo
Table 4-123 ItemRemoveListIdo - Object
| Items | Yes | object | A list of items to mark for removal. |
Table 4-124 ItemRemoveIdo - Object
| status | Yes | integer($int4) example: 2 |
The status to assign to the item to mark it for removal. Valid values are: 2 - Discontinued 3 - Inactive 4 - Deleted Enum: [ 2, 3, 4 |
Import Item Hierarchy
Imports up to 500 item hierarchies. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsHierarchy).
Request
A list of item hierarchies to import.
Example Value
"hierarchies": [
"departmentName": "Electronics",
"classId": 2000,
"className": "Blu-Ray",
"subclassId": 3000,
"subclassName": "Supports 4K"
Schema - ItemHierarchyImportListIdo
Table 4-125 ItemHierarchyImportListIdo - Object
| hierarchies | Yes | Objec | A list of item hierarchies to import. |
Table 4-126 ItemHierarchyImportIdo - Object
| departmentId | Yes | number($int12) example: 1000 | The hierarchy department identifier. |
| departmentName | NA | string($text360) example: Electronics | The hierarchy department name. |
| classId | NA | number($int12) example: 2000 | The hierarchy class identifier. |
| className | NA | string($text360) example: Blu-Ray | The hierarchy class name. |
| subclassId | NA | number($int12) example: 3000 | The hierarchy subclass identifier. |
| subclassName | NA | string($text360) example: Supports 4K | The hierarchy subclass name. |
Remove Item Hierarchy
Marks up to 500 item hierarchies for removal. They are removed later from the system when item cleanup occurs through batch processing. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsHierarchy).
Request
Schema - ItemHierarchyRemoveListIdo
Table 4-127 ItemHierarchyRemoveListIdo - Object
| hierarchies | Yes | object | A list of item hierarchies to remove. |
Table 4-128 ItemHierarchyRemoveIdo - Object
Import Related Item
Imports up to 500 item relationships records. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsItem).
Request
A list of related items to import.
Example Value
"relationships": [
"relationshipId": 12,
"relationshipType": 1,
"name": "Relationship Name",
"itemId": "300100400",
"mandatory": true,
"relatedItems": [
"itemId": "1000456",
"effectiveDate": "2025-03-12T12:23:25.195Z",
"endDate": "2025-03-12T12:23:25.195Z",
"priorityNumber": 2
Schema - ItemRelationshipImportListIdo
Table 4-129 ItemRelationshipImportListIdo - Object
| relationships | Yes | object | A list of item relationships to import. |
Table 4-130 ItemRelationshipImportIdo - Object
| relationshipId | Yes | number($text20) example: 12 | The identifier of the relationship. |
| relationshipType | Yes | integer($int6) example: 1 |
The relationship type. Valid values are: 1 - Related 2 - Substitute 3 - Up-Sell 4 - Cross-Sell Enum: [ 1, 2, 3, 4 |
| name | NA | string($text120) example: Relationship Name | The name of the relationship. |
| itemId | Yes | string($text25) example: 300100400 | The item whose related records are being records. |
| mandatory | Yes | boolean example: true | True if the relationship is mandatory. |
| relatedItems | Yes | object | A list of item relationships to import. |
Table 4-131 ItemRelationshipDetailIdo - Object
| itemId | Yes | string($text25) example: 1000456 | The item that is related to the base item. |
| effectiveDate | NA | string($date-time) | Date at which this relationship becomes active. |
| endDate | NA | string($date-time) | Last date at which this relationship is active. |
| priorityNumber | NA | integer($int4) example: 2 | The item that is related to the base item. |
Delete Related Item
Deletes up to 500 relationships between items. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is controlled by the MPS Work Type (DcsItem).
Request
A list of item relationships to remove.
Import Item Image
Imports up to 500 item image URLS associated to the item. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsItem).
Request
A list of item image URLs to import.
Example Value
"images": [
"imageType": 1,
"storeId": 5000,
"imageName": "Hat",
"imageSize": "T",
"url": "1000456",
"displaySequence": 2,
"startDate": "2025-03-12T13:29:07.670Z",
"endDate": "2025-03-12T13:29:07.670Z"
Schema - ItemImageImportListIdo
Table 4-133 ItemImageImportListIdo - Object
| Images | Yes | object | A list of item relationships to import. |
Table 4-134 ItemImageImportIdo - Object
| itemId | Yes | string($text25) example: 1000456 | The unique SKU number of the item. |
| imageType | Yes | integer example: 1 |
The type of the image. Valid values are: 1 - Image 2 - QR Code Enum: [ 1, 2 ] |
| storeId | NA | number($int10) example: 5000 | The store identifier. This attribute is required if the image type is a QR code. |
| imageName | Yes | string($text120) example: Hat | The name of the image. |
| imageSize | NA | string($text6) example: T | The size of the image. (T) is the only understood value (which indicates a thumbnail and is treated differently by the system). |
| url | Yes | string($text1000) example: 1000456 | The universal resource locator of the image. |
| displaySequence | NA | integer($int2) example: 2 | The sequence the item image should be displayed in. |
| startDate | NA | string($date-time) | The date the image becomes active. |
| endDate | NA | string($date-time) | The date the image ceases being active. |
Delete Item Image
Deletes up to 500 item image URLs. They are removed later from the system when item cleanup occurs through batch processing. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsItem).
Request
A list of item images URLs to delete.
Schema - ItemImageDeleteListIdo
Table 4-135 ItemImageDeleteListIdo - Object
| Images | Yes | Object | A list of item images to remove. |
Table 4-136 ItemImageRefIdo - Object
REST Service: Item Basket
tem Basket is a way of creating a list of items that can be utilized for other things such as line busting, gift registries, and so on. Item Basket allows a user to capture items and their quantities. An item basket that has only items on it is considered static, meaning that the number of items does not change. An item basket that has only hierarchies or hierarchies and items is considered dynamic, meaning that the items on the basket can change based upon the items associated to the hierarchy. This service defines operations to manage transfer delivery information by integration with an external system.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Baskets
This section describes the Find Baskets API. This API finds up to 10,000 item basket headers for the input criteria.
Request Parameters
This section describes the request parameters.
Table 4-137 Find Baskets — Request Parameters
| Parameters | Required | Data Type/Example | Description |
referenceId |
NA |
Include only item baskets with this reference identifier. |
alternateId |
NA |
Include only item baskets with this alternate identifier. |
storeId |
NA |
number($int10) (query) |
Include only item baskets with this store identifier. |
typeId |
NA |
number($int18) (query) |
Include only item baskets with this item basket type. |
status |
NA |
Include only item baskets with this status. Valid values are 1 - In Progress 2 - Completed 3 - Canceled Available values : 1, 2, 3 |
updateDateFrom |
NA |
Include only item baskets with an update date on or after this date. |
updateDateTo |
NA |
Include only item baskets with an update date on or before this date. |
itemId |
NA |
Include only item baskets that contain this item. |
Responses
This section describes the responses of the Find Baskets API.
Reason Code: 200
Successful response
Example Value
"basketId": 11111,
"referenceId": 211933,
"alternateId": 83027,
"storeId": 5000,
"typeId": 5,
"description": "Broken item investigation",
"status": 1,
"createDate": "2024-10-28T14:18:42.543Z",
"updateDate": "2024-10-28T14:18:42.543Z",
"expirationDate": "2024-10-28T14:18:42.543Z"
]Schema — ItemBasketHeaderIdo
This section describes the ItemBasketHeaderIdo schema.
Table 4-138 ItemBasketHeaderIdo — Object
basketId |
NA |
The unique identifier of the item basket. |
referenceId |
NA |
number($int12) example: 211933 |
An external reference identifier to the item basket. |
alternateId |
NA |
number($int12) example: 83027 |
An alternate identifier assigned by the user to the item basket. |
storeId |
NA |
A store identifier if the item basket belongs to a particular store. An empty or not-included store identifier indicates it can be used by all stores. |
typeId |
NA |
number($int18) example: 5 |
The unique identifier of the item basket type. |
description |
NA |
string($text255) example: Broken item investigation |
A description of the item basket. |
status |
NA |
The current status of the item basket. Valid values are: 1 - In Progress 2 - Completed 3 - Canceled Enum: [ 1, 2, 3 ] |
createDate |
NA |
The date the item basket was created. |
updateDate |
NA |
The date the item basket was last updated. |
expirationDate |
NA |
The date the item basket will expire. |
Create Basket
This section describes the Create Basket API. This API creates an in-progress item basket.
Request Parameters
There are not request parameters.
Request body is application/json.
The item basket details of the new item basket.
Example Value
"storeId": 5000,
"typeId": 5,
"expirationDate": "2024-10-28T15:00:53.432Z",
"hierarchies": [
"classId": 2000,
"subclassId": 3000
"lineItems": [
"itemId": "11111",
"caseSize": 1,
"quantity": 20
}Schema — ItemBasketCreateIdo
This section describes the ItemBasketCreateIdo schema.
Table 4-139 ItemBasketCreateIdo — Object
alternateId |
NA |
An alternate identifier assigned by rgw user to the item basket |
storeId |
NA |
typeId |
Yes |
description |
NA |
expirationDate |
NA |
hierarchies |
NA |
object |
A collection of hierarchies in the basket. |
lineItems |
NA |
object |
A collection of items in the basket. |
Table 4-140 ItemBasketHierarchyIdo — Object
departmentId |
NA |
The unique identifier of the department. |
classId |
NA |
The unique identifier of the class. |
subclassId |
NA |
The unique identifier of the subclass. |
Table 4-141 ItemBasketCreateItemIdo — Object
itemId |
NA |
string($text25) example: 11111 |
The unique identifier of the item. |
caseSize |
NA |
number($decimal(10,2)) example: 1 |
The case size of the item for this record. |
quantity |
NA |
number($decimal(12,4)) example: 20 |
The quantity of the item in the basket. |
Responses
This section describes the responses of the Create Baskets API.
Reason Code: 200
Successful response
Schema — ItemBasketStatusIdo
This section describes the ItemBasketStatusIdo schema.
Table 4-142 ItemBasketStatusIdo
basketId |
NA |
typeId |
NA |
status |
NA |
Read Basket
This section describes the Read Basket API. This API retrieves all the details about an item basket.
Request Parameters
Table 4-143 Read Basket — Request Parameters
| Parameter | Required | Data Type/Example | Description |
basketId |
Yes |
Responses
This section describes the responses of the Read Baskets API.
Reason Code: 200
Successful response
Example Value
"basketId": 11111,
"storeId": 5000,
"typeId": 5,
"status": 1,
"createDate": "2024-10-30T12:43:35.561Z",
"updateDate": "2024-10-30T12:43:35.561Z",
"expirationDate": "2024-10-30T12:43:35.561Z",
"dynamic": true,
"hierarchies": [
"classId": 2000,
"subclassId": 3000
"lineItems": [
"lineId": 11111,
"itemId": "11111",
"caseSize": 1,
"quantity": 20
Table 4-144 ItemBasketStatusIdo
basketId |
NA |
typeId |
NA |
status |
NA |
Update Basket
This section describes the Update Basket API. This API updates an item basket.
Request Parameters
Table 4-145 Update Basket — Request Parameters
basketId |
Yes |
Item basket details to update.
Example Value
"expirationDate": "2024-10-30T13:17:43.434Z",
"hierarchies": [
"classId": 2000,
"subclassId": 3000
"lineItems": [
"itemId": "11111",
"caseSize": 1,
"quantity": 20
}Schema — ItemBasketUpdateIdo
Table 4-146 ItemBasketUpdateIdo — Object
alternateId |
NA |
description |
NA |
expirationDate |
NA |
hierarchies |
NA |
object |
lineItems |
NA |
object |
Table 4-147 ItemBasketHierarchyIdo — Object
departmentId |
NA |
classId |
NA |
subclassId |
NA |
Table 4-148 ItemBasketUpdateItemIdo — Object
itemId |
NA |
caseSize |
NA |
quantity |
NA |
Copy Basket
This section describes the Copy Basket API. This API copies an item basket returning the newly copied basket.
Request Parameters
Table 4-149 Copy Basket — Request Parameters
basketId |
Yes |
Responses
This section describes the responses of the Copy Baskets API.
Response Code: 200
The media type os application/json.
Example Value
"basketId": 11111,
"storeId": 5000,
"typeId": 5,
"status": 1,
"createDate": "2024-10-30T14:05:24.790Z",
"updateDate": "2024-10-30T14:05:24.790Z",
"expirationDate": "2024-10-30T14:05:24.790Z",
"dynamic": true,
"hierarchies": [
"classId": 2000,
"subclassId": 3000
"lineItems": [
"lineId": 11111,
"itemId": "11111",
"caseSize": 1,
"quantity": 20
]Schema — ItemBasketStatusIdo
Table 4-150 ItemBasketStatusIdo
basketId |
NA |
typeId |
NA |
status |
NA |
Confirm Basket
This section describes the Confirm Basket API. This API confirms the item basket making it available for usage.
Delete Basket
This section describes the Delete Basket API. This API deletes the item basket.
Request Parameters
Table 4-151 Delete Basket — Request Parameters
basketId |
Yes |
Find Basket Types
This section describes the Find Basket Types API. This API finds all the available item basket types for an item basket.
Responses
This section describes the responses of the Find Basket Types API.
Response Code: 200
Schema — ItemBasketTypeIdo
This section describes the ItemBasketTypeIdo schema.
Table 4-152 ItemBasketTypeIdo — Object
typeId |
NA |
number($int18) example: 1 |
code |
NA |
string($text6) example: INV |
A short code of the item basket type. |
description |
NA |
string($text120) example: Investigation |
The description of the item basket type. |
REST Service: Item Inquiry
The service provides an external system the ability to retrieve information about items (with the exception of inventory information).
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiRetrieve Items
The Retrieve Items API searches for detailed information about the items using the specified input. If the number of items found exceeds 10,000, a maximum limit error will be returned. Additional limiting input criteria will be required.
Request
The store and items to find information for.
Schema — ItemInquiryCriteriaIdo
Table 4-153 ItemInquiryCriteria — Object
storeId |
Yes |
integer($int10) example: 5000 |
The store identifier (if passed in as query parameter). |
itemIds |
Yes |
string($text25) example: List [ 333000, 444001 ] |
A list of items to retrieve information for. |
Responses
This section describes the responses of the Retrieve Items API.
Response Code: 200
Example Value
"itemLevel": 2,
"classId": 2000,
"subclassId": 3000,
"pack": false,
"sellable": true,
"orderable": true,
"shipAlone": false,
"packageUom": "a",
"wastageType": 1,
"brand": "Brand A",
"createDate": "2024-09-18T13:33:41.160Z",
"updateDate": "2024-09-18T13:33:41.160Z",
"storeId": 4000,
"status": 1,
"primarySupplierId": 40001,
"storeControlPricing": true,
"rfid": false,
"defaultCurrencyCode": "USD",
"purchaseType": 1,
"uinType": 1,
"uinCaptureTime": 1,
"uinLabelId": 876544,
"uinExternalCreateAllowed": true,
"replenishmentMethod": "SO",
"rejectStoreOrder": false,
"multipleDeliveryPerDayAllowed": false,
"nextDeliveryDate": "2024-09-18T13:33:41.160Z",
"toleranceType": 1,
"toleranceUnit": 5.5,
"tolerancePercent": 2
]Schema — ItemInquiryIdo
Table 4-154 ItemInquiryIdo — Object
itemId |
NA |
transactionLevel |
NA |
itemLevel |
NA |
departmentId |
NA |
classId |
NA |
subclassId |
NA |
shortDescription |
NA |
longDescription |
NA |
differentiator1 |
NA |
differentiator2 |
NA |
differentiator3 |
NA |
differentiator4 |
NA |
parentId |
NA |
The unique ientifier of the item at the next level about this item. |
pack |
NA |
simplePack |
NA |
sellable |
NA |
orderable |
NA |
shipAlone |
NA |
inventoriable |
NA |
notionalPack |
NA |
NA |
True if the item alows estimating pack inventory from component positions, false otherwise. |
NA |
orderAsType |
NA |
standardUom |
NA |
packageUom |
NA |
packageSize |
NA |
eachToUomFactor |
NA |
The multiplication favtor to convert 1 EA to the equivalent standard unit of measure. |
barcodeFormat |
NA |
barcodePrefix |
NA |
wastageType |
NA |
The type of wastage. Validate value are: 1 - Sales Wastage 2 - Spoilage Wastage Enum: [ 1, 2 ] |
wastagePercent |
NA |
NA |
NA |
NA |
brand |
NA |
brandDescription |
NA |
string($text120) example: Brand A Full Descriptio |
createDate |
NA |
The date the item was created in EICS. |
updateDate |
NA |
storeId |
NA |
integer($int10) example: 4000 |
The store identifier |
status |
NA |
The status of the item. Valid values are: 1 - Active 2 - Discontinued 3 - Inactive 4 - Deleted 5 - Auto-Stockable Non-Ranged Enum: [ 1, 2, 3, 4, 5, 6 ] |
primarySupplierId |
NA |
integer($int10) example: 40001 |
The unique identifier of the primary supplier of the item to this store location. |
storeControlPricing |
NA |
True indicates the item price can be controlled by the store. |
rfid |
NA |
True indicates the item is RFID tagged. |
defaultCurrencyCode |
NA |
The default currency fo the item's price at this store. |
purchaseType |
NA |
integer($int2) example: 1 |
The purchase type. Valid values are: 1 - Consignment 2 - Concession Enum: [ 1, 2 ] |
uinType |
NA |
1 - Serial Number 2 - AGSN Enum: [1, 2 ] |
uinCaptureTime |
NA |
The UIN capture time. Valid values are: 1 - Sale 2 - Store Receiving Enum: [ 1, 2 ] |
uinLabelId |
NA |
integer($int12) example: 876544 |
The unique identifier of the UIN label. |
uinExternalCreateAllowed |
NA |
True if an external system can create a UIN, false otherwise. |
replenishmentMethod |
NA |
string($text6) example: SO |
The replenishment method. (SO) Store Orders has specific processing in the system, otherwise this is any text. |
rejectStoreOrder |
NA |
True indicates store orders must be on or after the next delivery date or should be rejected. |
multipleDeliveryPerDayAllowed |
NA |
True indicates the itemm allows multiple deliveries per day at the location. |
nextDeliveryDate |
NA |
The next delivery date of the time based on its replenishment type. |
toleranceType |
NA |
If not include, will default to unit. Valid values are: 1 - Unit 2 - Percent Enum: [ 1, 2 ] |
toleranceUnit |
NA |
integer($decimal12,4) example: 5.5 |
The unit tolerance amount. |
tolerancePercent |
NA |
integer($decimal12,4) example: 2 |
The percent tolerance amount. |
Retrieve Items By Scan
Search for item information by an unknown identifier, most likely a scan. It first searches for the item using the input as a potential item, and if found will return records based on that. It then searches as a UPC, barcode (including GS1), or UIN, in that order, halting if it finds potential matches. An optional store identifier can be included as well.
Request
The store and scan to search for.
Responses
This section describes the responses of the Retrieve Items By Scan API.
Response Code: 200
Example Value
"type": 1,
"status": 1,
"shortDescription": "Shoe",
"longDescription": "Steel-toed Shoe (two-tone)",
"classId": 2000,
"subclassId": 3000,
"storeId": 5000,
"ranged": true
Schema - ItemScannedIdo
Table 4-156 ItemScannedIdo - Object
| itemId | NA | string($text25) example: 1111111 | The item identifier. |
| type | NA | integer($int2) example: 1 |
The item type. Valid values are: 1 - Item 2 - Simple Pack 3 - Complex Pack 4 - Simple Breakable Pack 5 - Complex Breakable Pack Enum: [ 1, 2, 3, 4, 5 |
| status | NA | integer($int2) example: 1 |
The status of the item. Valid values are: 1 - Active 2 - Discontinued 3 - Inactive 4 - Deleted 5 - Auto-Stockable 6 - Non-Ranged Enum: [ 1, 2, 3, 4, 5, 6 ] |
| shortDescription | NA | string($text255) example: Shoe | The short description of the item. |
| longDescription | NA | string($text400) example: Steel-toed Shoe (two-tone) | The long description of the item. |
| departmentId | NA | number($int12) example: 1000 | The identifier of the department the item belongs to. |
| classId | NA | number($int12) example: 2000 | The identifier of the class the item belongs to. |
| subclassId | NA | number($int12) example: 3000 | The identifier of the subclass the item belongs to. |
| storeId | NA | integer($int10) example: 5000 | The store identifier (only if passed in as query parameter). |
| ranged | NA | boolean example: true | True if the item is ranged to the requested store, false otherwise. |
Retrieve Items by Search Scan
Search for item information by an unknown identifier, most likely a scan. It first searches for the item using the input as a potential item, and if found will return records based on that. It then searches as a UPC, barcode, or UIN, in that order, halting if it finds potential matches. An optional store identifier can be included as well. This operation is deprecated and should not be used! Use the retrieve items by scan POST version instead.
Request
Table 4-157 Retrieve Items By San Request — Request Parameters
searchScan |
Yes |
string($text128) (path) |
A scan or entered item information. |
storeId |
NA |
The identifier of a store to search within. |
Responses
This section describes the responses of the Retrieve Items By Search Scan API.
Response Code: 200
For details about the schema, see the Schema - ItemScannedIdo section.
Retrieve Items by Source
The Retrieve Items by Source API searches for summary information about an item based on search criteria, primarily hierarchy and source location.
Request
Table 4-158 Retrieve Items By Source — Request Parameters
description |
NA |
string($text255) (query) |
Include only items with description text matching this description. |
sourceType |
NA |
integer($int4) (query) |
Include only items available from this source type. Valid values are: 1 - Supplier 2 - Warehouse 3 - Finisher Available values : 1, 2, 3 |
sourceId |
NA |
Include only items available from this source. If source id is included, then sourceType is also required. |
departmentId |
NA |
Include only items associated to this merchandise hierarchy department. |
classId |
NA |
Include only items associated to this merchandise hierarchy class. |
subclassId |
NA |
Include only items associated to this merchandise hierarchy subclass. |
storeId |
NA |
Include only items ranged to this particular store. |
Responses
This section describes the responses of the Retrieve Items by Source API.
Response Code: 200
Example Value
"storeId": 5000,
"type": 1,
"status": 1,
"classId": 2000,
"subclassId": 3000
]Schema — ItemSummaryIdo
Table 4-159 ItemSummaryIdo — Object
itemId |
NA |
storeId |
NA |
type |
NA |
The item type. Valid values are: 1 - Item 2 - Simple Pack 3 - Complex Pack 4 - Simple Breakable Pack 5 - Complex Breakable Pack Enum: [ 1, 2, 3, 4, 5 ] |
status |
NA |
shortDescription |
NA |
longDescription |
NA |
departmentId |
NA |
classId |
NA |
subclassId |
NA |
Retrieve Items by Inventory
This section describes the Retrieve Items by Inventory API. This API searches for summary information about an item based on search criteria, primarily inventory information.
Request
Table 4-160 Retrieve Items by Inventory - Request Parameters
| Name | Required | Data Type | Description |
| available | NA | boolean (query) | Include only items with positive available inventory. |
| unavailable | NA | boolean (query) | Include only items with positive unavailable inventory. |
| nonsellableTypeId | NA | integer($int12) (query) | Include only items with this non-sellable quantity type. |
| departmentId | NA | integer($int12) (query) | Include only items associated to this merchandise hierarchy department. |
| classId | NA | integer($int12) (query) | Include only items associated to this merchandise hierarchy class. |
| subclassId | NA | integer($int12) (query) | Include only items associated to this merchandise hierarchy subclass. |
| storeId | NA | integer($int10) (query) | Include only items ranged to this particular store. |
Responses
This section describes the responses of the Retrieve Items by Inventory API.
Response Code: 200
For details about the schema, see the Schema — ItemSummaryIdo section.
Retrieve Items by Relationship
This section describes the Retrieve Items by Relationship API. This API searches for summary information about an item based on search criteria, primarily items associated by relationship.
Request
Table 4-161 Retrieve Items by Relationship - Request Parameter
| itemId | NA | string($text25) (query) | Include only items that have a relationship to this item identifier. |
Responses
This section describes the responses of the Retrieve Items by Relationship API.
Response Code: 200
Retrieve Items by UDA
This section descibes the Retrieve Items by UDA API. This API searches for summary information about an item based on search criteria, primarily user defined attributes.
Request
Table 4-162 Retrieve Items by UDA - Request Parameter
| udaId | NA | integer($int5) (query) | Include only items with this user defined attribute. |
| udaText | NA | string($text250) (query) | Include only items with this UDA text value. |
| udaLovId | NA | string($text25) (query) | Include only items with a UDA value matching this list of values identifiers. |
| udaDateFrom | NA | string($date-time) (query) | Include only items with a date UDA value on or after this date. |
| udaDateTo | NA | string($date-time) (query) | Include only items with a date UDA value on or before this date. |
Responses
This section describes the responses of the Retrieve Items by UDA API.
Response Code: 200
The media type is applicaton/json.
REST Service: Item Inventory
This service retrieves information about item inventory.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/inventory
API Definitions
| API | Description |
Find Available Inventory |
Search for available inventory information by multiple items and multiple locations. |
Find Inventory |
Searches for standard inventory information by multiple items and multiple locations. |
Find Expanded Inventory |
Searches for expanded inventory information by multiple items at a single store. |
Find Future Inventory |
Searches for future inventory delivery information by a single item and a single store. |
Find Inventory In Buddy Stores |
Searches for inventory information at buddy stores by single input store and multiple items. |
Find Inventory In Transfer Stores |
Searches for inventory information at transfer zone stores by single input store and multiple items. |
API: Find Available Inventory
Searches for available inventory quantity about an item in requested locations. Only transaction-level items are processed, and only current available inventory is returned. The multiplied combination of items and locations within the input criteria cannot exceed 10,000. Invalid items or locations will not cause this API to fail. Inventory is returned for any item and locations found and is not returned invalid or not found items or locations.
API Basics
Endpoint URL |
{base URL}/available |
Method |
POST |
Successful Response |
200 OK |
Processing Type |
Synchronous |
Input |
Criteria |
Output |
List of items |
Max Response Limit |
10,000 |
Input Data Definition
| Attribute | Data Type | Required | Description |
itemIds |
List of Strings |
Yes |
A list of items to retrieve available inventory for. |
locationIds |
List of Longs |
Yes |
A list of location identifiers to retrieve available inventory for. |
locationType |
Integer |
Yes |
A location type: See Location Type |
Example Input
"itemIds": [
"100637156",
"100637172",
"100653105"
"locationIds": [
5000,
5001,
5005
"locationType": 1
Output Data Definition
itemId |
String |
Yes |
locationId |
Long |
Yes |
The location identifier. |
locationType |
Integer |
Yes |
The location type: See Location Type. |
availableQuantity |
BigDecimal |
Yes |
The amount of available inventory. |
unitOfMeasure |
String |
Yes |
The unit of measure of the available inventory. |
estimatedPack |
Boolean |
Yes |
True if this is an estimated pack quantity, false otherwise. |
Example Output
"itemId": "100637113",
"locationId": 5000,
"locationType": 1,
"availableQuantity": 200.0000,
"unitOfMeasure": "EA",
"estimatedPack": false
"locationId": 5001,
"locationType": 1,
Additional Data Definitions
Location Type
| Value | Definition |
1 |
Store |
2 |
Warehouse |
API: Find Inventory
Query lookup of detailed inventory information about a multiple item in multiple stores. The multiplied combination of items and locations within the input criteria cannot exceed 10,000. Invalid items or locations will not cause this API to fail. Inventory is returned for any item and locations found and is not returned invalid or not found items or locations.
API Basics
Endpoint URL |
{base URL}/positions |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Input |
Criteria |
Output |
List of inventory of item at stores |
10,000 |
itemIds |
List of Strings |
Yes |
A list of items to retrieve inventory for. |
storeIds |
List of Longs |
Yes |
A list of store identifiers to retrieve inventory for. |
sellingUnitOfMeasure |
Boolean |
True indicates an attempt to use the selling unit of measure of the item, false indicates to use the standard unit of measure. If conversion cannot take place, it defaults back to standard unit of measure. |
Example Input
"itemIds": [
"100637156",
"100637172",
"100668091"
"storeIds": [
5000,
5001,
5002
"sellingUnitOfMeasure": true
itemId |
String |
Yes |
storeId |
Long |
The store identifier if the item is ranged to a store. |
ranged |
Boolean |
Yes |
True if the item is ranged to the store, false otherwise. |
estimated |
Boolean |
Yes |
True if the quantities are estimated, false otherwise. |
unitOfMeasure |
String |
Yes |
The unit of measure of the quantities. |
caseSize |
BigDecimal |
Yes |
The default case size of the item. |
quantityStockOnHand |
BigDecimal |
Yes |
The stock on hand quantity. |
quantityBackroom |
BigDecimal |
Yes |
The quantity located in the back room area. |
quantityShopfloor |
BigDecimal |
Yes |
The quantity located on the shop floor. |
quantityDeliveryBay |
BigDecimal |
Yes |
The quantity located in the delivery bay. |
quantityAvailable |
BigDecimal |
Yes |
The available to sell quantity. |
quantityUnavailable |
BigDecimal |
Yes |
The unavailable to sell quantity. |
quantityNonSellable |
BigDecimal |
Yes |
The total non-sellable quantity. |
quantityInTransit |
BigDecimal |
Yes |
The quantity currently in transit. |
quantityCustomerReserved |
BigDecimal |
Yes |
The quantity reserved for customer orders. |
quantityTransferReserved |
BigDecimal |
Yes |
The quantity reserved for transfers. |
quantityVendorReturn |
BigDecimal |
Yes |
The quantity reserved for vendor returns. |
nonSellableQuantities |
List of Non-Sellable Quantities |
A collection containing the specific quantity in each non-sellable quantity type bucket. |
Non-Sellable Quantity Data Definition
nonsellableTypeId |
Long |
Yes |
The non-sellable type unique identifier. |
quantity |
quantity |
Yes |
The quantity in this particular non-sellable type bucket. |
Example Output
"itemId": "100637156",
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantityStockOnHand": 10.0000,
"quantityBackroom": 10.0000,
"quantityShopfloor": 0.0000,
"quantityDeliveryBay": 0.0000,
"quantityAvailable": 10.0000,
"quantityUnavailable": 0.0000,
"quantityNonSellable": 0.0000,
"quantityInTransit": 0.0000,
"quantityCustomerReserved": 0.0000,
"quantityTransferReserved": 0.0000,
"quantityVendorReturn": 0.0000
"itemId": "100637172",
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantityBackroom": -10.0000,
"quantityAvailable": -10.0000,
"quantityUnavailable": 20.0000,
"quantityNonSellable": 20.0000,
"quantityVendorReturn": 0.0000,
"nonSellableIdos": [
"nonsellableTypeId": 1,
"quantity": 15.0000
"nonsellableTypeId": 2,
"quantity": 5.0000
API: Find Expanded Inventory
Searches for expanded inventory information about multiple items within a single store.
API Basics
Endpoint URL |
{base URL}/{storeId}/expanded |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Input |
Criteria |
Output |
List of inventory of items |
2,500 |
Path Parameter Definitions
| Attribute | Description |
storeId |
The store identifier of the store to process items for. |
itemIds |
List of Strings |
Yes |
A list of items to retrieve expanded inventory for. |
Example Input
"itemIds": [
"100637156",
"100637172",
"100695081"
itemId |
String |
Yes |
storeId |
Long |
ranged |
Boolean |
Yes |
estimated |
Boolean |
Yes |
unitOfMeasure |
String |
Yes |
caseSize |
BigDecimal |
Yes |
BigDecimal |
Yes |
quantityBackroom |
BigDecimal |
Yes |
quantityShopfloor |
BigDecimal |
Yes |
BigDecimal |
Yes |
quantityAvailable |
BigDecimal |
Yes |
BigDecimal |
Yes |
BigDecimal |
Yes |
quantityInTransit |
BigDecimal |
Yes |
BigDecimal |
Yes |
BigDecimal |
Yes |
BigDecimal |
Yes |
firstReceivedDate |
Date |
The first date the item was received into stock. |
lastReceivedDate |
Date |
The date the item last received inventory into stock. |
lastReceivedQuantity |
BigDecimal |
Total amount of inventory received on the last date it was received. |
openStockCounts |
Integer |
The number of stock counts open for the item at this store. |
lastStockCountType |
Integer |
The type of stock count (see Additional Data Definition). |
lastStockCountApprovedDate |
Date |
The date this item was last approved on a stock count at this store. |
lastStockCountTimeframe |
Integer |
The stock count timeframe (see Additional Data Definition). |
uinProblemLine |
Boolean |
Yes |
True indicates it is UIN problem line item, false otherwise. |
lastRequestedQuantity |
BigDecimal |
The quantity last requested for this item. |
lastUpdateDate |
Date |
Yes |
The timestamp of the last time this record was updated. |
Collection of Non-Sellable Quantities |
The specific quantities in each non-sellable quantity type bucket. |
nonsellableTypeId |
Long |
Yes |
quantity |
quantity |
Yes |
Example Output
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantityStockOnHand": 200.0000,
"quantityBackroom": 200.0000,
"quantityAvailable": 200.0000,
"quantityLastReceived": 0.0000,
"quantityLastRequested": 0.0000,
"openStockCounts": 0,
"lastStockCountTimeframe": 3,
"uinProblemLine": false,
"lastUpdateDate": "2022-07-15T06:23:27-05:00"
"itemId": "100637121",
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantityBackroom": 180.0000,
"quantityAvailable": 180.0000,
"lastUpdateDate": "2022-07-15T06:23:27-05:00",
"quantity": 15.0000
"quantity": 5.0000
API: Find Future Inventory
Searches for future delivery records for a single store and single item.
API Basics
Endpoint URL |
{base URL}/{storeId}/{itemId}/future |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Input |
None |
Output |
List of delivery records |
N/A |
storeId |
The store identifier to retrieve future inventory for. |
itemId |
The item identifier to retrieve future inventory for. |
itemId |
String (25) |
Yes |
storeId |
Long |
Yes |
The store identifier. |
deliveries |
List of deliveryIds |
A list of delivery information if it exists. |
Delivery Data Definition
sourceLocationType |
Integer |
Yes |
Item Location Type (see Additional Data Definition). |
sourceLocationId |
Long |
Yes |
The unique identifier of the source location of the delivery. |
deliveryType |
Integer |
Yes |
Item Delivery Type (see Additional Data Definition). |
expectedDate |
Date |
Yes |
The date the inventory is expected to arrive. |
quantityInbound |
BigDecimal |
Yes |
Amount of inventory inbound on the delivery. |
quantityOrdered |
BigDecimal |
Yes |
Amount of inventory on order. |
Example Output
"storeId": 5000,
"deliveryIdos": [
"sourceLocationType": 1,
"sourceLocationId": 5001,
"deliveryType": 3,
"quantityInbound": 30.0000,
"quantityOrdered": 0.0000
Item Delivery Type
1 |
Allocation |
2 |
Purchase Order |
3 |
Transfer |
Item Location Type
1 |
Store |
2 |
Supplier |
3 |
Warehouse |
4 |
Finisher |
API: Find Inventory in Buddy Stores
API Basics
Endpoint URL |
{baseUrl}/{storeId}/associated |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Input |
List of items |
Output |
List of inventory records |
N/A |
storeId |
The store identifier to find buddy stores for. |
itemIds |
List of Strings |
Yes |
Boolean |
Example Input
"itemIds": [
"100637156",
"100637172",
"100668091"
itemId |
String |
Yes |
storeId |
Long |
ranged |
Boolean |
Yes |
estimated |
Boolean |
Yes |
unitOfMeasure |
String |
Yes |
caseSize |
BigDecimal |
Yes |
BigDecimal |
Yes |
quantityBackroom |
BigDecimal |
Yes |
quantityShopfloor |
BigDecimal |
Yes |
BigDecimal |
Yes |
quantityAvailable |
BigDecimal |
Yes |
BigDecimal |
Yes |
BigDecimal |
Yes |
quantityInTransit |
BigDecimal |
Yes |
BigDecimal |
Yes |
BigDecimal |
Yes |
BigDecimal |
Yes |
nonsellableTypeId |
Long |
Yes |
quantity |
quantity |
Yes |
Example Output
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantity": 15.0000
"quantity": 5.0000
API: Find Inventory in Transfer Zone Stores
Searches for inventory at transfer zone stores by single input store and multiple items.
API Basics
Endpoint URL |
{baseUrl}/{storeId}/transferzone |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Input |
List of items |
Output |
N/A |
storeId |
The store identifier to find transfer zone stores for. |
itemIds |
List of Strings |
Yes |
Boolean |
Example Input
"itemIds": [
"100637156",
"100637172",
"100668091"
itemId |
String |
Yes |
storeId |
Long |
ranged |
Boolean |
Yes |
estimated |
Boolean |
Yes |
unitOfMeasure |
String |
Yes |
caseSize |
BigDecimal |
Yes |
BigDecimal |
Yes |
quantityBackroom |
BigDecimal |
Yes |
quantityShopfloor |
BigDecimal |
Yes |
BigDecimal |
Yes |
quantityAvailable |
BigDecimal |
Yes |
BigDecimal |
Yes |
BigDecimal |
Yes |
quantityInTransit |
BigDecimal |
Yes |
BigDecimal |
Yes |
BigDecimal |
Yes |
BigDecimal |
Yes |
nonsellableTypeId |
Long |
Yes |
quantity |
quantity |
Yes |
Example Output
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantity": 15.0000
"quantity": 5.0000
REST Service: Item ISN
This rest service defines operations to manage Item ISN information.
Service Base URL
https://<external_load_balancer>/<cust_env/siocs-int-services>/api/isns
APIs
API |
Description |
Create ISN |
Create a new ISN |
Update ISN |
Updates an existing ISN |
Delete ISN |
Delete an existing ISN |
Find ISNs |
Search for ISNs based on a set of criteria |
Read ISN Types |
Read all Item ISN types |
API: Create ISN
This API will create ISN information.
API Basics
Endpoint URL |
{base URL} |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Input |
The ISN |
Output |
The ISN including ID |
N/A |
Attribute |
Type |
Req |
Definition |
isn |
String(128) |
X |
A scan number used to scan the item |
isnTypeId |
Long(12) |
X |
The unique identifier of the item ISN type |
itemId |
String(25) |
X |
The unique item identifier (sku number) |
uin |
String(128) |
A universal identification number |
externalId |
String(128) |
An identifier from an external system |
Example
Attribute |
Type |
Definition |
isnId |
Long(12) |
The unique identifier of the ISN record |
isn |
String(128) |
This is a scan number used to scan the item |
externalId |
String(128) |
API: Update ISN
This API allows the ISN information to be modified. An optional value left blank will update the ISN information to blank for that value.
API Basics
Endpoint URL |
{base URL}/isnId |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Input |
ISN Update Information |
Output |
N/A |
N/A |
Path Data Definiton
Attribute |
Type |
Definition |
isnId |
Long(12) |
The unique identifier of the item ISN. |
Attribute |
Type |
Req |
Definition |
isnTypeId |
Long(12) |
X |
itemId |
String(25) |
X |
uin |
String(128) |
externalId |
String(128) |
Example
API: Delete ISN
This API deletes an item ISN.
API Basics
Endpoint URL |
{base URL}/{isnId}/delete |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Input |
N/A |
Output |
N/A |
N/A |
Path Data Definition
Attribute |
Type |
Definition |
isinId |
Long(12) |
API: Find ISNs
This API is used to lookup or find ISNs.
API Basics
Endpoint URL |
{base URL} |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Input |
N/A |
Output |
List of ISNs |
10,000 |
Query Parameters
Attribute |
Type |
Definition |
isn |
String(128) |
Retrieves records containing this ISN, which could be for multiple items. |
ItemId |
String(25) |
Retrieves records associated to this unique item identifier (sku number). |
uin |
String(128) |
Retrieves records associated to this universal identification number. |
updateDateFrom |
String |
Retrieves records on or after this date. |
updateDateTo |
String |
Retrieves records on or before this date. |
Attribute |
Type |
Definition |
itemIsnId |
Long(12) |
The unique identifier of the record |
isn |
String(128) |
ItemId |
String(25) |
uin |
String(128) |
itemIsnTypeId |
Long(12) |
externalId |
String(128) |
An identifier of this ISN from an external system |
createDate |
Date |
The date this ISN record was first created |
createUser |
String(128) |
The user that created this ISN record |
updateDate |
Date |
The last date this ISN record was updated |
updateUser |
String(128) |
The user that last updated this ISN record. |
API: Read ISN Types
This API is used to lookup all the ISN types available for an ISN.
API Basics
Endpoint URL |
{base URL}/types |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Input |
N/A |
Output |
List of ISN Types |
N/A |
Attribute |
Type |
Definition |
isnTypeId |
Long(12) |
The unique ISN type identifier |
labelKey |
String(128) |
A label for the ISN type (not translated) |
restricted |
Boolean |
Y if this represents secure data, N otherwise. |
REST Service: Item Price
This service allows for the search and retrieval of item pricing information stored within EICS.
Service Base URL
https://<external_load_balancer></cust_env>/siocs-int-services/api/prices
API Definitions
API Definitions
| API | Description |
| findPrices | This API can be used to search for price summary information matching filter criteria. |
| FindPriceByIds | Find extended price information based on a list of potential unique price identifiers. |
API: findPrices
At least one input criteria is required or a bad request error will be returned.
API Basics
| Endpoint URL | {base URL} |
| Method | GET |
| Success Response | 200 OK |
| Processing Type | Synchronous |
| Input | Query Parameters |
| Output | List of Prices |
| Maximum Results Allowed | 10,000 |
| Attribute | Data Type | Definition |
| storeId | Long(10) | Only retrieve item price information for this store. |
| effectiveDateFrom | String | Only retrieve item price information on or after this date. |
| effectiveDateTo | String | Only retrieve item price information on or before this date. |
| itemId | String(25) | Only retrieve item price information for this item. |
| priceId | Long(12) | The unique identifier of the price. |
| itemId | String(25) | The unique identifier of the item. |
| storeId | Long(10) | The unique identifier of the store. |
| status | Integer | The status of the price. |
| priceType | Integer | The type of the price. |
| effectiveDate | Date | The effective date of the price. |
| endDate | Date | The end date of the price. |
| priceValue | BigDecimal(20,4) | The price amount. |
| priceCurrency | String(3) | The price currency. |
| unitOfMeasure | String(4) | The item unit of measure associated with the price. |
API: findPriceByIds
It will return information only for price identifiers that are found. It will not return errors or fail to process if invalid identifiers occur. It is up to the accessing information to determined prices not found using this API.
