Email Introduction AMI Customer Education Report - Business
The email Introduction Customer Education Report is the first report business customers receive in the program. By default, it is delivered 30 days after smart meter installation. It provides an introduction to smart meters as well as personalized hourly and daily energy use insights. It also encourages customers to engage with other AMI programs and communications offered by the utility.
This image shows an example of the Introduction Email for business customers.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
In addition to the configuration options listed in the table below, be aware that the text that appears in this communication can be configured to meet the needs of your utility. The default, recommended text appears in the image above. If you want to update the default text, contact your delivery team. For detailed information about the default language and user experience, see the Product Overview.
Configuration Option Input Value
Introduction
Only minor text changes should be made to the report introduction.
Default: "<Name>, Your smart meter gives your business powerful new insights into how you use energy!"
Optional
Choose one of the following:
  • Use the default option.
  • Talk to your Service Delivery Manager for introduction text editing options.