API Basics
| Endpoint URL | {base URL}/find |
| Method | POST |
| Input | ID List |
| Maximum Input Allowed | 5,000 |
| Attribute | Type | Definition |
| priceIds | List<Long(12)> | A list of price identifiers. |
| Status | Integer | The status of the price. |
| priceType | Integer | The type of the price |
| externalPriceId | Long(12) | The unique identifier of the external price or price event. |
| clearanceId | Long(15) | The unique identifier of the clearance price change from the pricing engine. |
| promotionId | Long(10) | The unique identifier of the promotion. |
| regularPriceChangeId | Long(15) | The unique identifier of the regular price change from the pricing engine. |
| resetClearanceId | Long(15) | The identifier of the clearance reset. |
| storeRequested | Boolean | True indicates it is store requested, false indicates it is not store requested. |
| sellingUnitPriceChange | Boolean | True indicates the selling unit retail price has changed, false indicates it has not. |
| multiUnitPriceChange | Boolean | True indicates the multi-unit pricing has changed, false indicates it has not. |
| multiUnitRetail | BigDecimal(20,4) | The multi-unit retail price. |
| multiUnitRetailCurrency | String(3) | The currency type of the multi-unit retail price in the multi-selling unit of measure. |
| multiUnits | BigDecimal(12,4) | The number of multi-units. |
| multiUnitUom | String(4) | The unit of measure of the multi-unit retail price. |
| promotionName | String(160 | The promotion name. |
| promotionCompDtlId | Long(15) | The unique identifier of the promotion component detail from the pricing engine. |
| promotionType | Integer | Promotion Component Type (See Index) |
| promotionDurationType | Integer | Promotion Duration Type (See Index) |
| promotionCompId | Long(10) | The unique identifier of the promotion component. |
| promotionCompName | String(160) | The promotion component name. |
| promotionDescription | String(640) | The promotion description. |
| updateDate | Date | The date that the update took place. |
Example Input:
{ "priceIds": [ 123, 456, 789, 012 ] } |
Price Type
| ID | Status |
| 1 | Permanent |
| 2 | Promotional |
| 3 | Clearance |
| 4 | Clearance Reset |
Price Status
| ID | Status |
| 1 | New |
| 2 | Pending |
| 3 | Approved |
| 4 | Completed |
| 5 | Rejected |
| 6 | Ticket List |
| 7 | Extract Failed |
| 8 | Deleted |
| 99 | Default |
| ID | Status |
| 1 | Complex Promotion |
| 2 | Simple Promotion |
| 3 | Threshold Promotion |
| 4 | Credit (Finance) Promotion |
| 5 | Transaction Promotion |
| ID | Status |
| 1 | All Day Promotion |
| 2 | Partial Day Promotion |
| 3 | Multiple Day Promotion |
REST Service: Item UDA
This service integrates user defined attribute foundation data. Asynchronous item UDA integration is processed through staged messages and is controlled by the MPS Work Types.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/udas
API Definitions
API |
Description |
importUdas |
Imports user defined attributes. |
deleteUdas |
Deletes user defined attributes. |
importItemUdas |
Imports an association between items and user defined attributes. |
deleteItemUdas |
Deletes the association between items and user defined attributes. |
readItemUdas |
Retrieves all the user defined attributes for a particular item. |
API: Import Udas
Imports user defined attributes. It is managed by DcsUda work type. If the input exceeds 500 UDAs an input too large exception will be returned.
A "Forbidden" response will occur if application is integrated with MFCS or RMS.
API Basics
Endpoint URL |
{base URL}/import |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
UDA import List |
Output |
None |
N/A |
Attribute |
Data Type |
Required |
Description |
udas |
List of details |
Yes |
A list of user defined attributes. |
Detail Data Definition
Attribute |
Data Type |
Required |
Description |
udaId |
Integer (5) |
Yes |
The user defined attribute identifier. |
type |
Integer |
Yes |
See Index: UdaType |
description |
String (120) |
Yes |
The description of the user defined attribute. |
printTicket |
Boolean |
True indicates tickets are printed for this user defined attribute. |
printLabel |
Boolean |
True indicates labels are printed for this user defined attribute. |
lovId |
String (25) |
The unique identifier of a list of values UDA. |
lovDescription |
String (250) |
The description of the list of values UDA. |
API: Delete Udas
Deletes user defined attributes. It is managed by DcsUda work type. If the input exceeds 500 UDAs an input too large exception will be returned.
API Basics
Endpoint URL |
{base URL}/delete |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
UDA delete list |
Output |
None |
N/A |
Attribute |
Data Type |
Required |
Description |
udaIds |
List<Long> |
Yes |
A list of user defined attribute. |
API: Import Item Udas
Imports associations between items and user defined attributes. This is controlled by the work type: DcsItem.
If the input exceeds 500 Item UDAs an input too large exception will be returned.
A "Forbidden" response will occur if application is integrated with MFCS.
API Basics
Endpoint URL |
{base URL}/items/import |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
Item UDA list |
Output |
None |
N/A |
Attribute |
Data Type |
Required |
Description |
itemUdas |
List of details |
x |
A list of associations between an item and user defined attributes. |
Attribute |
Data Type |
Required |
Description |
itemId |
String |
X |
udaId |
Integer |
X |
udaDate |
Date |
Holds the value of the user defined attribute if it is a date. |
udaText |
String (250) |
Holds the value of the user defined attribute if it is text. |
udaLovId |
String (25) |
Holds the unique numeric identifier of the user defined attribute if it is a list of values selection. |
Boolean |
Y indicates printing is done for this item and user defined attribute (which is also controlled by the UDA). |
API: Delete Item Udas
Deletes an association between item and user defined attributes. This is controlled by the work type: DcsItem.
API Basics
Endpoint URL |
{base URL}/items/delete |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
UDA item delete list |
Output |
None |
N/A |
Attribute |
Data Type |
Required |
Description |
itemUdas |
List of details |
Yes |
A list of associations between item and user defined attribute identifiers. |
Attribute |
Data Type |
Required |
Description |
itemId |
String (25) |
Yes |
udaId |
Integer (5) |
Yes |
udaDate |
Date |
udaText |
String (250) |
udaLovId |
String (25) |
API: Find Item Udas
It will retrieve UDAs for the inputted items.
API Basics
Endpoint URL |
{base URL}/items/find |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Input |
Item list |
Output |
UDA item list |
N/A |
Attribute |
Data Type |
Required |
Description |
itemIds |
List<String> |
Yes |
A list of items to find UDAs for. |
Attribute |
Data Type |
Description |
itemId |
String |
udaId |
Integer |
type |
String |
The user defined attribute type: (LV) List of Value, (FF) Free Form Text, DT (Date) |
description |
String |
udaDate |
Date |
udaText |
String |
udaLovId |
Long |
udaLoveDescription |
String |
Holds the value description of the UDA List of Values selection. |
printTicket |
Boolean |
printLabel |
Boolean |
UDA Type|
Value |
Definition |
1 |
Date |
2 |
Free Form Text |
3 |
List of Value |
REST Service: Item UIN
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/uins
API Definitions
| API | Description |
| createUin | Create a new unique identification number. |
| readUin | Reads information about a Universal Identification Number. |
| findUins | Find unique identification number summary information based on search criteria. |
| findUinLabels | This API is used to find all the UIN labels available for a uin items. |
| findUinHistory | This API is used to find UIN historical information based on search criteria. |
| generateUins | This API generates new Type 2 (Auto Generated Serial Numbers) Universal Identification Numbers without changing store inventory positions. |
API: createUin
Create a new unique identification number. Note that the combination of store and item determines the administrative information about a UIN (such as UIN Type).
The newly created UIN will be in "Unconfirmed" status and its transaction type will be "UIN Web Service." To move it into inventory, use inventory adjustment or another transaction.
API Basics
Endpoint URL |
{base URL} |
Method |
POST |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
UIN information |
Output |
UIN confirmation information |
Payload |
Type |
Req |
Definition |
storeId |
Long |
X |
The identifier of the store. |
itemId |
String |
X |
The identifier of the item. |
uin |
String |
X |
The universal identification number. |
Payload |
Type |
Definition |
itemUinId |
Long |
The unique identifier to the record. |
storeId |
Long |
itemId |
String |
uin |
String |
status |
Integer |
The current status of the UIN. Valid values are in index. |
Example
"storeId": 5000,,
"itemId": "100700500",
"uin": "1234"
API: readUin
API Basics
Endpoint URL |
{base URL}/items/{itemId}/{uin} |
Method |
GET |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
Path Parameters Item identifier and UIN |
Output |
UIN information |
Payload |
Type |
Definition |
itemUinId |
Long |
A unique identifier representing the record in the database. |
itemId |
String |
uin |
String |
type |
Integer |
The type of UIN. Valid values are: (1) Serial Number, (2) Auto Generated Serial Number |
status |
Integer |
The current status of the UIN. See Index for valid values. |
storeId |
Long |
transactionType |
Integer |
The business area that last contained the UIN, |
transactionId |
String |
The transaction id of the transaction containing the UIN. |
cartonId |
String |
The identifier of the carton containing the UIN. |
nonsellableTypeId |
Long |
A non-sellable inventory bucket the UIN was within. |
previousStatus |
Integer |
The previous status of the UIN. Valid values are in index. |
previousStoreId |
Long |
The previous store identifier associated with the previous status. |
previousTransactionType |
Integer |
The previous business area that contained the UIN for that previous status. |
previousTransactionId |
String |
The transaction id of the transaction that previously contained the UIN for that previous status. |
previousCartonId |
String |
The identifier of the carton that previously container the UIN for that previous status. |
previousNonsellableTypeId |
Long |
A non-sellabable inventory bucket the UIN was last within for that previous status. |
damaged |
Boolean |
True if the UIN is damaged, N otherwise. |
createDate |
Date |
The date the UIN was first inserted into the system. |
updateDate |
Date |
The last date the UIN was updated. |
createUser |
String |
The user that first inserted the UIN into the system. |
updateUser |
String |
The user that last updated the UIN in the system. |
API: findUins
API Basics
Endpoint URL |
{base URL} |
Method |
GET |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
Query Parameters |
Output |
List of UINs (see ReadUIN API for Data Output) |
10,000 |
Attribute |
Type |
Definition |
storeId |
Long |
Include only UINs for this store identifier. |
itemId |
String |
Include only UINS for this item |
status |
Integer |
Include only UINs with this current status. |
updateDateFrom |
Date/String |
Include only UINs updated on or after this date. |
updateDateTo |
Date/String |
Include only UINs updated on or before this date. |
API: findUinLabels
API Basics
Endpoint URL |
{base URL}/labels |
Method |
GET |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
N/A |
Output |
List of labels |
Attribute |
Type |
Definition |
labelId |
Long |
The unique identifier of the record. |
labelCode |
String |
A unique code that defines the label. |
description |
String |
The description or label associated to the code (not translated). |
API: findUinHistory
API Basics
Endpoint URL |
{base URL}/histories |
Method |
GET |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
Query parameters |
Output |
List of UIN history records |
10,000 |
Attribute |
Type |
Definition |
itemId |
String |
Include only UIN history for this item. |
uin |
Integer |
Include only UIN history for this UIN. |
createDateFrom |
Date/String |
Include only UIN history created on or after this date. |
createDateTo |
Date/String |
Include only UIN history created on or before this date. |
Payload |
Type |
Definition |
itemId |
String |
uin |
String |
type |
Integer |
status |
Integer |
storeId |
Long |
transactionType |
Integer |
transactionId |
String |
cartonId |
String |
nonsellableTypeId |
Integer |
createDate |
Date |
updateDate |
Date |
createUser |
String |
updateUser |
String |
API: generateUins
If the UIN administrative data for the item and store used do not indicate Type 2, an error will be returned.
The new UINs generated will have a status of “Unconfirmed”.
API Basics
Endpoint URL |
{base URL}/generate |
Method |
POST |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
UIN generation information |
Output |
N/A |
Payload |
Type |
Req |
Definition |
itemId |
String |
X |
storeId |
Long |
X |
The identifier of the store |
quantity |
Integer |
X |
The amount of universal identification numbers to generate. |
transactionType |
Integer |
X |
See Index: UIN Functional Area |
transactionId |
String |
A transaction reference identifier. |
Example
"storeId": 5000,
"itemId": "100663071",
"uin": "1234",
"quantity": 5,
"transactionType": 13
UIN Type
ID |
Description |
1 |
Serial Number |
2 |
Auto-Generated Serial Number |
UIN Status
ID |
Description |
1 |
In Stock |
2 |
Sold |
3 |
Shipped To Warehouse |
4 |
Shipped To Store |
5 |
Reserved For Shipping |
6 |
Shipped To Vendor |
7 |
Removed From Inventory |
8 |
Unavailable |
9 |
Missing |
10 |
In Receiving |
11 |
Customer Order Reserved |
12 |
Customer Order Fulfilled |
13 |
Shipped To Finisher |
99 |
Unconfirmed |
UIN Functional Area
ID |
Description |
1 |
Warehouse Delivery Receipt |
2 |
Direct Delivery Receipt |
3 |
Create Transfer |
4 |
Dispatch Transfer |
5 |
Receive Transfer |
6 |
Receipt Adjustment |
7 |
Create Return |
8 |
Dispatch Return |
9 |
Inventory Adjustment |
10 |
Stock Count |
11 |
Stock Recount |
12 |
Stock Count Authorized |
13 |
Manual |
14 |
POS Sale |
15 |
POS Return |
16 |
POS Sales Void |
17 |
POS Return Void |
18 |
UIN Web Service |
19 |
Customer Order |
20 |
Direct Delivery ASN Inbound |
21 |
Transfer ASN Inbound |
22 |
Transfer Shipment |
REST Service: Manifest
Service Base URL
The Cloud service base URL follows the format:
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/manifests
API Definitions
| API | Description |
Close Manifest |
Call this method to close all manifested shipments matching the input criteria. |
API: Close Manifest
Call this method to close all manifested shipments for the carrier code and carrier services. A processing message is sent to the internal message processing system and the services returns an “Accepted” response. The closing of the manifest will occur later when the message is processed.
API Basics
Endpoint URL |
{base URL}/close |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
Criteria |
Output |
None |
Attribute |
Data Type |
Required |
Description |
carrierCode |
String (4) |
Yes |
A carrier code. |
carrierServiceCode |
String (6) |
Yes |
A carrier service code. |
trackingNumber |
List of Strings (120) |
Yes |
A list of tracking numbers associated to the contents of the manifest. |
shipDate |
Date |
Indicates all items manifested prior to this date for the carrier have been shipped. |
Example Input
"carrierCode": "O",
"carrierServiceCode": "O",
"trackingIds": ["7861","45722"],
"shipDate":"2022-04-19T23:59:59-05:00"
REST Service: Notification
This page captures the service APIs related to accepting notification from an external system.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/notifications
APIs
API |
Description |
findNotifications |
Find notifications |
createNotifications |
Create a series of notifications |
API: findNotifications
API is used to search for notifications.
Table 4-163 API Basics
Endpoint URL |
{base URL} |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Input |
Query parameters |
Output |
Collection of notifications |
20,000 |
Table 4-164 Query Parameters
Attribute |
Type |
Definition |
storeId |
Long(10) |
Include only records with this store identifier. |
notificationType |
Integer(4) |
Include only records with this notification type. |
transactionType |
Integer(4) |
Include only records with this transaction type. |
status |
Integer(4) |
Include only records with this status. |
createDateFrom |
Date |
Include only records with a create date on or after this date. |
createDateTo |
Date |
Include only records with a create date on or before this date. |
Attribute |
Type |
Definition |
notificationId |
Long(15) |
The unique identifier of the notification. |
notificationType |
Integer(4) |
The type of notification. See Index. |
storeId |
Long(10) |
subject |
String(400) |
The title or subject of the notification. |
message |
String(2000) |
The message text of the notification. |
status |
Integer(4) |
The current status of the notification. |
transactionType |
Integer(4) |
The type of a transaction associated to the notification. See Index. |
transactionId |
Long(15) |
The identifier of a transaction associated to the notification. |
createDate |
Date |
The date the notification was originally created. |
createUser |
String(128) |
The user that created the notification. |
API: createNotifications
Create one or more notifications within the system.
Payload |
Type |
Req |
Definition |
notifications |
Collection |
X |
The list of notifications to create. |
Table 4-165 Notification
Attribute |
Type |
Req |
Definition |
storeId |
Long(10) |
X |
notificationType |
Integer(4) |
X |
subject |
String(400) |
X |
message |
String(2000) |
X |
transactionType |
Integer(4) |
X |
transactionId |
Long(15) |
X |
createDate |
Date |
The date the notification was originally created. This will default to current date if not supplied. |
createUser |
String(128) |
The user that created the notification. This will default to integration user if not supplied. |
Example
Index
Table 4-166 Notification Type
ID |
Description |
1 |
Customer Order (New) |
2 |
Customer Order Reauthorization |
3 |
Customer Order Pick Reminder |
4 |
Customer Order Pickup |
5 |
Customer Order Receipt |
6 |
Customer Order Reminder |
7 |
Fulfillment Order Reverse Pick (New) |
8 |
UIN Items on Incoming ASN Failed |
9 |
Return To Vendor Expiration Approaching |
10 |
Transfer Delivery Damaged |
11 |
Transfer Delivery Receiving Discrepancy |
12 |
Transfer Delivery Carton Misdirected |
13 |
Transfer Delivery Overdue |
14 |
Transfer Delivery UIN Discrepancy (From Finisher) |
15 |
Transfer Delivery UIN Discrepancy |
16 |
Transfer Delivery Auto-Receive Failure (From Finisher) |
17 |
Transfer Delivery Auto-Receive Failure (From Warehouse) |
18 |
Transfer Delivery Auto-Receive Failure (From Store) |
19 |
Transfer Request Approved |
20 |
Transfer Request Quantity Unavailable |
21 |
Transfer Request Expiration Approaching |
22 |
Transfer Request Submitted |
23 |
Transfer Request Rejected |
24 |
UIN Store Unexpectedly Altered |
25 |
Vendor Delivery Over Received Quantity |
26 |
Vendor Return Quantity Unavailable |
Table 4-167 Transaction Type
ID |
Description |
1 |
Customer Order |
2 |
Customer Order Pick |
3 |
Customer Order Delivery |
4 |
Customer Order Reverse Pick |
5 |
Direct Store Delivery Receiving |
6 |
7 |
Item Basket |
8 |
Return To Vendor |
9 |
Return To Vendor Shipment |
10 |
Shelf Adjustment |
11 |
Shelf Replenishment |
12 |
Shelf Replenishment Gap |
13 |
Stock Count |
14 |
Store Order |
15 |
Transfer |
16 |
Transfer Shipment |
17 |
Transfer Receiving |
Table 4-168 Notification Status
ID |
Description |
1 |
Unread |
2 |
Read |
REST Service: POS Transaction
EICS integrates with POS systems and Sales Audit systems to ensure that the inventory positions are accurate. This is especially important where accurate up-to-date inventory positions are required to reduce customer disappointment when trying to locate items that appear in inventory or delays in filling customer orders. POS is the primary source of sales, returns, void, and some customer order transaction information to EICS. ReSA sends only modified or new POS transaction records to EICS. This service processes the information asynchronously so a short delay may occurs before inventory is updated. As part of the sales processing, EICS updates the inventory depending on the nature of the transaction. The following are the supported transaction types for the sales processing Sale, Return, and Post Void of these transactions. The audit system should not modify the post void transactions. A change to a void is not supported by EICS. Please refer to Sales Integration in the integration guide for more information. Duplicate transactions are prevented by scanning for unique instances of transactions by id, date, and register id. However, it is the responsibility of the calling application to make sure that duplicate transactions are not sent. Even in the case of REST call that fails, any retry or attempt to resend the transaction should have a delayed time period to make sure multiple attempts to transmit or retransmit a transaction does not occur simultaneously.
Service Base URL
The Cloud Service base URL follows the format:
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiImport POS Transaction
Point-Of-Sale systems may integration transactions to EICS using this service, which imports and processes point-of-sale transactions through an asynchronous process. The service has a default limit of 1,000 total items, though they may be distrubted across any number of transactions. Only one store is allowed across all the transactions sent in a single request. The web service is optimized for speed at greater than 400 items and less than 500 items per service call. The further above or below this optimized point, processing speed will be reduced, and it may take longer for the sales to be recorded in inventory. Since this import is asynchronous, only the basic form of the input is validated prior to the data being captured and processed.
Request
There are no request parameters.
The request body is application/json.
An array of transactions.
Example Value
"transactions": [
"storeId": 1234,
"transactionId": "444-555",
"transactionTimestamp": "2024-09-11T12:10:53.145Z",
"custOrderId": "44444",
"customerOrderComment": "Customer attrived late.",
"externalUser": "Employee A",
"items": [
"itemId": "10000345",
"quantity": 4,
"uin": "14000567000",
"epc": "urn:epc:tag:sgtin-96:1.012345.67890.10478932",
"reasonCode": 1,
"dropShip": true,
"fulfillmentOrderId": "7000",
"fulfillOrderLineNumber": 2,
"reservationType": 1,
"transactionCode": 1,
"comments": "Item packaging is slightly damaged."
Schema — PosTransactionListIdo
This section describes the POSTransactionListIdo schema.
Table 4-169 PosTransactionListIdo — Object
| Element Name | Required | Data Type/Example | Description |
transaction |
Yes |
object |
transaction |
Table 4-170 PosTransactionIdo — Object
storeId |
Yes |
number($int10) example: 1234 |
The unique identifier of the store that is the source of the transaction. |
transactionId |
Yes |
string($text128) example: 444-555 |
A unique identifier of this point-of-sale transaction. In order for the sales audit process to match and audit a POS transaction that was previously received, the transactionId attribute of the POS transaction must use the same data elements and format as the sales audit file. The sales audit file concatenates the THEAD file line id value, plus a dash separator, plus the THEAD transaction number value. For example, it will appear as 111-222. The transactionId attribute of the imported point-of-sale record must match that value and format. |
transactionTimestamp |
Yes |
string($date-time) |
The date and time of the sale transaction. |
custOrderId |
NA |
string($text128) example: 44444 |
An external customer order identifier. This attribute is required for customer order releated point-of-sale transactions. |
customerOrderComment |
NA |
string($text512) example: Customer attrived late. |
A comment associated with the customer order. |
externalUser |
NA |
string($text128) example: Employee A |
User information from the external point-of-sale system. |
items |
Yes |
object |
Items |
Table 4-171 PosTransactionItemIdo — Object
itemId |
Yes |
string($text25) example: 10000345 |
The transaction-level SKU number of the item. |
quantity |
Yes |
number($dec12.4) example: 4 |
The quantity of the item transacted. |
unitOfMeasure |
Yes |
string($text4) example: EA |
The unit of measure of the quantity. |
uin |
NA |
string($text128) example: 14000567000 |
A unique identifaction number. If not empty, the quantity will be modified to 1. |
epc |
NA |
string($text256) example: urn:epc:tag:sgtin-96:1.012345.67890.10478932 |
The complete SGTIN-96 Electronic Product Code of the item. |
reasonCode |
NA |
integer($int4) example:1 |
Reason code associated to the item transaction. This field is required if unavailable sub-buckets system configuration is active and you wish to move unavailable inventory. |
dropShip |
Yes |
Boolean example:true |
True if this item is drop ship, false if it is not. Drop ship sales will not impact stock positions. |
fulfillmentOrderId |
NA |
string($text128) example: 7000 If the transaction is associated to a customer order, this is the external fulfillment order identifier. |
fulfillOrderLineNumber |
NA |
number($int15) example:2 |
If the transaction is for a customer order, this is the line number on the order that this item transactions aligns with. |
reservationType |
NA |
If the transaction is a custoemr order, this is the type of reservation. Valid values are: 1 - Web Order 2 - Special Order 3 - Pickup or Delivery 4 - Layaway 5 - On Hold Enum:[ 1, 2, 3, 4, 5 ] |
transactionCode |
Yes |
integer($int4) example: 1 |
A code that indicates the transaction event that took place on item. Valid values are: 1 - Sale 2 - Return 3 - Void Sale 4 - Void Return 5 - Order New 6 - Order Fulfill 7 - Order Cancel Enum: [ 1, 2, 3, 4, 5, 6, 7 ] |
comments |
NA |
string($text512) example: Item packaging is slightly damaged. |
Comments associated to this line item of the transaction. |
REST Service: Product Area
A product area consists of an item basket (group of items) associated to a group of stores. Areas are used within customer order picking and to manage store order restrictions.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Product Areas
This section describes the Find Product Areas API. This API finds up to 1000 product areas for the input criteria.
Request Parameters
Table 4-172 Find Product Areas — Request Parameters
| Parameter | Required | Data Type | Description |
itemBasketId |
NA |
number($int12) (query) |
Include only product areas that are associated to this item basket. |
description |
NA |
Include only product areas with this description. |
status |
NA |
Include only product areas with this status. Valid values are: 1 - In Progress 2 - Completed 3 - Canceled Available values : 1, 2, 3 |
type |
NA |
integer($int2) (query) |
Include only product areas with this type. Valid values are 1 - Customer Order Picking Available values : 1 |
updateDateFrom |
NA |
Include only product areas with an update date on or after this date. |
updateDateTo |
NA |
Include only product areas with an update date on or before this date. |
Responses
This section describes the responses of the Find Product Areas API.
Response Code: 200
The request has been successful.
The media type is application/json.
Example Value
"productAreaId": 11111,
"itemBasketId": 211933,
"description": "Cold Items",
"status": 1,
"type": 1,
"createStoreId": 5000,
"updateDate": "2024-11-04T14:16:17.231Z",
"updateUser": "john.smith"
]Schema — ProductAreaHeaderIdo
Table 4-173 ProductAreaHeaderIdo — Object
productAreaId |
NA |
number($int12) example: 11111 |
The unique identifier of the product area. |
itemBasketId |
NA |
number($int12) example: 211933 |
The identifier of an item basket associated to the product area. |
description |
NA |
string($text255) example: Cold Items |
A description of the product area. |
status |
NA |
The current status of the product area. Valid values are 1 - In Progress 2 - Completed 3 - Canceled Enum: [ 1, 2, 3 ] |
type |
NA |
The type of the product area. Valid values are: 1 - Customer Order Picking Enum: [ 1 ] |
createStoreId |
NA |
number($int10) example: 5000 |
The identifier of the store that created the product area. |
updateDate |
NA |
The date the product area was last updated. |
updateUser |
NA |
string($text128) example: john.smith |
The user that last updated the product area. |
Create Product Area
This section describes the Create Product Area API. This API creates an in-progress product area.
Request Parameters
There are no parameters.
Example Value
"type": 1,
"stores": [
5000,
5001
Schema — ProductAreaCreateIdo
Table 4-174 ProductAreaCreateIdo — Object
itemBasketId |
NA |
description |
NA |
type |
Yes |
The type of the product area. Valid values are 1 - Customer Order Picking Enum: Array [ 1 ] |
createStoreId |
Yes |
stores |
NA |
example: List [ 5000, 5001 ] |
The stores associated to this product area. |
Responses
This section describes the responses of the Create Product Areas API.
Response Code: 200
Schema — ProductAreaStatusIdo
Table 4-175 ProductAreaStatusIdo — Object
productAreaId |
NA |
status |
NA |
The current status of the product area. Valid values are 1 - In Progress 2 - Completed 3 - Canceled Enum: Array [ 3 ] |
type |
NA |
Read Product Area
This section describes the Read Product Area API. This API retrieves all the details about a product area.
Request Parameters
Table 4-176 Read Product Area — Request Parameters
areaId |
Yes |
number($int12) (path) |
Responses
This section describes the responses of the Read Product Areas API.
Response Code: 200
Example Value
"status": 1,
"type": 1,
"createDate": "2024-11-05T11:49:20.419Z",
"createUser": "smith123",
"updateDate": "2024-11-05T11:49:20.419Z",
"updateUser": "smith123",
"stores": [
5000,
5001
]Schema — ProductAreaIdo
Table 4-177 ProductAreaIdo — Object
productAreaId |
NA |
itemBasketId |
NA |
description |
NA |
status |
NA |
type |
NA |
createStoreId |
NA |
createDate |
NA |
The date the product area was created. |
createUser |
NA |
string($text128) example: smith123 |
The user that created the product area. |
updateDate |
NA |
updateUser |
NA |
stores |
NA |
number($int10)] example: List [ 5000, 5001 ] |
Update Product Area
This section describes the Update Product Area API. This API updates a product area.
Request Parameters
Table 4-178 Update Product Area — Request Parameters
areaId |
Yes |
Item basket details to update.
Cancel Product Area
This section describes the Cancel Product Area API. This API cancels a product area.
Request Parameters
Table 4-180 Cancel Product Area — Request Parameters
areaId |
Yes |
Confirm Product Area
This section describes the Confirm Product Area API. This API confirms the product area making it available for usage.
Request Parameters
Table 4-181 Confirm Product Area — Request Parameters
areaId |
Yes |
REST Service: Product Group
This service allows for the integration of product group with external systems.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/productgroups
APIs
API |
Description |
findProductGroups |
Searches for product group summary headers based on input criteria. |
readProductGroup |
Reads the details about a specific product group. |
createProductGroup |
Creates a new product group including its components. |
updateProductGroup |
Modifies an existing product group including its components. |
cancelProductGroup |
Cancels an existing product group. |
API: findProductGroup
This API is used to search for a product group summary using input criteria.
Table 4-182 API Basics
Endpoint URL |
{base URL} |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Input |
Query parameters |
Output |
Collection of product groups |
5,000 |
Table 4-183 Query Parameters
Query |
Type |
Definition |
storeId |
Long(10) |
Returns only product groups that match this store (which includes all store product groups). |
type |
Integer(3) |
Returns only product groups that match this product group type. See Index for types. |
description |
String(100) |
Returns only products groups that contain this text in its description. |
itemId |
String(25) |
Returns only product groups that contain this individual sku number in its single items list. |
departmentId |
Long(12) |
Returns only product groups that contain this hierarchy department identifier. |
classId |
Long(12) |
Returns only product groups that contain this hierarchy class identifier. |
subclassId |
Long(12) |
Returns only product groups that contain this hierarchy subclass identifier. |
updateDateFrom |
String |
Returns only product groups updated on or after this date. |
updateDateTo |
String |
Returns only product groups updated on or before this date. |
Table 4-184 Output Data Definitions
Payload |
Type |
Definition |
productGroupId |
Long(12) |
The unique product group identifier. |
description |
String(100) |
A description of the product group. |
storeId |
Long(10) |
The store identifier or blank if the product group is for all stores. |
type |
Integer(3) |
Indicates the type of product group. See Index. |
status |
Integer(1) |
Indicates the status of the product group. See Index. |
updateDate |
Date |
The date the product group was last updated. |
API: readProductGroup
This API is used to read a product group.
Table 4-185 API Basics
Endpoint URL |
{base URL}/{productGroupId} |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Path Parameter |
The identifier of the product group. |
Output |
5,000 |
Table 4-186 Output Data Definition
Payload |
Type |
Definition |
productGroupId |
Long(12) |
The unique identifier of the product group. |
description |
String(100) |
storeId |
Long(10) |
The unique identifier of a store associated to the product group. This will be blank/null if the product group is for all stores. |
type |
Integer(3) |
status |
Integer(1) |
unitOfMeasureMode |
Integer(4) |
Unit of measure type for pick list product groups. See Index. |
allItemGroup |
Boolean |
True indicates the product group is for all items. If set to true, then hierarchies and items will not be present. |
updateDate |
Date |
stockCountDetail |
Object |
Details about a stock count product group (used for all three stock count types). This will only be populated if the product group type is for a stock count. |
replenishmentDetail |
Object |
Details about a replenishment product group. This will only be populated if the product group type is for replenishment. |
storeOrderDetail |
Object |
Details about a store order product group. This will only be populated if the product group type is for store orders. |
autoAdjustmentDetail |
Object |
Details about an auto inventory adjustment product group. This will only be populated if the product group type is for auto adjustments. |
autoTicketPrintDetail |
Object |
Details about an auto ticket print product group. This will only be populated if the product group type is for auto ticket print. |
hierarchies |
List<Object> |
A list of merchandise item hierarchies that belong to the group. |
itemIds |
List<String(25)> |
A list of item SKU numbers associated to the product group. |
Table 4-187 Stock Count Detail
Payload |
Type |
Definition |
countingMethod |
Integer |
The method of counting a stock count: See Index (StockCountingMethod) |
breakdownType |
Integer |
The method of breaking a stock count down into child counts: See Index (StockCountBreakdownType) |
varianceCount |
Integer(8) |
The number of units in standard unit of measure considered discrepant on a stock count. |
variancePercent |
BigDecimal(12,4) |
The percentage of units in standard unit of measure considered discrepant on a stock count. |
varianceValue |
BigDecimal(12,4) |
The value of units considered discrepant on a stock count. This will only be populated for unit and amount stock count product group type. |
performRecount |
Boolean |
True indicates the stock count should be recounted if discrepancies are found. |
autoAuthorize |
Boolean |
True indicates the stock count should be automatically authorized after count. |
activeItems |
Boolean |
True indicates active items should be included on the stock count. |
inactiveItems |
Boolean |
True indicates inactive items should be included on the stock count. |
discontinuedItems |
Boolean |
True indicates discontinued items should be included on the stock count. |
deletedItems |
Boolean |
True indicates deleted items should be included on the stock count. |
zeroStockOnHand |
Boolean |
True indicates items with 0 stock on hand should be included on the stock count. |
positiveStockOnHand |
Boolean |
True indicates items with positive stock on hand should be included on the stock count. |
negativeStockOnHand |
Boolean |
True indicates items with negative stock on hand should be included on the stock count. |
problemLineNegativeAvailable |
Boolean |
True indicates to include items with negative available quantities. This will only be populated if the product group type is for a problem line stock count. |
problemLinePickLessSuggested |
Boolean |
True indicates to include pick lists less than suggested amount. This will only be populated if the product group type is for a problem line stock count. |
problemLineReplenishLessSuggested |
Boolean |
True indicates to include shelf replenishments that are less than the suggested amount. This will only be populated if the product group type is for a problem line stock count. |
problemLineUinDiscrepancy |
Boolean |
True indicates UIN discrepancies should be included in the stock count. This will only be populated if the product group type is for a problem line stock count. |
Table 4-188 Replenishment Detail
Payload |
Type |
Definition |
autoReplenishment |
Boolean |
True indicates that the product group is eligible for automatic replenishment through a scheduled batch run. |
differentiatorMode |
Integer(3) |
The display type of the diffentiator. See Index. |
Table 4-189 Store Order Detail
Payload |
Type |
Definition |
daysBeforeDelivery |
Integer(3) |
The date calculated from the creation date that the user wants the store order delivery by. |
storeOrderAddItems |
Boolean |
True indicates items can be added to the store order after it has been generated by the system. |
storeOrderItemsOnly |
Boolean |
Y indicates the store order can only include items that are marked as store order replenishment. |
restrictSupplierId |
Long(12) |
Limits the creation of a store order from this product group to only this supplier. |
restrictWarehouseId |
Long(12) |
Limits the creation of a store order from this product group to only this warehouse. |
restrictHierarchyId |
Long(12) |
Limits the creation of a store order from this product group to only this merchandise hierarchy. |
restrictAreaId |
Long(12) |
Limits the creation of a store order from this product group to only this store sequence area. |
Table 4-190 Auto Adjustment Detail
Payload |
Type |
Definition |
adjustmentQuantity |
BigDecimal(20,4) |
The quantity that should be automatically adjusted by this product group. |
adjustmentPercent |
BigDecimal(20,4) |
The percentage of quantity that should be automatically adjusted by this product group. |
adjustmentReasonCode |
Long(12) |
The unique identifier of a reason code associated to this product group. |
updateToZero |
Boolean |
Update stock to zero when generating adjustment with this product group. |
Table 4-191 Auto Ticket Print Detail
Payload |
Type |
Definition |
refreshTicketQuantity |
Boolean |
True if the ticket quantity should be refreshed prior to printing. |
Table 4-192 Item Hierarchy Detail
Payload |
Type |
Definition |
departmentId |
Long(12) |
The department identifier |
classId |
Long(12) |
The class identifier |
subclassId |
Long(12) |
The subclass identifier |
API: createProductGroup
This API is used to create a new product group that will be in progress status.
Table 4-193 API Basics
Endpoint URL |
{base URL} |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Input |
Product Group |
Output |
Product Group Status |
5,000 |
Table 4-194 Input Data Definition
Payload |
Type |
Req |
Definition |
description |
String(100) |
X |
type |
Integer(3) |
X |
storeId |
Long(10) |
allItems |
Boolean |
True if the product group is for all items, false otherwise. If all items, any hierarchies and items included will be ignored. |
unitOfMeasureMode |
Integer |
Unit of measure type for pick lists. See Index.. |
Object |
Details about an auto inventory adjustment product group. This is only processed and is required if the type is auto inventory adjustment type. |
Object |
Details about an auto ticket print product group. This is only processed and is required if the type is auto ticket print. |
Object |
Details about a replenishment product group. This is only processed and is required if the type is a shelf replenishment type.. |
storeOrderDetail |
Object |
Details about a store order product group. This is only processed and is required if the type is the store order type. |
unitCountDetail |
Object |
Details about a unit stock count product group. This is only processed and is required if the type is a stock count type. |
unitAmountCountDetail |
Object |
Details about a unit and amount stock count product group. This is only processed and is required if the type is a stock count type. |
problemLineCountDetail |
Object |
Details about a problem line stock count product group. This is only processed and is required if the type is a stock count type. |
hierarchies |
List<Object> |
A list of up to 5,000 unique merchandise item hierarchies that belong to the group (avoid duplicate or overlapping hierarchies). |
itemIds |
List<String(25)> |
A list of up to 5,000 unique item SKU numbers on the product group. |
Table 4-195 Unit Count Detail
Payload |
Type |
Req |
Definition |
countingMethod |
Integer |
X |
breakdownType |
Integer |
X |
The method of breaking a stock count down into child counts: See Index (StockCountBreakdownType). Must be "Location" for guided counts. |
varianceCount |
Integer(8) |
The number of units in standard unit of measure considered discrepant on a stock count. Variance count and percent cannot both be empty. |
variancePercent |
BigDecimal(12,4) |
The percentage of units in standard unit of measure considered discrepant on a stock count. Variance count and percent cannot both be empty. |
performRecount |
Boolean |
True indicates the stock count should be recounted if discrepancies are found. This cannot be set to true if the counting method is "Third Party. |
autoAuthorize |
Boolean |
activeItems |
Boolean |
True indicates active items should be included on the stock count. At least one item status choice is required as true. |
inactiveItems |
Boolean |
True indicates inactive items should be included on the stock count. At least one item status choice is required as true. |
discontinuedItems |
Boolean |
True indicates discontinued items should be included on the stock count. At least one item status choice is required as true. |
deletedItems |
Boolean |
True indicates deleted items should be included on the stock count. At least one item status choice is required as true. |
zeroStockOnHand |
Boolean |
True indicates items with 0 stock on hand should be included on the stock count. At least one stock choice is required as true. |
Boolean |
True indicates items with positive stock on hand should be included on the stock count. At least one stock choice is required as true. |
Boolean |
True indicates items with negative stock on hand should be included on the stock count. At least one stock choice is required as true. |
Table 4-196 Unit and Amount Count Detail
Payload |
Type |
Req |
Definition |
countingMethod |
Integer |
X |
breakdownType |
Integer |
X |
varianceCount |
BigDecimal(12,4) |
The number of units in standard unit of measure considered discrepant on a stock count. Count, percent, and value cannot all be empty. |
variancePercent |
BigDecimal(12,4) |
The percentage of units in standard unit of measure considered discrepant on a stock count. Count, percent, and value cannot all be empty. |
varianceValue |
BigDecimal(12,4) |
The value of units considered discrepant on a stock count. Count, percent, and value cannot all be empty. |
performRecount |
Boolean |
True indicates the stock count should be recounted if discrepancies are found. This cannot be set to true if the counting method is "Third Party". |
autoAuthorize |
Boolean |
zeroStockOnHand |
Boolean |
Table 4-197 Problem Line Count Detail
Payload |
Type |
Req |
Definition |
countingMethod |
Integer |
X |
The method of counting a stock count: See Index (StockCountingMethod). |
breakdownType |
Integer |
X |
autoReplenishment |
Boolean |
Integer(3) |
The display type of the differentiator. See Index. |
varianceCount |
BigDecimal(12,4) |
variancePercent |
BigDecimal(12,4) |
The percentage of units in standard unit of measure considered discrepant on a stock count. Variance count and percent cannot both be empty |
performRecount |
Boolean |
True indicates the stock count should be recounted if discrepancies are found. This cannot be set to true if the counting method is "Third Party." |
autoAuthorize |
Boolean |
Boolean |
negativeAvailable |
Boolean |
True indicates to include items with negative available quantities. |
pickLessSuggested |
Boolean |
True indicates to include pick lists less than suggested amount. |
replenishLessSuggested |
Boolean |
True indicates to include shelf replenishments that are less than the suggested amount. |
uinDiscrepancy |
Boolean |
Table 4-198 Store Order Detail
Payload |
Type |
Req |
Definition |
Integer(3) |
Boolean |
Boolean |
Y indicates can only include items that are marked as store order replenishment. |
Long(12) |
Long(12) |
Long(12) |
restrictAreaId |
Long(12) |
Table 4-199 Auto Adjustment Detail
Payload |
Type |
Req |
Definition |
BigDecimal(20,4) |
The quantity that should be automatically adjusted by this product group. Either quantity or percent is required. |
adjustmentPercent |
BigDecimal(20,4) |
The percentage of quantity that should be automatically adjusted by this product group. Either quantity or percent is required. |
Long(12) |
X |
updateToZero |
Boolean |
Table 4-200 Auto Ticket Print Detail
Payload |
Type |
Req |
Definition |
Boolean |
Table 4-201 Item Hierarchy Detail
Payload |
Type |
Req |
Definition |
departmentId |
Long(12) |
X |
classId |
Long(12) |
subclassId |
Long(12) |
Table 4-202 Output Data Definition
Attribute |
Type |
Definition |
productGroupId |
Long(12) |
The product group identifier. |
status |
Integer(1) |
Indicates the status of the product group: (0) Active, (1) Canceled |
Figure 4-1 Example input unitCountDetail
Figure 4-2 Example input unitAmountCountDetail:
Figure 4-3 Example input problemLineCountDetail:
Figure 4-4 Example input autoAdjustmentDetail:
Figure 4-5 Example input autoTicketPrintDetail:
Figure 4-6 Example input replenishmentDetail:
Figure 4-7 Example input storeOrderDetail:
API: updateProductGroup
This API is used to modify a product group.
See API createProductGroup for the data definition of the product group type data objects.
API Basics
Table 4-203 API Basics
Endpoint URL |
Method |
POST |
Successful Response |
200 OK |
Processing Type |
Synchronous |
Path Parameter |
The identifier of the product group |
Input |
Product Group |
Output |
Payload |
Type |
Req |
Definition |
storeId |
Long(10) |
The unique identifier of a store associated to the product group. This will be blank/null if the product group is for all stores. If this is altered for a unit and amount group already assigned to schedules, it may return a validate error that it can no longer be altered. |
description |
String(100) |
X |
allItems |
Boolean |
True if the product group is for all items, false otherwise. If all items, any hierarchies and items included will be ignored. Unit of measure type for pick lists. See Index. |
unitOfMeasureMode |
Integer |
ProductGroupAdjustmentIdo |
ProductGroupTicketPrintIdo |
ProductGroupReplenishmentIdo |
Details about a replenishment product group. This is only processed and is required if the type is a shelf replenishment type. |
storeOrderDetail |
ProductGroupStoreOrderIdo |
unitCountDetail |
ProductGroupUnitCountIdo |
ProductGroupUnitAmountCountIdo |
ProductGroupProblemLineCountIdo |
hierarchies |
ProductGroupHierarchyIdo |
A list of up to 5,000 unique merchandise item hierarchies that belong to the group (avoid duplicates or overlapping hierarchies). |
itemIds |
List<String(25)> |
Figure 4-8 Example Input unitCountDetail:
Figure 4-9 Example Input unitAmountCountDetail:
Figure 4-10 Example Input problemLineCountDetail:
Figure 4-11 Example Input autoAdjustmentDetail:
Figure 4-12 Example Input autoTicketPrintDetail:
Figure 4-13 Example Input replenishmentDetail:
Figure 4-14 Example Input storeOrderDetail:
API: cancelProductGroup
Cancels the product group.
Table 4-204 API Basics
Endpoint URL |
{base URL}/{productGroupId}/cancel |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Path Parameter |
Index
Table 4-205 Product Group Type
ID |
Description |
1 |
Stock Count: Unit |
2 |
Stock Count: Unit and Amount |
3 |
Stock Count: Problem Line |
4 |
Auto Inventory Adjustment |
5 |
Auto Ticket Print |
6 |
7 |
Store Order |
Table 4-206 Product Group Status
ID |
Description |
1 |
Active |
2 |
Canceled |
Table 4-207 Unit of Measure Mode
ID |
Description |
1 |
Standard |
2 |
Cases |
3 |
Preferred |
Table 4-208 Shelf Replenishment Differentiator Mode
ID |
Description |
1 |
Differentiator 1 |
2 |
Differentiator 2 |
3 |
Differentiator 3 |
4 |
Differentiator 4 |
Table 4-209 Stock Counting Method
ID |
Description |
1 |
Guided |
2 |
Unguided |
3 |
Third Party |
4 |
Auto |
Table 4-210 Stock Count Breakdown Type
ID |
Description |
1 |
Department |
2 |
Class |
3 |
Subclass |
4 |
Location |
5 |
None |
REST Service: Product Group Schedule
A product group schedule allows the customer to schedule different kinds of product groups for work. A product group can be scheduled for a date range where the start date must be greater than today. For unit and amount counts, the start date must be greater than today plus the configured stock count lockout days. Schedules are setup daily, weekly, monthly, or yearly. Schedules may be assigned to execute for all stores or created for selected specific stores. Once a product group schedule is created, it becomes available for the system batches to pick up and execute. This service defines operations to manage product group schedule information by integration with an external system.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Schedules
This section describes the Find Schedules API. This API finds up to a maximum of 5,000 schedule summary headers based on input search criteria.
Request Parameters
Table 4-211 Find Schedules — Request Parameters
productGroupId |
NA |
integer($int10) (query) |
Include only schedules associated to this product group. |
description |
NA |
string($text250) (query) |
Include only schedules that contain this text in its description. |
type |
NA |
integer($int3) (query) |
Include only schedules that match this schedule type. Valid values are: 1 - Daily 2 - Daily By Weekday 3 - Weekly 4 - Monthy by Day 5 - Monthly By Week 6 - Yearly By Day 7 - Yearly By Week Available values : 1, 2, 3, 4, 5, 6, 7 |
status |
NA |
Include only schedules that match this status. Valid values are: 1 - Open 2 - Closed Available values : 1, 2 |
updateDateFrom |
NA |
string($date-time) (query) |
Include only schedules with an update date on or after this date. |
updateDateTo |
NA |
Include only schedules with an update date on or before this date. |
Responses
This section describes the responses of the Find Schedules API.
Response Code: 200
Example Value
"scheduleId": 11111,
"productGroupId": 223343,
"description": "Test Schedule",
"type": 1,
"status": 1,
"startDate": "2024-11-07T11:17:51.016Z",
"endDate": "2024-11-07T11:17:51.016Z",
"updateDate": "2024-11-07T11:17:51.016Z"
]Schema — ProductGroupScheduleHeaderIdo
Table 4-212 ProductGroupScheduleHeaderIdo — Object
scheduleId |
NA |
integer($int8) example: 11111 |
The unique identifier of the schedule. |
productGroupId |
NA |
number($int12) example: 223343 |
The unique identifier of the product group the schedule is for. |
description |
NA |
string($text250) example: Test Schedule |
A description of the schedule. |
type |
NA |
The type of schedule. Valid values are: 1 - Daily 2 - Daily By Weekday 3 - Weekly 4 - Monthly by Day 5 - Monthly By Week 6 - Yearly By Day 7 - Yearly By Week Enum: [ 1, 2, 3, 4, 5, 6, 7 ] |
status |
NA |
The current status of the schedule. Valid values are: 1 - Open 2 - Closed Enum: [ 1, 2 ] |
startDate |
NA |
The date the schedule becomes active. |
endDate |
NA |
The date the schedule terminates. |
updateDate |
NA |
The date the schedule was last updated. |
Create Schedule
This section describes the Create Schedule API. This API creates a new open schedule.
Request Parameters
Details about the schedule to create.
Example Value
"type": 1,
"startDate": "2024-11-07T11:44:35.142Z",
"endDate": "2024-11-07T11:44:35.142Z",
"dailySchedule": {
"dailyFrequency": 3
"dailyByWeekSchedule": {
"weeklyFrequency": 3,
"sunday": false,
"monday": false,
"tuesday": false,
"wednesday": false,
"thursday": false,
"friday": false,
"saturday": false
"weeklySchedule": {
"sunday": false,
"monday": false,
"tuesday": false,
"wednesday": false,
"thursday": false,
"friday": false,
"saturday": false
"monthlyByDaySchedule": {
"monthlyFrequency": 6,
"dayOfMonth": 10
"monthlyByWeekSchedule": {
"weekOfTheMonth": 1,
"dayOfTheWeek": 7
"yearlyByDaySchedule": {
"monthOfTheYear": 1,
"dayOfTheMonth": 20
"yearlyByWeekSchedule": {
"dayOfTheWeek": 7
"stores": [
333,
444
}Schema — ProductGroupScheduleCreateIdo
Table 4-213 ProductGroupScheduleCreateIdo — Object
productGroupId |
yes |
description |
yes |
type |
yes |
The type of schedule. Only the data set matching this type needs to be included. Valid values are 1 - Daily 2 - Daily By Weekday 3 - Weekly 4 - Monthly by Day 5 - Monthly By Week 6 - Yearly By Day 7 - Yearly By Week Enum: [ 1, 2, 3, 4, 5, 6, 7 ] |
startDate |
NA |
The date the schedule becomes active. This must be tomorrow or a later date except for unit stock counts, which allow for same day scheduling. |
endDate |
NA |
dailySchedule |
object |
daily schedule |
dailyByWeekSchedule |
object |
daily schedule |
weeklySchedule |
object |
weekly schedule |
monthlyByDaySchedule |
object |
monthly by day schedule |
monthlyByWeekSchedule |
object |
monthly by week schedule |
yearlyByDaySchedule |
object |
yearly by day schedule |
yearlyByWeekSchedule |
object |
yearly by week schedule |
stores |
yes |
number($int15)] example: List [ 333, 444 ] |
A list of store identifiers the schedule applies to. |
Table 4-214 ScheduleDailyIdo — Object
dailyFrequency |
yes |
number ($int12) example: 3 |
The number of days between occurrences of the schedule. |
Table 4-215 ScheduleDailyByWeekIdo — Object
weeklyFrequency |
yes |
number($int12) example: 3 |
The number of weeks between occurrences of the schedule. |
sunday |
NA |
boolean example: false |
True if scheduled on Sunday. |
monday |
NA |
True if scheduled on Monday. |
tuesday |
NA |
True if scheduled on Tuesday. |
wednesday |
NA |
True if scheduled on Wednesday. |
thursday |
NA |
True if scheduled on Thursday. |
friday |
NA |
True if scheduled on Friday. |
saturday |
NA |
True if scheduled on Saturday. |
Table 4-216 ScheduleDailyByWeekIdo — Object
weeklyFrequency |
yes |
sunday |
NA |
monday |
NA |
tuesday |
NA |
wednesday |
NA |
thursday |
NA |
friday |
NA |
saturday |
NA |
Table 4-217 ScheduleWeekIyIdo — Object
weeklyFrequency |
yes |
sunday |
NA |
monday |
NA |
tuesday |
NA |
wednesday |
NA |
thursday |
NA |
friday |
NA |
saturday |
NA |
Table 4-218 ScheduleMonthlyByDayIdo — Object
monthlyFrequency |
yes |
number($int12) example: 6 |
The number of months between occurrences. |
dayOfMonth |
yes |
number($int2) example: 10 |
The day of the month to execute the schedule on. Valid values are 1-31 |
Table 4-219 ScheduleMonthlyByWeekIdo— Object
monthlyFrequency |
yes |
The number of months between occurences. |
weekOfTheMonth |
yes |
number($int2) example: 1 |
The week of the month to execute the schedule on. Valid values are 1-5. |
dayOfTheWeek |
yes |
number($int2) example: 7 |
The day of the week to execute the schedule on. Valid values are 1-7. |
Table 4-220 ScheduleYearlyByDayIdo— Object
monthOfTheYear |
yes |
The month of the year to execute the schedule on. Valid values are 1-12. |
dayOfTheMonth |
yes |
number($int2) example: 20 |
The day of the month to execute the schedule on. Valid values are 1-31. |
Table 4-221 ScheduleYearlyByWeekIdo — Object
monthOfTheYear |
yes |
weekOfTheMonth |
yes |
dayOfTheWeek |
yes |
Responses
This section describes the responses of the Create Schedules API.
Response Code: 200
Example Value
"type": 1,
"status": 1,
Table 4-222 ProductGroupScheduleHeaderIdo — Object
scheduleId |
NA |
productGroupId |
NA |
description |
NA |
type |
NA |
status |
NA |
startDate |
NA |
endDate |
NA |
updateDate |
NA |
Read Schedule
This section describes the Read Schedules API. This API retrieves all the details about a product group schedule.
Request Parameters
Table 4-223 Read Schedule — Request Parameters
scheduleId |
yes |
integer($int12) (path) |
Responses
This section describes the responses of the Read Schedule API.
Response Code: 200
Example Value
"type": 1,
"status": 1,
"startDate": "2024-11-11T12:49:09.159Z",
"endDate": "2024-11-11T12:49:09.159Z",
"updateDate": "2024-11-11T12:49:09.159Z",
"dailySchedule": {
"dailyFrequency": 3
"sunday": false,
"monday": false,
"tuesday": false,
"wednesday": false,
"thursday": false,
"friday": false,
"saturday": false
"weeklySchedule": {
"sunday": false,
"monday": false,
"tuesday": false,
"wednesday": false,
"thursday": false,
"friday": false,
"saturday": false
"dayOfMonth": 10
"dayOfTheWeek": 7
"dayOfTheMonth": 20
"dayOfTheWeek": 7
"stores": [
"storeId": 5000,
"lastExtractedDate": "2024-11-11T12:49:09.159Z"
]Schema — ProductGroupScheduleIdo
Table 4-224 ProductGroupScheduleIdo — Object
scheduleId |
NA |
productGroupId |
NA |
number($int12) example: 22334 |
description |
NA |
type |
NA |
The type of schedule. Valid values are 1 - Daily 2 - Daily By Weekday 3 - Weekly 4 - Monthly by Day 5 - Monthly By Week 6 - Yearly By Day 7 - Yearly By Week Enum: [ 1, 2, 3, 4, 5, 6, 7 ] |
status |
NA |
The current status of the schedule. Valid values are 1 - Open 2 - Closed Enum: [ 1, 2 ] |
startDate |
NA |
endDate |
NA |
updateDate |
NA |
The date the schedule was lasted updated. |
dailySchedule |
NA |
object |
daily schedule |
NA |
object |
daily by week schedule |
weeklySchedule |
NA |
object |
weekly schedule |
NA |
object |
NA |
object |
NA |
object |
NA |
object |
stores |
NA |
object |
A list of stores associated to the schedule. |
Table 4-225 ScheduleDailyIdo — Object
dailyFrequency |
yes |
Table 4-226 ScheduleDailyByWeekIdo — Object
weeklyFrequency |
yes |
sunday |
NA |
monday |
NA |
tuesday |
NA |
wednesday |
NA |
thursday |
NA |
friday |
NA |
saturday |
NA |
Table 4-227 ScheduleWeeklyIdo — Object
weeklyFrequency |
yes |
sunday |
NA |
monday |
NA |
tuesday |
NA |
wednesday |
NA |
thursday |
NA |
friday |
NA |
saturday |
NA |
Table 4-228 ScheduleMonthlyByDayIdo — Object
weeklyFrequency |
yes |
dayOfMonth |
yes |
Table 4-229 ScheduleMonthlyByWeekIdo — Object
weeklyFrequency |
yes |
weekOfTheMonth |
yes |
dayOfTheWeek |
yes |
Table 4-230 ScheduleYearlyByDayIdo — Object
weeklyFrequency |
yes |
number($int12) example: 1 |
dayOfTheMonth |
yes |
Table 4-231 ScheduleYearlyByWeekIdo — Object
monthOfTheYear |
yes |
weekOfTheMonth |
yes |
dayOfTheWeek |
yes |
Table 4-232 ProductGroupScheduleStoreIdo — Object
storeId |
NA |
The unique identifier of the store. |
lastExtractedDate |
NA |
The date the schedule was lasted extracted for this store. |
Update Schedule
This section describes the Update Schedule API. This API updates the details of an open schedule.
Request Parameters
Table 4-233 Update Schedule — Request Parameters
scheduleId |
yes |
Details to update within the schedule.
Example Value
"type": 1,
"endDate": "2024-11-11T14:08:23.049Z",
"dailySchedule": {
"dailyFrequency": 3
"sunday": false,
"monday": false,
"tuesday": false,
"wednesday": false,
"thursday": false,
"friday": false,
"saturday": false
"weeklySchedule": {
"sunday": false,
"monday": false,
"tuesday": false,
"wednesday": false,
"thursday": false,
"friday": false,
"saturday": false
"dayOfMonth": 10
"dayOfTheWeek": 7
"dayOfTheMonth": 20
"dayOfTheWeek": 7
"stores": [
333,
444
}Schema — ProductGroupScheduleUpdateIdo
Table 4-234 ProductGroupScheduleUpdateIdo — Object
description |
yes |
type |
yes |
endDate |
NA |
The date the schedule terminates. It must be greater than the start date. |
dailySchedule |
NA |
object |
daily schedule |
NA |
object |
weeklySchedule |
NA |
object |
weekly schedule |
NA |
object |
NA |
object |
NA |
object |
NA |
object |
yearly by week scheulde |
stores |
yes |
Table 4-235 ScheduleDailyIdo — Object
dailyFrequency |
yes |
Table 4-236 ScheduleDailyByWeekIdo — Object
weeklyFrequency |
yes |
sunday |
NA |
monday |
NA |
tuesday |
NA |
wednesday |
NA |
thursday |
NA |
friday |
NA |
saturday |
NA |
Table 4-237 ScheduleWeeklyIdo — Object
weeklyFrequency |
yes |
sunday |
NA |
monday |
NA |
tuesday |
NA |
wednesday |
NA |
thursday |
NA |
friday |
NA |
saturday |
NA |
Table 4-238 ScheduleMonthlyByDayIdo — Object
weeklyFrequency |
yes |
dayOfMonth |
yes |
Table 4-239 ScheduleMonthlyByWeekIdo — Object
weeklyFrequency |
yes |
weekOfTheMonth |
yes |
dayOfTheWeek |
yes |
Table 4-240 ScheduleYearlyByDayIdo — Object
weeklyFrequency |
yes |
dayOfTheMonth |
yes |
Table 4-241 ScheduleYearlyByWeekIdo — Object
monthOfTheYear |
yes |
weekOfTheMonth |
yes |
dayOfTheWeek |
yes |
Delete Schedule
This section describes the Delete Schedule API. This API deletes a schedule from the system.
Request Parameters
Table 4-242 Delete Schedule — Request Parameters
scheduleId |
yes |
REST Service: Purchase Order
A purchase order is a document that indicates items and quantities that have been ordered for delivery to the store within a specific timeframe. The order can be created by the supplier or store user on the fly or alternatively by corporate users. These are used for Direct Store Delivery (or vendor/supplier deliveries). This service allows the direct integration of customer orders from a third party system as well as some management of the order with the system.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Orders
This section describes the Find Orders API. This API finds up to 5,000 purchase orders headers for the input criteria. No item information is returned.
Request Parameters
Table 4-243 Find Orders — Request Parameters
orderNumber |
NA |
string($text128) (query) |
Include only purchase orders associated to this external order number. |
storeId |
NA |
number($int10) (query) |
Include only purchase orders for this store. |
supplierId |
NA |
Include only purchase orders for this supplier. |
status |
NA |
integer($int4) (query) |
Include only purchase orders in this status. Valid values are: 1 - Approved 2 - In Progress 3 - Canceled 4 - Completed 99 - Active Available values : 1, 2, 3, 4, 99 |
updateDateFrom |
NA |
Include only purchase orders with an update date on or after this date. |
updateDateTo |
NA |
Include only purchase orders with an update date on or before this date. |
Responses
This section describes the responses of the Find Orders API.
Response Code: 200
Example Value
"purchaseOrderId": 11111,
"orderNumber": "4823534",
"storeId": 5000,
"supplierId": 5101,
"status": 1,
"customerOrderId": "799003",
"fulfillmentOrderId": "7994203",
"notBeforeDate": "2025-01-02T09:18:14.032Z",
"notAfterDate": "2025-01-02T09:18:14.032Z",
"updateDate": "2025-01-02T09:18:14.032Z",
"completeDate": "2025-01-02T09:18:14.032Z"
]Schema — PurchaseOrderHearderIdo
Table 4-244 PurchaseOrderHearderIdo— Object
purchaseOrderId |
NA |
The unique identifier of the purchase order. |
orderNumber |
NA |
string($text128) example: 4823534 |
The non-unique order number of the purchase order in an external system. |
storeId |
NA |
The identifier of the store receiving the inventory. |
supplierId |
NA |
number($int10) example: 5101 |
The identifier of the supplier shipping the goods. |
status |
NA |
The current status of the purchase order. Valid values are: 1 - Approved 2 - In Progress 3 - Canceled 4 - Completed Enum: [ 1, 2, 3, 4 ] |
customerOrderId |
NA |
string($text128) example: 799003 |
A customer order identifier if associated to a customer order. |
NA |
string($text128) example: 7994203 |
A fulfillment order identifier if associated to a customer order. |
notBeforeDate |
NA |
Earliest date that the inventory should arrive at the store for this order. |
notAfterDate |
NA |
Latest date that the inventory can arrive at the store for this order. |
updateDate |
NA |
The date the purchase order was last updated. |
completeDate |
NA |
The date the purchase order was completed. |
Read Order By ID
This section describes the Read Order By ID API. This API reads a store level purchase order by its unique system identifier. This operation retrieves the full information of the purchase order within the context of the store including items and quantities.
Request Parameters
Table 4-245 Read Order By ID — Request Parameters
purchaseOrderId |
yes |
The unique EICS identifier of the purchase order. |
Responses
This section describes the responses of the Read Order By ID API.
Response Code: 200
Example Value
"storeId": 5000,
"supplierId": 5101,
"status": 1,
"externalStatus": 1,
"notBeforeDate": "2025-01-02T09:59:21.146Z",
"notAfterDate": "2025-01-02T09:59:21.146Z",
"comments": "Summer product pre-order",
"source": "POXD",
"createDate": "2025-01-02T09:59:21.146Z",
"updateDate": "2025-01-02T09:59:21.146Z",
"completeDate": "2025-01-02T09:59:21.146Z",
"lineItems": [
"lineId": 11111,
"itemId": "11111",
"supplierCountryCode": "US",
"supplierCaseSize": 5,
"quantityOrdered": 20,
"quantityReceived": 20,
"unitCostCurrency": "USD",
"unitCostValue": 10,
"preferredUom": "LBS",
"published": true
]Schema — PurchaseOrderIdo
Table 4-246 PurchaseOrderIdo — Object
purchaseOrderId |
NA |
orderNumber |
NA |
storeId |
NA |
supplierId |
NA |
status |
NA |
externalStatus |
NA |
The current status of the purchase order in the originating system. Valid values are: 1 - Worksheet 2 - Submitted 3 - Approved 4 - Closed Enum: [ 1, 2, 3, 4 ] |
notBeforeDate |
NA |
notAfterDate |
NA |
comments |
NA |
string($text2000) example: Summer product pre-order |
Comments associated to the purchase order. |
customerOrderId |
NA |
NA |
source |
NA |
string($text25) example: POXD |
Text indicating the system that originated the purchase order. |
createUser |
NA |
The user that created the purchase order within the system. |
createDate |
NA |
The date the purchase order was created within the system. |
updateDate |
NA |
completeDate |
NA |
lineItems |
NA |
object |
A collection of line items on the purchase order. |
Table 4-247 PurchaseOrderLineItemIdo — Object
lineId |
NA |
number($int15) example: 11111 |
The unique identifier of the line item record. |
itemId |
NA |
string($text25) example: 11111 |
The unique identifier of the item. |
supplierCountryCode |
NA |
string($text3) example: US |
The country code of the supplier country of origin. |
supplierCaseSize |
NA |
number($decimal(10,2)) example: 5 |
The case size coming from the supplier. |
quantityOrdered |
NA |
number($decimal(20,4)) example: 20 |
The number of units (in standard unit of measure) expected to be delivered to the store. |
quantityReceived |
NA |
The number of units (in standard unit of measure) received to date against the order. |
unitCostCurrency |
NA |
string($text3) example: USD |
The unit cost ISO currency code. |
unitCostValue |
NA |
number($decimal(12,4)) example: 10 |
The unit cost value of the line item. |
preferredUom |
NA |
string($text4) example: LBS |
The preferred unit of measure of the line item. |
published |
NA |
boolean example: true |
True indicates the line item has been published out to an exteral system, false otherwise. This is used when the purchase order originates within EICS. |
Read Order
This section describes the Read Order API. This API reads a store level purchase order by its external identifier. This operation retrieves the full information of the purchase order within the context of the store including items and quantities.
Request Parameters
Table 4-248 Read Order — Request Parameters
orderNumber |
yes |
string($text128) (path) |
The external identifier of the purchase order. |
storeId |
yes |
number ($int10) (path) |
The store identifier of the purchase order. |
Responses
This section describes the responses of the Read Order API.
Response Code: 200
Example Value
"storeId": 5000,
"supplierId": 5101,
"status": 1,
"notBeforeDate": "2025-01-02T10:32:05.695Z",
"notAfterDate": "2025-01-02T10:32:05.695Z",
"source": "POXD",
"createDate": "2025-01-02T10:32:05.695Z",
"updateDate": "2025-01-02T10:32:05.695Z",
"completeDate": "2025-01-02T10:32:05.695Z",
"lineItems": [
"lineId": 11111,
"itemId": "11111",
"published": true
Table 4-249 PurchaseOrderIdo — Object
purchaseOrderId |
NA |
orderNumber |
NA |
storeId |
NA |
supplierId |
NA |
status |
NA |
externalStatus |
NA |
notBeforeDate |
NA |
notAfterDate |
NA |
comments |
NA |
customerOrderId |
NA |
NA |
source |
NA |
createUser |
NA |
createDate |
NA |
updateDate |
NA |
completeDate |
NA |
lineItems |
NA |
object |
Table 4-250 PurchaseOrderLineItemIdo — Object
lineId |
NA |
itemId |
NA |
NA |
supplierCaseSize |
NA |
quantityOrdered |
NA |
quantityReceived |
NA |
unitCostCurrency |
NA |
unitCostValue |
NA |
preferredUom |
NA |
published |
NA |
Close Order
This section describes the Close Order API. This API closes an existing purchase order. An already closed order will ignore the request and successfully return. If a store is not managed and the system is not configured to override, the request will also be ignored. If quantities are already received, the purchase order will go to completed status, otherwise it will be cancelled. A forbidden error response will occur if the application is integrated with Oracle Merchandising.
Request Parameters
Table 4-251 Close Order— Request Parameters
orderNumber |
yes |
The external order number of the purchase order. |
Import Order
This section describes the Import Order API. This API imports of approved purchase orders ared is staged and processed asynchronously by the MPS work queue DcsOrder. If the order number exists already, the order will be treated as an update. If the order number does not exist, a new order will be created. If a record for item and store combination is found for an item, then the item will be updated, otherwise a new line item will be created for the item-store combination. Items cannot be removed from already existing purchase orders, however, their ordered quantity can be reduced to zero. If the system is integrated with Oracle Merchandising, then this operation will return a Forbidden response. As an asynchronous service, minimal validation will be done prior to submitting the information for later processing. Business validation that fails during asynchronous processing can be found along with the processing message in the MPS staged message table.
Request Parameters
Table 4-252 Import Order— Request Parameters
orderNumber |
yes |
Example Value
"supplierId": 5101,
"notBeforeDate": "2025-01-02T11:14:26.297Z",
"notAfterDate": "2025-01-02T11:14:26.297Z",
"unitCostCurrency": "799003",
"source": "POXD",
"lineItems": [
"itemId": "11111",
"storeId": 5000,
"unitCost": 10,
"published": true
Schema — PurchaseOrderImportIdo
Table 4-253 PurchaseOrderImportIdo — Object
supplierId |
Yes |
externalStatus |
Yes |
The current status of the purchase order. Valid values are 1 - Worksheet 2 - Submitted 3 - Approved 4 - Closed Enum: [ 1, 2, 3, 4 ] |
notBeforeDate |
NA |
notAfterDate |
NA |
unitCostCurrency |
Yes |
string($text3) example: 799003 |
The currency code of the unit costs of the items on this purchase order. |
customerOrderId |
NA |
A customer order identifier if associated to a customer order. This is only accepted only when the purchase order is originally created and will not be modified on an update. |
NA |
A fulfillment order identifier if associated to a customer order. This is accepted only when the purchase order is originally created and will not be modified on an update. |
source |
Yes |
Text indicating the system that originated the purchase order. This is only used when the purchase order is originally created and will not be modified on an update. |
comments |
NA |
lineItems |
Yes |
object |
Table 4-254 PurchaseOrderImportItemIdo — Object
itemId |
Yes |
storeId |
Yes |
Yes |
The country code of the supplier country of origin. This value will be ignored on an update of the item/store combination. |
supplierCaseSize |
NA |
quantityOrdered |
Yes |
unitCost |
NA |
preferredUom |
NA |
published |
NA |
REST Service: Reason Code
This service allows and external system to retrieve available reason codes. Reason codes are attached to inventory adjustments or shipments.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/ reasoncodes
API Definitions
| API | Description |
Find Adjustment Reason Codes |
Finds reason codes available for inventory adjustments. |
Find Shipment Reason Codes |
Finds reason codes available for shipments. |
API: Find Adjustment Reason Codes
This API is used to find reason codes available for inventory adjustments.
API Basics
Endpoint URL |
{base URL} /adjustments |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Input |
None |
Output |
List of inventory adjustment reasons |
Max Response Limit |
N/A |
Attribute |
Data Type |
Description |
reasonId |
Long |
The unique identifier of the inventory adjustment reason code. |
reasonCode |
Integer |
Unique reason code associated to external systems. |
description |
String |
A description of the inventory reason code. |
dispositionCode |
Integer |
The inventory disposition associated to the code. |
dispositionDescription |
String |
A description of the inventory disposition associated to the code (not translated). |
fromNonSellableType |
Long |
From unavailable sub-bucket (indicates the sub-bucket of disposition of stock movement) |
fromNonSellableTypeDescription |
String |
The description of the from unavailable sub-bucket (not translated). |
toNonSellableType |
Long |
To unavailable sub-bucket (indicates the sub-bucket of disposition of stock movement) |
toNonSellableTypeDescription |
String |
The description of the to unavailable sub-bucket (not translated). |
systemRequired |
Boolean |
True indicates the reason code is required for the system to function. A system required reason code cannot be deactivated. |
displayable |
Boolean |
True indicates the reason code can be used by a transactional inventory adjustment created by an entity other than EICS internal service. |
publish |
Boolean |
True indicating inventory movements with this reason code should be published to external systems |
Example Input
"reasonId": 1,
"reasonCode": 1,
"description": “invAdjReason.1",
"dispositionCode": 4,
"dispositionDescription": "inventoryDisposition.ATS-DIST",
"systemRequired": true,
"displayable": false,
"publish": true
"reasonId": 2,
"reasonCode": 81,
"description": "invAdjReason.81",
"systemRequired": false,
"displayable": true,
"publish": true
API: Find Shipment Reason Codes
Finds all the reason codes in the system available for any type of shipment. You can use properties of the reason code to determine if it is available for usage on a particular transaction.
API Basics
Endpoint URL |
{base URL} /shipments |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Input |
None |
Output |
List of reasons codes |
N/A |
Attribute |
Data Type |
Description |
reasonId |
Long |
reasonCode |
String |
description |
String |
A description of the inventory reason code (not translated). |
type |
Integer |
The Shipment Reason Code Type: See the Shipment Reason Code Type. A reason code can only be used on a transaction that matches its type. For example, 3 – Warehouse can only be used on a store to warehouse shipment. |
useAvailable |
Boolean |
True if it must use available inventory, false indicates it must use unavailable inventory. The reason code will need to match the type of inventory being shipped. |
nonSellableTypeId |
Long |
An identifier of associated unavailable sub-bucket (indicates the sub-bucket of disposition of stock movement) |
Example Input
"reasonId": 1,
"reasonCode": "F",
"description": "shipmentReason.4.F",
"type": 4,
"useAvailable": true
“reasonId": 2,
"reasonCode": "O",
"description": "shipmentReason.4.O",
"type": 4,
"reasonId": 3,
"reasonCode": "U",
"description": "shipmentReason.4.U",
"type": 4,
"useAvailable": false,
"nonSellableTypeId": 1
Additional Data Definitions
Value |
Definition |
1 |
Store |
2 |
Supplier |
3 |
Warehouse |
4 |
Finisher |
5 |
Customer |
RFID
If the point-of-sale record for an item includes an RFID tag, the tag will be moved to a SOLD status indicating it should be out-of-store.
Service Base URL
The Cloud service base URL follows the format:
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Zones
This section describes the Find Zones API. This API finds RFID zones by location type and identifier.
Request Parameters
Table 4-255 Find Zones — Request Parameters
locationType |
NA |
Include only zones with this location type. Valid values are: 1 — Store 2 —Warehouse Available values : 1, 2 |
locationId |
NA |
Include only zones within this locaiton. |
Responses
This section describes the responses of the Find Zones API.
Response Code: 200
Example Value
"zoneId": 11111,
"locationType": 1,
"locationId": 5000,
"externalId": 789012,
"zoneType": 1,
"description": "Front Sale Counter"
]Schema —RfidZoneIdo
Table 4-256 RfidZoneIdo — Object
zoneId |
NA |
The unique identifier of the zone. |
locationType |
NA |
integer($int2) example: 1 |
The type of location of the zone. Valid values are: 1 - Store 2 - Warehouse Enum: [ 1, 2 ] |
locationId |
NA |
The unique identifier of the location. |
externalId |
NA |
number($int15) example: 789012 |
A unique identifier of the zone in an extrenal system. |
zoneType |
NA |
The zone type. Valid values are: 1 - Shopfloor 2 - Backroom 3 - None Enum: [ 1, 2, 3 ] |
description |
NA |
string($text255) example: Front Sale Counter |
A description of the RFID scanning zone. |
Create Zone
This section describes the Create Zone API. This API create a new RFID zone.
Request Parameters
The details of the new zone.
Example Value
"locationType": 1,
"locationId": 5000,
"zoneType": 1,
}Schema — RfidZoneIdo
Table 4-257 RfidZoneCreateIdo — Object
locationType |
Yes |
locationId |
Yes |
externalId |
NA |
A unique identifier of the zone in an external system. |
zoneType |
Yes |
description |
NA |
Responses
This section describes the responses of the Create Zone API.
Response Code: 200
Example Value
"zoneId": 11111,
"locationType": 1,
"locationId": 5000,
"zoneType": 1,
Table 4-258 RfidZoneIdo — Object
zoneId |
NA |
locationType |
NA |
locationId |
NA |
externalId |
NA |
zoneType |
NA |
description |
NA |
Update Zone
This section describes the Update Zone API. This API updates an existing RFID zone.
Request Parameters
Table 4-259 Update Zone — Request Parameters
zoneId |
yes |
The unique identifier of the RFID zone. |
The details to update about the zone.
Schema — RfidZoneUpdateIdo
Table 4-260 RfidZoneUpdateIdo — Object
externalId |
NA |
zoneType |
yes |
The zone type. Valid values are 1 - Shopfloor 2 - Backroom 3 - None Enum: [ 1, 2, 3 ] |
description |
NA |
Delete Zone
This section describes the Delete Zone API. This API deletes an RFID zone.
Request Parameters
Table 4-261 Delete Zone — Request Parameters
zoneId |
yes |
Import Events
This section describes the Import Events API. This API processes up to 1,500 Radio Frequency Identification based events. This processing will update the tag information based on the event as well as the stock on hand positions for the item. Events should be sent in groups of 50-100 at a time for optimal processing speed..
Request Parameters
The request type is application/json.
Details about the events to import.
Example Value
"events": [
"locationType": 1,
"locationId": 5000,
"itemId": "100637120",
"epc": "8347492243434",
"zoneId": 11111,
"eventType": "OBSERVE",
"eventDate": "2024-11-12T10:28:01.725Z"
}Schema — RfidEventListIdo
Table 4-262 RfidEventListIdo — Object
events |
yes |
object |
Events |
Table 4-263 RfidEventIdo — Object
locationType |
yes |
locationId |
yes |
itemId |
yes |
string($text25) example: 100637120 |
The identifier of the item on the RFID tag. |
epc |
yes |
string($text255) example: 8347492243434 |
The electronic product code (SGTIN-96) of the RFID tag. |
zoneId |
NA |
The unique identifier of the zone the tag is in. |
eventType |
yes |
string($text7) example: OBSERVE |
The type of the event. Valid values are: ADD - Indicates a new tag at the facility DELETE - Indicates deactivation at a facility OBSERVE - Indicates tag is present at the facility |
eventDate |
yes |
The date and time the scan event occurred. |
REST Service: Security
This service provides an end point for the management of security information within SIOCS.
Service Base URL
Scope To Be Used
Security services are protected by the security scope, so to obtain a token use this scope - rgbu:siocs:security-<ENV>.
API Definitions
Table 4-264 Security API Definitions
API |
Description |
Import Users |
Imports a collection of user security information changes and processes them synchronously. This allows up to 2,000 users. |
Delete Users |
Deletes security information for the specified users within SIOCS. |
API: Import Users
Table 4-265 API Basics
Endpoint URL |
/security/import/users |
Method |
POST |
202 Accepted |
Processing Type |
synchronous |
Input |
Query parameters |
Output |
N/A |
Max Response |
2000 |
Table 4-266 Input Data Definition
Parameter |
Format |
Required |
Definition |
users |
array |
No |
A list of security changes to import. See below: |
Security Changes to Import |
userName |
string(text128) |
Yes |
The user name of the user. |
addedStores |
array[Integer](int10) |
No |
The stores to be added to the user. |
removedStores |
array[Integer](int10 |
No |
The stores to be removed from the user. |
addedRoles |
array |
No |
The roles to be assigned to the user: roleName — The name of the role, string(text128), required storeId — The identifier of the store for a specific store assignment, or no value for assignment applying to all allowed stores., BigDecimal(int10), optional startDate — The date the role assignment should start to be allowed., date-time, optional endDate — The date the role assignment should stop being allowed., date-time, optional |
removedRoles |
array |
No |
The role assignments to be removed from the user: roleName — The name of the role, string(text128), required storeId — The identifier of the store for a specific store assignment, or no value for assignment applying to all allowed stores., BigDecimal(int10), optional |
Example Input ImportUsers
"users": [
"userName": "abc",
"addedStores":[1000, 2000],
"removedStores":[1001, 2001],
"addedRoles": [
"roleName": "role_a",
"storeId": 3000,
"endDate": "2032-11-19T23:59:59-05:00"
"roleName": "role_c",
"startDate": "2022-11-19T23:59:59-05:00"
"roleName": "role_e",
"removedRoles": [
"storeId": 3001
"roleName": "role_d"
}Table 4-267 Responses
Code |
Description |
202 |
Accepted |
400 |
Bad Request Example: |
API: Delete Users
Table 4-268 API Basics
Endpoint URL |
/security/users/delete |
Method |
POST |
202 Accepted |
Processing Type |
Input |
Query parameters |
Output |
N/A |
Max Response |
Table 4-269 Query Parameter Definitions
Property |
Format |
Required |
Definition |
userNames |
string(text128) |
Yes |
A list of user names to delete information for. Example: |
Table 4-270 Responses
Code |
Description |
202 |
Accepted |
400 |
REST Service: Shelf Adjustment
A shelf adjustment moves quantities between locations within the store. A shelf adjustment to move to back room will move quantities from the shop floor to the back room. A shelf adjustment to update the shop floor will update the shop floor positions with the adjustment quantity. A shelf adjustment to update the backroom will adjust the back room quantities.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Adjustment
This section describes the Find Adjustment API. This API finds up to 1,500 shelf adjustments headers for the input criteria.
Request Parameters
Table 4-271 Find Adjustment — Request Parameters
storeId |
NA |
Include only adjustments for this store. |
status |
NA |
Include only adjustments with this status. Valid values are: 1 - In Progress 2 - Complete Available values : 1, 2 |
type |
NA |
Include only adjustments with this type. Valid values are: 1 - Move To Backroom 2 - Update Shopfloor 3 - Update Backroom Available values : 1, 2, 3 |
itemId |
NA |
string($text25) (query) |
Include only shelf adjsutments with this item. |
userName |
NA |
Include only shelf adjsutments with this username. |
updateDateFrom |
NA |
Include only adjustments with an update date on or after this date. |
updateDateTo |
NA |
Include only adjustments with an update date on or before this date. |
Responses
This section describes the responses of the Find Adjustment API.
Response Code: 200
Example Value
"adjustmentId": 11111,
"storeId": 5000,
"type": 1,
"status": 1,
"userName": "smith123",
"createDate": "2025-01-03T13:12:18.180Z",
"updateDate": "2025-01-03T13:12:18.180Z"
]Schema — ShelfAdjustmentHeaderIdo
Table 4-272 ShelfAdjustmentHeaderIdo— Object
| Element Name | Required | Data Type/Example | Description |
adjustmentId |
NA |
The unique identifier of the shelf adjustment. |
storeId |
NA |
The store of the shelf adjustment. |
type |
NA |
integer($int4) example: 1 |
The type of shelf adjustment. Valid values are 1 - Move To Backroom 2 - Update Shopfloor 3 - Update Backroom Enum: [ 1, 2, 3 ] |
status |
NA |
The current status of the shelf adjustment. Valid values are 1 - In Progress 2 - Complete Enum: [ 1, 2 ] |
userName |
NA |
The name of the user that last updated the shelf adjustment. |
createDate |
NA |
string($date-time) |
The date the shelf adjustment was created. |
updateDate |
NA |
The date the shelf adjustment was last updated. |
Create Adjustment
This API creates an in progress shelf adjustment.
Request Parameters
There are no request parameters.
The request body is application/json.
The details of the new shelf adjustment.
Schema — ShelfAdjustmentCreateIdo
Table 4-273 ShelfAdjustmentCreateIdo — Object
storeId |
Yes |
type |
Yes |
The type of shelf adjustment. Valid values are: 1 - Move To Backroom 2 - Update Shopfloor 3 - Update Backroom Enum: [ 1, 2, 3 ] |
lineItems |
Yes |
object |
A collection of line items on the shelf adjustment. |
Table 4-274 ShelfAdjustmentCreateItemIdo — Object
itemId |
Yes |
caseSize |
NA |
number($decimal(10,2)) example: 1 |
The case size of the item for this record. |
quantity |
Yes |
number($decimal(12,4)) example: 20 |
The quantity to adjust. |
Responses
This section describes the responses of the Create Adjustment API.
Response Code: 200
The request has been successful.
The media type is application/json.
Schema — ShelfAdjustmentStatusIdo
Table 4-275 ShelfAdjustmentStatusIdo — Object
adjustmentId |
NA |
storeId |
NA |
type |
NA |
status |
The current status of the shelf adjustment. Valid values are: 1 - In Progress 2 – Complete Enum: [ 1, 2 ] |
Read Adjustment
This API retrieves all the details about a shelf adjustment.
Request Parameters
Table 4-276 Read Adjustment— Request Parameters
| Parameter | Required | Data Type | Description |
adjustmentId |
Yes |
number ($int15) (path) |
Responses
This section describes the responses of the Read Adjustment API.
Response Code: 200
Example Value
"storeId": 5000,
"type": 1,
"status": 1,
"createDate": "2025-01-08T11:10:30.977Z",
"updateDate": "2025-01-08T11:10:30.977Z",
"lineItems": [
"lineId": 11111,
"itemId": "11111",
"caseSize": 1,
"quantity": 20
]Schema — ShelfAdjustmentStatusIdo
Table 4-277 ShelfAdjustmentStatusIdo — Object
adjustmentId |
NA |
storeId |
NA |
number($int10) example: 5000 |
type |
NA |
status |
Update Adjustment
This section describes the Update Adjustment API. This API updates an active shelf adjustment.
Request Parameters
Table 4-278 Update Adjustment— Request Parameters
adjustmentId |
yes |
integer($int15) (path) |
Shelf adjustment details to update.
Confirm Adjustment
This section describes the Confirm Adjustment API. This API confirms a shelf adjustment updating the appropriate quantities of inventory position depending on the type of shelf adjustment.
Request Parameters
Table 4-279 Confirm Adjustment — Request Parameters
adjustmentId |
yes |
Delete Adjustment
This section describes the Delete AdjustmentAPI. This API deletes a shelf adjustment.
Request Parameters
Table 4-280 Delete Adjustment — Request Parameters
adjustmentId |
yes |
REST Service: Shelf Replenishment
The replenishment process attempts to ensure that the shop floor inventory is set at a level best suited for enticing customers to buy a product and to prevent empty shelves. Shelf replenishment functionality within the mobile application is related to the movement of goods from the back room to the shop floor and shop floor to back room. For example, when a certain soda quantity is low, you can initiate a replenishment process so that more of the soda is moved from the back room. Similarly, if there is excess stock on the shop floor, the mobile application supports processes to move inventory to the back room. Some of the processes require capacity setup and some form of plan-o-gram sequenced data, while others do not. See user's guide for additional information. This service provides the ability to manage shelf replenishment through public interfaces.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Replenishment
This section describes the Find Replenishment API. This API finds up to 10,000 shelf replenishment headers for the input criteria.
Request Parameters
Table 4-281 Find Replenishment — Request Parameters
storeId |
NA |
Include only replenishments with this store identifier. |
type |
NA |
integer($int2) (query) |
Include only replenishments with this type. Valid values are: 1 - Capacity 2 - Display 3 - Gap 4 - Sales Available values : 1, 2, 3, 4 |
status |
NA |
Include only replenishments with this status. Valid values are: 1 - New 2 - In Progress 3 - Complete 4 - Canceled Available values : 1, 2, 3, 4 |
mode |
NA |
Include only replenishments with this mode. Valid values are: 1 - End of Day 2 - Within Day Available values : 1, 2 |
productGroupId |
NA |
number($int12) (query) |
Include only replenishments with this product group. |
departmentId |
NA |
number($int15) (query) |
Include only replenishments with this department. |
replenishmentGapId |
NA |
Include only replenishments with this replenishment gap. |
statusDateFrom |
NA |
Include only replenishments with a status date on or after this date. |
statusDateTo |
NA |
Include only replenishments with a status date on or before this date. |
createDateFrom |
NA |
Include only replenishments with an create date on or after this date. |
createDateTo |
NA |
Include only replenishments with an create date on or before this date. |
itemId |
NA |
Include only shelf replenishments with this item. |
Responses
This section describes the responses of the Find Replenishment API.
Response Code: 200
Example Value
"replenishmentId": 11111,
"storeId": 5000,
"type": 1,
"status": 1,
"statusDate": "2025-01-03T10:08:47.605Z",
"mode": 1,
"createUser": "smith123",
"createDate": "2025-01-03T10:08:47.605Z"
]Schema — ShelfReplenishmentHeaderIdo
Table 4-282 ShelfReplenishmentHeaderdo— Object
replenishmentId |
NA |
The unique identifier of the shelf replenishment. |
storeId |
NA |
The store of the shelf replenishment. |
type |
NA |
The type of shelf replenishment. Valid values are: 1 - Capacity 2 - Display 3 - Gap 4 - Sales Enum: [ 1, 2, 3, 4 ] |
status |
NA |
The current status of the shelf replenishment. Valid values are: 1 - New 2 - In Progress 3 - Complete 4 - Canceled Enum: [ 1, 2, 3, 4 ] |
statusDate |
NA |
string($date-time) The date the last time the status of the shelf replenishment was altered. |
mode |
NA |
The current status of the shelf replenishment. Valid values are: 1 - End of Day 2 - Within Day Enum: [ 1, 2 ] |
createUser |
NA |
string($text128) example: smith123 |
The name of the user that created the shelf replenishment. |
createDate |
NA |
The date the shelf replenishment was created. |
Create Replenishment
This API creates an in progress shelf replenishment.
Request Parameters
The details of the new shelf replenishment..
Example Value
"storeId": 5000,
"type": 1,
"checkAvailableStockOnHand": true,
"productGroupId": 5683232,
"replenishmentGapId": 5834134,
"departmentId": 1000,
"classId": 2000,
"subclassId": 3000,
"mode": 1
}Schema — ShelfReplenishmentCreateIdo
Table 4-283 ShelfReplenishmentCreateIdo — Object
storeId |
Yes |
type |
Yes |
checkAvailableStockOnHand |
NA |
True indicates that items with no available stock will not be placed on the replenishment list. If false, they will be included. |
productGroupId |
NA |
number($int12) example: 5683232 |
The identifier of an associated product group. |
NA |
number($int15) example: 5834134 |
The identifier of an associated replenishment gap. |
departmentId |
NA |
number($int12) example: 1000 |
The identifier of a department. |
classId |
NA |
number($int12) example: 2000 |
The identifier of a class within the department. |
subclassId |
NA |
number($int12) example: 3000 |
The identifier of a subclass within the class. |
mode |
NA |
The mode of the shelf replenishment. Valid values are: 1 - End of Day 2 - Within Day Enum: [ 1, 2 ] |
Responses
This section describes the responses of the Import Allocation API.
Response Code: 200
Schema — ShelfReplenishmentStatusIdo
Table 4-284 ShelfReplenishmentStatusIdo — Object
replenishmentId |
NA |
storeId |
NA |
type |
NA |
status |
NA |
Read Replenishment
This API retrieves all the details about a shelf replenishment.
Request Parameters
Table 4-285 Read Replenishment— Request Parameters
replenishmentId |
Yes |
Responses
This section describes the responses of the Read Replenishment API.
Response Code: 200
Example Value
"storeId": 5000,
"type": 1,
"status": 1,
"statusDate": "2025-01-03T11:46:50.199Z",
"mode": 1,
"classId": 2000,
"subclassId": 3000,
"transactionEventId": 23894134,
"transactionEventDescription": "Flash Sale",
"createDate": "2025-01-03T11:46:50.199Z",
"lineItems": [
"lineId": 11111,
"itemId": "200167123",
"pickFromArea": 1,
"pickFromRequest": 20,
"pickAount": 10,
"caseSize": 1,
"unitOfMeasure": "LBS",
"substituteLineId": 3243
]Update Replenishment
This section describes the Update Replenishment API. This API updates an active shelf replenishment.
Request Parameters
Table 4-286 Update Replenishment — Request Parameters
replenishmentId |
yes |
Shelf replenishment details to update.
Confirm Replenishment
This section describes the Confirm Replenishment API. This API confirms a shelf replenishment moving the inventory.
Request Parameters
Table 4-287 Confirm Replenishment — Request Parameters
replenishmentId |
yes |
Cancel Replenishment
This section describes the Cancel Replenishment API. This API cancels a shelf replenishment.
Request Parameters
Table 4-288 Cancel Replenishment — Request Parameters
replenishmentId |
yes |
REST Service: Shelf Replenishment Gap
The gap scanning method is the easiest method of all the various types of shelf replenishment. With this method, you scan the goods that need replenishment and a replenishment list is created from the units scanned. The system uses this replenishment list to move the goods from the back room to the shop floor based on back room availability. The reason to have a separate process between scanning and generating is that one user can create a list and another user can execute the shelf replenishment allowing for distribution of workload. Since this process does not have a dependency with either sales or capacity, it gives an advantage to the retailer to move goods without any complex setup.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Gap
This section describes the Find Gap API. This API finds up to 10,000 replenishment gap summary headers for the input criteria.
Request Parameters
Table 4-289 Find Gap — Request Parameters
storeId |
NA |
Include only replenishment gaps for this store. |
status |
NA |
Include only replenishment gaps with this status. Valid values are: 1 - In Progress 2 - Complete Available values : 1, 2 |
type |
NA |
Include only replenishment gaps with this type. Valid values are: 1 - Display Scan 2 - Gap Scan Backroom Available values : 1, 2 |
itemId |
NA |
Include only replenishment gaps with this item. |
updateDateFrom |
NA |
Include only replenishment gaps with an update date on or after this date. |
updateDateTo |
NA |
Include only replenishment gaps with an update date on or before this date. |
Responses
This section describes the responses of the Find Gap API.
Response Code: 200
Example Value
"gapId": 11111,
"storeId": 5000,
"type": 1,
"status": 1,
"createDate": "2024-11-12T11:27:17.130Z",
"updateDate": "2024-11-12T11:27:17.130Z"
]Schema — ShelfReplenishmentGapHearderIdo
Table 4-290 ShelfReplenishmentGapHearderIdo — Object
gapId |
NA |
The unique identifier of the replenishment gap. |
storeId |
NA |
The store identifier of the replenishment gap. |
type |
NA |
The type of replenishment gap. Valid values are: 1 - Display Scan 2 - Gap Scan Enum: [ 1, 2 ] Enum: [ 1, 2 ] |
status |
NA |
The current status of the replenishment gap. Valid values are: 1 - In Progress 2 - Complete |
userName |
NA |
The name of the user that last updated the replenishment gap. |
createDate |
NA |
The date the replenishment gap was created. |
updateDate |
NA |
The date the replenishment gap was last updated. |
Create Gap
This section describes the Create Gap API. This API creates an in progress shelf replenishment gap.
Request Parameters
The details of the new shelf replenishment gap.
Example Value
"storeId": 5000,
"type": 1,
"lineItems": [
"itemId": "11111",
"caseSize": 1,
"suggestedQuantity": 20
}Schema — ShelfReplenishmentGapCreateIdo
Table 4-291 ShelfReplenishmentGapCreateIdo — Object
storeId |
yes |
The store of the replenishment gap. |
type |
yes |
The type of replenishment gap. Valid values are: 1 - Display Scan 2 - Gap Scan Enum: [ 1, 2 ] |
lineItems |
yes |
object |
A collection of line items on the shelf replenishment gap. |
Table 4-292 ShelfReplenishmentGapCreateItemIdo — Object
itemId |
yes |
caseSize |
NA |
suggestedQuantity |
yes |
The quantity suggested to repelnish for the item. |
Responses
This section describes the responses of the Create Gap API.
Response Code: 200
Schema — ShelfReplenishmentGapStatusIdo
Table 4-293 ShelfReplenishmentGapStatusIdo — Object
gapId |
NA |
storeId |
NA |
type |
NA |
status |
NA |
The current status of the replenishment gap. Valid values are: 1 - In Progress 2 - Complete Enum: [ 1, 2 ] |
Read Gap
This section describes the Read Gap API. This API retrieves all the details about a shelf replenishment gap.
Request Parameters
Table 4-294 Read Gap — Request Parameters
gapId |
yes |
number($int15) (path) |
Responses
This section describes the responses of the Read Gap API.
Response Code: 200
Example Value
"gapId": 11111,
"storeId": 5000,
"type": 1,
"status": 1,
"createDate": "2024-11-14T13:43:09.417Z",
"updateDate": "2024-11-14T13:43:09.417Z",
"lineItems": [
"lineId": 11111,
"itemId": "11111",
"caseSize": 1,
]Schema — ShelfReplenishmentGapIdo
Table 4-295 ShelfReplenishmentGapIdo — Object
gapId |
NA |
storeId |
NA |
type |
NA |
status |
NA |
The current status of the replenishment gap. Valid values are: 2 - Complete 1 - In Progress Enum: [ 1, 2 ] |
userName |
NA |
createDate |
NA |
updateDate |
NA |
lineItems |
NA |
object |
A collection of line items on the replenishment gap. |
Table 4-296 ShelfReplenishmentGapLineItemIdo — Object
lineId |
NA |
itemId |
NA |
caseSize |
NA |
suggestedQuantity |
NA |
The quantity suggested to replenish for the item. |
Update Gap
This section describes the Update Gap API. This API updates an active shelf replenishment gap.
Request Parameters
Table 4-297 Update Gap — Request Parameters
gapId |
yes |
The unique identifier of the shelf replenishment gap. |
Shelf replenishment gap details to update.
Schema — ShelfReplenishmentGapUpdateIdo
Table 4-298 ShelfReplenishmentGapUpdateIdo — Object
lineItems |
yes |
object |
Table 4-299 ShelfReplenishmentGapUpdateItemIdo — Object
itemId |
Yes |
caseSize |
NA |
suggestedQuantity |
Yes |
The quantity suggested for the item. Setting the quantity to zero will remove the line item. |
Delete Gap
This section describes the Delete Gap API. This API deletes a shelf replenishment gap.
Request Parameters
Table 4-300 Delete Gap — Request Parameters
GapId |
yes |
REST Service: Shipping
This service integrates various shipping support information with an external application. This is primarily various lookups of shipping data such as carriers and package sizes to use within shipping transactions.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/shipping
APIs
Table 4-301 APIs
API |
Description |
findCarriers |
Finds all the carriers available for shipping. |
findCarrierServices |
Finds all the carrier services available for shipping. |
findCartonSizes |
Finds the available sizes of cartons for shipping. |
findWeightUoms |
Finds all the various units of measurement of the carton measurements. |
findMotives |
Finds all the motives available for a shipping type. |
API: findCarriers
This API is used to find all the carriers available for shipping.
Table 4-302 API Basics
Endpoint URL |
/carriers |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Output |
Collection of carriers |
Table 4-303 Output Data Definition
Attribute |
Type |
Definition |
carrierId |
Long(10) |
The unique identifier of the carrier. |
code |
String(4) |
A unique character code for the carrier. |
description |
String(128) |
A description or name of the carrier. |
manifestType |
Integer(1) |
The carrier delivery manifest type (see Additional Data Definitions) |
API: findCarrierServices
This API is used to find all the carrier services available for shipping.
Table 4-304 API Basics
Endpoint URL |
/carrierservices |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Output |
Table 4-305 Output Data Definition
Attribute |
Type |
Definition |
carrierServiceId |
Long(10) |
The unique identifier of the carrier service. |
code |
String(6) |
A unique character code for the carrier service. |
description |
String(128) |
A description or name of the carrier service. |
averageDeliveryDays |
Integer(4) |
The average number of days it takes to deliver using this service. |
carrierId |
Long(10) |
The unique identifier of the carrier this service is used with. |
defaultService |
Boolean |
True is this is the default service type for the carrier, false otherwise. |
weightRequired |
Boolean |
True is weight is required for this carrier service, false otherwise. |
cartonSizeRequired |
Boolean |
True if dimensions/size is required for this carrier service, false otherwise. |
API: findCartonSizes
This API is used to find all the carton services available for shipping at the particular store.
Table 4-306 API Basics
Endpoint URL |
/cartonsizes/{storeId} |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Path Parameter |
The store identifier of the store to retrieve carton sizes for. |
Output |
Collection of carton sizes |
Table 4-307 Output Data Definition
Attribute |
Type |
Definition |
cartonSizeId |
Long(12) |
A unique identifier of this particular carton size definition. |
storeId |
Long(10) |
The store identifier the carton size is used at. |
description |
String(120) |
A description of the carton size. |
height |
BigDecimal(12,4) |
The height of the carton in units of measure. |
width |
BigDecimal(12,4) |
The width of the carton in units of measure. |
length |
BigDecimal(12,4) |
The length of the carton in units of measure. |
unitOfMeasure |
String(4) |
The unit of measure of the height, width, and length. |
API: findWeightUoms
This API is used to find all the weight unit of measures available for shipping.
Table 4-308 API Basics
Endpoint URL |
/weightuoms |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Output |
Collection of shipping weight units of measure |
Attribute |
Type |
Definition |
uom |
String(4) |
The unit of measure |
description |
String(120) |
The unit of measure description |
API: findMotives
This API is used to find all the motives available for a shipping type. See index for available shipment types.
Table 4-309 API Basics
Endpoint URL |
/motives/(shipmentType} |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Path Parameter |
The shipment type to retrieve motives for (see Additional Data Definitions) |
Output |
Table 4-310 Output Data Definition
Attribute |
Type |
Definition |
id |
Long(18) |
The unique identifier of the shipping motive |
code |
String(6) |
The external code of the shipping motive |
description |
String(120) |
A description of the motive |
sequence |
Long |
The sequence in which the motive should appear in a list |
REST Service: Stock Count
Stock Counts allow the user to count the inventory in the store, determine discrepancy of items, and authorize new inventory positions triggering adjustments to bring the inventory into alignment. There are four main types of stock counts: ad hoc, unit, problem line, and unit-amount. Ad Hoc stock counts are not schedule, but rather performed at random times when a user decides to correct inventory. Unit stock counts must be secheduled. They can be scheduled and executed the same day. A problem line stock count features items that have inventory positions issues, such as having negative inventory. A problem line is also scheduled and follow the same overall workflows as unit counts. Unit and amount counts must be scheduled for a single specific date. These stock counts must be scheduled at least one day ahead of time. When the count is scheduled, it is sent to the merchandising system so that it can also create a corresponding stock count. The service defines operations to manage stock count information by integration with an external system.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Stock Counts
This section describes the Find Stock Counts API. This API finds up to 1,000 stock counts matching the input criteria.
Request Parameters
Table 4-311 Find Stock Counts — Request Parameters
storeId |
NA |
Include only stock counts for this store. |
scheduleDate |
NA |
Include only stock counts that are scheduled to be executed on this date. |
phase |
NA |
Include only stock counts in this phase. Valid values are: 1 - Count 2 - Recount 3 - Authorize 4 - Future Available values : 1, 2, 3, 4 |
status |
NA |
Include only stock counts in this status. Valid values are: 1 - New 2 - Count Scheduled 3 - Count In Progress 4 - Count Complete 5 - Recount Scheduled 6 - Recount In Progress 7 - Recount Complete 8 - Approval Scheduled 9 - Approval In Progress 10 - Approval Processing 11 - Approval Authorized 12 - Approval Complete 13 - Canceled Available values : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 |
departmentId |
NA |
Include only stock counts associated to this department. |
classId |
NA |
Include only stock counts associated to this class. A department is required if this attribute is used. |
subclassId |
NA |
Include only stock counts associated to this subclass. A class is required if this attribute is used. |
Responses
This section describes the responses of the Find Stock Counts API.
Response Code: 200
Example Value
"stockCountId": 11111,
"storeId": 5000,
"description": "Weekly Department Count",
"productGroupId": 966400,
"productGroupDescription": "Clothing Department",
"productGroupScheduleId": 966400,
"type": 1,
"status": 1,
"phase": 1,
"scheduleDate": "2025-01-16T13:19:10.243Z",
"startDateTime": "2025-01-16T13:19:10.243Z",
"updateDateTime": "2025-01-16T13:19:10.243Z",
"totalItemCount": 2000,
"totalLeftToCount": 950
]Schema — StockCountHeaderIdo
Table 4-312 StockCountHeaderIdo— Object
stockCountId |
NA |
number($int12) example: 11111 |
The unique identifier of the stock count. |
storeId |
NA |
The identifier of the store. |
description |
NA |
string($text255) example: Weekly Department Count |
A description of the stock count. |
productGroupId |
NA |
number($int12) example: 966400 |
The identifier of the product group |
productGroupDescription |
NA |
string($text100) example: Clothing Department |
The description of the product group. |
productGroupScheduleId |
NA |
The identifier of the product group schedule. |
type |
NA |
The type of the stock count. Valid values are: 1 - Unit 2 - Unit and Amount 3 - Problem Line 4 - Adhoc Enum: [ 1, 2, 3, 4 ] |
status |
NA |
The current status of the stock count. Valid values are: 1 - New 2 - Count Scheduled 3 - Count In Progress 4 - Count Complete 5 - Recount Scheduled 6 - Recount In Progress 7 - Recount Complete 8 - Approval Scheduled 9 - Approval In Progress 10 - Approval Processing 11 - Approval Authorized 12 - Approval Complete 13 - Canceled Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 ] |
phase |
NA |
The current phase of the stock count. Valid values are: 1 - Count 2 - Recount 3 - Authorize 4 - Future Enum: [ 1, 2, 3, 4 |
scheduleDate |
NA |
The date the stock count is scheduled to be executed on. |
startDateTime |
NA |
The time stamp when the stock count was started. |
updateDateTime |
NA |
The time stamp when the stock count was last updated. |
totalItemCount |
NA |
The total number of items on the stock count. |
totalLeftToCount |
NA |
number($int12) example: 950 |
The total number of items left to count. |
Read Stock Count
This section describes the Read Stock Count API. This API reads information about a stock count. It includes the information for the stock count header as well as the header information for each stock count child. It does not include the item detail. To retrieve detailed information, the stock count child must be read individually.
Request Parameters
Table 4-313 Read Stock Count — Request Parameters
stockCountId |
Yes |
number($int12) (path) |
The stock count identifier. |
Responses
This section describes the responses of the Read Stock Count API.
Response Code: 200
Example Value
"storeId": 5000,
"type": 1,
"status": 1,
"phase": 1,
"scheduleDate": "2025-01-16T13:48:59.866Z",
"startDateTime": "2025-01-16T13:48:59.866Z",
"updateDateTime": "2025-01-16T13:48:59.866Z",
"exportUser": "smith123",
"totalLeftToCount": 950,
"stockCountTimeframe": 1,
"varianceCount": 5,
"variancePercent": 2.5,
"varianceValue": 2.5,
"countingMethod": 1,
"breakdownType": 1,
"recountRequired": true,
"autoAuthorize": false,
"includeAllItems": true,
"includeActiveItems": false,
"includeDiscontinuedItems": true,
"includeDeletedItems": true,
"includeSohZero": false,
"includeSohPositive": true,
"includeSohNegative": false,
"problemLinePickLessSuggested": true,
"problemLineReplenishLessSuggested": true,
"problemLineReplenishNegativeAvailable": false,
"problemLineReplenishDiscrepantUin": true,
"adhocItemLock": false,
"childCounts": [
"childCountId": 1223465,
"locationId": "738429",
"locationArea": 45,
"description": "Frozen Foods",
"breakdownDescription": "123 - Pies",
"phase": 1,
"status": 1,
"countUser": "smith123",
"recountUser": "smith123",
"authorizeUser": "jones123",
"countSnapshotDate": "2025-01-16T13:48:59.866Z",
"recountSnapshotDate": "2025-01-16T13:48:59.866Z",
"authorizedDate": "2025-01-16T13:48:59.866Z"
]Schema — StockCountIdo
Table 4-314 StockCountIdo— Object
stockCountId |
NA |
storeId |
NA |
description |
NA |
productGroupId |
NA |
The identifier of the product group. |
NA |
NA |
type |
NA |
status |
NA |
phase |
NA |
1 - Count 2 - Recount 3 - Authorize 4 - Future Enum: [ 1, 2, 3, 4 ] |
scheduleDate |
NA |
startDateTime |
NA |
updateDateTime |
NA |
exportUser |
NA |
string($text128) example: smith12 |
The user that exported the stock count. |
totalItemCount |
NA |
totalLeftToCount |
NA |
stockCountTimeframe |
NA |
integer($int1) example: 1 |
1 - Before Store Open 2 - After Store Closed 3 - None Enum: [ 1, 2, 3 ] |
varianceCount |
NA |
number($int12) example: 5 |
The amount in standard unit of measure that the count can vary before being considered discrepant. |
variancePercent |
NA |
number($decimal(12,4)) example: 2.5 |
The percent in standard unit of measure that the count can vary before being considered discrepant. |
varianceValue |
NA |
The value variance allowed before the count is considered discrepant. |
countingMethod |
NA |
1 - Guided 2 - Unguided 3 - Third Party 4 - Auto Enum: [ 1, 2, 3, 4 ] |
breakdownType |
NA |
1 - Department 2 - Class 3 - Subclass 4 - Location 5 - None Enum: [ 1, 2, 3, 4, 5 ] |
recountRequired |
NA |
True indicates stock count should be recounted. |
autoAuthorize |
NA |
True indicates stock count should automatically authorize after count. |
includeAllItems |
NA |
True indicates stock count should include all items. |
includeActiveItems |
NA |
True indicates stock count should include active items. |
includeDiscontinuedItems |
NA |
True indicates stock count should include inactive items. |
includeDeletedItems |
NA |
True indicates stock count should include deleted items. |
includeSohZero |
NA |
True indicates stock count should include zero stock on hand items. |
includeSohPositive |
NA |
True indicates stock count should include positive stock on hand items. |
includeSohNegative |
NA |
True indicates stock count should include negative stock on hand items. |
problemLinePickLessSuggested |
NA |
True indicates stock count should include pick lists less than suggested amounts. |
problemLineReplenishLessSuggested |
NA |
True indicates stock count should include shelf replenishments that are less than the suggested amount. |
problemLineReplenishNegativeAvailable |
NA |
True indicates stock count should include items with negative available quantities. |
problemLineReplenishDiscrepantUin |
NA |
True indicates stock count should include UIN discrepancies. |
adhocItemLock |
NA |
True indicates an ad-hoc count is locked and new items can no longer be added. |
childCounts |
NA |
object |
A list of child stock counts that organize the items for counting. |
Table 4-315 StockCounChildHeadertIdo— Object
childCountId |
NA |
number($int12) example: 1223465 |
The unique identifier of the stock count child. |
locationId |
NA |
string($text128) example: 738429 |
The unique identifier of the sequence location being counted. |
locationArea |
NA |
integer($int9) example: 45 |
An area number associated with the location. |
description |
NA |
string($text1000) example: Frozen Foods |
The description of the stock count location. |
breakdownDescription |
NA |
string($text30) example: 123 – Pies |
The description of a breakdown sub-location within the stock count location. |
phase |
NA |
status |
NA |
countUser |
NA |
The user that performed the count in this location. |
recountUser |
NA |
The user that performed the recount in this location. |
authorizeUser |
NA |
string($text128) example: jones123 |
The user that performed the authorization in this location. |
totalItemCount |
NA |
The total number of items in the location. |
totalLeftToCount |
NA |
The items remaining to be counted in the location. |
countSnapshotDate |
NA |
The time stamp when this child had its count snapshot taken. |
recountSnapshotDate |
NA |
The time stamp when this child had its recount snapshot taken. |
authorizedDate |
NA |
The time stamp when this child was authorized. |
Snapshot Stock Count
Snapshots a stock count capturing the current stock on hand quantity as a snapshot quantity for each item on the count. The process of doing a snapshot first determines whether or not the stock count needs a snapshot and only snapshots a stock count or stock count childs that need a snapshot. However, if the stock count or stock count child does not need a snapshot, the service is still considered successful as the snapshot exists.
Request Parameters
Table 4-316 Snapshot Stock Count — Request Parameters
stockCountId |
Yes |
Cancel Stock Count
This section describes the Cancel Stock Count API. This API cancels a stock count if it has not begun approval processing. If a unit and amount stock count is canceled, it will notify merchandising of the cancellation.
Request Parameters
Table 4-317 Cancel Stock Count — Request Parameters
stockCountId |
Yes |
Read Stock Count Child
This section describes the Read Stock Count Child API. This API reads information about a stock count child, including all its items.
Request Parameters
Table 4-318 Read Stock Count Child — Request Parameters
stockCountChildId |
Yes |
The stock count child identifier. |
Responses
This section describes the responses of the Read Stock Count Child API.
Response Code: 200
Example Value
"locationArea": 45,
"phase": 1,
"status": 1,
"countSnapshotDate": "2025-01-16T14:34:40.120Z",
"recountSnapshotDate": "2025-01-16T14:34:40.120Z",
"authorizedDate": "2025-01-16T14:34:40.120Z",
"lineItems": [
"lineId": 1223465,
"itemId": "20045673",
"departmentId": 2000,
"classId": 3000,
"subclassId": 4000,
"primaryLocation": true,
"multiLocated": false,
"discrepant": true,
"breakableComponent": false,
"countSnapshot": 100,
"recountSnapshot": 110,
"quantityCounted": 99,
"quantityRecounted": 101,
"quantityAuthorized": 101,
"quantityCountedTotal": 99,
"quantityRecountedTotal": 99,
"countedDateTime": "2025-01-16T14:34:40.120Z",
"recountedDateTime": "2025-01-16T14:34:40.120Z",
"authorizedDateTime": "2025-01-16T14:34:40.120Z",
"snapshotDateTime": "2025-01-16T14:34:40.120Z",
"priceType": 1,
"priceCurrency": "USD",
"priceValue": 12.99,
"uins": [
"uin": "200456734823",
"uinId": 1223465,
"snapshotStatus": 1
"epcs": [
"epc": "2004435813456734700",
"scanDateTime": "2025-01-16T14:34:40.120Z"
]Schema — StockCountChildIdo
Table 4-319 StockCountChildIdo— Object
childCountId |
NA |
locationId |
NA |
locationArea |
NA |
description |
NA |
NA |
phase |
NA |
status |
NA |
countUser |
NA |
recountUser |
NA |
authorizeUser |
NA |
totalItemCount |
NA |
totalLeftToCount |
NA |
countSnapshotDate |
NA |
NA |
authorizedDate |
NA |
lineItems |
NA |
object |
The items counted within this location. |
Table 4-320 StockCountLineItemIdo — Object
lineId |
NA |
itemId |
NA |
string($text128) example: 20045673 |
departmentId |
NA |
The unique identifier of the department. |
classId |
NA |
The unique identifier of the class. |
subclassId |
NA |
number($int12) example: 4000 |
The unique identifier of the subclass. |
primaryLocation |
NA |
True indicates this is the primary stock count child for the item. |
multiLocated |
NA |
boolean example: false |
True indicates this item is located within multiple stock count child records. |
discrepant |
NA |
True indicates the item count is discrepant. |
breakableComponent |
NA |
True indicates this is a component of a breakable (notional) pack. |
countSnapshot |
NA |
number($decimal(12,4)) example: 100 |
The stock on hand at the time the count snapshot was executed. |
recountSnapshot |
NA |
number($decimal(12,4)) example: 110 |
The stock on hand at the time the recount snapshot was executed. |
quantityCounted |
NA |
number($decimal(12,4)) example: 99 |
The amount in standard unit of measure counted during the initial stock counting phase. |
quantityRecounted |
NA |
number($decimal(12,4)) example: 101 |
The amount in standard unit of measure counted during the recount of stock. |
quantityAuthorized |
NA |
The amount in standard unit of measure to be approved during authorization. |
quantityCountedTotal |
NA |
The amount in standard unit of measure counted during the initial stock counting phase for this item across all children in which it appears. |
quantityRecountedTotal |
NA |
The amount in standard unit of measure counted during the recount for this item across all children in which it appears. |
countedDateTime |
NA |
The time stamp when counting began for the item. |
recountedDateTime |
NA |
The time stamp when recounting began for the item. |
authorizedDateTime |
NA |
The time stamp when the item was authorized. |
snapshotDateTime |
NA |
The time stamp when the snapshot was last taken for this item. |
priceType |
NA |
integer($int3) example: 1 |
1 - Permanent 2 - Promotional 3 - Clearance Enum: [ 1, 2, 3 ] |
priceCurrency |
NA |
The price currency at the time of the snapshot. |
priceValue |
NA |
number($decimal(20,4)) example: 12.99 |
The price amount at the time of the snapshot. |
uins |
NA |
object |
The UINs associated to this item on the count. |
epcs |
NA |
object |
The EPCs associated to this item on the count. |
Table 4-321 StockCountLineItemUinIdo — Object
uin |
NA |
string($text128) example: 200456734823 |
The unique identifier number. |
uinId |
NA |
The record identifier of the UIN. |
snapshotStatus |
NA |
number($int2) example: 1 |
1 - In Stock 2 - Sold 3 - Shipped To Warehouse 4 - Shipped To Store 5 - Reserved For Shipping 6 - Shipped To Vendor 7 - Remove From Inventory 8 - Unavailable 9 - Missing 10 - In Receiving 11 - Customer Reserved 12 - Customer Fulfilled 13 - Shipped To Finisher 99 - Unconfirmed Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 99 ] |
Table 4-322 StockCountLineItemEpcIdo — Object
epc |
NA |
string($text256) example: 2004435813456734700 |
The Electronic Product Code |
scanDateTime |
NA |
Snapshot of the last time the EPC was scanned. |
Update Stock Count Child
This section describes the Update Stock Count Child API. This API updates a child count's quantities based on the current phase of counting. Counted quantity is updated in count phase, recounted quantity for recount phase, and authorization quantity for authorization phase. A maximum of 10,000 line items is allowed per update.
Request Parameters
Table 4-323 Update Stock Count Child — Request Parameters
stockCountChildId |
Yes |
Details of the stock count child to update.
Example Value
"lineItems": [
"lineId": 456333,
"quantity": 12.4,
"timestamp": "2025-01-16T15:10:31.345Z",
"uins": [
111222333,
444555666
}Schema — StockCountChildUpdateIdo
Table 4-324 StockCountChildUpdateIdo— Object
lineItems |
Yes |
object |
Information about the items that were counted. |
Table 4-325 StockCountChildUpdateItemIdo— Object
lineId |
Yes |
number($int12) example: 456333 |
The unique identifier of the line item record being updated. |
quantity |
Yes |
number($decimal(12,4)) example: 12.4 |
The quantity to assign to the line item based on the current phase of the stock count. If UINs are enabled for the store and this is a UIN item, the quantity value will be overwritten by the sum of the UINs on the line item. |
timestamp |
NA |
The timestamp when the quantity was counted, recounted, or authorized. If the item does not yet have a timestamp, this value will be assigned to the item. If left blank, current timestamp of processing will be used instead. |
uins |
Yes |
string($text128)] example: List [ 111222333, 444555666 ] |
The UINs to attach to this line item. |
Complete Stock Count Child
This section describes the Complete Stock Count Child API. This API completes the count or recount of a stock count child moving it to the next phase of stock count processing if possible. Many factors may cause a child count to be pending until further counting is completed in other child counts. If the child has not yet been counted, it can still be completed and will follow the business rules and configurations for uncounted items.
Request Parameters
Table 4-326 Complete Stock Count Child — Request Parameters
stockCountChildId |
Yes |
REST Service: Store
This service integrates store foundation data. Asychronous store integration is processed through staged messages and is controlled by the MPS Work Type: DcsStore.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/storeitems
Import Store
This operation will import store orders from an external system. These store orders are already transfers or purchase orders that are being planned and require store approval before proceeding.
Request Parameters
A list of stores to import.
Example Value
"stores": [
"storeId": 1111111,
"storeName": "MyStore",
"languageCode": "EN",
"countryCode": "US",
"currencyCode": "USD",
"timezone": "America/Chicago",
"transferZoneId": "1000",
"organizationUnitId": "1111",
"managedStore": true,
"customerOrdering": true
}Schema — StoreImportIdo
Table 4-327 StoreImportIdo — Object
store |
Yes |
object |
Stores |
Table 4-328 StoreImportIdo — Object
| storeId | Yes | number($int10) example: 1111111 |
| storeName | Yes | string($text150) example: MyStore |
The name of the store. |
| languageCode | NA | string($text3) example: EN |
The language code of the store. |
| countryCode | NA | string($text3) example: US |
The country code of the store. |
| currencyCode | NA | string($text4) example: USD |
The currency code of the store. |
| timezone | NA | string($text80) example: America/Chicago |
The timezone of the store. |
| transferZoneId | NA | string($text128) example: 1000 |
The transfer zone identifier of the store. |
| organizationUnitId | NA | string($text15) example: 1111 |
The organization unit identifier of the store |
| managedStore | NA | boolean example: true |
True indicates that EICS manages the inventory for the store, false indicates it does not. |
| customerOrdering | NA | boolean example: true |
True indicates this store can take customer orders, false indicates it does not. |
Delete Store
Deletes a store. Prior to placing the request to delete into the MPS queue, it validates that the store exists and that the store contains no items assigned to it. A forbidden response will occur if the application is integrated with MFCS or RMS.
Request Parameters
This section describes the request parameters.
Table 4-329 Delete Store — Request Parameters
| Parameters | Required | Data Type | Description |
storeId |
Yes |
The unique identifier of the store. |
Read Store
Reads information about a store based on a single unique store identifier.
Request Parameters
Table 4-330 Read Store — Request Parameters
storeId |
Yes |
integer($int10) (path) |
Responses
This section describes the responses of the Read Store API.
Response Code: 200
Example Value
"storeId": 1111111,
]Schema — StoreIdo
Table 4-331 StoreIdo — Object
| storeId | NA | number($int10) example: 1111111 |
| storeName | NA | string($text150) example: MyStore |
Find Store
Finds stores based on a list of potential unique store identifiers. It allows up to a maximum of 10,000 store identifiers.
Request Parameters
A list of stores identifiers to find.
Responses
This section describes the responses of the Find Store API.
Response Code: 200
Example Value
"storeId": 1111111,
]Schema — StoreIdo
Table 4-333 StoreIdo — Object
Find Associated Store
Find potential associate stores (buddy stores) to the specified store.
Request Parameters
Table 4-334 Find Associated Store — Request Parameters
storeId |
Yes |
Responses
This section describes the responses of the Find Associated Store API.
Response Code: 200
Example Value
"storeId": 1111111,
]Schema — StoreIdo
Table 4-335 StoreIdo — Object
Delete Auto Receive Stores
Delete all the stores that can auto-receive from this store.
Request Parameters
Table 4-336 Delete Auto Receive Stores — Request Parameters
storeId |
Yes |
Find Auto Receive Store
Find stores that are allowed to auto receive from the specified input store.
Request Parameters
Table 4-337 Find Auto Receive Store — Request Parameters
storeId |
Yes |
Responses
This section describes the responses of the Find Auto Receive Store API.
Response Code: 200
Example Value
"storeId": 1111111,
]Schema — StoreIdo
Table 4-338 StoreIdo — Object
Update Auto Receive Stores
Update all the stores that are allowed to auto-receive from the accessing store.
Request Parameters
Table 4-339 Update Auto Receive Stores — Request Parameters
storeId |
Yes |
A list of auto receiving store identifiers.
Find Transfer Zone Store
Find stores that are available to the transfer zone of the input store.
Request Parameters
Table 4-341 Find Transfer Zone Store — Request Parameters
storeId |
Yes |
Responses
This section describes the responses of the Find Transfer Zone Store API.
Response Code: 200
Example Value
"storeId": 1111111,
]Schema — StoreIdo
Table 4-342 StoreIdo — Object
Delete Excluded Warehouses
Delete the list of warehouses that are excluded from the stores warehouse network effectively making them included for shipment.
Request Parameters
Table 4-343 Delete Excluded Warehouses — Request Parameters
storeId |
Yes |
Find Excluded Warehouses
Finds the warehouses excluded from the stores shipping network.
Request Parameters
Table 4-344 Find Excluded Warehouses — Request Parameters
storeId |
Yes |
Responses
This section describes the responses of the Find Excluded Warehouses API.
Response Code: 200
Example Value
"warehouseId": 1111111,
"excludeReturn": true,
"excludeReceipt": true,
"createDate": "2025-07-10T13:24:43.819Z",
"updateDate": "2025-07-10T13:24:43.819Z",
"updateUser": "smith123"
]Schema — StoreWarehouseIdo
Table 4-345 StoreWarehouseIdo — Object
| warehouseId | NA | number($int10) example: 1111111 |
The identifier of the warehouse. |
| excludeReturn | NA | boolean example: true |
True indicates this warehouse is excluded from returns, false indicates it is not excluded. |
| excludeReceipt | NA | boolean example: true |
True indicates this warehouse is excluded from receiving, false indicates it is not excluded. |
| createDate | NA | string($date-time) |
The date the store's warehouse network record was created in SIOCS. |
| createUser | NA | string($text128) example: smith123 |
The user that created the store's warehouse network record. |
| updateDate | NA | string($date-time) |
The date the store's warehouse network record was last updated in SIOCS. |
| updateUser | NA | string($text128) example: smith123 |
The user that last updated the store's warehouse network record. |
Update Excluded Warehouses
Assigns the list of warehouses that are excluded from a store's shipping network.
Request Parameters
Table 4-346 Update Excluded Warehouses — Request Parameters
storeId |
Yes |
A list of excluded store/warehouse network information.
Example Value
"warehouses": [
Schema — StoreWarehouseUpdateListIdo
Table 4-347 StoreWarehouseUpdateListIdo — Object
| warehouses | NA | object |
Warehouses |
Table 4-348 StoreWarehouseUpdateIdo — Object
| warehouseId | Yes | number($int10) example: 1111111 |
| excludeReturn | Yes | boolean example: true |
| excludeReceipt | Yes | boolean example: true |
Delete Excluded Stores
Deletes all the stores excluded from a store's shipping network.
Request Parameters
Table 4-349 Delete Excluded Stores — Request Parameters
storeId |
Yes |
Find Excluded Stores
Finds stores includes from the store's shipping network.
Request Parameters
Table 4-350 Find Excluded Stores — Request Parameters
storeId |
Yes |
Update Excluded Stores
Request Parameters
Table 4-352 Update Excluded Stores — Request Parameters
storeId |
Yes |
A list of excluded store network information.
Schema — StoreShippingNetworkUpdateIdo
Table 4-353 StoreShippingNetworkUpdateIdo — Object
| excludedStoreIds | NA | integer($int10) example: List [ 11111, 22222 ] | A list of stores to add to the excluded network stores. |
| removedStoreIds | NA | integer($int10) example: List [ 11111, 22222 ] | A list of stores to remove from the excluded network stores. |
REST Service: Store Item
This service integrates the store item foundation data with an external application. Store integration is controlled by the MPS Work Type: DcsItemLocation.
Service Base URL
API Definitions
API |
Description |
Import Store Items |
Imports items at a store location. |
Remove Store Items |
Deactivate items at a store location. |
Import Replenishment Items |
Imports replenishment item information. |
Remove Replenishment Items |
Deactivate replenishment item information. |
API: Import Store Items
Imports store items into the system.
If more than 10,000 items are included in a single call, an input too large error will be returned.
A "Forbidden" response will occur if application is integrated with MFCS or RMS.
API Basics
Endpoint URL |
{base URL}/import |
Method |
POST |
Successful Response |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of store Items to Import |
Output |
None |
10,000 |
Attribute |
Data Type |
Required |
Description |
items |
List of stores items to import |
Yes |
A collection of up to 10,000 stores items to import. |
Stores Items Data Definition
Attribute |
Data Type |
Required |
Description |
itemId |
String(25) |
Yes |
The unique item identifier (sku number). |
shortDescription |
String(255) |
A short description of the item at this store. |
longDescirption |
String(400) |
A long description of the item at this store. |
status |
String |
Yes |
See Index (Item Status) |
primarySupplierId |
Long(10) |
The unique identifier of the primary supplier of the item to this store location. |
storeControlPricing |
Boolean |
True indicates the item price can be controlled by the store. |
rfid |
Boolean |
True indicates the item is RFID tagged. |
defaultCurrencyCode |
String(3) |
The default currency of the item's price at this store. |
purchaseType |
Long |
See Index (Purchase Type) |
uinType |
Integer |
The UIN type of this item at this store. This attribute can only be altered to an empty value after the store item is created. Valid values are: 1 - Serial Number, 2 - Auto-Generated Serial Number |
uinCaptureTime |
Integer |
The UIN capture time of this item at this store. This attribute can only be altered to an empty value after the store item is created. Valid values are: 1 - Sale, 2 - Store Processing |
uinLabelCode |
Integer |
The unique identifier of the UIN label. This attribute will be ignored if the store item already exists. |
uinExternalCreateAllowed |
Boolean |
True if an external system can create a UIN, false otherwise. |
Example Input
"items": [
"itemId": "100637121",
"defaultCurrencyCode": "USB",
"longDescription": "TestDescriptionAA",
"primarySupplierId": 1,
"purchaseType": 1,
"rfid": true,
"shortDescription": "TestShortAA",
"status": 1,
"storeControlPricing": false,
"uinCaptureTime": 1,
"uinExternalCreateAllowed": true,
"uinLabelCode": "SN",
"uinType": 1
Item Status
Value |
Definition |
1 |
Active |
2 |
Discontinued |
3 |
Inactive |
4 |
Auto Stockable |
Purchase Type
Value |
Definition |
1 |
Normal Merchandise |
2 |
Consignment Stock |
3 |
Concession Items |
UIN Capture Time
Value |
Definition |
1 |
Sale |
2 |
Store Receiving |
UIN Type
Value |
Definition |
1 |
Serial Number |
2 |
API: Remove Store Items
This will mark items as no longer usable. When all data is cleared out of transactions that reference this data, later batch jobs will eventually delete the material.
If more than 1000 items are included in a single call, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/{storeId}/remove |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
None |
Output |
None |
Max Input Limit |
1000 |
Path Parameter Definitions
Attribute |
Definition |
storeId |
The internal identifier of the store. |
Attribute |
Data Type |
Required |
Description |
items |
List of items to remove |
Yes |
A collection of up to 1000 items to remove. |
Example Input
"itemIds": [
"100637121",
"100637113"
API: Import Replenishment Items
Imports item replenishment information for an item at a store location.
API Basics
Endpoint URL |
{base URL}/{storeId}/replenish/import |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
None |
Output |
List of Items Replenishment to import |
Max Input Limit |
1000 |
Attribute |
Definition |
storeId |
Attribute |
Data Type |
Required |
Description |
items |
List of Item Replenishment Import |
Yes |
The item replenishment information to import. |
Item Replenishment Import Data Definition
Attribute |
Data Type |
Required |
Description |
itemId |
String (25) |
Yes |
replenishmentMethod |
String(6) |
A code representing the replenishment method. (SO indicates Store Order). |
rejectStoreOrder |
Boolean |
True indicates store orders must be on or after the next delivery date or should be rejected. |
multipleDeliveryPerDayAllowed |
Boolean |
True indicates the item allows multiple deliveries per day at the location. |
nextDeliveryDate |
Date |
The next delivery date of the time based on its replenishment type. |
Example Input
"items": [
"replenishmentMethod": "AB",
"rejectStoreOrder": false,
"multipleDeliveryPerDayAllowed": false,
"nextDeliveryDate": "2022-11-19T23:59:59-05:00"
API: Remove Replenishment Items
Clears the replenishment item information from within the store item setting the replenishment properties to empty, null, or default flag settings.
API Basics
Endpoint URL |
{base URL}/replenish/remove |
Method |
POST |
200 OK |
Processing Type |
Asynchronous |
Input |
List of item ids |
Output |
None |
Max Input Limit |
1000 |
Attribute |
Data Type |
Required |
Description |
Items |
List of item Ids |
Yes |
A collection of up to 1000 items to read. |
Example Input
"itemIds": [
"100637121",
"100637113"
REST Service: Store Order
Store orders allow a store to request items to be ordered to the store. The items being requested may come from a supplier or warehouse. Store orders allows a user to capture items and their quantities to be ordered as well as restrictions for the store order. The inventory will be sourced to the store based on the corporate replenishment setup. This can be either a delivery from a warehouse or a drop ship from the supplier. The actual sourcing, delivery timings, and final quantities remain a function of the external replenishment system.
Service Base URL
The Cloud service base URL follows the format:
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Store Order
This section describes the Find Store Order API. This API finds up to a maximum of 5,000 store orders for the input criteria.
Request Parameters
Table 4-354 Find Store Order — Request Parameters
storeId |
NA |
integer($int10) (query) |
Include only store orders with this store identifier. |
externalReference |
NA |
string($text128) (query) |
Include only store orders with this external reference number. |
externalTransferId |
NA |
Include only store orders with this external transfer identifier. |
externalPurchaseOrderId |
NA |
Include only store orders with this external purchase order identifier. |
status |
NA |
integer($int4) (query) |
1 - New 2 - In Progress 3 - Approved 4 - Canceled 5 - Submitted Available values : 1, 2, 3, 4, 5 |
itemId |
NA |
Include only store orders containing this item. |
updateDateFrom |
NA |
string($date-time) (query) |
Include only store orders with an update date on or after this date. |
updateDateTo |
NA |
Include only store orders with an update date on or before this date. |
Responses
This section describes the responses of the Find Store Order API.
Response Code: 200
Example Value
"storeOrderId": 11111,
"storeId": 1234,
"externalTransferId": "7000",
"externalPurchaseOrderId": "8000",
"externalReference": "9000",
"description": "Need more inventory",
"status": 1,
"requestedDeliveryDate": "2025-01-21T14:44:31.735Z",
"updateDate": "2025-01-21T14:44:31.735Z"
]Schema — StoreOrderHeaderIdo
Table 4-355 StoreOrderHeaderIdo— Object
storeOrderId |
NA |
integer($int12) example: 11111 |
The unique identifier of the store order. |
storeId |
NA |
number($int10) example: 1234 |
The store identifier of the store order. |
NA |
string($text128) example: 7000 |
An external transfer identifier that this store order is associated to. |
NA |
string($text128) example: 8000 |
An external purchase order identifier that this store order is associated to. |
externalReference |
NA |
string($text128) example: 9000 |
A reference to this store order in an external system. |
description |
NA |
string($text2000) example: Need more inventory |
A description of the store order or cause of the store order. |
status |
NA |
1 - New 2 - In Progress 3 - Approved 4 - Canceled 5 - Submitted Enum: [ 1, 2, 3, 4, 5 ] |
requestedDeliveryDate |
NA |
The date the store request the delivery arrive by. |
updateDate |
NA |
The date the store order was lasted updated within the system. |
Create Store Order
This operation will cause the system to generate a new inventory request to an external system which will then generate a new transfer or purchase order to fulfill the inventory request.
Request Parameters
Details about the store order to request.
Example Value
"storeId": 1234,
"requestedDeliveryDate": "2025-01-21T15:26:24.751Z",
"contextTypeId": 1234,
"restrictToSupplierId": 1111,
"restrictToWarehouseId": 2222,
"restrictToAreaId": 4444,
"restrictToDepartmentId": 1000,
"restrictToClassId": 1000,
"restrictToSubclassId": 1000,
"storeOrderOnly": false,
"lineItems": [
"itemId": "55001234",
"quantity": 2,
"caseSize": 5,
"deliverySlotId": 55555
}Schema — StoreOrderCreateIdo
Table 4-356 StoreOrderCreateIdo — Object
storeId |
Yes |
description |
NA |
NA |
contextTypeId |
NA |
integer($int18) example: 1234 |
A context identifier associated to the store order. |
restrictToSupplierId |
NA |
integer($int12) example: 1111 |
Only allow items on the store order that are associated to this supplier. |
restrictToWarehouseId |
NA |
integer($int12) example: 2222 |
Only allow items on the store order that are associated to this warehouse. |
restrictToAreaId |
NA |
integer($int12) example: 4444 |
Only allow items on the store order that are associated to this store sequence area. |
restrictToDepartmentId |
NA |
integer($int15) example: 1000 |
Only allow items that are within this department. |
restrictToClassId |
NA |
Only allow items that are within this class. If included, department must also be included. |
restrictToSubclassId |
NA |
Only allow items that are within this subclass. If included, class must also be included. |
storeOrderOnly |
NA |
If true, only store order replenishment items can be added to the order. |
lineItems |
Yes |
object |
The items to request inventory for. |
Table 4-357 StoreOrderCreateItemIdo — Object
itemId |
Yes |
string($text25) example: 55001234 |
The SKU level item identifier. |
quantity |
Yes |
number($decimal(20,4)) example: 2 |
The quantity of the item to be requested from an external system. |
caseSize |
NA |
number($decimal(10,2)) example: 5 |
The case size of this line item. |
deliverySlotId |
NA |
integer($int15) example: 55555 |
The unique identifier of the delivery time. |
Responses
This section describes the responses of the Create Store Order API.
Response Code: 200
Schema — StoreOrderStatusIdo
Table 4-358 StoreOrderStatusIdo — Object
storeOrderId |
NA |
storeId |
NA |
status |
NA |
Read Store Order
This section describes the Read Store Order API. This API retrieves all the details about a store order.
Request Parameters
Table 4-359 Read Store Order — Request Parameters
storeOrderId |
Yes |
The unique identifier of the store order.. |
Responses
This section describes the responses of the Read Store Order API.
Response Code: 200
Example Value
"storeId": 1234,
"parentReference": 1111,
"status": 1,
"origin": 1,
"requestedDeliveryDate": "2025-01-21T15:43:39.415Z",
"autoApproveDate": "2025-01-21T15:43:39.415Z",
"addItemsAllowed": true,
"replenishmentItemsOnly": false,
"deliverySlotId": 4565,
"productGroupId": 5678,
"productGroupDescription": "Bi-Weekly Restock",
"restrictToHierarchyId": 3333,
"externalCreateDate": "2025-01-21T15:43:39.415Z",
"createDate": "2025-01-21T15:43:39.415Z",
"createUser": "userAbc",
"updateDate": "2025-01-21T15:43:39.415Z",
"approvedDate": "2025-01-21T15:43:39.415Z",
"approvedUser": "userAbc",
"lineItems": [
"lineId": 1234,
"approvedQuantity": 2,
"suggestedQuantity": 2,
"caseSize": 5,
"unitCostCurrency": "USD",
"unitCostAmount": 5.5,
]Schema — StoreOrderIdo
Table 4-360 StoreOrderIdo— Object
storeOrderId |
NA |
storeId |
NA |
NA |
NA |
externalReference |
NA |
parentReference |
NA |
Reference to a parent transfer or order. |
description |
NA |
status |
NA |
origin |
NA |
1 - External 2 - Manual 3 - System Enum: [ 1, 2, 3 ] |
NA |
The date the store requested the delivery arrive by. |
autoApproveDate |
NA |
The date the record was automatically approved in the system. |
addItemsAllowed |
NA |
True indicates new items can be added to the store order. |
replenishmentItemsOnly |
NA |
True indicates only store order replenishment items can be added to the store order. |
contextTypeId |
NA |
deliverySlotId |
NA |
integer($int15) example: 4565 |
The unqiue identifer of a delivery time. |
productGroupId |
NA |
integer($int12) example: 5678 |
The unique identifier of a product group associated to the order. |
NA |
string($text250) example: Bi-Weekly Restock |
The description of the product group associated to the order. |
NA |
NA |
restrictToHierarchyId |
NA |
integer($int12) example: 3333 |
Only allow items on the store order that belong to this merchandise hierarchy. |
restrictToAreaId |
NA |
Only allow items on teh store order that are associated to this store sequence area. |
externalCreateDate |
NA |
The date the store order was created in an external system. |
createDate |
NA |
The date the store order was created in the system. |
createUser |
NA |
string($text128) example: userAbc |
The user that created the store order in the system. |
updateDate |
NA |
The date the store order was lasted updated in the system. |
approvedDate |
NA |
The date the store order was approved in the system. |
approvedUser |
NA |
The user that approved the store order in the system. |
lineItems |
NA |
object |
A list of items on the store order. |
Table 4-361 StoreOrderItemIdo— Object
| Element Name | Required | Data Type/Example | Description |
lineId |
NA |
number($int12) example: 1234 |
The unique system identifier of the line item. |
itemId |
NA |
approvedQuantity |
NA |
The quantity of the item approved to order. |
suggestedQuantity |
NA |
The quantity of the item ordered from an external system. |
caseSize |
NA |
unitCostCurrency |
NA |
string($text3) example: USD |
The currency of the unit cost. |
unitCostAmount |
NA |
number($decimal(12,4)) example: 5.5 |
The value of the unit cost. |
deliverySlotId |
NA |
Update Store Order
This section describes the Update Store Order API. This operation update the information on a store order before store order approval.
Request Parameters
Table 4-362 Update Store Order — Request Parameters
storeOrderId |
yes |
integer($int12) (path) |
The request body is application/json.
Details to update on the store order.
Example Value
"requestedDeliveryDate": "2025-01-22T11:09:54.923Z",
"lineItems": [
"quantity": 2,
"caseSize": 5,
}Schema — StoreOrderUpdateIdo
Table 4-363 StoreOrderUpdateIdo— Object
description |
NA |
NA |
contextTypeId |
NA |
lineItems |
NA |
object |
A list of line items to update on the store order. |
Table 4-364 StoreOrderUpdateItemIdo— Object
itemId |
Yes |
quantity |
Yes |
If the store order originated internally, then this modifies the quantity to be requested from the external system. If the store order originated in an external system, then this defines the approved amount of the original order. |
caseSize |
NA |
deliverySlotId |
NA |
Approve Store Order
This section describes the Approve Store Order API. This operations will approve a store order. It may be either a new request for inventory or the approval of an already existing transfer or purchase order. Either way, the store is approved and a notification sent to external systems, either a request to create a new transfer/purchase order or notification of an approval of an existing transfer/purchase order.
Request Parameters
Table 4-365 Approve Store Order — Request Parameters
| Parameter | Required | Data Type | Description |
storeOrderId |
yes |
Cancel Store Order
This section describes the Cancel Store Order API. This operation will cancel the store order.
Request Parameters
Table 4-366 Cancel Store Order — Request Parameters
storeOrderId |
yes |
Import Store Order
Request Parameters
There are no request parameters.
Details about the store order.
Example Value
"orderNumber": "7000",
"storeId": 1234,
"locationType": 1,
"locationId": 4500,
"requestedDeliveryDate": "2025-01-22T11:41:05.395Z",
"comments": "Automated department replenishment",
"lineItems": [
"quantity": 2,
"caseSize": 5,
}Schema — StoreOrderImportIdo
Table 4-367 StoreOrderImportIdo — Object
orderNumber |
Yes |
The original transfer or purchase order identifier of the store order from an external system. |
storeId |
Yes |
locationType |
Yes |
integer($int4) example: 1 |
1 - Supplier 2 - Warehouse Enum: [ 1, 2 ] |
locationId |
Yes |
integer($int18) example: 4500 |
The identifier the location shipping the goods. |
parentReference |
NA |
NA |
The date the store requests the delivery arrive by. |
contextTypeId |
NA |
deliverySlotId |
NA |
currencyCode |
NA |
integer($int15) example: USD |
The currency code of cost values on the order. |
comments |
NA |
string($text2000) example: Automated department replenishment |
Comments associated to the store order. |
lineItems |
Yes |
object |
The items to import on the store order. |
Table 4-368 StoreOrderImportItemIdo — Object
itemId |
NA |
quantity |
NA |
number($decimal20,4) example: 2 |
The quantity of the suggested item order generated from an external system. |
caseSize |
NA |
number($decimal10,2) example: 5 |
unitCostAmount |
NA |
The value of the unit cost in the currency of the order. |
Responses
This section describes the responses of the Import Store Order API.
Response Code: 200
The request has been successful.
The media type is application/json.
Table 4-369 StoreOrderStatusIdo — Object
storeOrderId |
NA |
storeId |
NA |
status |
NA |
Find Order Timeslots
This section describes the Find Order Timeslots. This API retrieves all the store order delivery timeslots.
Responses
This section describes the responses of the Find Order Timeslots API.
Response Code: 200
Example Value
"id": 1,
"code": "Morn",
"description": "Morning",
"sequence": 1,
"publish": true
]Schema — StoreOrderTimeslotIdo
Table 4-370 StoreOrderTimeslotIdo — Object
id |
NA |
number($int15) example: 1 |
The unique identifier of the delivery slot. |
code |
NA |
string($text15) example: Morn |
The external code of the delivery time slot. |
description |
NA |
string($text240) example: Morning |
The description of the time slot. |
sequence |
NA |
number($int8) example: 1 |
The order the time slot should appear in a list. |
publish |
NA |
True if the delivery time slot should be published, false otherwise. |
Find Order Context Types
This section describes the Find Order Context Types. This API retrieves all the context type available for a store order
Responses
This section describes the responses of the Find Order Context Types API.
Response Code: 200
Schema — StoreOrderContextTypeIdo
Table 4-371 StoreOrderContextTypeIdo — Object
id |
NA |
number($int18) example: 11111 |
The identifier of the context type. |
code |
NA |
string($text6) example: CS |
The identification code of the context type. |
description |
NA |
string($text1) example: Consumables |
The description of the context type. |
sequence |
NA |
number($int3) example: 1 |
This number indicates the order the context type should appear in a list. |
Find Order Areas
This section describes the Find Order Areas. This API retrieves all the order areas available for a store order.
Request Parameters
Table 4-372 Find Order Areas— Request Parameters
storeId |
yes |
The store to retrieve completed product areas for. |
Responses
This section describes the responses of the Find Order Areas API.
Response Code: 200
Schema — StoreOrderAreaIdo
Table 4-373 StoreOrderAreaIdo — Object
areaId |
NA |
integer($int12) example: 13413513443 |
The unique identifier of the product area. |
itemBasketId |
NA |
integer($int12) example: 34134134 |
The unique identifier of an item basket associated to the area. |
description |
NA |
string($text255) example: 11111 |
The description of the store order product area. |
REST Service: Store Sequencing
This service defines operations to manage Store Sequence information.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/sequences
APIs
API |
Description |
Find Sequence Areas |
Finds sequence area header based on search criteria. |
Read Sequence Area |
Reads the details of a sequence area. |
Create Sequence Area |
Create a sequence area along with all its details. |
Update Sequence Area |
Replace the entire sequence area including all its details (a complete sequence area must be sent). |
Delete Sequence Area |
Delete a sequenced area and all its details. |
Create Sequence Item |
Create a single sequence item in a sequence area. |
Update Sequence Item |
Updates a single sequence item from a sequence area. |
Delete Sequence Item |
Removes a single sequence item from a sequence area. |
API: Find Sequence Areas
This API is used to search for sequence area headers. No items or detailed information is returned by this API. At least one criteria is required in order to search.
API Basics
Table 4-374 API Basics
Endpoint URL |
{base URL} |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Input |
Query Parameters |
Output |
Collection of Sequence Areas |
Max Response Limit |
15,000 |
Query Parameters
Table 4-375 Query Parameters
Attribute |
Type |
Definition |
storeId |
Long(12) |
Include only records for this store. |
areaType |
Integer(9) |
Area Type (see Index). |
departmentId |
Long(12) |
The unique identifier of a department associated to the area. |
classId |
Long(12) |
The unique identifier of a class within the department associated to the area. |
itemId |
String(25) |
Include only records with this item on them. |
Table 4-376 Output Data Definition
Attribute |
Type |
Definition |
sequenceAreaId |
Long(10) |
The unique identifier of the sequence area. |
storeId |
Long(10) |
description |
String(255) |
A description of this store sequence. |
areaType |
Integer(9) |
departmentId |
Long(12) |
classId |
Long(12) |
sequenceOrder |
Long(20 |
The order of this store sequence compared to other store sequences at the store. |
unsequenced |
Boolean |
True indicates that this is a default sequence area that contains all the items that have not been sequenced within a different area. |
API: Read Sequence Area
This API is used to read an entire sequence area including its details.
API Basics
Table 4-377 API Basics
Endpoint URL |
{base URL}/{sequenceAreaId} |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Input |
N/A |
Output |
Sequence Area |
N/A |
Table 4-378 Path Parameter Definition
Attribute |
Type |
Definition |
sequenceAreaId |
Long(10) |
Table 4-379 Output Data Definition
Attribute |
Type |
Definition |
sequenceAreaId |
Long(10) |
storeId |
Long(10) |
description |
String(255) |
areaType |
Integer(9) |
departmentId |
Long(12) |
classId |
Long(12) |
sequenceOrder |
Long(20 |
unsequenced |
Boolean |
Items |
Collection |
Contains all the items in the area (see Store Sequence Item) |
Store Sequence Item
Table 4-380 Store Sequence Item
Payload |
Type |
Definition |
sequenceItemId |
Long(12) |
The unique area item identifier. |
itemId |
String(25) |
The unique identifier of the item |
sequenceOrder |
Long(20) |
The order of the item within its sequence. |
capacity |
BigDecimal(11,2) |
The amount of the item that can be contained in the area for that item at the unit of measure. |
width |
Long(12) |
The number of items that can fit across the width of the shelf. |
uomMode |
Integer(2) |
The mode of display of the unit of measure of the item. |
primaryLocation |
Boolean |
Y indicates this is the primary sequence for the item. |
ticketQuantity |
BigDecimal(11,2) |
The quantity of tickets that need to be printed for the item inventory area. |
ticketFormatId |
Long(10) |
The unique identifier of the ticket format used to print the tickets. |
API: Create Sequence Area
API Basics
Endpoint URL |
{base URL} |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Input |
Sequence Area Create Info |
Output |
Sequence Area Reference Info |
1,000 items in the area |
Input Data Definition
Attribute |
Type |
Req |
Definition |
storeId |
Long(10) |
X |
description |
String(255) |
areaType |
Integer(9) |
X |
departmentId |
Long(12) |
classId |
Long(12) |
sequenceOrder |
Long(20) |
X |
The order of this store sequence compared to other store sequences at the store. The sequence order must be unique for the set of areas within the store. |
items |
Collections |
X |
All the items that belong to this sequence area (see Sequence Area Item Create) |
Store Sequence Area Item Create
Payload |
Type |
Req |
Definition |
itemId |
String(25) |
X |
sequenceOrder |
Long(20) |
X |
capacity |
BigDecimal(11,2) |
X |
width |
Long(12) |
uomMode |
Integer(2) |
X |
primaryLocation |
Boolean |
ticketQuantity |
BigDecimal(11,2) |
ticketFormatId |
Long(10) |
Attribute |
Type |
Definition |
sequenceAreaId |
Long(12) |
The newly created adjustment identifier. |
storeId |
Long(10) |
The store identifier. |
Example
API: Update Sequence Area
This API is used to update a sequence area within a store.
This API will replace the entire sequence area with the new data passed to the API. Only the area identifier and store identifier will be preserved from previous data.
API Basics
Table 4-381 API Basics
Endpoint URL |
{base URL} |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Input |
Sequence Area Update Info |
Output |
N/A |
Table 4-382 Path Parameter Definition
Attribute |
Type |
Definition |
sequenceItemId |
Long(12) |
The unique area item identifier |
Table 4-383 Input Data Definition
Attribute |
Type |
Req |
Definition |
description |
String(255) |
areaType |
Integer(9) |
X |
departmentId |
Long(12) |
classId |
Long(12) |
sequenceOrder |
Long(20) |
X |
items |
Collections |
X |
All the items that belong to this sequence area (see Sequence Area Item Update) |
Store Sequence Area Item Update
Table 4-384 Store Sequence Area Item Update
Payload |
Type |
Req |
Definition |
itemId |
String(25) |
X |
sequenceOrder |
Long(20) |
X |
capacity |
BigDecimal(11,2) |
X |
width |
Long(12) |
uomMode |
Integer(2) |
X |
primaryLocation |
Boolean |
ticketQuantity |
BigDecimal(11,2) |
ticketFormatId |
Long(10) |
Example
API: Delete Sequence Area
This API is used to delete a sequence area and all its items. This will not delete a sequence area currently being used by a sequenced stock count.
API Basics
Table 4-385 API Basics
Endpoint URL |
{base URL} |
Method |
DELETE |
204 No Content |
Processing Type |
Synchronous |
Input |
N/A |
Output |
N/A |
N/A |
API: Create Sequence Item
This API is used to create a new sequence item within a sequence area.
API Basics
Table 4-386 API Basics
Endpoint URL |
{base URL}/{sequenceAreaId}/items |
Method |
POST |
200 No Content |
Processing Type |
Synchronous |
Input |
Store Sequence Item Create |
Output |
Store Sequence Item |
N/A |
Table 4-387 Input Data Definition
Payload |
Type |
Req |
Definition |
itemId |
String(25) |
X |
sequenceOrder |
Long(20) |
X |
capacity |
BigDecimal(11,2) |
X |
width |
Long(12) |
uomMode |
Integer(2) |
X |
The mode of display of the unit of measure of the item. (see Index) |
primaryLocation |
Boolean |
ticketQuantity |
BigDecimal(11,2) |
ticketFormatId |
Long(10) |
Example
API: Update Sequence Item
This API is used to update a sequence item within a sequence area.
API Basics
Table 4-388 API Basics
Endpoint URL |
{base URL}/{sequenceAreaId}/items/{itemId} |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Input |
N/A |
Output |
N/A |
N/A |
Table 4-389 Path Parameter Definition
Attribute |
Type |
Definition |
sequencerAreaId |
Long(12) |
The unique sequence area identifier. |
itemId |
String(25) |
The item to be deleted from the sequence. |
Table 4-390 Input Data Definition
Payload |
Type |
Req |
Definition |
sequenceOrder |
Long(20) |
X |
capacity |
BigDecimal(11,2) |
X |
width |
Long(12) |
uomMode |
Integer(2) |
X |
primaryLocation |
Boolean |
ticketQuantity |
BigDecimal(11,2) |
ticketFormatId |
Long(10) |
Example
API: Delete Sequence Item
This API is used to delete a sequence item from an area.
API Basics
Table 4-391 API Basics
Endpoint URL |
Method |
DELETE |
204 No Content |
Processing Type |
Synchronous |
Input |
N/A |
Output |
N/A |
N/A |
Table 4-392 Path Parameter Definition
Attribute |
Type |
Definition |
sequencerAreaId |
Long(12) |
itemId |
String(25) |
REST Service: Supplier
This service integrates supplier and supplier item foundation data.
Asynchronous supplier integration is processed through staged messages and is controlled by the MPS Work Type: DcsSupplier.
Asynchronous supplier item integration is processed through staged messages and is controlled by the MPS Work Type: DcsSupplierItem.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/suppliers
API Definitions
API |
Description |
Import Suppliers |
Imports supplier. |
Delete Supplier |
Deletes a supplier. |
Import Items |
Imports items for a supplier. |
Delete Items |
Deletes items from a supplier. |
Import Item UOMs |
Imports units of measure for a supplier item. |
Delete Item UOMs |
Deletes units of measure from a supplier item. |
Import Item Countries |
Imports countries for a supplier item. |
Delete Item Countries |
Deletes countries from a supplier item. |
Import Item Dimensions |
Imports items dimensions for a supplier item country. |
Delete Item Dimensions |
Deletes dimensions from a supplier item country. |
Import Item Manufacturers |
Imports manufacturers for a supplier item country. |
Delete Item Manufacturers |
Deletes manufacturers from a supplier item country. |
API: Import Suppliers
Imports a list of suppliers.
If the import contains more than 500 suppliers, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/import |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of suppliers to Import |
Output |
None |
500 |
Attribute |
Data Type |
Required |
Description |
suppliers |
List of details |
Yes |
A collection of up to 500 suppliers to import. |
Detail Data Definition
Attribute |
Data Type |
Required |
Description |
supplierId |
Long (10) |
Yes |
The supplier identifier. |
name |
String (240) |
The supplier's name. |
status |
Integer |
Yes |
The supplier’s status: See Supplier Status |
dunsNumber |
String (9) |
The nine-digit number assigned and maintained by Dun and Bradstreet. |
taxId |
String (18) |
The tax identification number of the supplier. |
parentId |
Long (128) |
The parent supplier's identifier. |
countryCode |
String (3) |
The 2-3 character ISO code of the country. |
languageCode |
String (3) |
The 2-3 character ISO code of the language. |
currencyCode |
String (3) |
The 2-3 character ISO code of the currency. |
returnAllowed |
Boolean |
True is return is allowed to the supplier, N otherwise. |
authorizationRequired |
Boolean |
True indicates an authorization number is required when merchandise is return to this supplier. |
orderCreateAllowed |
Boolean |
True indicates at a purchase order can be created for the supplier when processing deliveries from that supplier. |
vendorCheck |
Boolean |
True indicates that orders from this supplier requires vendor control. |
vendorCheckPercent |
BigDecimal |
Indicates the percentage of items per receipt that will be marked for vendor checking. |
quantityLevel |
Integer |
Yes |
The Quantity Level: See Quantity Level |
deliveryDiscrepancy |
Integer |
Yes |
The delivery discrepancy: See Supplier Delivery Discrepancy Type |
organizationUnitIds |
List<Long> |
Yes |
A complete list of organization unit identifiers for the supplier. |
Example Input
"suppliers": [
"supplierId": 5000,
"status": 1,
"quantityLevel": 1,
"deliveryDiscrepancy": 1,
"organizationUnitIds": [ 1 ]
"supplierId": 5001,
"status": 1,
"returnAllowed": false,
"quantityLevel": 1,
Value |
Definition |
1 |
Allow Any Discrepancy |
2 |
Allow Overage But Not Short Receipts |
3 |
Discrepancy Not Allowed |
Supplier Status
Value |
Definition |
1 |
Active |
2 |
Inactive |
Quantity Level
Value |
Definition |
1 |
Eaches |
2 |
Cases |
API: Delete Supplier
Deletes a supplier.
API Basics
Endpoint URL |
{base URL}/{supplierId}/delete |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
None |
Output |
None |
1000 |
Attribute |
Definition |
supplierId |
The internal identifier of the supplier. |
API: Import Items
Imports supplier items. Later during asynchronous processing, it validates that both the supplier and item exist before inserting new records.
If the import contains more than 500 supplier items, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/items |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of Supplier Items to import |
Output |
None |
500 |
Attribute |
Definition |
supplierId |
Attribute |
Data Type |
Required |
Description |
items |
List of details |
Yes |
The supplier item information to import. |
Attribute |
Data Type |
Required |
Description |
supplierId |
Long (10) |
Yes |
itemId |
String (25) |
Yes |
The item identifier. |
vendorProductNumber |
String (256) |
Vendor product number. |
primary |
Boolean |
True indicates this supplier is the primary supplier for the item at all locations. |
Example Input
"items": [
"supplierId": 5000,
"itemId": "163715121",
"vendorProductNumber": "abc"
"supplierId": 5001,
"vendorProductNumber": "def"
API: Delete Items
Deletes supplier items.
If the delete contains more than 500 supplier items, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/items/delete |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of supplier items |
Output |
None |
500 |
Attribute |
Data Type |
Required |
Description |
items |
List of details |
Yes |
The supplier item information to delete. |
Attribute |
Data Type |
Required |
Description |
supplierId |
Long (10) |
Yes |
itemId |
String (15) |
Yes |
Example Input
"items":
"supplierId":"9002",
"itemId": "100637130"
"itemId": "100637148"
API: Import Item UOMs
Imports supplier item unit of measure information.
If the import contains more than 500 supplier item units of measure, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/uoms |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of supplier items UOMs to import |
Output |
None |
500 |
Attribute |
Data Type |
Required |
Description |
uoms |
List of details |
Yes |
The UOMs to import. |
Attribute |
Data Type |
Required |
Description |
supplierId |
Long (10) |
Yes |
itemId |
String (25) |
Yes |
unitOfMeasure |
String (4) |
Yes |
The unit of measure. |
Value |
BigDecimal |
Yes |
Equivalent item/supplier shipping carton value in unit of measure |
Example Input
"uoms": [
"supplierId": 5000,
"unitOfMeasure": "KG",
"value": "1.0"
"supplierId": 5001,
"value": "1.0"
API: Delete Item UOMs
Deletes supplier item unit of measure information.
If the delete contains more than 500 supplier item units of measure, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/uoms/delete |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of supplier items UOMs to delete |
Output |
None |
500 |
Attribute |
Data Type |
Required |
Description |
uoms |
List of details |
Yes |
The UOMs to delete. |
Attribute |
Data Type |
Required |
Description |
supplierId |
Long (10) |
Yes |
itemId |
String (25) |
Yes |
unitOfMeasure |
String (4) |
Yes |
Example Input
"uoms":
"itemId": "100637130",
"unitOfMeasure":"EA"
"itemId": "100637148",
API: Import Item Countries
Imports supplier item country information. If the imported supplier item country is for the primary supplier of the item, the item's case size will be updated on the item master to reflect the imported case size.
If the import contains more than 500 supplier item countries, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/countries |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of supplier items country to import |
Output |
None |
500 |
Attribute |
Data Type |
Required |
Description |
countries |
List of details |
Yes |
The countries to import. |
Attribute |
Data Type |
Required |
Description |
supplierId |
Long (10) |
Yes |
itemId |
String (25) |
Yes |
countryCode |
String (3) |
Yes |
The ISO country code of the supplier that produces the item. |
caseSize |
BigDecimal |
Yes |
Number of items with a case from the supplier. |
unitCostCurrency |
String (3) |
The unit cost currency for that item and supplier in that country. |
unitCostValue |
BigDecimal |
The unit cost of the item and supplier in that country. |
Example Input
"countries": [
"supplierId": 5100,
"caseSize":7
"supplierId": 5200,
"caseSize":8
API: Delete Item Countries
Deletes supplier item country information.
If the delete contains more than 500 supplier item countries, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/countries/delete |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of supplier items country to remove |
Output |
None |
500 |
Attribute |
Data Type |
Required |
Description |
countries |
List of details |
Yes |
The countries to remove. |
Attribute |
Data Type |
Required |
Description |
supplierId |
Long (10) |
Yes |
itemId |
String (25) |
Yes |
countryCode |
String (3) |
Yes |
Example Input
"countries":
"countryCode":"US"
API: Import Item Dimensions
Imports supplier item country dimension information.
If the import contains more than 500 supplier item dimensions, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/dimensions |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of supplier items dimensions to import |
Output |
None |
500 |
Attribute |
Data Type |
Required |
Description |
dimensions |
List of details |
Yes |
The dimensions to import. |
Attribute |
Data Type |
Required |
Description |
supplierId |
Long (10) |
Yes |
itemId |
String (25) |
Yes |
countryCode |
String (3) |
Yes |
dimensionName |
String (6) |
Yes |
Dimension name |
presentationMethod |
String (6) |
Describes the packaging method |
Length |
BigDecimal |
The length in dimension unit of measure. |
Width |
BigDecimal |
The width in dimension unit of measure. |
Height |
BigDecimal |
The height in dimension unit of measure. |
dimensionUom |
String (4) |
The unit of measure of the dimensions. |
Weight |
BigDecimal |
The weight of the object in weight unit of measure. |
netWeight |
BigDecimal |
The net weight of the goods without packaging in weight unit of measure. |
weightUom |
String (4) |
The weight unit of measure. |
liquidVolume |
BigDecimal |
The liquid value or capacity of the object. |
liquidVolumeUom |
String (4) |
The liquid volume unit of measure. |
statisticalCube |
BigDecimal |
A statistical value of the object’s dimensions used for shipment loading purposes. |
Example Input
"dimensions": [
"supplierId": 5100,
"dimensionName": "Hello"
"supplierId": 7100,
"dimensionName": "Bye"
API: Delete Item Dimensions
Deletes supplier item country dimension information.
API Basics
Endpoint URL |
{base URL}/dimensions/delete |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of supplier items dimensions to remove |
Output |
None |
500 |
Attribute |
Data Type |
Required |
Description |
Dimensions |
List of details |
Yes |
The dimensions to remove. |
Supplier Items Dimensions Data Definition
Attribute |
Data Type |
Required |
Description |
supplierId |
Long (10) |
Yes |
itemId |
String (25) |
Yes |
countryCode |
String (3) |
Yes |
The ISO country code of the supplier that produces the item |
dimensionName |
String (6) |
Yes |
Dimension name |
Example Input
"dimensions":
"countryCode":"US",
"dimensionName":"Dimen1"
"countryCode":"US",
"dimensionName":"Dimen2"
API: Import Item Manufacturers
Import supplier item country manufacturer information.
If the import contains more than 500 supplier item manufacturers, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/manufacturers |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of supplier items manufacturer to import |
Output |
None |
500 |
Attribute |
Data Type |
Required |
Description |
manufacturers |
List of details |
Yes |
The manufacturers to import. |
Attribute |
Data Type |
Required |
Description |
supplierId |
Long (10) |
Yes |
itemId |
String (25) |
Yes |
countryCode |
String (3) |
Yes |
primary |
Boolean |
True indicates it is primary country of manufacture. |
Example Input
"manufacturers": [
"supplierId": 5100,
"primary": true
"supplierId": 7100,
"primary": true
API: Delete Item Manufacturers
Deletes supplier item country manufacturer information.
If the delete contains more than 500 supplier item manufacturers, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/manufacturers/delete |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of supplier items manufacturers to remove |
Output |
None |
500 |
Attribute |
Data Type |
Required |
Description |
manufacturers |
List of details |
Yes |
The manufacturers to remove. |
Attribute |
Data Type |
Required |
Description |
supplierId |
Long (10) |
Yes |
itemId |
String (25) |
Yes |
countryCode |
String (3) |
Yes |
Example Input
"manufacturers":
"countryCode":"US"
"countryCode":"US"
REST Service: Ticket
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/tickets
API Definitions
API |
Description |
readTicket |
This API reads a current actively ticket by its identifier. |
findTickets |
API is used to find summarized ticket headers for a set of criteria. |
readArchivedTicket |
This API reads a previously printed and archived ticket by its identifier. |
findArchivedTickets |
API is used to find archived ticket summaries. |
createTickets |
Creates new tickets within the system. |
updateTickets |
Updates current tickets within the system. |
printTickets |
Prints the requested tickets. |
findTicketFormats |
Reads all the available ticket formats. |
findTicketPrinters |
Finds the printers available to print tickets. |
API: readTicket
API Basics
Endpoint URL |
{base URL}/{ticketId} |
Method |
GET |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
The ticket identifier |
Output |
The ticket |
Column |
Type |
Definition |
ticketId |
Long(12) |
The unique ticket identifier. |
itemId |
String(25) |
storeId |
Long(10) |
originType |
Integer(2) |
The origin type (See Index) |
ticketFormatId |
Long(12) |
The identifier of the ticket format used for printing. |
ticketFormatDescription |
String(100) |
The description of the ticket format associated to the ticket. |
ticketFormatType |
Integer(4) |
The type of the ticket format associated to the ticket. |
ticketFormatReference |
String(255) |
The format reference used to print the ticket. |
ticketFormatZplId |
Long(12) |
The ZPL format file identifier. |
ticketCount |
Integer(3) |
The number of instances of this ticket to print. |
ticketSequence |
Integer(3) |
The sequence number of a ticket within a ticket grouping. |
printQuantity |
BigDecimal(12,4) |
The quantity to be printed on the ticket. |
printDate |
Date |
The date the ticket should be printed. |
groupId |
Long(12) |
An internal EICS grouping identifier that groups the tickets. |
groupIdExternal |
String(128) |
An external system grouping identifier that groups the tickets. |
autoPrint |
Boolean |
True if the ticket should automatically print, false if the ticket requires manual printing. |
autoRefeshQuantity |
Boolean |
True indicates the ticket count gets refreshed with SOH at the time of printing, false it prints as is. |
countryOfManufacture |
String(3) |
A two letter country code denoting the country of manufacture for the item. |
shortDescription |
String(255) |
The short description of the item. |
longDescription |
String(400) |
The long description of the item. |
shortDescriptionLanguage |
String(255) |
The short description of the item in the language of the store. |
longDescriptionLanguage |
String(400) |
The long description of the item in the language of the store. |
differentiatorType1 |
String(10) |
The description of the differentiator type for differentiator 1. |
differentiatorType2 |
String(10) |
The description of the differentiator type for differentiator 2. |
differentiatorType3 |
String(10) |
The description of the differentiator type for differentiator 3. |
differentiatorType4 |
String(10) |
The description of the differentiator type for differentiator 4. |
differentiatorDescription1 |
String(255) |
The description of differentiator 1 of the item. |
differentiatorDescription2 |
String(255) |
The description of differentiator 2 of the item. |
differentiatorDescription3 |
String(255) |
The description of differentiator 3 of the item. |
differentiatorDescription4 |
String(255) |
The description of differentiator 4 of the item. |
departmentId |
Long(12) |
The department identifier of the item. |
departmentName |
String(360) |
The department name of the item. |
classId |
Long(12) |
The class identifier of the item. |
className |
String(360) |
The class name of the item. |
subclassId |
Long(12) |
The subclass identifier of the item. |
subclassName |
String(360) |
The subclass name of the item. |
primaryUpc |
String(25) |
The primary Unique Product Code for the item. |
priceCurrency |
String(3) |
The currency code of the ticket price. |
priceAmount |
BigDecimal(12,4) |
The amount of the ticket price. |
priceType |
Integer(3) |
The type of the ticket price. (See Index) |
priceUom |
String(4) |
The unit of measure of the ticket price. |
priceActiveDate |
Date |
The date the ticket price became active. |
priceExpireDate |
Date |
The date the ticket price expires. |
mutliUnitPriceCurrency |
String(3) |
The currency code of the ticket's multi-unit price. |
multiUnitPriceAmount |
BigDecimal(12,4) |
The amount of the ticket's multi-unit price. |
multiUnitPriceUom |
String(4) |
The unit of measure of the ticket's multi-unit price. |
multiUnitQuantity |
BigDecimal(12,4) |
The multi-unit quantity associated to the price. |
overridePriceCurrency |
String(3) |
The override price currency code. |
overridePriceAmount |
BigDecimal(20,4) |
The override price amount. |
previousPriceCurrency |
String(3) |
The currency code of the previous price. |
previousPriceAmount |
BigDecimal(12,4) |
The amount of the previous price. |
previousPriceType |
Integer(3) |
The price type of the previous price. |
lowestMonthlyPriceCurrency |
String(3) |
The currency code of the lowest monthly price. |
lowestMonthlyPriceAmount |
BigDecimal(12,4) |
The amount of the lowest monthly price. |
lowestMonthlyPriceType |
Integer(3) |
The price type of the lowest monthly price. |
printedDate |
Date |
The date that the ticket was printed. |
printedUser |
String(128) |
The user that printed the ticket. |
createDate |
Date |
The date the ticket was created. |
createUser |
String(128) |
The user that created the ticket. |
updateDate |
Date |
The date the ticket was last updated. |
updateUser |
String(128) |
The user that last updated the ticket. |
udas |
Collection |
A group of associated user defined attributes. |
UDA
Column |
Type |
Definition |
name |
String |
The name of the user defined attribute. |
value |
String |
The value of the user defined attributes. |
API: findTickets
If maximum results are exceeded, additional or more limiting input criteria will be required.
API Basics
Endpoint URL |
{base URL} |
Method |
GET |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
Query Parameters |
Output |
List of Ticket Headers |
Maximum Results Allowed |
5,000 |
Attribute |
Type |
Definition |
itemId |
String(25) |
Include only records with this item identifier. |
storeId |
Long(10) |
Include only records with this store identifier. |
ticketFormatId |
Long(12) |
Include only records with this ticket format identifier. |
groupId |
Long(12) |
Include only records with this EICS group identifier. |
groupIdExternal |
String(128) |
Include only records with this external system group identifier. |
printDateFrom |
String |
Include only records on or after this scheduled print date and time. |
printDateTo |
String |
Include only records on or before this scheduled print date and time. |
updateDateFrom |
String |
updateDateTo |
String |
Column |
Type |
Definition |
ticketId |
Long(12) |
itemId |
String(25) |
storeId |
Long(10) |
originType |
Integer(2) |
ticketFormatId |
Long(12) |
ticketSequence |
Integer(3) |
groupId |
Long(12) |
groupIdExternal |
String(128) |
autoPrint |
Boolean |
printDate |
Date |
printQuantity |
BigDecimal(12,4) |
updateDate |
Date |
API: readArchivedTicket
API Basics
Endpoint URL |
{base URL}/archives/{ticketId} |
Method |
GET |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
Output |
The ticket details |
See readTicket() for the output data definition of this API.
API: findArchivedTickets
If the number of tickets found exceeds the limit, additional or more limiting input criteria will be required.
API Basics
Endpoint URL |
{base URL}/archives |
Method |
GET |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
Query Parameters |
Output |
5,000 |
Attribute |
Type |
Definition |
itemId |
String(25) |
storeId |
Long(10) |
ticketFormatId |
Long(12) |
groupId |
Long(12) |
groupIdExternal |
String(128) |
printedDateFrom |
String |
Include only records that were printed on or after this date and time. |
printedDateTo |
String |
Include only records that were printed on or before this date and time. |
Column |
Type |
Definition |
ticketId |
Long(12) |
itemId |
String(25) |
storeId |
Long(10) |
originType |
Integer(2) |
ticketFormatId |
Long(12) |
ticketSequence |
Integer(3) |
groupId |
Long(12) |
groupIdExternal |
String(128) |
printedDate |
Date |
The date the ticket was printed. |
printQuantity |
BigDecimal(12,4) |
The quantity printed on the ticket. |
priceCurrency |
String(3) |
The currency of the price of the ticket. |
priceAmount |
BigDecimal(12,4) |
The amount of the price of the ticket. |
API: createTickets
API Basics
Endpoint URL |
{base URL} |
Method |
POST |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
Ticket group |
Output |
List of ticket identifying information |
Maximum Input Allowed |
2,000 tickets within the group |
Payload |
Type |
Req |
Definition |
storeId |
Long(10) |
X |
groupIdExternal |
String(128) |
printDate |
Date |
X |
autoPrint |
Boolean |
True if the ticket should automatically print, false if the ticket requires manual printing. Defaults to false. |
Boolean |
True indicates the ticket count gets refreshed with SOH at the time of printing, false it prints as is. Defaults to false. |
tickets |
Collection |
X |
The tickets to create. |
Ticket
Payload |
Type |
Req |
Definition |
itemId |
String(25) |
X |
originType |
Integer(2) |
X |
ticketFormatId |
Long(12) |
X |
ticketCount |
Integer(3) |
X |
ticketSequence |
Integer(3) |
X |
printQuantity |
BigDecimal(12,4) |
X |
String(3) |
The override price currency code. Required if an amount is entered. |
BigDecimal(20,4) |
String(3) |
Payload |
Type |
Definition |
ticketId |
Long(12) |
storeId |
Long(10) |
ticketFormatId |
Long(12) |
Example Input
"storeId": 5000,
"groupIdExternal": "123456",
"printDate": "2023-01-10T23:59:59-05:00",
"autoPrint": false,
"autoRefreshQuantity": false,
"tickets": [
"originType": 1,
"ticketFormatId": 1,
"ticketCount": 2,
"ticketSequence": 3
"itemId": "100637113",
"originType": 2,
"ticketFormatId": 2,
"ticketCount": 4,
"ticketSequence": 5
API: Update Tickets
If a field that is not required contains an empty or null value, the ticket will be updated to that empty or null value.
API Basics
Endpoint URL |
{base URL}/update |
Method |
POST |
Success Response |
204 No Content |
Processing Type |
Synchronous |
Processing Type |
Synchronous |
Input |
Tickets |
Output |
N/A |
2,000 tickets |
Payload |
Type |
Req |
Definition |
ticketId |
Long(12) |
X |
originType |
Integer(2) |
X |
ticketCount |
Integer(3) |
X |
ticketSequence |
Integer(3) |
X |
printQuantity |
BigDecimal(12,4) |
X |
printDate |
Date |
X |
autoPrint |
Boolean |
Boolean |
String(3) |
BigDecimal(20,4) |
String(3) |
Example Input
"tickets": [
"ticketId": 8,
"originType": 2,
"ticketCount": 22,
"ticketSequence": 33
"ticketId": 9,
"originType": 1,
"ticketCount": 44,
"ticketSequence": 55
API: printTickets
Prints the requested tickets. This can print both current tickets and previously printed tickets.
It is assumed that the calling system will have verified or retrieved the ticket ids prior. The ticket ids and archived ticket ids will not be validated.
This service operation will simply print any tickets that are found that match identifiers passed in and ignore any identifiers for which tickets are not found.
Depending on printing configuration with the system, the printing may occur synchronous and real-time or the tickets may be staged and sent asynchronously to another system after a short delay.
API Basics
Endpoint URL |
{base URL}/print |
Method |
POST |
Success Response |
204 No Content |
Processing Type |
Synchronous/Asynchronous |
Input |
Ticket identifiers |
Output |
N/A |
100 total ticket ids |
Payload |
Type |
Req |
Definition |
printerId |
Long |
X |
The identifier of the printer to print the tickets on. |
refreshQuantity |
Boolean |
If true, the quantities of all the tickets will be refreshed prior to printing. If false, they will not. |
ticketIds |
List<Long> |
A list of ticket identifiers of the tickets to print. If this is null or empty, then archived ticket ids must contain a value. Not validated. |
archivedTicketIds |
List<Long> |
A list of archived ticket identifiers of tickets to print. If this is null or empty, then ticket ids must contain a value. Not validated. |
API: findTicketFormats
API Basics
Endpoint URL |
{base URL}/formats |
Method |
GET |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
Query parameters |
Output |
List of ticket formats |
Column |
Type |
Definition |
storeId |
Long(10) |
Include only ticket formats available at this store. |
Column |
Type |
Definition |
formatId |
Long(12) |
The unique format identifier. |
storeId |
Long(10) |
description |
String(100) |
A description of the ticket (possibly from ticket format). |
type |
Integer(4) |
The type of ticket format. (See Index) |
zplTemplateId |
Long(12) |
The unique identifier to the ZPL template to be used for printing. |
formatReference |
String(255) |
A reference to the format content to use for this format. |
defaultFormat |
Boolean |
True if this is the default form for the type, False otherwise. |
defaultPrinterId |
Long(6) |
Teh default printer identifier for the format. |
createDate |
Date |
The date the format was created. |
createUser |
String(128) |
The user that created the format. |
updateDate |
Date |
The date the format was last updated. |
updateUser |
String(128) |
The user that last updated the format. |
API: findTicketPrinters
API Basics
Endpoint URL |
{base URL}/printers |
Method |
GET |
Success Response |
200 OK |
Processing Type |
Synchronous |
Input |
Query parameters |
Output |
List of printers |
Query Params
Column |
Type |
Definition |
storeId |
Long(10) |
Include only ticket printers available at this store. |
Column |
Type |
Definition |
printerId |
Long(6) |
The unique identifier of the printer. |
storeId |
Long(10) |
The identifier of the store the printer is assigned to. |
printerType |
Integer(3) |
The print type of the printer (see Index). |
printerDescription |
String(200) |
A description of the printer. |
printerUri |
String(300) |
The URI address of the printer. |
printerName |
String(128) |
The logical name of the printer. |
defaultManifest |
Boolean |
True if the printer is the default printer at the store for manifest printing. |
defaultPreshipment |
Boolean |
True if the printer is the default printer at the store for preshipment printing. |
Additional Data Definitions
Ticket Format Type
ID |
Description |
1 |
Item Basket |
2 |
Shelf Label |
Price Type
ID |
Description |
1 |
Permanent |
2 |
Promotional |
3 |
Clearance |
4 |
Clearance Reset |
Printer Type
ID |
Description |
1 |
Item Ticket |
2 |
Shelf Label |
3 |
Postscript |
Ticket Origin Type
ID |
Description |
1 |
External |
2 |
Price Change |
3 |
Foundation |
4 |
Manual |
5 |
Promotional Price Change |
6 |
Clearance Price Change |
7 |
Permanent Price Change |
8 |
Reset Price Change |
REST Service: Transfer
Transfers define the movement of goods between internal entities or trading partners. Requests from corporate or other stores for shipping inventory out can be auto-approved without human interaction and it is possible to transfer unavailable inventory between entities with a store as a starting or ending point of the transaction. A transfer defines the logical movement of goods and are often created at corporate offices. They define the intent of what needs to be shipped. Some validations and features to consider include transfer zone restrictions may be enforced, shipping network restrictions may be enforced, auto receiving may be active, and non-inventory items may be transferred. A transfer request is a transfer that is initiated by the receiving location and is awaiting approval from the sending location. Once approved, it can be shipped. A transfer can be initiated by the sending location without any request or input from the receiving location. Once approved, it can be shipped. This service defines operations to manage transfer information by integration with an external system.
Find Transfer
This section describes the Find Transfer API. The Find Transfer API finds up to 10,000 summary header records of both transfers and transfer requests that match the search criteria.
Request
Table 4-395 Find Transfer — Request Parameters
NA |
Include only transfers with this external transfer identifier. |
sourceLocationId |
NA |
Include only transfers with this source location identifier. |
sourceLocationType |
NA |
Include only transfers with this source location type. Valid values are: 1 - Store 2 - Warehouse 3 - Finisher Available values : 1, 2, 3 |
destinationLocationId |
NA |
Include only transfers with this destination location identifier. |
destinationLocationType |
NA |
Include only transfers with this desintation location type. Valid values are: 1 - Store 2 - Warehouse 3 - Finisher Available values : 1, 2, 3 |
status |
NA |
Include only shipments with this delivery status. Valid values are: 1 - New Request 2 - Requeste 3 - Request In Progress 4 - Rejected Request 5 - Canceled Request 6 - Transfer In Progress 7 - Approved 8 - In Shipping 9 - Completed Transfer 10 - Canceled Transfer 99 - Active Available values : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 99 |
itemId |
NA |
string($text25) (query) |
Include only transfers that contain this item. |
updateDateFrom |
NA |
Include only transfers with an update date on or after this date. |
updateDateTo |
NA |
Include only transfers with an update date on or before this date. |
Responses
This section describes the responses of the Find Transfer API.
Response Code: 200
Example Value
"transferid": 11111,
"externalTransferId": "AX57684",
"sourceLocationType": 1,
"sourcelocationId": 4000,
"desintationLocationType": 1,
"destinationLocationId": 5000,
"status": 1,
"originType": 1,
"notAfterDate": "2024-09-19T09:10:14.140Z",
"createDate": "2024-09-19T09:10:14.140Z",
"updateDate": "2024-09-19T09:10:14.140Z",
"requestDate": "2024-09-19T09:10:14.140Z",
"approvalDate": "2024-09-19T09:10:14.140Z"
Schema — TransferSummaryIdo
Table 4-396 TransferSummaryIdo —Object
transferid |
NA |
integer($int15) example: 11111 |
The unique identifier of the transfer. |
NA |
string($text128) example: AX57684 |
An identifier supplied from an external system. |
NA |
The type of the source location of the transfer. Valid values are: 1 - Store 2 - Warehouse 3 - Finisher Enum: [ 1, 2, 3 ] |
sourcelocationId |
NA |
integer($int10) example: 4000 |
The identifier of the source location of the transfer. |
desintationLocationType |
NA |
The type of the destination location of the transfer. Valid values are: 1 - Store 2 - Warehouse 3 - Finisher Enum: [ 1, 2, 3 ] |
NA |
integer($int10) example: 5000 |
The identifier of the destination location of the transfer. |
status |
NA |
The current status of the transfer. Valid values are: 1 - New Request 2 - Request 3 - Request In Progress 4 - Rejected Request 5 - Canceled Request 6 - Transfer In Progress 7 - Approved 8 - In Shipping 9 - Completed Transfer 10 - Canceled Transfer Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 ] |
originType |
NA |
The origin type of the transfer. Valid values are: 1 - External 2 - Internal 3 - Adhoc Enum: [ 1, 2, 3 ] |
notAfterDate |
NA |
string($date-time) |
A date after which the transfer should not be shipped. |
createDate |
NA |
The date the transfer was created. |
updateDate |
NA |
The date the transfer was last updated. |
requestDate |
NA |
The date the transfer was requested. |
approvalDate |
NA |
The date the transfer was approved. |
Create Transfer
The Create Transfer API creates a new transfer from a source store that does not need involvement or approval from a receiving location. The transfer will be created as in progress and must be approved before shipping can begin.
Request
The request body is appliaction/json.
Details about the transfer to create.
Example Value
"sourceStoreId": 5000,
"destinationLocationType": 1,
"notAfterDate": "2025-01-10T12:45:31.430Z",
"authorizationCode": "1111",
"contextTypeId": 400000,
"contextValue": "Repair Needed",
"useUnavailableInventory": false,
"allowPartialDelivery": true,
"lineItems": [
"itemId": "10045600",
"quantity": 100,
"caseSize": 3
"notes": [
"Transfer needs to be rushed.",
"Items are in the back room."
}Schema — TransferCreateIdo
Table 4-397 TransferCreateIdo —Object
sourceStoreId |
Yes |
The identifier of the store that will be shipping the goods. |
Yes |
Yes |
notAfterDate |
NA |
authorizationCode |
NA |
string($text12) example: 1111 |
An authorization code assigned to the transfer. |
contextTypeId |
NA |
number($int18) example: 400000 |
Unique identifier of a context associated to the transfer. |
contextValue |
NA |
string($text25) example: Repair Needed |
A value or some information related to the context associated to the transfer. |
useUnavailableInventory |
NA |
boolean example: false |
True if the transfer is for unavailable inventory, false otherwise. |
allowPartialDelivery |
NA |
boolean example: true |
True indicates that a partial delivery is allowed for the transfer, false indicates it is not. |
lineItems |
Yes |
object |
A collection of up to 5,000 items to be added to the transfer. |
notes |
NA |
string($text2000) example: List [ "Transfer needs to be rushed.", "Items are in the back room." ] |
A collection of notes that will be added to the transfer notes. |
Table 4-398 TransferCreateLineItemIdo —Object
itemId |
Yes |
string($text25) example: 10045600 |
The unique identifier of the SKU item. |
quantity |
Yes |
number($decimal(20,4)) example: 100 |
The quantity that is requested. |
caseSize |
NA |
number($decimal(10,2)) example: 3 |
The case size of this record. |
Responses
This section describes the responses of the Create Transfer API.
Response Code: 200
Example Value
"transferId": 11111,
"sourceLocationId": 4000,
"status": 1,
"originType": 1,
"notAfterDate": "2025-01-08T12:56:00.798Z",
"createDate": "2025-01-08T12:56:00.798Z",
"updateDate": "2025-01-08T12:56:00.798Z",
"requestDate": "2025-01-08T12:56:00.798Z",
"approvalDate": "2025-01-08T12:56:00.798Z"
]Schema — TransferSummaryIdo
Table 4-399 TransferSummaryIdo —Object
transferid |
NA |
NA |
NA |
sourcelocationId |
NA |
NA |
NA |
status |
NA |
originType |
NA |
notAfterDate |
NA |
createDate |
NA |
updateDate |
NA |
requestDate |
NA |
approvalDate |
NA |
Read Transfer
The Read Transfer API retrieves all the details about a transfer or transfer request.
Request
Table 4-400 Read Transfer — Request Parameter
transferId |
Yes |
number($int12) (path) |
Responses
This section describes the responses of the Read Transfer API.
Response Code: 200
Example Value
"distroNumber": "440213",
"status": 1,
"originType": 1,
"contextTypeCode": "CNTXA",
"customerOrderNumber": "67008700",
"fulfillmentOrderNumber": "67008711",
"useAvailable": true,
"notAfterDate": "2025-01-08T13:34:27.151Z",
"createDate": "2025-01-08T13:34:27.151Z",
"createUser": "smith123",
"updateDate": "2025-01-08T13:34:27.151Z",
"updateUser": "smith123",
"requestDate": "2025-01-08T13:34:27.151Z",
"requestUser": "smith123",
"approvalDate": "2025-01-08T13:34:27.151Z",
"approvedUser": "smith123",
"importId": "smith123",
"lineItems": [
"lineId": 2222222,
"caseSize": 3,
"quantityRequested": 100,
"quantityApproved": 90,
"quantityShipping": 50,
"quantityShipped": 40,
"quantityReceived": 20,
"quantityDamaged": 20,
"preferredUom": "EA"
]Schema — TransferIdo
Table 4-401 TransferIdo — Object
transferid |
NA |
NA |
distroNumber |
NA |
string($text128) example: 440213 |
A distribution number( used for integration with other systems). It is another type of external identifier. |
NA |
sourcelocationId |
NA |
NA |
NA |
status |
NA |
The current status of the transfer. Valid values are: 1 - New Request 2 - Requeste 3 - Request In Progress 4 - Rejected Request 5 - Canceled Request 6 - Transfer In Progress 7 - Approved 8 - In Shipping 9 - Completed Transfer 10 - Canceled Transfer Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 ] |
originType |
NA |
contextTypeId |
NA |
contextTypeCode |
NA |
integer($int4) example: CNTXA |
An external code of a context associated to the transfer. |
contextValue |
NA |
customerOrderNumber |
NA |
string($text128) example: 67008700 |
External system identifier of a customer order. |
fulfillmentOrderNumber |
NA |
string($text128) example: 67008711 |
External system identifier of a fulfillment order. |
NA |
True indicates that parial delivery is allowed for the transfer, false indicates it is not. |
useAvailable |
NA |
True indicates the transfer must use available stock, false indicates it uses unavailable stock. |
authorizationCode |
NA |
notAfterDate |
NA |
createDate |
NA |
createUser |
NA |
string($text128) example: smith123 |
The user that created this transfer. |
updateDate |
NA |
updateUser |
NA |
The user that last updated this transfer. |
requestDate |
NA |
requestUser |
NA |
The user that requested this transfer. |
approvalDate |
NA |
approvedUser |
NA |
The user that approved this transfer. |
importId |
NA |
An identifier from an original data seed import. |
lineItems |
object |
Line items |
Table 4-402 TransferLineItemIdo — Object
lineId |
NA |
integer($int15) example: 2222222 |
The unique identifier of the line record. |
itemId |
NA |
caseSize |
NA |
quantityRequested |
NA |
The quantity that was requested. |
quantityApproved |
NA |
number($decimal(20,4)) example: 90 |
The quantity that was approved. |
quantityShipping |
NA |
number($decimal(20,4)) example: 50 |
The quantity that is currently in shipping. |
quantityShipped |
NA |
number($decimal(20,4)) example: 40 |
The quantity that has shipped. |
quantityReceived |
NA |
number($decimal(20,4)) example: 20 |
The quantity that was received into stock. |
quantityDamaged |
NA |
The quantity that was received as damaged. |
preferredUom |
NA |
string($text4) example: EA |
The preferred unit of measure of this line item. |
Update Transfer
The Update Transfer API updates a transfer request that has been requested or updates a newly created transfer that is prior to being approved. It allows the approved quantities to be updated until the transfer becomes approved.
Request
Table 4-403 Update Transfer — Request Parameter
transferId |
Yes |
Details about the transfer to update.
Example Value
"notAfterDate": "2025-01-10T12:58:44.635Z",
"lineItems": [
"quantity": 100,
"caseSize": 3
"notes": [
}Schema — TransferRequestUpdateIdo
Table 4-404 TransferRequestUpdateIdo— Object
sourceStoreId |
Yes |
destinationStoreId |
Yes |
contextTypeId |
NA |
contextValue |
NA |
NA |
notAfterDate |
NA |
lineItems |
Yes |
object |
Up to 5,000 Items to update on the transfer. |
Table 4-405 TransferRequestUpdatweLineItemIdo— Object
notes |
NA |
string($text2000)] example: List [ "Transfer needs to be rushed.", "Items are in the back room." ] |
Responses
This section describes the responses of the Update Transfer API.
Response Code: 200
Example Value
"status": 1,
"originType": 1,
"notAfterDate": "2025-01-08T13:54:30.666Z",
"createDate": "2025-01-08T13:54:30.666Z",
"updateDate": "2025-01-08T13:54:30.666Z",
"requestDate": "2025-01-08T13:54:30.666Z",
"approvalDate": "2025-01-08T13:54:30.666Z",
"lineItems": [
"lineId": 2222222,
"caseSize": 3,
Table 4-406 TransferIdo — Object
transferid |
NA |
externalTransferId |
NA |
distroNumber |
NA |
NA |
sourcelocationId |
NA |
NA |
NA |
status |
NA |
originType |
NA |
contextTypeId |
NA |
contextTypeCode |
NA |
contextValue |
NA |
NA |
NA |
NA |
useAvailable |
NA |
authorizationCode |
NA |
notAfterDate |
NA |
createDate |
NA |
createUser |
NA |
updateDate |
NA |
updateUser |
NA |
requestDate |
NA |
requestUser |
NA |
approvalDate |
NA |
approvedUser |
NA |
importId |
NA |
lineItems |
object |
Line items |
Table 4-407 TransferLineItemIdo — Object
lineId |
NA |
itemId |
NA |
caseSize |
NA |
quantityRequested |
NA |
quantityApproved |
NA |
quantityShipping |
NA |
quantityShipped |
NA |
quantityReceived |
NA |
quantityDamaged |
NA |
preferredUom |
NA |
Create Request
The Create Request API creates a new store-to-store transfer request. The transfer must be released in order to be available to the sending store to later approve or reject. EICS will be the originator of this transfer request, not the external system. To import transfers from an external system, see Import Transfer.
Request
Example Value
"sourceStoreId": 4000,
"destinationStoreId": 5000,
"notAfterDate": "2025-01-08T14:01:57.301Z",
"lineItems": [
"quantity": 100,
"caseSize": 3
"notes": [
}Schema — TransferRequestCreateIdo
Table 4-408 TransferRequestCreateIdo— Object
sourceStoreId |
Yes |
Yes |
contextTypeId |
NA |
contextValue |
NA |
NA |
notAfterDate |
NA |
lineItems |
Yes |
object |
A collection of up to 5,000 items that will be added to the transfer. |
notes |
NA |
Table 4-409 TransferRequestCreateLineItemIdo— Object
itemId |
Yes |
string($text25) example: 10045600q |
quantity |
Yes |
caseSize |
NA |
Responses
This section describes the responses of the Create Request API.
Response Code: 200
Schema — TransferStatusIdo
Table 4-410 TransferStatusIdo — Object
transferId |
NA |
NA |
status |
NA |
Update Request
The Update Request API updates requested quantities on a store-to-store request while it is still in new status, prior to being released to the shipping store.
Request
Table 4-411 Update Transfer — Request Parameter
transferId |
Yes |
Example Value
"notAfterDate": "2025-01-08T14:41:38.414Z",
"lineItems": [
"quantity": 100,
"caseSize": 3
"notes": [
Table 4-412 TransferRequestUpdateIdo— Object
sourceStoreId |
Yes |
Yes |
contextTypeId |
NA |
contextValue |
NA |
NA |
notAfterDate |
NA |
lineItems |
Yes |
object |
Table 4-413 TransferRequestUpdatweLineItemIdo— Object
notes |
NA |
Cancel Request
The Cancel Request API cancels a new request before it is released to the sending store for approval. This is done when the receiving location decides the transfer is not needed prior to finishing their request. The status must be new request in order to cancel.
Request
Table 4-414 Cancel Request — Request Parameter
transferId |
Yes |
number($int15) (path) |
Release Request
The Release Request API finalizes the request of the transfer at the receiving location and begins the approval process at the sending location.
Request
Table 4-415 Release Request — Request Parameter
transferId |
Yes |
Approve Request
The Approve Request API approves a transfer request created by a receiving store and released to the sending store. The transfer request must be in requested or request in progress status in order to approve.
Request
Table 4-416 Approve Request — Request Parameter
transferId |
Yes |
Reject Request
The Reject Request API rejects a transfer request from a receiving store closing out the transfer. This is done when the shipping store decides it will not fulfill it. The status must be requested or request in progress in order for it to be rejected.
Request
Table 4-417 Reject Request — Request Parameter
transferId |
Yes |
Approve Transfer
The Approve Transfer API approves a transfer created by the sending store moving it to the shipping stage. The status of the transfer must be transfer in progress in order to approve it.
Request
Table 4-418 Approve Transfer — Request Parameter
transferId |
Yes |
Cancel Transfer
The Cancel Transfer API cancels a transfer created by a sending store that has yet to be approved. The status must be transfer in progress in order to cancel the transfer.
Request
Table 4-419 Cancel Transfer — Request Parameter
transferId |
Yes |
Close Transfer
The Close Transfer API closes a transfer that has been approved. It can close a request that currently is in requested or request in progress status, but only if the shipping location is a store. It can close a transfer that is in shipping status so long as it does not have shipping quantities (this can happen if a previous partial shipment has already shipped).
Request
Table 4-420 Close Transfer — Request Parameter
transferId |
Yes |
Find Transfer Contexts
The Find Transfer Contexts API reads all the available contexts for a transfer.
Responses
This section describes the responses of the Find Transfer Contexts API.
Response Code: 200
Schema — TransferContextIdo
Table 4-421 TransferContextIdo — Object
| Element Name | Required | Data Type/Example | Description |
contextId |
NA |
number($int18) example: 1234 |
The unqiue identifier of the context record. |
code |
NA |
string($text6) example: CNTXIA |
A short code associated to the context. |
description |
NA |
string($text120) example: Repair |
A description of the context. |
sequence |
NA |
integer($int6) example: 2 |
The order it should be sequenced in. |
Import Transfer
The Import Transfer API imports a transfer (stock order) that is managed by an external system. This is an asynchronous process where minimal validation is performed on input and the message is staged in MPS for later processing. The message is managed by the MPS work queue (DcsTransfer). If Oracle Merchandising is enabled in the system, this service operation is not allowed.
Request
The request body is application/json.
Example Value
"deliveryDate": "2025-01-10T12:19:54.491Z",
"notAfterDate": "2025-01-10T12:19:54.491Z",
"useUnavailableInventory": true,
"lineItems": [
"quantity": 100,
}Schema — TransferImportIdo
Table 4-422 TransfeImportIdo — Object
Yes |
Yes |
sourceLocationId |
Yes |
Yes |
The type of the destination location of the transfer. Valid values are 1 - Store 2 - Warehouse 3 - Finisher Enum: [ 1, 2, 3 ] |
Yes |
contextTypeId |
NA |
contextValue |
NA |
deliveryDate |
NA |
string($date-time) . |
The date in which the transfer delivery should take place |
notAfterDate |
NA |
A date after which the transfer should not be shipped |
NA |
NA |
NA |
NA |
lineItems |
Yes |
object |
A collecton of up to 5,000 line items on the transfer. |
Table 4-423 TransfeImportLineItemIdo — Object
itemId |
Yes |
quantity |
Yes |
preferredUom |
NA |
Delete Transfer Import
The Delete Transfer Import API deletes a transfer request or trasnfer (stock order) if it has not yet become active.
Request
Table 4-424 Delete Transfer Import — Request Parameter
Yes |
The unique identifier of the transfer from the external system. |
REST Service: Transfer Delivery
A transfer delivery is the physical accounting of receiving goods from a store, warehouse, or external finisher. Deliveries consists of containers that hold items. Containers may be received blind, without knowing the expected quantities. The containers can also be for unavailable inventory. Transfer deliveries allow for receiving by Advance Shipment Notice (ASN), container, item level, or the entire delivery. Damages may be recorded during the receiving. This service defines operations to manage transfer delivery information by integration with an external system.
Find Delivery
This section describes the Find Delivery API. This API finds up to 10,000 delivery headers for the input criteria.
Request
Table 4-425 Find Delivery — Request Parameters
storeId |
NA |
number($int10) (query) |
Include only deliveries from this store. |
asn |
NA |
string($text128) (query) |
Include only deliveries with this ASN. |
status |
NA |
integer($int4) (query) |
Include only deliveries with this status. Valid values are 1 - New 2 - In Progress 3 - Received Available values : 1, 2, 3 |
updateDateFrom |
NA |
string($date-time) (query) |
Include only deliveries with an update date on or after this date. |
updateDateTo |
NA |
Include only deliveries with an update date on or before this date. |
Responses
This section describes the responses of the Find Delivery API.
Response Code: 200
Example Value
"deliveryId": 11111,
"storeId": 5000,
"sourceType": 1,
"sourceId": 5101,
"asn": "789012",
"status": 1,
"receiptNumber": "799003",
"carrierName": "Speedy, Inc.",
"expectedDate": "2025-01-10T13:35:33.734Z",
"receivedDate": "2025-01-10T13:35:33.734Z",
"createDate": "2025-01-10T13:35:33.734Z",
"updateDate": "2025-01-10T13:35:33.734Z"
Schema — TransferDeliveryHeaderIdo
Table 4-426 TransferDeliveryHeaderIdo —Object
deliveryId |
NA |
number($int15) example: 11111 |
The unique identifier of the transfer delivery. |
storeId |
NA |
number($int10) example: 5000 |
The identifier of the store receiving the inventory. |
sourceType |
integer($int4) example: 1 |
The type of location that is shipping the goods. Valid values are: 1 - Store 2 - Warehouse 3 - Finisher Enum: Array [ 3 ] |
sourceId |
NA |
number($int10) example: 5101 |
The identifier of the location shipping the goods. |
asn |
NA |
string($text128) example: 789012 |
The advanced shipping notification number. |
status |
NA |
The current status of the delivery. Valid values are: 1 - New 2 - In Progress 3 - Received Enum: [ 1, 2, 3 ] |
receiptNumber |
NA |
string($text128) example: 799003 |
The receipt number of the delivery. |
carrierName |
NA |
string($text128) example: Speedy, Inc. |
The name of the carrier of the delivery. |
expectedDate |
NA |
The date the delivery is epxected to be received. |
receivedDate |
NA |
The date the delivery was received. |
createDate |
NA |
The date the delivery was created. |
updateDate |
NA |
The date the delivery was last updated. |
Create Delivery
Creates a new transfer delivery as if SIOCS was the originator of the delivery. For integration of ASN deliveries originating from an external system, please see import delivery operation.
Request
There are no request parameters.
The delivery details of the new delivery.
Example Value
"storeId": 5000,
"sourceType": 1,
"sourceId": 5101,
"asn": "789012",
"billOfLadingId": "BOL884455",
"carrierType": 1,
"carrierCode": "SPI",
"sourceAddress": "Solid Supplies",
"licensePlate": "ABX100",
"freightId": "666234522",
"expectedDate": "2025-01-10T14:25:34.133Z",
"cartons": [
"externalCartonId": "GH124000",
"referenceId": "3461353",
"damagedReason": "Vehicle Accident",
"serialCode": 3333600,
"trackingNumber": "346139384726043",
"damagedRemaining": true,
"receiveAtShopFloor": false,
"qualityControl": true,
"lineItems": [
"itemId": "11111",
"documentId": 222222,
"documentType": 1,
"documentDate": "2025-01-10T14:25:34.133Z",
"customerOrderNumber": "1444923",
"fulfillmentOrderNumber": "11123412",
"caseSize": 1,
"quantityExpected": 20,
"uins": [
"uin": "11123412",
"shipped": true,
"received": true,
"damaged": true
}Schema — TransferDeliveryCreateIdo
Table 4-427 TransferDeliveryCreateIdo —Object
storeId |
Yes |
sourceType |
Yes |
The type of location that is shipping the goods. Valid values are |
1 - Store |
2 - Warehouse |
3 - Finisher |
Enum: [ 1, 2, 3 ] |
sourceId |
Yes |
asn |
Yes |
billOfLadingId |
NA |
string($text128) example: BOL884455 |
A bill of lading identifier from an external system. |
carrierType |
NA |
The carrier type of the carrier. Valid values are: 1 - Corporate 2 - Third Party Enum: [ 1, 2 ] |
carrierName |
NA |
carrierCode |
NA |
string($text4) example: SPI |
A unique code that identifies the carrier. |
sourceAddress |
NA |
string($text1000) example: Solid Supplies |
The address of the source location that shipped the inventory. |
licensePlate |
NA |
string($text128) example: ABX100 |
A license plate number of the delivery vehicle. |
freightId |
NA |
string($text128) example: 666234522 |
A freight identifier associated to the delivery. |
expectedDate |
NA |
string($date-time) The date the delivery is epxected to be received. |
cartons |
Yes |
object |
A collection of up to 500 cartons on the delivery. |
Table 4-428 TransferDeliveryCreateCartonIdo —Object
externalCartonId |
NA |
string($text128) example: GH124000 |
A carton identifier from an external system. |
referenceId |
NA |
string($text128) example: 3461353 |
A reference identifier (another way to identify the carton). |
damagedReason |
NA |
string($text128) example: Vehicle Accident |
A reason for the container damage. |
serialCode |
NA |
number($int15) example: 3333600 |
A serial code associated to the container. |
trackingNumber |
NA |
string($text128) example: 346139384726043 |
A tracking number associated to the container. |
damagedRemaining |
NA |
True indicates all remaining unreceived quantities should be marked as damaged on the final receipt. |
receiveAtShopFloor |
NA |
True indicates the container is to be received on the shopfloor, false indicates it should not. |
qualityControl |
NA |
True indicates the container requires quality control, false indicates it does not. |
lineItems |
Yes |
object |
A collection of up to 2,000 items on the container. |
Table 4-429 TransferDeliveryCreateLineItemIdo —Object
itemId |
Yes |
string($text25) example: 11111 |
The unique identifier of the item. |
documentId |
Yes |
number($int15) example: 222222 |
The unique identifier of the transfer or allocation document. |
documentType |
Yes |
The type of the document. Valid values are: 1 - Transfer 2 - Allocation Enum: [ 1, 2 ] |
documentDate |
Yes |
The date the document was created. |
NA |
string($text128) example: 1444923 |
The customer order identifier if a customer order is associated to the item. |
NA |
string($text128) example: 11123412 |
The fulfillment order identifier if a customer order is associated to the item. |
useAvailable |
NA |
True indicates to use available inventory, false indicuates to use unavailable inventory. |
caseSize |
NA |
number($decimal(10,2)) example: 1 |
The case size of the item for this record. |
quantityExpected |
NA |
The quantity expected to be received. |
quantityReceived |
NA |
The quantity received as good. |
quantityDamaged |
NA |
The quantity received as damaged. |
uins |
NA |
object |
A collection of UINs on the line item. |
Table 4-430 TransferDeliveryUinIdo —Object
uin |
Yes |
The unique identification number. |
shipped |
NA |
True, if the UIN is shipped, false otherwise. |
received |
NA |
True, if the UIN is received, false otherwise. |
damaged |
NA |
True if the UIN is received as damaged, false otherwise. |
Responses
This section describes the responses of the Create Delivery API.
Response Code: 200
The request has been successful.
The media type is application/json.
Schema — TransferDeliveryStatusIdo
Table 4-431 TransferDeliveryStatusIdo —Object
deliveryId |
NA |
status |
NA |
Read Delivery
The Read Delivery API retrieves all the details about an transfer delivery.
Request
Table 4-432 Read Delivery — Request Parameter
deliveryId |
Yes |
Responses
This section describes the responses of the Read Delivery API.
Response Code: 200
Example Value
"storeId": 5000,
"sourceType": 1,
"sourceId": 5101,
"status": 1,
"asn": "789012",
"carrierType": 1,
"fiscalDocumentRequestId": 100234,
"fiscalDocumentReferenceId": 63452277,
"fiscalDocumentNumber": "84478274",
"expectedDate": "2025-01-10T14:36:21.974Z",
"receivedDate": "2025-01-10T14:36:21.974Z",
"receivedUser": "smith123",
"createDate": "2025-01-10T14:36:21.974Z",
"updateDate": "2025-01-10T14:36:21.974Z",
"importId": "3461353",
"cartons": [
"cartonId": 11111,
"misdirectedId": 3461353,
"discrepant": true,
"externalCreate": true,
"adjusted": false,
"copied": true,
"status": 1,
"customerOrderRelated": 1,
"lineItems": [
"lineId": 11111,
"itemId": "11111",
"documentType": 1,
"documentDate": "2025-01-10T14:36:21.974Z",
"caseSize": 1,
"quantityPreviousReceived": 20,
"quantityPreviousDamaged": 20,
"uins": [
"uin": "11123412",
"itemUinId": 8475,
"shipped": true,
"received": true,
"damaged": true
}Schema — TransferDeliveryIdo
Table 4-433 TransferDeliveryIdo — Object
deliveryId |
NA |
storeId |
NA |
sourceType |
NA |
The type of location that is shipping the goods. Valid values are 1 - Store 2 - Warehouse 3 - Finisher Enum: [ 1, 2, 3 ] |
sourceId |
NA |
status |
NA |
The current status of the delivery. Valid values are 1 - New 2 - In Progress 3 - Received Enum: [ 1, 2, 3 ] |
asn |
NA |
receiptNumber |
NA |
carrierName |
NA |
carrierType |
NA |
The carrier type of the carrier. Valid values are 1 - Corporate 2 - Third Party Enum: [ 1, 2, 3 ] |
carrierCode |
NA |
sourceAddress |
NA |
licensePlate |
NA |
freightId |
NA |
A freight identifier associated to the shipment. |
fiscalDocumentRequestId |
NA |
number($int20) example: 100234 |
The identifier of the request for a fiscal document. |
fiscalDocumentReferenceId |
NA |
number($int20) example: 63452277 |
The unique identifier of the fiscal document record. |
fiscalDocumentNumber |
NA |
string($text255) example: 84478274 |
The fiscal document number. |
billOfLadingId |
NA |
An external bill of lading identifier. |
expectedDate |
NA |
The date the delivery is expected to be received. |
receivedDate |
NA |
receivedUser |
NA |
The user that received the delivery. |
createDate |
NA |
createUser |
NA |
The user that created the delivery. |
updateDate |
NA |
updateUser |
NA |
The user that last updated the delivery. |
importId |
NA |
An original import identifier if the data was imported through data-seeding. |
cartons |
NA |
object |
A collection of cartons on the delivery. |
Table 4-434 TransferDeliveryCartonIdo — Object
cartonId |
NA |
The unique identifier of the transfer delivery carton. |
externalCartonId |
NA |
referenceId |
NA |
A reference identifier (another way to identify the carton) |
misdirectedId |
NA |
number($int15) example: 3461353 |
A misdirected container identifier (if this is copy of a another container). |
discrepant |
NA |
True indicates the container is discrepant, false indicates it is not. |
NA |
externalCreate |
NA |
True indicates the container was externally created, false indicates it was created internally. |
adjusted |
NA |
True indicates the container has been adjusted, false indicates it has not. |
qualityControl |
NA |
copied |
NA |
True indicates the container has been copied as a misdirected container, false means it has not. |
damagedRemaining |
NA |
damagedReason |
NA |
serialCode |
NA |
trackingNumber |
NA |
status |
NA |
The status of the container. Value values are 1 - New 2 - In Progress 3 - Damaged 4 - Received 5 - Missing Enum: [ 1, 2, 3, 4, 5 ] |
customerOrderRelated |
NA |
Indicates if the carton is related to a customer order. Valid values are 1 - Yes 2 - Mix 3 - No Enum: [ 1, 2, 3 ] |
createUser |
NA |
The user that created the container. |
updateDate |
NA |
The date the container was last updated. |
updateUser |
NA |
The user that last updated the container. |
receivedDate |
NA |
The date the container was received. |
receivedUser |
NA |
lineItems |
NA |
object |
A collection of items in the container. |
Table 4-435 TransferDeliveryLindeItemIdo — Object
lineId |
NA |
The unique identifier of the line item record. |
itemId |
NA |
documentId |
NA |
documentType |
NA |
The type of the document. Value values are 1 - Transfer 2 - Allocation Enum: [ 1, 2 ] |
documentDate |
NA |
NA |
A customer order identifier if a customer order is associated to the delivery. |
NA |
The fulfillment order identifier if a customer order is associated to the delivery. |
useAvailable |
NA |
True indicates to use available inventory, false indicates to use unavailable inventory. |
caseSize |
NA |
quantityExpected |
NA |
quantityReceived |
NA |
quantityDamaged |
NA |
quantityPreviousReceived |
NA |
The quantity last received as good. |
quantityPreviousDamaged |
NA |
The quantity last received as damaged. |
uins |
NA |
object |
A collections of UINs on the line item. |
Table 4-436 TransferDeliveryLindeItemUinIdo — Object
uin |
NA |
itemUinId |
NA |
number($int14) example: 8475 |
The unique identifier of the item UIN record. |
shipped |
NA |
True if the UIN is shipped, false otherwise. |
received |
NA |
True if the UIN is received, false otherwise. |
damaged |
NA |
Update Delivery
The Update Delivery API update the header portion of a delivery.
Request
Table 4-437 Update Delivery — Request Parameter
deliveryId |
Yes |
Delivery header details to update.
Example Value
"carrierType": 1,
"expectedDate": "2025-01-10T15:43:51.438Z"
}Schema — TransferDeliveryUpdateIdo
Table 4-438 TransferDeliveryUpdateIdo— Object
billOfLadingId |
NA |
carrierType |
NA |
The carrier type of the carrier. Valid values are 1 - Corporate 2 - Third Party Enum: [ 1, 2 ] |
carrierName |
NA |
carrierCode |
NA |
sourceAddress |
NA |
licensePlate |
NA |
freightId |
NA |
expectedDate |
NA |
Receive Delivery
The Receive Delivery API receives the transfer delivery. The quantities will be updated to the expected quantity value (if no quantity has been recorded previously, including recording 0 previously) and the delivery will be set to in progress stats. To finalize the delivery, use the confirm operation.
Request
Table 4-439 Receive Delivery — Request Parameter
deliveryId |
Yes |
Confirm Delivery
The Confirm Delivery API confirms the delivery finalizing the movement of inventory and closing the delivery.
Request
Table 4-440 Confirm Delivery — Request Parameter
deliveryId |
Yes |
Open Delivery
The Open Delivery API opens the delivery for additional receiving but leaves all the cartons in their current state.
Request
Table 4-441 Open Delivery — Request Parameter
deliveryId |
Yes |
Create Carton
The Create Carton Delivery API adds a new container to a new or in progress shipment.
Request
Table 4-442 Create Carton — Request Parameter
deliveryId |
Yes |
The unique identifier of the delivery. |
Details about the carton to add to the shipment.
Example Value
"lineItems": [
"itemId": "11111",
"documentType": 1,
"documentDate": "2025-01-13T12:33:47.167Z",
"caseSize": 1,
"uins": [
"uin": "11123412",
"shipped": true,
"received": true,
"damaged": true
}Schema — TransferDeliveryCreateCartonIdo
Table 4-443 TransferDeliveryCreateCartonIdo— Object
externalCartonId |
NA |
referenceId |
NA |
damagedReason |
NA |
serialCode |
NA |
trackingNumber |
NA |
damagedRemaining |
NA |
NA |
qualityControl |
NA |
lineItems |
Yes |
object |
Table 4-444 TransferDeliveryCreateLineItemIdo —Object
itemId |
Yes |
documentId |
Yes |
documentType |
Yes |
documentDate |
Yes |
NA |
NA |
useAvailable |
NA |
caseSize |
NA |
quantityExpected |
NA |
quantityReceived |
NA |
quantityDamaged |
NA |
uins |
NA |
object |
Table 4-445 TransferDeliveryUinIdo —Object
uin |
Yes |
shipped |
NA |
received |
NA |
damaged |
NA |
Responses
This section describes the responses of the Create Carton API.
Response Code: 200
Example Value
"cartonId": 24680,
"status": 1
]Schema — TransferDeliveryCartonStatusIdo
Table 4-446 TransferDeliveryICartonStatusdo — Object
deliveryId |
NA |
cartonId |
NA |
number($int15) example: 24680 |
externalCartonId |
NA |
status |
NA |
The status of the container. Valid values are 1 - New 2 - In Progress 3 - Damaged 4 - Received 5 - Missing Enum: [ 1, 2, 3, 4, 5 ] |
Update Carton
The Update Carton API Updates a previously existing carton that is in a new or in progress state, on a delivery that is also new or in progress.
Request
Table 4-447 Update Carton — Request Parameter
cartonId |
Yes |
The unique identifier of the delivery carton. |
Details about the carton update.
Example Value
"lineItems": [
"itemId": "11111",
"documentType": 1,
"documentDate": "2025-01-13T13:33:02.273Z",
"caseSize": 1,
"uins": [
"uin": "11123412",
"shipped": true,
"received": true,
"damaged": true
Schema — TransferDeliveryCartonUpdateIdo
Table 4-448 TransferDeliveryCartonUpdateIdo — Object
externalCartonId |
NA |
referenceId |
NA |
NA |
qualityControl |
NA |
damagedRemaining |
NA |
damagedReason |
NA |
serialCode |
NA |
trackingNumber |
NA |
lineItems |
NA |
object |
A collection of up to 2,000 items in the container. |
Table 4-449 TransferDeliveryCartonUpdateItemIdo — Object
itemId |
Yes |
documentId |
Yes |
documentType |
Yes |
The type of the document. Valid values are 1 - Transfer 2 - Allocation Enum: [1, 2] |
documentDate* |
Yes |
caseSize |
NA |
quantityReceived |
NA |
quantityDamaged |
NA |
uins |
NA |
object |
Table 4-450 TransferDeliveryUinIdo — Object
uin |
Yes |
shipped |
NA |
received |
NA |
damaged |
NA |
Receive Carton
The Receive Carton API receives the container. The quantities will be updated to the expected quantity value (if no quantity has been previously entered, including 0) and the container will be moved to in progress. Use the confirm operation to finalize the carton.
Request
Table 4-451 Receive Carton — Request Parameter
cartonId |
Yes |
Confirm Carton
The Confirm Carton API confirms the container finalizing its status as received or damaged.
Request
Table 4-452 Confirm Carton — Request Parameter
cartonId |
Yes |
Cancel Carton
The Cancel Carton API cancels the container indicating it will not be received as part of the delivery.
Request
Table 4-453 Cancel Carton — Request Parameter
cartonId |
Yes |
Open Carton
The Open Carton API re-opens a confirmed container, placing it back into in progress state in order to adjust and confirm again.
Request
Table 4-454 Open Carton — Request Parameter
cartonId |
Yes |
Import ASN Delivery
The Import ASN Delivery API imports a transfer delivery (ASN) managed by an external system that is notifying SIOCS of an ASN creation or modification that took place. This request is staged and processed asynchronously, and is controlled by the MPS message type DcsAsn.
Request
Details about the delivery to import.
Example Value
"asn": "789012",
"storeId": 5000,
"sourceType": 1,
"sourceId": 5101,
"carrierType": 1,
"expectedDate": "2025-01-13T14:21:38.692Z",
"cartons": [
"lineItems": [
"itemId": "11111",
"documentType": 1,
"documentDate": "2025-01-13T14:21:38.692Z",
"caseSize": 1,
"quantity": 20
}Schema — TransferDeliveryImportIdo
Table 4-455 TransferDeliveryImportIdo— Object
asn |
Yes |
storeId |
Yes |
sourceType |
Yes |
sourceId |
Yes |
carrierType |
NA |
carrierName |
NA |
carrierCode |
NA |
sourceAddress |
NA |
licensePlate |
NA |
freightId |
NA |
NA |
The fiscal document number of an associated fiscal document. |
billOfLadingId |
NA |
expectedDate |
NA |
string($date-time) The date the delivery is expected to be received. |
cartons |
Yes |
object |
Table 4-456 TransferDeliveryImporCartontIdo— Object
externalCartonId |
Yes |
referenceId |
NA |
serialCode |
NA |
trackingNumber |
NA |
qualityControl |
NA |
Boolean example: true |
lineItems |
Yes |
object |
Table 4-457 TransferDeliveryImportItemtIdo— Object
itemId |
Yes |
documentId |
Yes |
documentType |
Yes |
The type of the document. Valid values are 1 - Transfer 2 - Allocation Enum: [ 1, 2 ] |
documentDate |
Yes |
useAvailable |
NA |
caseSize |
NA |
Quantity |
Yes |
Import ASN Delete Delivery
A transfer delivery in new status can be deleted from the system. A transfer delivery that has progressed past the point cannot. This request is staged and processed asynchronously, and is controlled by the MPS message type DcsAsn.
Request
Details about the delivery to delete.
Schema — TransferDeliveryDeleteImportIdo
Table 4-458 TransferDeliveryDeleteImportIdo— Object
asn |
Yes |
storeId |
Yes |
REST Service: Transfer Shipment
This service allows the creation, modification, and cancellation of transfer shipments from an external application.
Service Base URL
The Cloud service base URL follows the format:
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/tsfshipments
API Definitions
API |
Definition |
readShipment |
Reads the transfer shipment. This does not include containers or items. |
findShipments |
Finds transfer shipment header information based on a set of criteria. |
submitShipment |
Submits the transfer shipment. |
cancelSubmitShipment |
Cancels the submission of a transfer shipment. |
dispatchShipment |
Dispatches a transfer shipment. |
cancelShipment |
Cancels a transfer shipment. |
confirmCarton |
Confirms a container for shipment. |
cancelCarton |
Cancels a container, removing it from the shipment. |
openCarton |
Opens a confirmed container so that it can be modified again. |
createShipment |
Creates a shipment. |
updateShipment |
Updates shipment header information. |
createCarton |
Adds a carton to the shipment. |
updateCarton |
Updates a carton on the shipment. |
API: Read Shipment
Read a transfer shipment.
Table 4-459 API Basics
Endpoint URL |
/{shipmentId} |
Method |
GET |
Successful Response |
200 OK |
Processing Type |
Synchronous |
Input |
None |
Output |
Transfer Shipment |
Table 4-460 Path Parameter Definitions
Parameter |
Definition |
shipmentId |
The internal identifier of the transfer shipment header. |
Table 4-461 Output Data Definition
Column |
Type |
Definition |
shipmentId |
Long(15) |
The unique internal identifier of the transfer shipment. |
storeId |
Long(10) |
The unique store identifier that is the source of the shipment. |
destinationType |
Integer(2) |
The location type of the destination. See Additional Data Definitions-Destination Type. |
destinationId |
Long(10) |
The unique identifier of the destination. |
asn |
String(128) |
The advance shipment notification number. |
status |
Integer(2) |
The current status of the shipment. See Additional Data Definitions: Status |
authorizationCode |
String(12) |
An authorization code associated to the shipment. |
billOfLadingId |
Long(12) |
The unique identifier of the bill of lading. |
adhocDocumentId |
Long(15) |
An adhoc transfer document identifier associated to the shipment. |
billOfLadingId |
Long(15) |
The bill of lading number. |
alternateAddress |
String(2000) |
An alternate destination address. |
carrierRole |
Integer(2) |
The type of carrier for the shipment. See Additional Data Definitions |
carrierId |
Long(10) |
A unique identifier of a carrier for the shipment. |
carrierServiceId |
Long(10) |
A unique identifier of a carrier service for the shipment. |
alternateCarrierName |
String(240) |
The name of a third-party shipping company. |
alternateCarrierAddress |
String(2000) |
The address of a third-party shipping company. |
motive |
String(120) |
A motive for the shipment. |
taxId |
String(18) |
The tax identifier of the supplier it is being shipped to. |
trackingNumber |
String(128) |
A tracking number associated to the shipment. |
dimensionId |
Long(12) |
The identifier of a dimension associated to the shipment. |
weight |
BigDecimal(12,4) |
The weight of the shipment. |
weightUom |
String(4) |
The unit of measure of the weight of the shipment. |
requestedPickupDate |
Date |
The requested pickup date. |
Long(20) |
Long(20) |
The unique identifier of the fiscal document. |
String(255) |
fiscalDocumentStatus |
Integer(4) |
The status of the fiscal document. |
fiscalDocumentRejectReason |
String(255) |
A reason the fiscal document was rejected. |
fiscalDocumentUrl |
String(255) |
A URL to the fiscal document. |
createUser |
String(128) |
The user that created the shipment record. |
createDate |
Date |
The date the shipment record was created. |
updateUser |
String(128) |
The user that last updated the shipment. |
updateDate |
Date |
The last date the shipment was updated. |
submitUser |
String(128) |
The user that submitted the shipment record. |
submitDate |
Date |
The date the shipment was submitted within EICS. |
dispatchUser |
String(128) |
The user that dispatched the shipment. |
dispatchDate |
Date |
The date the shipment was dispatched within EICS. |
cartons |
Collection |
A collection of cartons on the shipment. |
Table 4-462 Output Data Definition (Cartons)
Column |
Type |
Definition |
cartonId |
Long(10) |
The unique identifier of the record. |
externalCartonId |
String(128) |
A container identifier from an external system. |
status |
Integer(4) |
The current status of the container. |
dimensionId |
Long(10) |
The shipment container dimension identifier. |
weight |
BigDecimal(12,4) |
The weight of the container. |
weightUom |
String(4) |
The unit of measure of the weight of the container. |
trackingNumber |
String(128) |
A tracking number for the container. |
useAvailableInventory |
Boolean |
True indicates use only available inventory, False indicates use non-available inventory. |
restrictionLevel |
Integer(4) |
A hierarchy restriction level for items in the container. |
Integer(4) |
The customer order related value (see Additional Data Definitions). |
createUser |
String(128) |
The user that created the container in EICS. |
createDate |
Date |
The date the container was created in EICS. |
updateUser |
String(128) |
The user that last updated the container in EICS. |
updateDate |
date |
The date the container was last updated in EICS. |
approvalUser |
String(128) |
The user that approved the container in EICS. |
approvalDate |
Date |
The date the container was approved in EICS. |
lineItems |
Collection |
The line items in the container. |
Table 4-463 Output Data Definition (Line Item)
Column |
Type |
Definition |
lineId |
Long(15) |
itemId |
String(25) |
caseSize |
BigDecimal(10,2) |
The case size of this line item. |
quantity |
BigDecimal(20,4) |
The quantity being shipped. |
transferId |
Long(12) |
The unique identifier of the associated transfer. |
Long(15) |
The external system identifier of the associated transfer. |
String(128) |
The customer order number if line item is for a customer order. |
String(128) |
The fulfillment order number if line item is for a customer order. |
preferredUom |
String(4) |
The preferred unit of measure for the shipment quantity. |
shipmentReasonId |
Long(15) |
A unique identifier of a shipment reason associated to this item. |
uins |
List<String> |
A list of UINs that are shipped. The number of UINs must match the quantity attribute. |
Example
Figure 4-15 Example
Figure 4-16 Example, continued
API: Find Transfer Shipment
Search for shipments based on a set of criteria.
If more than 10,000 shipments are found a "Results Too Large" response is returned and search criteria will need to be more restrictive.
Table 4-464 API Basics
Endpoint URL |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Input |
Query Parameters |
Output |
List of Transfer Shipments Headers |
Table 4-465 Query Parameter Definitions
Attribute |
Type |
Definition |
storeId |
Long(10) |
Include only transfer shipments from this store. |
destinationType |
Integer(2) |
Include only transfer shipments to this destination type. |
destinationId |
Long(10) |
Include only transfer shipments to this destination identifier. |
asn |
String(128) |
Include only transfer shipments with this ASN. |
status |
Integer(2) |
Include only transfer shipments in this status. |
updateDateFrom |
String |
Include only transfer shipments last updated on or after this date. |
updateDateTo |
String |
Include only transfer shipments last updated on or before this date. |
Table 4-466 Output Data Definition
Column |
Type |
Definition |
shipmentId |
Long(15) |
storeId |
Long(10) |
destinationType |
Integer(2) |
The location type of the destination. See Additional Data Definitions: Destination Type. |
destinationId |
Long(10) |
The unique identifier of the destination location. |
asn |
String(128) |
status |
Integer(4) |
createDate |
Date |
updateDate |
Date |
submitDate |
Date |
dispatchDate |
Date |
API: Submit Shipment
Submits the transfer shipment moving it to a noneditable state while it is waiting to be dispatched.
Table 4-467 API Basics
Endpoint URL |
/{shipmentId}/submit |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Input |
None |
Output |
None |
Table 4-468 Path Parameter Definitions
Parameter |
Definition |
shipmentId |
API: Cancel Submit Shipment
Cancels the submissions of the transfer shipment return it to an in progress and editable state.
Table 4-469 API Basics
Endpoint URL |
/{shipmentId}/cancelsubmit |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Input |
None |
Output |
None |
Table 4-470 Path Parameter Definitions
Parameter |
Definition |
shipmentId |
API: Dispatch Shipment
Dispatches the transfer shipment updating all the inventory positions and closing the shipment.
Table 4-471 API Basics
Endpoint URL |
/{shipmentId}/dispatch |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Input |
None |
Output |
None |
Table 4-472 Path Parameter Definitions
Parameter |
Definition |
shipmentId |
API: Cancel Shipment
Cancels the transfer shipment reversing any reserved inventory currently picked.
Table 4-473 API Basics
Endpoint URL |
/{shipmentId}/cancel |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Input |
None |
Output |
None |
Table 4-474 Path Parameter Definitions
Parameter |
Definition |
shipmentId |
API: Confirm Carton
Confirms a transfer shipment container, completing the container and making it non-editable and awaiting dispatch.
Table 4-475 API Basics
Endpoint URL |
cartons/{cartonId}/confirm |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Input |
None |
Output |
None |
Table 4-476 Path Parameter Definitions
Parameter |
Definition |
cartonId |
The internal identifier of the transfer shipment carton. |
API: Cancel Carton
Cancels a transfer shipment container.
Table 4-477 API Basics
Endpoint URL |
cartons/{cartonId}/cancel |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Input |
None |
Output |
None |
Table 4-478 Path Parameter Definitions
Parameter |
Definition |
cartonId |
API: Open Carton
Opens a transfer shipment container.
Table 4-479 API Basics
Endpoint URL |
cartons/{cartonId}/open |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Input |
None |
Output |
None |
Table 4-480 Path Parameter Definitions
Parameter |
Definition |
cartonId |
API: createShipment
This API is used to create a new transfer shipment whose status is "In Progress."
Container item/reason combination cannot be duplicated within the container.Table 4-481 API Basics
Endpoint URL |
{base URL} |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Input |
Transfer Shipment |
Output |
Transfer Shipment Status |
Maximum Input Limit |
1,000 overall line items on shipment |
Table 4-482 Input Data Definition
Attribute |
Type |
Req |
Definition |
storeId |
Long(10 |
X |
The identifier of the store shipping the goods. |
destinationType |
Integer(2) |
X |
The location type of the destination (see Index). |
destinationId |
Long(10) |
X |
The location identifier of the destination |
asn |
String(15) |
The advance shipping number from an external system. |
authorizationCode |
String(12) |
A vendor authorization code. It may be required for some suppliers. |
displayCartons |
Boolean |
True if cartons should be displayed, otherwise false. |
addressType |
Integer |
The type of return address. See Index. |
carrierRole |
Integer(2) |
X |
The type of carrier for the shipment. See Index |
carrierId |
Long(10) |
carrierServiceId |
Long(10) |
alternateAddress |
String(2000) |
String(240) |
String(2000) |
motiveId |
Long(18) |
The unique identifier of a bill of lading motive. |
taxId |
taxId |
trackingNumber |
String(128) |
dimensionId |
Long(12) |
weight |
BigDecimal(12,4) |
weightUom |
String(4) |
Date |
cartons |
Collection |
X |
A group of cartons to create along with the shipment. |
notes |
Collections of Strings |
A collection of up to 100 notes. |
Table 4-483 Shipment Carton Data Definition
Payload |
Type |
Req |
Definition |
externalCartonId |
String(128) |
trackingNumber |
String(128) |
The tracking number of the container. |
restrictionLevel |
Integer(4) |
cartonSizeId |
Long(10) |
weight |
Long(12,4) |
weightUom |
String(4) |
Boolean |
True indicates available inventory will be used, false indicates unavailable inventory should be used. |
lineItems |
Collection |
X |
A collection of line items to create along with the carton. |
Table 4-484 Shipment Lien Item Data Definition
Payload |
Type |
Req |
Definition |
itemId |
String(25) |
X |
transferId |
Long(12) |
X |
The unique identifier of a transfer this item is being shipped for. |
reasonId |
Long(15) |
The unique identifier of the shipment reason associated to this line item. It is not allowed for available inventory and required for unavailable inventory. |
quantity |
BigDecimal(12,4) |
X |
The quantity to ship. |
caseSize |
BigDecimal(10,2) |
The case size of the item for this particular shipment. |
uins |
Collecton<String> |
A collection of UINs to ship. This number of UINs must match the quantity. |
Table 4-485 Output Data Definition
Attribute |
Type |
Definition |
shipmentId |
Long(15) |
The unique identifier of the shipment. |
storeId |
Long(10) |
The store identifier of the store shipping the goods. |
asn |
String(15) |
The Advancing Shipping Number. |
status |
Integer(2) |
The shipment status. See Index. |
Figure 4-17 Example Code
API: updateShipment
This API is used to update to the header portion of a shipment as well as its bill of lading information.
The shipment header cannot be updated while containers/cartons are currently confirmed for shipping.
Table 4-486 API Basics
Endpoint URL |
{base URL}/{shipmentId} |
Method |
POST |
204 No Content |
Processing Type |
Synchronous |
Path Parameter |
The identifier of the transfer shipment |
Input |
Transfer Shipment |
Table 4-487 Input Data Definition
Column |
Type |
Definition |
authorizationCode |
String(12) |
displayCartons |
Boolean |
addressType |
Integer(2) |
carrierRole |
Integer(2) |
The type of carrier for the shipment. See Index. |
carrierId |
Long(10) |
carrierServiceId |
Long(10) |
alternateAddress |
String(2000) |
String(240) |
String(2000) |
The address of a third-party shipping company |
motiveId |
Long(18) |
taxId |
String(18) |
trackingNumber |
String(128) |
dimensionId |
Long(12) |
weight |
BigDecimal(12,4) |
weightUom |
String(4) |
Date |
notes |
Collection(String) |
A collection of up to 100 notes to add to the notes associated to the shipment. |
Figure 4-18 Code Example
API: createCarton
This API is used to add a new carton/container to a "New" or "In Progress" shipment.
Table 4-488 API Basics
Endpoint URL |
{base URL}/{shipmentId}/cartons |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Path Parameter |
Input |
Transfer Shipment Carton |
Output |
Transfer Shipment Carton Status |
1,000 overall line items on carton |
Table 4-489 Input Data Definition
Column |
Type |
Req |
Definition |
externalCartonId |
String(128) |
A carton identifier or barcode label from an external system. |
cartonSizeId |
Long(10) |
weight |
BigDecimal(12,4) |
weightUom |
String(4) |
trackingNumber |
String(128) |
Boolean |
restrictionLevel |
Integer(4) |
lineItems |
Collection |
X |
Table 4-490 Shipment Line Item Data Definition
Column |
Type |
Req |
Definition |
itemId |
String(25) |
X |
caseSize |
BigDecimal(10,2) |
quantity |
BigDecimal(20,4) |
X |
The quantity to be shipped. |
transferId |
Long(12) |
X |
reasonId |
Long(15) |
A unique identifier of a shipment reason associated to this item. It is not allowed for available inventory and required for unavailable inventory. |
uins |
List<String> |
A list of UINs to be shipped. This must match the quantity. |
Table 4-491 Output Data Definition
Attribute |
Type |
Definition |
shipmentId |
Long(15) |
cartonId |
Long(15) |
The unique identifier of the new carton. |
externalId |
String(128) |
The external identifier or barcode label of the container. |
status |
Integer(2) |
The carton status. See Index. |
Figure 4-19 Code Example
API: updateCarton
This API is used to update an existing carton that is in "New" or "In Progress" shipment.
Table 4-492 API Basics
Endpoint URL |
{base URL}/cartons/{cartonId} |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Path Parameter |
The identifier of the carton |
Input |
Output |
Table 4-493 Input Data Definition
Payload |
Type |
Req |
Definition |
externalCartonId |
String(128) |
trackingNumber |
String(128) |
restrictionLevel |
Integer(4) |
cartonSizeId |
Long(10) |
weight |
Long(12,4) |
weightUom |
String(4) |
lineItems |
Collection |
A collection of up to 1,000 line items to update or add within the carton. See TransferShipmentUpdateCartontemIdo. |
Payload |
Type |
Req |
Definition |
itemId |
String(25) |
X |
transferId |
Long(12) |
X |
reasonId |
Long(15) |
quantity |
BigDecimal(12,4) |
X |
The quantity shipped. Reducing this to 0 will remove the line item from the shipment. |
caseSize |
BigDecimal(10,2) |
uins |
Collection<String> |
The UINs associated to the item quantities. The number of UINS must match the quantity shipped. |
Figure 4-20 Code Example
REST Service: Translations
This page captures the service APIs related to retrieving translations. It allows the translation of such things as labels and item descriptions.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/translations
API Definitions
API |
Description |
Find Locales |
Finds all locales that can be used to translation a series of text keys. |
Find Translations |
Finds the translations for a series of text keys, translating into text for the locale if it is available. |
Find Item Descriptions |
Finds the translations for item descriptions, translating it to the text of the locale if it is available. |
API: Find Locales
Finds all locales available for use in translation.
API Basics
Endpoint URL |
{base URL}/locales |
Method |
GET |
200 OK |
Processing Type |
Synchronous |
Input |
Criteria |
Output |
List of locales |
Max Response Limit |
N/A |
Attribute |
Data Type |
Description |
localeId |
Long |
The SIOCS internal unique identifier of the record. |
language |
String |
A code representing a language (ISO 639 alpha-2 or alpha-3 language code). |
country |
String |
A code representing a country of the language (ISO 3166 alpha-2 country code or UN M.49 numeric-3 area code. ) |
variant |
String |
A code representing a variant of the country of the language (an arbitrary value indication the variant). |
description |
String |
A description of the locale. |
Example Output
"localeId": 1,
"language": "en",
"description": "English"
"localeId": 2,
"language": "de",
"description": "German"
"localeId": 3,
"language": "fr",
"description": "French"
API: Find Translations
Searches for translations for text keys and a given locale.
API Basics
Endpoint URL |
{base URL}/find |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Input |
Criteria |
Output |
A map of translation key and its translation |
N/A |
Attribute |
Data Type |
Required |
Description |
localeId |
Long(12) |
Yes |
Unique identifier of the Locale to translate keys for (see find Locales). |
keys |
List<String(600)> |
Yes |
A list of text keys to attempt to translate. |
Example Input
"localeId": 1,
"keys": [
"invAdjReason.1",
"invAdjReason.2"
Attribute |
Data Type |
Description |
values |
Map<String, String> |
A map where the key is the translation key and the value is the translation value. |
Example Output
"invAdjReason.2": "Shrinkage",
"invAdjReason.1": "Wastage"
API: Find Items Descriptions
API Basics
Endpoint URL |
{base URL}/items |
Method |
POST |
200 OK |
Processing Type |
Synchronous |
Input |
Criteria |
Output |
A list of translation items |
N/A |
Attribute |
Data Type |
Required |
Description |
LocaleId |
Long (12) |
Yes |
Unique identifier of the Locale to translate descriptions for (see findLocales). |
itemIds |
List<String(25)> |
Yes |
A list of items to get descriptions for within the locale. |
Example Input
"localeId": 1,
"itemIds": [
"100637121",
"100637113"
Attribute |
Data Type |
Required |
Description |
itemId |
String |
The item identifier. |
shortDescription |
String |
The short description in the locale's text if available. |
longDescription |
String |
The long description in the locale's text if available. |
Example Output
"itemId": "100637121",
"shortDescription": "translation value for 100637121",
"longDescription": "translation value for 100637121"
"itemId": "100637113",
"shortDescription": "translation value for 100637113",
"longDescription": "translation value for 100637113"
REST Service: Vendor Delivery
A direct store delivery (or vendor delivery) is a delivery in which the supplier drops off merchandise directly as the store. These deliveries can be against a planned delivery, an existing purchase order (PO) raised by corporate or by the store, or a purchase order created on the fly. The delivery supports containers coming in directly with Advanced Shipment Notice (ASN) or the system will create a container when the ASN is loaded into the system. Even for receipts without ASN, the system will allow the creation of containers. The four main types of deliveries are a delivery against a purchase order with an advance shipment notice, a delivery against a purchase order without an advance shipment notice, a delivery without a purchase order, and a DEX/NEX or Direct Exchange delivery. This service defines operations to manage vendor delivery information by integration with an external system.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Delivery
Request Parameters
Table 4-497 Find Delivery — Request Parameters
| Parameter | Required | Data Type | Description |
storeId |
NA |
Include only records where the delivery is to this store. |
asn |
NA |
Include only records for this advanced shipping notification. |
originType |
NA |
Include only records with this delivery origin type. Valid values are: 1 - Advanced Shipping Notification 2 - Purchase Order 3 - DEX-NEX 4 - Manual/On The Fly Available values : 1, 2, 3, 4 |
status |
NA |
Include only records with this delivery status. Valid values are: 1 - New 2 - In Progress 3 - Received 4 - Canceled 5 - Rejected 99 - Active Available values: 1, 2, 3, 4, 5, 99 |
NA |
Include only deliveries for this customer order number. |
NA |
Include only deliveries for this fulfillment order number. |
invoiceNumber |
NA |
Include only deliveries for this invoice number. |
supplierId |
NA |
integer($int10) (query) |
Include only deliveries for this supplier. |
purchaseOrderNumber |
NA |
string($text12) (query) |
Include only deliveries for this purchase order number. |
updateDateFrom |
NA |
updateDateTo |
NA |
Responses
Response Code: 200
Example Value
"storeId": 5000,
"supplierId": 5101,
"status": 1,
"originType": 1,
"purchaseOrderId": 789012,
"receiptNumber": 90000,
"asn": "784562",
"invoiceId": "10056",
"customerOrderId": "45000",
"fulfillmentOrderId": "45001",
"createDate": "2025-01-22T14:55:02.719Z",
"updateDate": "2025-01-22T14:55:02.719Z",
"expectedDate": "2025-01-22T14:55:02.719Z",
"invoiceDate": "2025-01-22T14:55:02.719Z",
"receivedDate": "2025-01-22T14:55:02.719Z"
]Schema — VendorDeliveryHeaderIdo
Table 4-498 VendorDeliveryHeaderIdo— Object
deliveryId |
NA |
number($int12) example: 11111 |
The unique identifier of the vendor delivery. |
storeId |
NA |
supplierId |
NA |
The identifier of the supplier shipping the inventory. |
status |
NA |
The current status of the vendor delivery. Valid values are: 1 - New 2 - In Progress 3 - Received 4 - Canceled 5 - Rejected Enum: [ 1, 2, 3, 4, 5 |
originType |
NA |
The origin type of the vendor delivery. Valid values are: 1 - Advanced Shipping Notification 2 - Purchase Order 3 - DEX-NEX 4 - Manual/On The Fly Enum: [ 1, 2, 3, 4 ] |
purchaseOrderId |
NA |
number($int12) example: 789012 |
The purchase order that the delivery is associated to (at header level). |
receiptNumber |
NA |
integer($int12) example: 90000 |
The global receipt number of the delivery, used to identify the receipt across applications through integration. |
asn |
NA |
string($text128) example: 784562 |
The advanced shipping notification. |
invoiceId |
NA |
string($text128) example: 10056 |
The unique identifier of the invoice. |
customerOrderId |
NA |
string($text128) example: 45000 |
The identifier of a customer order associated to the delivery. |
fulfillmentOrderId |
NA |
string($text128) example: 45001 |
The identifier of a fulfillment order associated to the delivery. |
createDate |
MA |
string($date-time) |
updateDate |
NA |
expectedDate |
NA |
The expected delivery date of the delivery. |
invoiceDate |
NA |
The date of the delivery invoice. |
receivedDate |
NA |
The date the delivery was actually received. |
Create Delivery
This API creates a new vendor delivery as if SIOCS was the originator of the delivery. To create a ASN-based delivery where an external system manages the delivery as the originator, see the import delivery operation.
Request Parameters
Example Value
"storeId": 5000,
"supplierId": 5101,
"originType": 1,
"billOfLadingId": "55601",
"carrierName": "Speedy Delivery",
"carrierType": 1,
"carrierCode": "SPDE",
"sourceAddress": "200 Apple Street, Coolsville, WI, 55555",
"licensePlate": "ABC-123",
"freightId": "882211",
"countryCode": "US",
"currencyCode": "USD",
"invoiceNumber": "10056",
"invoiceDate": "2025-03-27T12:01:04.024Z",
"invoiceAmount": 999.99,
"cartons": [
"externalCartonId": "444200301",
"referenceId": "200440012",
"damageReason": "Dropped",
"serialCode": 337654,
"trackingNumber": "AZB12743D",
"damageRemaining": false,
"qualityControl": false,
"lineItems": [
"itemId": "10045600",
"caseSize": 10,
"quantityReceived": 3,
"quantityDamaged": 2,
"unitCostOverrideAmount": 17.5,
"purchaseOrderId": 500678,
"uins": [
"uin": "14532B12",
"received": true,
"damaged": false
}Schema — VendorDeliveryCreateIdo
Table 4-499 VendorDeliveryCreateIdo — Object
storeId |
Yes |
supplierId |
Yes |
purchaseOrderId |
NA |
The purchase order that the delivery is being shipped for (if the shipment is for a single purchase order). |
originType |
Yes |
The origin type of the vendor delivery. Valid values are: 2 - Purchase Order 3 - DEX-NEX 4 - Manual/On The Fly Enum: [ 2, 3, 4 ] |
billOfLadingId |
NA |
string($text128) example: 55601 |
An external identifier of a bill of lading record. |
carrierName |
NA |
string($text128) example: Speedy Delivery |
The name of the carrier. |
carrierType |
NA |
The carrier type of the vendor delivery. Valid values are: 1 - Corporate 2 - Third Party Enum: [ 1, 2] |
carrierCode |
NA |
string($text4) example: SPDE |
sourceAddress |
NA |
string($text1000) example: 200 Apple Street, Coolsville, WI, 55555 |
The address of the source shipping location sending the delivery. |
licensePlate |
NA |
string($text128) example: ABC-123 |
The license plate of the delivery vehicle. |
freightId |
NA |
string($text128) example: 882211 |
countryCode |
NA |
string($text3) example: US |
A country code of the country of the bill of lading. |
currencyCode |
NA |
string($text3) example: USD |
The currency code of the invoice cost. |
invoiceNumber |
NA |
The unique identifier of the invoice associated to the delivery. |
invoiceDate |
NA |
invoiceAmount |
NA |
number($decimal(12,4)) example: 999.99 |
The value of the invoice cost. |
cartons |
Yes |
object |
The cartons present on the delivery. |
Table 4-500 VendorDeliveryCreateCartonIdo — Object
externalCartonId |
NA |
string($text128) example: 444200301 |
The external identifier of the carton. |
referenceId |
NA |
string($text128) example: 200440012 |
A reference identifier to the carton. |
damageReason |
NA |
string($text128) example: Dropped |
A reason for the carton damage that took place. |
serialCode |
NA |
number($int18) example: 337654 |
A serial code for the carton. |
trackingNumber |
NA |
string($text128) example: AZB12743D |
A tracking number for the carton. |
damageRemaining |
NA |
boolean example: false |
True indicates all remaining unaddressed quantities should be marked damaged on final receipt. |
NA |
True if it should receive inventory to the shop floor, false otherwise. |
qualityControl |
NA |
True indicates the carton requires detailed receiving. |
lineItems |
Yes |
object |
The items contained within the carton. |
Table 4-501 VendorDeliveryCreateItemIdo — Object
itemId |
Yes |
string($text25) example: 10045600 |
The unique identifier of the SKU item. |
caseSize |
NA |
number($decima(10,2)) example: 10 |
The case size of the item. |
quantityReceived |
NA |
number($decimal(20,4)) example: 3 |
The amount received on the delivery. |
quantityDamaged |
NA |
number($decimal(20,4)) example: 2 |
The amount received as damaged on the delivery. |
unitCostOverrideAmount |
NA |
number($decimal(20,4)) example: 17.5 |
The override unit cost value of this delivery. |
purchaseOrderId |
NA |
integer($int12) example: 500678 |
The unique identifier of the purchase order for this item. |
uins |
NA |
object |
The UINs associated to this item. |
Table 4-502 VendorDeliveryUinIdo — Object
uin |
NA |
string($text128) example: 14532B12 |
The Universal Identification Number. |
received |
NA |
boolean example: true |
True if the UIN is received as part of the delivery, false otherwise. |
damaged |
NA |
True if the UIN is received as damaged as part of the delivery, false otherwise. |
Responses
Response Code: 200
Schema — VendorDeliveryStatusIdo
Table 4-503 VendorDeliveryStatusIdo — Object
deliveryId |
NA |
storeId |
NA |
supplierId |
NA |
status |
NA |
The current status of the vendor delivery. Valid values are: 1 - New 2 - In Progress 3 - Received 4 - Canceled 5 - Rejected Enum: [ 1, 2, 3, 4, 5 ] |
Read Delivery
This section describes the Read Delivery API. This API retrieves all the details about a vendor delivery.
Request Parameters
Table 4-504 Read Delivery — Request Parameters
deliveryId |
Yes |
number($int12) (path) |
Responses
Response Code: 200
Example Value
"storeId": 5000,
"supplierId": 5101,
"status": 1,
"originType": 1,
"asn": "784562",
"invoiceCurrency": "USD",
"displayCartonInfo": true,
"fiscalDocumentRequestId": 22233344455566,
"fiscalDocumentReferenceId": 77788899100,
"fiscalDocumentNumber": "128745",
"createDate": "2025-03-27T12:03:25.084Z",
"updateDate": "2025-03-27T12:03:25.084Z",
"expectedDate": "2025-03-27T12:03:25.084Z",
"invoiceDate": "2025-03-27T12:03:25.084Z",
"receivedDate": "2025-03-27T12:03:25.084Z",
"createUser": "smith123",
"updateUser": "smith123",
"cartons": [
"cartonId": 100200300,
"status": 1,
"uinRequired": false,
"externalCreate": false,
"adjusted": false,
"lineItems": [
"lineId": 2222222,
"caseSize": 10,
"quantityExpected": 5,
"quantityReceivedOverage": 3,
"quantityDamagedOverage": 2,
"quantityPreviouslyReceived": 3,
"quantityPreviouslyDamaged": 2,
"unitCostCurrency": "USD",
"unitCostAmount": 14.5,
"unitCostOverrideCurrency": "USD",
"purchaseOrderNumber": "DX4600",
"customerOrderNumber": "CO100000",
"fulfillmentOrderNumber": "FO12",
"vendorProductNumber": "147800",
"uins": [
"uin": "14532B12",
"shipped": true,
"received": true,
"damaged": false
]Schema — VendorDeliveryIdo
Table 4-505 VendorDeliveryIdo— Object
deliveryId |
NA |
storeId |
NA |
supplierId |
NA |
status |
NA |
originType |
NA |
purchaseOrderId |
NA |
receiptNumber |
NA |
asn |
NA |
invoiceNumber |
NA |
invoiceCurrency |
NA |
invoiceAmount |
NA |
customerOrderId |
NA |
NA |
displayCartonInfo |
NA |
True if carton information should be displayed in the UI, false otherwise. |
billOfLadingId |
NA |
carrierName |
NA |
carrierCode |
NA |
countryCode |
NA |
sourceAddress |
NA |
licensePlate |
NA |
freightId |
NA |
NA |
number($int20) example: 22233344455566 |
NA |
number($int20) example: 77788899100 |
NA |
string($text255) example: 128745 |
createDate |
NA |
updateDate |
NA |
expectedDate |
NA |
invoiceDate |
NA |
receivedDate |
NA |
createUser |
NA |
string($text128) example: smith123 |
The user that created the delivery record. |
updateUser |
NA |
The user that last updated the delivery record. |
receivedUser |
NA |
The user that received the delivery record. |
cartons |
NA |
object |
The containers belonging to this delivery. |
Table 4-506 VendorDeliveryCartonIdo— Object
cartonId |
NA |
integer($int12) example: 100200300 |
The unique identifier of the carton record. |
externalCartonId |
NA |
referenceId |
NA |
A reference identifier for the carton. |
status |
NA |
The current status of the carton. Valid values are: 1 - New 2 - In Progress 3 - Submitted 4 - Received 5- Damaged 6 - Missing 7 - Canceled Enum: [ 1, 2, 3, 4, 5, 6, 7 ] |
damageReason |
NA |
serialCode |
NA |
trackingNumber |
NA |
damageRemaining |
NA |
True indicates all remaining quantities should be marked damaged on final receipt. |
uinRequired |
NA |
True if a UIN item exists within the carton, false otherwise. |
NA |
True if delivery should receive inventory to the shop floor, false otherwise. |
qualityControl |
NA |
externalCreate |
NA |
True indicates the carton was externally created, false indicates it was created by EICS. |
adjusted |
NA |
True indicates the carton has been adjusted. |
NA |
Defines whether or not the items within the carton are related to customer orders. Valid values are: 1 - Yes 2 - Mix 3 - No Enum: [ 1, 2, 3 ] |
createDate |
NA |
The date the carton was created. |
updateDate |
NA |
The date the carton was last updated. |
receivedDate |
NA |
The date the carton was received. |
createUser |
NA |
The user that created the carton record. |
updateUser |
NA |
The user that last updated the carton record. |
receivedUser |
NA |
The user that received the carton record. |
lineItems |
NA |
object |
The items belonging to the carton. |
Table 4-507 VendorDeliveryLineItemIdo— Object
lineId |
NA |
integer($int12) example: 2222222 |
The unique identier of the line item record. |
itemId |
NA |
caseSize |
NA |
number($decimal(10,2)) example: 10 |
A case size of the item in this container. |
quantityExpected |
NA |
number($decimal(20,4)) example: 5 |
The total amount expected on the delivery. |
quantityReceived |
NA |
The total amount received on the delivery. |
quantityDamaged |
NA |
The total amount received as damaged on the delivery. |
quantityReceivedOverage |
NA |
Amount of received inventory over expected quantities. |
quantityDamagedOverage |
NA |
Amount of received as damaged inventory over expected quantities. |
quantityPreviouslyReceived |
NA |
Units previously received (captured at time container is re-opened after receipt). |
quantityPreviouslyDamaged |
NA |
Units previously received as damaged (captured at time container is re-opened after receipt). |
unitCostCurrency |
NA |
The currency of the unit cost of this delivery. |
unitCostAmount |
NA |
number($decimal(20,4)) example: 14.5 |
The unit cost value of this delivery. |
unitCostOverrideCurrency |
NA |
The currency of the override unit cost of this delivery. |
NA |
purchaseOrderId |
NA |
NA |
string($text128) example: DX4600 |
The external purchase order number for this item. |
customerOrderNumber |
NA |
string($text128) example: CO100000 |
The unique external customer order identifier this item is fulfilling. |
fulfillmentOrderNumber |
NA |
string($text3) example: FO12 |
The unique external fulfillment order identifier this item is fulfilling. |
vendorProductNumber |
NA |
string($text256) example: 147800 |
The vendor product number of the item. |
uins |
NA |
object |
The UINs being received as part of this item. |
Table 4-508 VendorDeliveryLineItemUinIdo— Object
uin |
NA |
shipped |
NA |
True if the UIN was shipped from the supplier as part of the delivery, false otherwise. |
received |
NA |
damaged |
NA |
Update Delivery
This section describes the Update Delivery API. This API update the header portion of a delivery.
Request Parameters
Table 4-509 Update Delivery — Request Parameters
deliveryId |
Yes |
Example Value
"carrierType": 1,
"invoiceDate": "2025-01-28T13:22:31.457Z",
"expectedDate": "2025-01-28T13:22:31.457Z"
} Schema — VendorDeliveryUpdateIdo
Table 4-510 VendorDeliveryUpdateIdo — Object
billOfLadingId |
NA |
carrierName |
NA |
carrierType |
NA |
The carrier type of the vendor delivery. Valid values are: 1 - Corporate 2 - Third Party Enum: [ 1, 2 ] |
carrierCode |
NA |
sourceAddress |
NA |
licensePlate |
NA |
freightId |
NA |
countryCode |
NA |
currencyCode |
NA |
invoiceNumber |
NA |
The number or identifier of the invoice associated to the delivery. |
invoiceDate |
NA |
invoiceAmount |
NA |
expectedDate |
NA |
Receive Delivery
This section describes the Receive Delivery API. This API updates the received quantities to the quantities that were expected so that it is ready to be confirmed. This will place the delivery into the "In Progress" state if that is not already its current state.
Request Parameters
Table 4-511 Receive Delivery — Request Parameters
deliveryId |
Yes |
Confirm Delivery
This section describes the Confirm Delivery API. This API confirms the vendor delivery and receives the goods into inventory.
Request Parameters
Table 4-512 Confirm Delivery — Request Parameters
deliveryId |
Yes |
Reject Delivery
This section describes the Reject Delivery API. This API cancels the vendor delivery without receiving goods and places it in rejected status.
Request Parameters
Table 4-513 Reject Delivery — Request Parameters
deliveryId |
Yes |
Cancel Delivery
This section describes the Cancel Delivery API. This API cancels the vendor delivery without receiving goods and places it in canceled status.
Request Parameters
Table 4-514 Cancel Delivery — Request Parameters
deliveryId |
Yes |
Create Carton
This section describes the Crate Carton API. This API adds a new container to a new or in progress shipment.
Request Parameters
Table 4-515 Create Carton — Request Parameters
deliveryId |
Yes |
Details about the carton to create.
Example Value
"lineItems": [
"caseSize": 10,
"uins": [
"uin": "14532B12",
"received": true,
"damaged": false
Schema — VendorDeliveryCartonCreateIdo
Table 4-516 VendorDeliveryCartonCreateIdo — Object
| Element Name | Required | Data Type/Example | Description |
externalCartonId |
NA |
referenceId |
NA |
damageReason |
NA |
serialCode |
NA |
trackingNumber |
NA |
damageRemaining |
NA |
NA |
True if will receive inventory to the shop floor, false otherwise. |
qualityControl |
NA |
lineItems |
Yes |
object |
The items to create within the carton. |
Table 4-517 VendorDeliveryCartonCreateItemIdo — Object
itemId |
Yes |
caseSize |
NA |
The case size of the item in this carton. |
quantityReceived |
NA |
The amount of the item received on the delivery. |
quantityDamaged |
NA |
The amount of the item received as damaged on the delivery. |
NA |
purchaseOrderId |
NA |
The unique identifier of the purchase order for this item delivery. |
uins |
NA |
object |
Table 4-518 VendorDeliveryUinIdo — Object
uin |
NA |
received |
NA |
damaged |
NA |
Responses
Response Code: 200
Example Value
"status": 1
]Schema — VendorDeliveryCartonStatusIdo
Table 4-519 VendorDeliveryCartonStatusIdo— Object
eliveryId |
NA |
The unique identifier of the delivery record. |
cartonId |
NA |
externalCartonId |
NA |
status |
NA |
The current status of the carton. Valid values are: 1 - New 2 - In Progress 3 - Submitted 4 - Received 5 - Damaged 6 - Missing 7 - Canceled Enum: [ 1, 2, 3, 4, 5, 6, 7 ] |
Update Carton
This section describes the Update Carton API. This API updates a previously existing carton that is in a new or in progress state, on a delivery that is also new or in progress.
Request Parameters
Table 4-520 Update Carton — Request Parameters
cartonId |
Yes |
The request body is application/json.
Details about the carton to update.
Example Value
"lineItems": [
"caseSize": 10,
"uins": [
"uin": "14532B12",
"received": true,
"damaged": false
}Schema — VendorDeliveryCartonUpdateIdo
Table 4-521 VendorDeliveryCartonUpdateIdo — Object
externalCartonId |
NA |
referenceId |
NA |
damageReason |
NA |
serialCode |
NA |
trackingNumber |
NA |
damageRemaining |
NA |
NA |
True if the item should receive inventory to the shop floor, false otherwise. |
qualityControl |
NA |
lineItems |
NA |
object |
The items to update within the carton. |
Table 4-522 VendorDeliveryCartonUpdateItemIdo — Object
itemId |
Yes |
caseSize |
NA |
A case size of the item within this carton. |
quantityReceived |
NA |
The amount received for this item. |
quantityDamaged |
NA |
The amounted received as damaged for this item. |
NA |
The override unit cost value of this item. |
purchaseOrderId |
Na |
The unique identifer of the purchase order for this item. |
uins |
NA |
object |
Table 4-523 VendorDeliveryUinIdo — Object
uin |
NA |
received |
NA |
damaged |
NA |
Submit Carton
This section describes the Submit Carton API. This API moves the status of the carton to submitted and prevents further updates. The carton may still be confirmed. No inventory positions are updated via this operation.
Request Parameters
Table 4-524 Submit Carton — Request Parameters
cartonId |
Yes |
Cancel Submitted Carton
This section describes the Cancel Submitted Carton API. This API opens a submitted carton for further updates, moving the status to in progress.
Request Parameters
Table 4-525 Cancel Submitted Carton — Request Parameters
cartonId |
Yes |
Confirm Carton
This section describes the Confirm Carton API. This API confirms the final receipt of a vendor delivery carton.
Request Parameters
Table 4-526 Confirm Carton — Request Parameters
cartonId |
Yes |
Cancel Carton
This section describes the Cancel Carton API. This API cancels a vendor delivery carton.
Request Parameters
Table 4-527 Cancel Carton — Request Parameters
cartonId |
Yes |
Open Carton
This section describes the Open Carton API. This API re--opens a completed carton after reciept allowing it to be received again.
Request Parameters
Table 4-528 Open Carton — Request Parameters
cartonId |
Yes |
Import ASN Delivery
This section describes the Import ASN Delivery API. This API imports an ASN vendor delivery that is managed by an external system. When importing, the contents must contain the entire delivery. This asynchronous call places a record in the MPS message table for later processing, controlled by the DcsAsn work type.
Request Parameters
Example Value
"asn": "789012",
"storeId": 5000,
"supplierId": 5101,
"invoiceDate": "2025-02-06T11:48:31.239Z",
"fiscalDocumentNumber": "USD",
"expectedDate": "USD",
"carrierType": 1,
"cartons": [
"cartonNumber": "444200301",
"lineItems": [
"quantity": 3,
"purchaseOrderNumber": "500678",
"uins": [
333000341341,
444001343243
"looseItems": [
"quantity": 3,
"uins": [
333000341341,
444001343243
"notes": [
"This is note number one.",
"This is note number two."
}Schema — VendorDeliveryImportIdo
Table 4-529 VendorDeliveryImportIdo — Object
asn |
Yes |
string($text128) example: 789012 |
The the asn. |
storeId |
NA |
number($int10) example: 5000 |
The identifier of the store receiving the inventory. |
supplierId |
Yes |
number($int10) example: 5101 |
invoiceNumber |
NA |
invoiceDate |
NA |
invoiceAmount |
NA |
currencyCode |
NA |
NA |
The fiscal document number. This is an imported external fiscal document number and is simply stored. The document may not exist in the system as a fiscal document. |
expectedDate |
NA |
string($date-time) example: USD |
The date the delivery is expected to arrive. |
displayCartonInfo |
NA |
If true, carton information will be displayed on the UI, otherwise only item information will be displayed. |
billOfLadingId |
NA |
carrierName |
NA |
carrierType |
NA |
integer($int4) example: 1 |
The carrier type of the vendor delivery. Valid values are: 1 - Corporate 2 - Third Party Enum: Array [ 2 |
carrierCode |
NA |
sourceAddress |
NA |
The address of the source shipping location sending the delivery |
licensePlate |
NA |
freightId |
NA |
countryCode |
NA |
cartons* |
Yes |
object |
looseItems |
NA |
object |
A collection of loose items not on the delivery. These will be gathered and placed in a generated carton. |
notes |
NA |
string($text2000)] example: List [ "This is note number one.", "This is note number two." ] |
A collection of notes on the delivery. |
Table 4-530 VendorDeliveryImportCartonIdo — Object
cartonNumber |
NA |
The external identifier of the carton. A carton will be added or updated based on whether or not it already exists on the delivery. |
trackingNumber |
NA |
qualityControl |
NA |
lineItems |
Yes |
object |
A collection of items in the container. If all items within the container are set to a zero quantity, the carton will be cancelled. |
Table 4-531 VendorDeliveryImportItemdo — Object
itemId |
Yes |
quantity |
Yes |
The total amount of the item expected on the delivery. |
Yes |
string($text128) example: 500678 |
The external system purchase order number. |
uins |
NA |
string($text128)] example: List [ 333000341341, 444001343243 ] |
A list of UINs that shipped as part of the delivery. |
Import ASN Cancel Delivery
This section describes the Import ASN Cancel Delivery API. This API imports a cancellation of the vendor delivery. The vendor delivery must be in new status in order to be canceled. It cannot be cancelled if receiving has begun against it as well. This asynchronous call places a record in the MPS message table for later processing, controlled by the DcsAsn work type.
Request Parameters
There are no request parameters.
Schema — VendorDeliveryImportCancelIdo
Table 4-532 VendorDeliveryImportCanelIdo — Object
asn |
NA |
string($text128) example: 5101 |
The advanced shipping notification of the delivery. |
storeId |
NA |
Import ASN Adjustments
This section describes the Import ASN Adjustments API. This API is used to import external adjustments made to a vendor delivery. It does not adjust the delivery itself but does track adjustments made after the delivery is closed. It updates the inventory stock positions and the received amount of the purchase order. This asynchronous call places a record in the MPS message table for later processing, controlled by the DcsAsn work type.
Request Parameters
Example Value
"asn": "93471341",
"storeId": 5000,
"items": [
"cartonNumber": "9834834",
"purchaseOrderNumber": "34AA04134",
"quantity": 55.23
}Schema — VendorDeliveryAdjustmentImportIdo
Table 4-533 VendorDeliveryAdjustmentImportIdo — Object
asn |
Yes |
string($text128) example: 93471341 |
storeId |
Yes |
The unique identifier of the store receiving the inventory. |
items |
Yes |
object |
itmes |
Table 4-534 VendorDeliveryAdjustmentImportItemIdo — Object
itemId |
Yes |
string($text25) example: 100637121 |
The item that is being adjusted. |
cartonNumber |
Yes |
string($text128) example: 9834834 |
The carton number of the carton containing the item. |
Yes |
string($text128) example: 34AA04134 |
The purchase order number associated to the adjustment. |
quantity |
Yes |
number($decimal(20,4)) example: 55.23 |
The new amount of the item received to be adjusted to. |
Find ASN Adjustments
This section describes the Find ASN Adjustments API. This API retrieves the adjustments made for a delivery after the delivery was received.
Request Parameters
Table 4-535 Find ASN Adjustments — Request Parameters
deliveryId |
NA |
number($int10) (query) |
Include only records for this delivery. |
asn |
NA |
string($text128) (query) |
Responses
This section describes the responses of the Find ASN Adjustments API.
Response Code: 200
The request has been successful.
The media type is application/json.
Example Value
"adjustmentId": 55601,
"deliveryId": 513434,
"storeId": 5000,
"adjustmentDate": "2025-02-06T13:25:54.461Z",
"quantity": 55.23
]Schema — VendorDeliveryAdjustmentIdo
Table 4-536 VendorDeliveryAdjustmentIdo— Object
adjustmentId |
NA |
number($int15) example: 55601 |
The identifier of the delivery adjustment record. |
deliveryId |
NA |
number($int12) example: 513434 |
The identifier of the delivery. |
storeId |
NA |
NA |
itemId |
NA |
The item that was adjusted. |
adjustmentDate |
NA |
The date of the adjustment. |
quantity |
NA |
The new amount of the item to be adjusted to. |
REST Service: Vendor Return
A return request is a return to vendor that comes into the store from an external system. A return request is a made for items to be returned to the supplier from the store. The items and quantities requested to be returned and reasons (for RTV) will be listed. Updating the return allows the approved quantity to be assigned. Once the request has been approved, the items are shipped to the supplier. This service allows for the integration of return requests with an external system.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Return
This section describes the Find Return API. This API Finds up to 10,000 return headers for the input criteria.
Request Parameters
Table 4-537 Find Return — Request Parameters
storeId |
NA |
Include only returns from this store. |
supplierId |
NA |
Include only returns to this supplier. |
externalReturnId |
NA |
Include only returns for this vendor return external identifier. |
status |
NA |
integer($int4) (query) |
Include only returns with this status. Valid values are: 1 - Requested 2 - Request In Progress 3 - RTV In Progress 4 - Approved 5 - In Shipping 6 - Completed 7 - Rejected 8 - Canceled Request 9 - Canceled RTV 99 - Active Available values : 1, 2, 3, 4, 5, 6, 7, 8, 9, 99 |
itemId |
NA |
string($text25) (query) |
Include only returns that contain this item. |
shipmentReasonId |
NA |
number($int15) (query) |
Include only returns that contain this shipment reason. |
updateDateFrom |
NA |
string($date-time) (query) |
Include only returns with an update date on or after this date. |
updateDateTo |
NA |
Include only returns with an update date on or before this date. |
Responses
This section describes the responses of the Find Return API.
Response Code: 200
Example Value
"returnId": 11111,
"storeId": 5000,
"supplierId": 5101,
"externalReturnId": "90000",
"status": 1,
"notAfterDate": "2025-01-17T16:44:28.715Z",
"approvedDate": "2025-01-17T16:44:28.715Z",
"closedDate": "2025-01-17T16:44:28.715Z",
"createDate": "2025-01-17T16:44:28.715Z",
"updateDate": "2025-01-17T16:44:28.715Z"
]Schema — VendorReturnHeaderIdo
Table 4-538 VendorReturnHeaderIdo— Object
returnId |
NA |
The unique identifier of the vendor return. |
storeId |
NA |
The identifier of the store returning the inventory. |
supplierId |
NA |
The identifier of the supplier the goods are being shipped to. |
externalReturnId |
NA |
string($text128) example: 90000 |
A unique identifier of the vendor return from an external system. |
status |
NA |
1 - Requested 2 - Request In Progress 3 - RTV In Progress 4 - Approved 5 - In Shipping 6 - Completed 7 - Rejected 8 - Canceled Request 9 - Canceled RTV Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9 ] |
notAfterDate |
NA |
A date after which the return should not be shipped. |
approvedDate |
NA |
The date the return was approved. |
closedDate |
NA |
The date the return was closed. |
createDate |
NA |
The date the return was created in SIOCS. |
updateDate |
NA |
The date the return was last updated in SIOCS. |
Create Return
This section describes the Create Return API. This service creates a new vendor return document.
Request Parameters
The are no request parameters.
Example Value
"storeId": 5000,
"supplierId": 5101,
"notAfterDate": "2025-01-20T14:04:51.208Z",
"authorizationCode": "JID112",
"addressLine1": "460 Summer Street",
"addressLine2": "Apartment 2",
"addressLine3": "c/o John Smith",
"aAddressCity": "Coolsville",
"addressState": "NY",
"addressCountry": "US",
"addressPostalCode": "55555-1111",
"lineItems": [
"reasonId": "82236",
"quantity": 100,
"caseSize": 1
}Schema — VendorReturnCreateIdo
Table 4-539 VendorReturnCreateIdo— Object
storeId |
Yes |
The identifier of the store returning the inventory. This value is ignored if the return already exists. |
supplierId |
Yes |
The identifier of the supplier the goods are being shipped to. This value is ignored if the return already exists. |
notAfterDate |
NA |
A date after which the return should not be shipped. If not included, this value will be defaulted through system configuration. |
authorizationCode |
NA |
string($text12) example: JID112 |
An authorization number that may be required for the return. |
addressLine1 |
NA |
string($text240) example: 460 Summer Street |
The first line of the destination address. |
addressLine2 |
NA |
string($text240) example: Apartment 2 |
The second line of the destination address. |
addressLine3 |
NA |
string($text240) example: c/o John Smith |
The third line of the destination address. |
aAddressCity |
NA |
string($text120) example: Coolsville |
The city of the destination address. |
addressState |
Na |
string($text3) example: NY |
The state of the destination address. |
addressCountry |
NA |
The country code of the destination address. |
addressPostalCode |
NA |
string($text30) example: 55555-1111 |
The postal code of the destination address. |
lineItems* |
Yes |
object |
The items to be returned. |
Table 4-540 VendorReturnCreateLineItemIdo— Object
itemId |
Yes |
reasonId |
NA |
string($text6) example: 82236 |
The unique identifier of a return reason code for this item return. |
quantity |
Yes |
number($decimal(20,4)) example: 100 |
The quantity to return. |
caseSize |
number($decimal(20,4)) example: 1 |
The case size of this item return. |
Responses
This section describes the responses of the Create Return API.
Response Code: 200
Schema — VendorReturnStatusIdo
Table 4-541 VendorReturnStatusIdo— Object
returnId |
NA |
storeId |
NA |
supplierId |
Na |
status |
NA |
Read Return
This section describes the Read Return API. This service retrieves all the details about a vendor return.
Request Parameters
Table 4-542 Read Return — Request Parameters
returnId |
Yes |
Responses
This section describes the responses of the Read Return API.
Response Code: 200
Example Value
"returnId": 11111,
"storeId": 5000,
"supplierId": 5101,
"externalLocked": true,
"originType": 1,
"status": 1,
"notAfterDate": "2025-01-17T16:59:15.721Z",
"approvedUser": "smith123",
"approvedDate": "2025-01-17T16:59:15.721Z",
"closedUser": "smith123",
"closedDate": "2025-01-17T16:59:15.721Z",
"createDate": "2025-01-17T16:59:15.721Z",
"updateDate": "2025-01-17T16:59:15.721Z",
"lineItems": [
"lineId": 2222222,
"externalLineId": 456,
"shipmentReasonId": 82236,
"caseSize": 3,
"quantityRequested": 100,
"quantityApproved": 100,
"quantityShipping": 100,
"quantityShipped": 100
Schema — VendorReturnIdo
Table 4-543 VendorReturnIdo— Object
returnId |
NA |
storeId |
NA |
supplierId |
NA |
externalReturnId |
NA |
A unique identifer of the vendor return from an external system. |
externalLocked |
NA |
True if the system no longer accepts changes to the vendor return from an external source. |
originType |
NA |
The origin type of the return. Valid values are: 1 - External 2 - Internal <br/ 3 - Shipment Enum: [ 1, 2, 3 ] |
status |
NA |
notAfterDate |
NA |
authorizationCode |
NA |
addressLine1 |
NA |
addressLine2 |
NA |
addressLine3 |
NA |
aAddressCity |
NA |
addressState |
NA |
addressCountry |
NA |
addressPostalCode |
NA |
approvedUser |
NA |
The user that approved the return. |
approvedDate |
NA |
closedUser |
NA |
The user that closed the return. |
closedDate |
NA |
createUser |
NA |
The user that created the return. |
createDate |
NA |
The date the return was created. |
updateUser |
NA |
The user that last updated the return. |
updateDate |
NA |
The date the return was last updated. |
lineItems |
NA |
object |
A collection of items to be returned. |
Table 4-544 VendorReturnLineItemIdo— Object
lineId |
NA |
integer($int15) example: 2222222 |
The unique identifier of the line record. |
externalLineId |
NA |
integer($int15) example: 456 |
An external identifier to this particular line item on the return. |
itemId |
NA |
shipmentReasonId |
NA |
integer($int15) example: 82236 |
The unique identifier of the shipment reason. |
caseSize |
NA |
number($decimal(10,2)) example: 3 |
The case size of this record. |
quantityRequested |
NA |
The quantity requested to return. |
quantityApproved |
NA |
The quantity approved to return. |
quantityShipping |
NA |
The quantity prepared to ship on the return. |
quantityShipped |
NA |
The quantity that has shipped on the return. |
Update Return
This section describes the Update Return API. This service updates vendor return approved quantities prior to approving the vendor return.
Request Parameters
Table 4-545 Update Return — Request Parameters
returnId |
Yes |
Vendor return details to update.
Example Value
"lineItems": [
"quantity": 100
}Schema — VendorReturnUpdateIdo
Table 4-546 VendorReturnUpdateIdo— Object
authorizationCode |
NA |
lineItems |
NA |
object |
A list of up to 1,000 items with approved quantities to be included on the return. The collection can remain empty if only updating the authorization code. |
Table 4-547 VendorReturnUpdateLineItemIdo— Object
itemId |
Yes |
shipmentReasonId |
Yes |
The unique identier of the shipment reason. If the shipment reason is unavailable, the quantity must not exceed the item's unavailable stock. Unavailable sub-buckets are not considered in vendor return and are only used when creating the vendor shipment. |
quantity |
Yes |
Approve Return
This section describes the Approve Return API. This service approves a vendor return for shipment. Use the Update Return operation to assign and persist desired quantities before approval.
Request Parameters
Table 4-548 Approve Return — Request Parameters
returnId |
Yes |
Close Return
This section describes the Close Return API. This service closes out the vendor return.
Request Parameters
Table 4-549 Close Return — Request Parameters
returnId |
Yes |
Import Return
This section describes the Import Return API. This service imports a vendor return request managed by an external system. Processing assumes that any notification to other systems about the creation of this information will be managed by the external system. The imported return is processed asynchronous through our MPS sub-system and is controlled by the DcsRtv work type. If more than 1,000 items are included in the return, a "input too large" error will be returned. This operation will return a forbidden error code if the system is integrated with Oracle merchandising.
Request Parameters
Vendor return details to import.
Example Value
"storeId": 5000,
"supplierId": 5101,
"notAfterDate": "2025-01-20T15:17:16.265Z",
"comment": "Originally overshipped goods.",
"createDate": "2025-01-20T15:17:16.265Z",
"lineItems": [
"reasonCode": "82236",
"quantity": 100,
"sequence": 1
}Schema — VendorReturnImportIdo
Table 4-550 VendorReturnImportIdo— Object
externalReturnId |
Yes |
A unique identifer of the vendor return from an external system. This identifier is used to determine if the import will be created or updated. |
storeId |
Yes |
supplierId |
Yes |
notAfterDate |
NA |
authorizationCode |
NA |
addressLine1 |
NA |
addressLine2 |
NA |
addressLine3 |
NA |
aAddressCity |
NA |
addressState |
NA |
addressCountry |
NA |
addressPostalCode |
NA |
comment |
NA |
string($text2000) example: Originally overshipped goods. |
A comment to associate to the vendor return request. |
createDate |
Yes |
lineItems |
Yes |
object |
Table 4-551 VendorReturnImportLineItemIdo— Object
itemId |
Yes |
reasonCode |
Yes |
A reason code associate to the item return. |
quantity |
Yes |
sequence |
NA |
number($int15) example: 1 |
An external sequence number for the item on the return. |
Import Return Delete
This section describes the Import Return Delete API. This service will place a delete notification in the system (in the MPS work queue with DcsRtv work type) for asynchronous processing. When processed, it will cancel the vendor return if it qualifies for cancellation (it is not already in progress). This operation will return a forbidden error code if the system is integrated with Oracle merchandising.
Request Parameters
Table 4-552 Import Return Delete — Request Parameters
externalReturnId |
Yes |
string($text128) (path) |
The unique identifier of the vendor return from the external system. |
REST Service: Vendor Shipment
Vendor shipment is the process of shipping inventory out of the store back to a supplier for redistribution or disposal. If the store plans to return items to the vendor, it can be done by creating a vendor shipment (RTV shipment). The items, quantities to be returned, and reasons for the return, can be added to the shipment. When the shipment is dispatched, the goods are removed from inventory.
To create a shipment, a supplier must be identified for this return. The supplier must allow for returns and must be a DSD supplier, and if the system is configured to use multiple sets of books, then the supplier is limited to the same operating unit as that of the store.
Items along with reasons can be added to the return. For Return to Vendors, the system allows a mix of available and unavailable inventory status items on the return; therefore, all reasons for the Return to Vendor type will be listed. All items on the return must be sourced by the supplier designated on the RTV. Authorization Number, which is required for certain suppliers, would need to be entered before dispatching.
The service defines operations to manage vendor shipment information by integration with an external system.
Service Base URL
The Cloud service base URL follows the format:
https://<external_load_balancer>/<cust_env>/siocs-int-services/apiFind Shipments
This section describes the Find Shipments API. This API finds up to 10,000 shipments headers for the input criteria.
Request
This section describes the request parameters.
Table 4-553 Find Shipments— Request Parameters
storeId |
NA |
number ($int10) (query) |
Include only records where the shipment is from this store. |
supplierId |
NA |
Include only shipments where the shipment is to this supplier. |
vendorReturnId |
NA |
number ($int15) (query) |
Include only shipments for this vendor return (by internal identifier). |
vendorReturnExternalId |
NA |
string ($text128) (query) |
Include only shipments for this vendor return (by external identifier). |
status |
NA |
integer ($int4) (query) |
Include only shipments with this delivery status. Valid values are 1 – New 2 - In Progress 3 – Submitted 4 – Shipped 5 – Canceled 99 – Active Available values: 1, 2, 3, 4, 5, 99 |
itemId |
NA |
Include only shipments that contain this item. |
updateDateFrom |
NA |
string ($date-time)(query) |
Include only shipments with an update date on or after this date. |
updateDateTo |
NA |
string ($date-time) (query) |
Include only shipments with an update date on or before this date. |
Responses
This section describes the responses of the Find Shipments API.
Response Code: 200
Example Value
"shipmentId": 11111,
"storeId": 5000,
"supplierId": 5101,
"vendorReturnId": 789012,
"vendorReturnExternalId": "90000",
"status": 1,
"notAfterDate": "2024-08-30T07:40:22.421Z",
"submitDate": "2024-08-30T07:40:22.421Z",
"dispatchDate": "2024-08-30T07:40:22.422Z",
"updateDate": "2024-08-30T07:40:22.422Z"
]Schema — VendorShipmentHeaderIdo
This section describes the VendorShipmentHeaderIdo schema.
Table 4-554 VendorShipmentHeaderIdo — Object
| Element Name | Required | Data Type | Description |
shipmentId |
NA |
The unique identifier of the vendor shipment. |
storeId |
NA |
The identifier of the store shipping the inventory. |
supplierId |
NA |
vendorReturnId |
NA |
number($int15) example: 789012 |
The unique identifier of the vendor return this shipment is for. |
NA |
status |
NA |
The current status of the vendor shipment. Valid values are: 1 – New 2 - In Progress 3 – Submitted 4 – Shipped 5 – Canceled Enum: [ 1, 2, 3, 4, 5 ] |
notAfterDate |
NA |
A date after which the shipment should not be shipped. |
submitDate |
NA |
The date the shipment was submitted. |
dispatchDate |
NA |
The date the shipment was dispatched. |
updateDate |
NA |
The date the delivery was last updated. |
Create Shipment
This section describes the Create Shipment API. It creates a new vendor shipment whose status is in progress. When creating the vendor shipment, it only allows up to 1,000 items in the overall shipment.
Request
The shipment details of the new shipment.
Example Value
"storeId": 5000,
"supplierId": 5101,
"supplierCountryCode": "USA",
"authorizationCode": "H112",
"notAfterDate": "2024-08-30T07:55:27.191Z",
"contextId": 90000,
"contextValue": "Spring Return",
"addressType": 1,
"carrierRole": 1,
"carrierId": 123,
"carrierServiceId": 456,
"alternateAddress": "Another Street, Different City, NY, 44444",
"alternateCarrierName": "Speedy Delivery",
"alternateCarrierAddress": "Carrier Street, Carrier City, NY, 44444",
"motiveId": 123,
"taxId": "11-33500",
"trackingNumber": "44000567002",
"dimensionId": 100,
"weight": 12.8,
"weightUom": "KG",
"requestedPickupDate": "2024-08-30T07:55:27.191Z",
"cartons": [
"externalCartonId": "4500300",
"trackingNumber": "876300456",
"restrictionLevel": 1,
"cartonSizeId": 1000,
"weight": 4.5,
"weightUom": "LBS",
"lineItems": [
"reasonId": 2222222,
"caseSize": 3,
"quantity": 100,
"uins": [
111345000,
222220000
"notes": [
"The first note",
"The second note"
Schema — VendorShipmentCreateIdo
This section describes the VendorShipmentCreateIdo schema.
Table 4-555 VendorShipmentCreateIdo — Object
storeId |
Yes |
supplierId |
Yes |
supplierCountryCode |
NA |
string($text3) example: USA |
The country code of the supplier for this shipment. All items must be available with this country code. If left blank, a country code will be selected from the available supplier items giving preference to a country code that matches the store. |
vendorReturnId |
NA |
authorizationCode |
NA |
string($text12) example: H112 |
A vendor authorization code |
notAfterDate |
NA |
contextId |
NA |
number($int18) example: 90000 |
A unique identifier of a context for the shipment (see shipping service). |
contextValue |
NA |
string($text25) example: Spring Return |
An additional value associated to the context for the shipment. |
addressType |
NA |
The hierarchy restriction level for items in the container. Valid values are: 1 - Department 2 - Class 3 - Subclass 4 - None Enum: [ 1, 2, 3, 4 |
carrierRole |
Yes |
integer($int2) example: 1 |
The type of carrier for the shipment. Valid values are: 1 - Sender 2 - Receiver 3 - Third Party Enum: [ 1, 2, 3 ] |
carrierId |
NA |
integer($int10) example: 123 |
A unique identifier of a carrier for the shipment. |
carrierServiceId |
NA |
integer($int10) example: 456 |
A unique identifier of a carrier service for the shipment. |
alternateAddress |
NA |
string($text2000) example: Another Street, Different City, NY, 44444 |
An alternate destination address. |
alternateCarrierName |
NA |
string($text240) example: Speedy Delivery |
The name of a third-party shipping company. |
alternateCarrierAddress |
NA |
string($text240) example: Carrier Street, Carrier City, NY, 44444 |
The address of a third-party shipping company. |
motiveId |
NA |
number($int18) example: 123 |
The identifier ofa motive for the bill of lading. |
taxId |
NA |
string($text18) example: 11-33500 |
The tax identifier of the supplier it is being shipped to. |
trackingNumber |
NA |
string($text128) example: 44000567002 |
A tracking number associated to the shipment. |
dimensionId |
NA |
integer($int12) example: 100 |
The identifier of a dimension object associated to the shipment. |
weight |
NA |
number($decimal(12,4)) example: 12.8 |
The weight of the shipment. |
weightUom |
NA |
string($text4) example: KG |
The unit of measure of the weight of the shipment. |
requestedPickupDate |
NA |
The requested pickup date. |
| cartons | Yes | object | cartons |
| notes | NA | string ($text2000) example: List [ "The first note", "The second note" ] | A collection of up to 100 notes to be created. |
Table 4-556 VendorShipmentCreateCartonIdo — Object
externalCartonId |
NA |
string($text128) example: 4500300 |
A container identifier from an external system. |
trackingNumber |
NA |
string($text128) example: 876300456 |
restrictionLevel |
NA |
integer($int4) |
example: 1 The hierarchy restriction level for items in the container. Valid values are: 1 - Department 2 - Class 3 - Subclass 4 - None Enum: [ 1, 2, 3, 4 ] |
cartonSizeId |
NA |
integer($int10) example: 1000 |
The unique identifier of the container dimension object. |
weight |
NA |
number($decimal(12,4)) example: 4.5 |
The weight of the container. |
weightUom |
NA |
string($text4) example: LBS |
The unit of measure of the weight of the container. |
lineItems |
Yes |
object |
line items |
Table 4-557 VendorShipmentCreateLineItemIdo — Object
itemId |
Yes |
reasonId |
Yes |
The unique identier of the shipment reason. |
caseSize |
NA |
quantity |
Yes |
The quantity that was shipped. |
uins |
NA |
string($text128)] example: List [ 111345000, 222220000 ] |
The UINs that were shipped. They total number must match the quantity shipped. |
Responses
This section describes the responses of the Create Shipment API.
Response Code: 200
Successful response.
Schema — VendorShipmentStatusIdo
This section describes the VendorShipmentStatusIdo schema.
Table 4-558 VenderoShipmentStatusIdo
shipmentId |
NA |
number($int15) example: 11111 |
returnId |
NA |
number($int15) example: 5000 |
The identifier of the associated vendor return. |
status |
NA |
The current status of the vendor shipment. Valid values: 1 - New 2 - In Progress 3 - Submitted 4 - Shipped 5 - Canceled Enum: [ 1, 2, 3, 4, 5 ] |
Read Shipment
This section describes the Read Shipment API. This API retrieves all the details about an vendor shipment.
Request
Table 4-559 Read Shipment — Request Parameters
| Parameters | Required | Data Type | Description |
shipmentId |
Yes |
Responses
This section describes the responses of the Read Shipment API.
Response Code: 200
Successful response
This media type is application/json.
Example Value
"shipmentId": <shipmentId>,
"storeId": 5000,
"supplierId": 5101,
"status": 1,
"notAfterDate": "2024-08-28T09:29:33.327Z",
"contextId": 90000,
"destinationAddress1": "460 Summer Street",
"destinationAddress2": "Apartment 2",
"destinationAddress3": "c/o John Smith",
"destinationAddressCity": "Coolsville",
"destinationAddressState": "NY",
"destinationAddressCountry": "US",
"destinationAddressPostalCode": "55555-1111",
"billOfLadingId": 55601,
"carrierRole": 1,
"carrierId": 123,
"motive": "Overstock",
"dimensionId": 100,
"weight": 12.8,
"weightUom": "KG",
"requestedPickupDate": "2024-08-28T09:29:33.327Z",
"fiscalDocumentStatus": 1,
"fiscalDocumentRejectReason": "Missing Requirements",
"fiscalDocumentUrl": "http://fiscaldoc/doc123",
"createDate": "2024-08-28T09:29:33.327Z",
"submitUser": "smith123",
"submitDate": "2024-08-28T09:29:33.327Z",
"dispatchUser": "smith123",
"dispatchDate": "2024-08-28T09:29:33.327Z",
"updateDate": "2024-08-28T09:29:33.327Z",
"cartons": [
"status": 1,
"cartonDimensionId": 1000,
"weight": 4.5,
"weightUom": "LBS",
"createDate": "2024-08-28T09:29:33.328Z",
"updateDate": "2024-08-28T09:29:33.328Z",
"approvalDate": "2024-08-28T09:29:33.328Z",
"approvalUser": "smith123",
"lineItems": [
"lineId": 2222222,
"shipmentReasonId": 2222222,
"caseSize": 3,
"quantity": 100,
"uins": [
111345000,
222220000
]Schema — VendorShipmentIdo
This section describes the VendorShipmentIdo schema.
Table 4-560 VendorShipmentIdo — Object
shipmentId |
NA |
storeId |
NA |
supplierId |
NA |
vendorReturnId |
NA |
NA |
status |
NA |
The current status of the vendor shipment. Valid values are 1 - New 2 - In Progress 3 - Submitted 4 - Shipped 5 - Canceled Enum: [ 1, 2, 3, 4, 5 ] |
notAfterDate |
NA |
authorizationCode |
NA |
contextId |
NA |
A unique identifer of a context for the shipment (see shipping service). |
contextValue |
NA |
destinationAddress1 |
NA |
destinationAddress2 |
NA |
destinationAddress3 |
NA |
destinationAddressCity |
NA |
destinationAddressState |
NA |
destinationAddressCountry |
NA |
destinationAddressPostalCode |
NA |
billOfLadingId |
NA |
A bill of lading identifier. |
alternateAddress |
NA |
carrierRole |
NA |
The type of carrier for the shipment. Valid values are 1 - Sender 2 - Receiver 3 - Third Party Enum: [ 1, 2, 3 ] |
carrierId |
NA |
carrierServiceId |
NA |
NA |
NA |
motive |
NA |
string($text120) example: Overstock |
A motive for the shipment. |
taxId |
NA |
trackingNumber |
NA |
dimensionId |
NA |
weight |
NA |
weightUom |
NA |
NA |
fiscalDocumentRequestId |
NA |
The identifier of the request for a fiscal document. |
fiscalDocumentReferenceId |
NA |
The unique identifier of the fiscal document |
fiscalDocumentNumber |
NA |
The fiscal document number. |
fiscalDocumentStatus |
NA |
The status of the fiscal document. Valid values are 1 - Approved 2 - Submitted 3 - Rejected 4 - Canceled Enum: [ 1, 2, 3, 4 ] |
fiscalDocumentRejectReason |
NA |
string($text255) example: Missing Requirements |
A reason the fiscal document was rejected. |
fiscalDocumentUrl |
NA |
string($text255) example: |
A URL to the fiscal document. |
createUser |
NA |
The user that created the shipment. |
createDate |
NA |
The date the shipment was created. |
submitUser |
NA |
The user that submitted the shipment. |
submitDate |
NA |
dispatchUser |
NA |
The user that dispatched the shipment. |
dispatchDate |
NA |
updateUser |
NA |
The user that last updated the shipment. |
updateDate |
NA |
| cartons | NA | object | cartons |
Table 4-561 VendorShipmentCartonIdo — Object
cartonId |
NA |
integer($int15) example: 100200300 |
externalCartonId |
NA |
status |
NA |
The current status of the carton. Valid values are 1 - New 2 - In Progress 3 - Completed 4 - Shipped 5 - Canceled Enum: [ 1, 2, 3, 4, 5 ] |
cartonDimensionId |
NA |
weight |
NA |
weightUom |
NA |
trackingNumber |
NA |
The tracking number of the container. |
restrictionLevel |
NA |
The hierarchy restriction level for items in the container. Valid values are1 - Department 2 - Class 3 - Subclass 4 - None Enum: [ 1, 2, 3, 4 ] |
createDate |
NA |
createUser |
NA |
The user that created the carton. |
updateDate |
NA |
updateUser |
NA |
The user that last updated the carton. |
approvalDate |
NA |
The date the carton was approved. |
approvalUser |
NA |
The user that approved the carton. |
| lineItems | NA | object | line items |
Table 4-562 VendorShipmentLineItemIdo — Object
lineId |
NA |
The unique identier of the line record. |
itemId |
NA |
shipmentReasonId |
NA |
caseSize |
NA |
quantity |
NA |
uins |
Na |
string($text128) example: List [ 111345000, 222220000 ] |
Update Shipment
This section describes the Update Shipment API. This API updates the header portion of a shipment as well as its bill of lading information. See carton related operations for creating or updating cartons on the shipment.
Request
Table 4-563 Update Shipment — Request Parameters
shipmentId |
Yes |
Shipment header details to update
Example Value
"notAfterDate": "2024-08-28T12:54:48.823Z",
"contextId": 90000,
"addressType": 1,
"carrierRole": 1,
"carrierId": 123,
"motiveId": 123,
"dimensionId": 100,
"weight": 20.4,
"weightUom": "KG",
"requestedPickupDate": "2024-08-28T12:54:48.823Z",
"notes": [
"The first note",
"The second note"
Schema — VendorShipmentUpdateIdo
This section describes the VendorShipmentUpdateIdo schema.
Table 4-564 VendorShipmentUpdateIdo — Object
notAfterDate |
NA |
authorizationCode |
NA |
contextId |
NA |
contextValue |
NA |
addressType |
NA |
The hierarchy restriction level for items in the container. Valid values are 1 - Department 2 - Class 3 - Subclass 4 - None Enum: [ 1, 2, 3, 4 ] |
carrierRole |
Yes |
carrierId |
NA |
carrierServiceId |
NA |
alternateAddress |
NA |
NA |
NA |
motiveId |
NA |
The unique identifier of a mtoive for the bill of lading. |
taxId |
NA |
trackingNumber |
NA |
dimensionId |
NA |
The idnetifier of a dimension object associated to the shipment. |
weight |
NA |
number($decimal(12,4)) example: 20.4 |
weightUom |
NA |
NA |
notes |
NA |
string($text2000) example: List [ "The first note", "The second note" ] |
A collection of up to 100 notes to be added to the list of notes. |
Submit Shipment
This section describes the Submit Shipment API. This API submits a vendor shipment placing it into submitted status awaiting review and eventual dispatch. Fiscal document data capture can occur as part of this process.
Request
This section describes the request paramters.
Table 4-565 Submit Shipment — Request Parameters
shipmentId |
Yes |
Fiscal document information to include as part of the submission.
Example Value
"vehicleNumber": "ABC-222",
"vehicleStateOrCountry": "New York",
"driverName": "John Smith",
"driverLicenseNumber": "HBAC-123456"
}Schema — VendorShipmentFiscalSubmitIdo
This section describes the VendorShipmentFiscalSubmitIdo schema.
Table 4-566 VendorShipmentFiscalSubmitIdo — Object
vehicleNumber |
NA |
string($text25) example: ABC-222 |
The vehicle license plate or identifying number. |
vehicleStateOrCountry |
NA |
string($text25) example: New York |
The vehicle's state or country. |
driverName |
NA |
string($text30) example: John Smith |
The name of the driver. |
driverLicenseNumber |
NA |
string($text30) example: HBAC-123456 |
The driver's liscence number. |
Cancel Submit Shipment
This section describes the Cancel Submit Shipment API. Cancels the submission of a shipment moving it back to in progress state.
Request
Table 4-567 Cancel Submit Shipment — Request Parameters
shipmentId |
Yes |
Dispatch Shipment
This section describes the Dispatch Shipment API. This API dispatches the shipment to the destination, closing the shipment, and updating inventory.
Request
Table 4-568 Dispatch Shipment — Request Parameters
shipmentId |
Yes |
Cancel Shipment
This section describes the Cancel Shipment API. This API cancels the shipment. This will close the associated vendor return.
Request
Table 4-569 Cancel Shipment — Request Parameters
shipmentId |
Yes |
Create Carton
This section describes the Create Carton API. This API adds a new container to a new or in progress shipment.
Request
Table 4-570 Create Carton — Request Parameters
shipmentId |
Yes |
The unique identifier of the shipment. |
The request body is applicaton/json.
Details for the carton to create.
Example Value
"weight": 4.5,
"weightUom": "LBS",
"lineItems": [
"caseSize": 3,
"quantity": 100,
"uins": [
111345000,
222220000
}Schema — VendorShipmentCartonCreateIdo
This section describes the VendorShipmentCartonCreateIdo schema.
Table 4-571 VendorShipmentCartonCreateIdo — Object
externalCartonId |
NA |
trackingNumber |
NA |
restrictionLevel |
NA |
cartonSizeId |
NA |
weight |
NA |
weightUom |
NA |
lineItems |
Yes |
object |
line items |
Table 4-572 VendorShipmentCartonCreateLineItemIdo — Object
itemId |
Yes |
reasonId |
Yes |
caseSize |
NA |
quantity |
Yes |
uins |
NA |
string($text128 example: List [ 111345000, 222220000 ] |
The UINs that were shipped. The total number must match the quantity shipped. |
Responses
This section describes the responses of the Create Carton API.
Reason Code: 200
Successful response
Schema — VendorShipmentCartonStatusIdo
This section describes the VendorShipmentCartonStatusIdo schema.
Table 4-573 VendorShipmentCartonStatusIdo — Object
shipmentId |
NA |
cartonId |
NA |
The identifier of the new carton. |
status |
NA |
The current status of the vendor shipment. Valid values are 1 - New 2 - In Progress 3 - Completed 4 - Shipped 5 - Canceled Enum: [ 1, 2, 3, 4, 5 ] |
Update Carton
This section describes the Update Carton API. Updates a previously existing carton that is in a new or in progress state, on a shipment that is also new or in progress.
Request
Table 4-574 Update Create — Request Parameters
| Parameters | Required | Data Type/Example | Description |
cartonId |
Yes |
The unique identifier of the shipment carton. |
Details for the carton to update.
Example Value
"weight": 4.5,
"weightUom": "LBS",
"lineItems": [
"caseSize": 3,
"quantity": 100,
"uins": [
111345000,
222220000
}Schema — VendorShipmentCartonUpdateIdo
This section describes the VendorShipmentCartonUpdateIdo schema.
Table 4-575 VendorShipmentCartonUpdateIdo — Object
externalCartonId |
NA |
trackingNumber |
NA |
restrictionLevel |
NA |
cartonSizeId |
NA |
weight |
NA |
weightUom |
NA |
lineItems |
Yes |
object |
Line items |
Table 4-576 VendorShipmentCreateLineItemIdo — Object
itemId |
Yes |
reasonId |
Yes |
caseSize |
NA |
quantity* |
Yes |
uins |
NA |
Confirm Carton
This section describes the Confirm Carton API. This API confirms a carton indicating the carton is ready for dispatch. This sets the carton so it can no longer be modified.
Request
Table 4-577 Confirm Carton — Request Parameters
cartonId |
Yes |
Cancel Carton
This section describes the Cancel Carton API. This API cancels a carton effectively removing its contents from the shipment.
Request
Table 4-578 Cancel Carton — Request Parameters
cartonId |
Yes |
Open Carton
This section describes the Open Carton API. This API opens a previously confirmed carton so that it can be modified again.
Request
Table 4-579 Open Carton — Request Parameters
cartonId |
Yes |
REST Service: Warehouse
This service integrates warehouse and warehouse item foundation data as well as warehouse item inventory adjustments.
Asynchronous warehouse integration is processed through staged messages and is controlled by the MPS Work Type: DcsWarehouse.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/warehouses
API Definitions
API |
Description |
Import Warehouses |
Imports a collection of warehouses into the system. |
Delete Warehouse |
Deletes a warehouse from the system. |
Import Items |
Imports a collection of warehouse items. |
Delete Items |
Deletes warehouse items from the system. |
Import Adjustments |
Imports a collection of warehouse items adjustments that took place. |
Import Inventory |
Imports a collection of warehouse item inventory to update the inventory positions. |
API: Import Warehouses
This will import warehouses through foundation warehouse processing.
If more than 500 warehouses are sent in a single call, an input too large error will be returned.
API Basics
Endpoint URL |
{base URL}/import |
Method |
POST |
Successful Response |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of warehouses to import |
Output |
None |
Max Response Limit |
500 |
Input Data Definition
Attribute |
Data Type |
Required |
Description |
warehouses |
List of details |
Yes |
A list of warehouses to import. |
Detail Data Definition
Attribute |
Data Type |
Required |
Size |
Description |
warehouseId |
Long (10) |
Yes |
The warehouse identifier. |
name |
String (150) |
Yes |
150 |
The name of the warehouse. |
organizationUnit |
String (15) |
15 |
The organization the warehouse belongs to. |
countryCode |
String (3) |
3 |
The ISO country code of the warehouse. |
currencyCode |
String (40) |
3 |
The ISO currency code of the warehouse. |
Example Output
"warehouses": [
"warehouseId": 64,
"name": "DownTownWarehouse-1",
"organizationUnit": "70001",
"countryCode": "IN",
"currencyCode": "INR"
"warehouseId": 65,
"name": "CitynWarehouse-1",
API: Delete Warehouse
Deletes a warehouse. The warehouse will not be deleted if any items remain ranged to the warehouse.
API Basics
Endpoint URL |
{base URL}{warehouseId}/delete |
Method |
POST |
202 Accepted |
Processing Type |
Synchronous |
Input |
None |
Output |
None |
N/A |
Path Parameter Definitions
Attribute |
Definition |
warehouseId |
The internal identifier of the warehouse. |
API: Import Items
API Basics
If more than 5000 items are sent in a single call, an input too large error will be returned.
Endpoint URL |
{base URL}/{warehouseId}/items/import |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous (High Volume) |
Input |
A list of warehouse items to import |
Output |
None |
5000 |
Attribute |
Definition |
warehouseId |
Attribute |
Data Type |
Required |
Description |
items |
List of details |
Yes |
A list of warehouse items to import. |
Detail Import Data Definition
Attribute |
Data Type |
Required |
Description |
itemId |
String (25) |
Yes |
The item identifier. |
standardUom |
String (4) |
Yes |
The standard unit of measure of the item. |
status |
Integer |
Yes |
The status (See Index: Warehouse Item Import Status) |
clearInventory |
Boolean |
Yes |
True indicates that the inventory positions should all be set to zero. |
Example Input
"items": [
"itemId": "100000147",
"standardUom": "EA",
"status": 1,
"clearInventory": true
"itemId": "100000148",
"standardUom": "KG",
"status": 2,
"clearInventory": false
Additional Data Definitions
Warehouse Import Item Status
Value |
Definition |
1 |
ACTIVE |
2 |
DISCONTINUED |
3 |
INACTIVE |
API: Delete Items
Marks warehouse items for later deletion.
API Basics
Endpoint URL |
Method |
POST |
202 Accepted |
Processing Type |
Asynchronous |
Input |
List of item ids to delete |
Output |
None |
5000 |
Attribute |
Definition |
warehouseId |
Attribute |
Data Type |
Required |
Description |
items |
List<String(25)> |
Yes |
A collection of up to 5000 items to remove. |
Example Input
"itemIds": [ "100000301", "100000147" ]
API: Import Adjustments
A list of warehouse adjustments is processed, inventory is updated for the warehouse items, and then the adjustments are discarded.
They are not persisted anywhere and this process does not produce a transaction history record.
API Basics
Endpoint URL |
{base URL} {warehouseId}/adjustments/import |
Method |
POST |
202 Accepted |
Processing Type |
Input |
A list of warehouse adjustments to import |
Output |
None |
5000 |
Attribute |
Definition |
warehouseId |
Attribute |
Data Type |
Required |
Description |
adjustments |
List of details |
Yes |
A list of adjustments that occurred for that warehouse. |
Attribute |
Data Type |
Required |
Description |
itemId |
String (25) |
Yes |
The unique item identifier. |
quantity |
BigDecimal |
Yes |
The quantity to be adjusted. |
reasonCode |
Integer |
Yes |
The unique reason code of an inventory adjustment reason code. |
Example Input
"adjustments": [
"quantity": 100,
"reasonCode": 182
"itemId": "100000024",
"quantity": 50,
"reasonCode": 183
API: Import Inventory
This operation updates the inventory positions of a warehouse.
API Basics
Endpoint URL |
{base URL}/{warehouseId}/inventory/import |
Method |
POST |
200 Accepted |
Processing Type |
Asynchronous |
Input |
List of items with their inventory |
Max Input |
10,000 items |
Output |
N/A |
N/A |
Attribute |
Type |
Definition |
Items |
List of Warehouse Inventory |
A list of items to overwrite inventory for at the warehouse. |
Warehouse Inventory Ido
Attribute |
Type |
Definition |
itemId |
String(25) |
quantityTotal |
BigDecimal(12,4) |
The total quantity of the item in inventory. |
quantityReserved |
BigDecimal(12,4) |
he quantity reserved for outgoing shipping. |
quantityUnavailable |
BigDecimal(12,4) |
The quantity unavailable for usage. |
quantityInTransit |
BigDecimal(12,4) |
The quantity in transit to the warehouse. |
Example Input
"items
"quantityTotal”: 100,
"quantityReserved”: 8
"quantityTotal”: 50,
"quantityInTransit”: 183
