Embedded Widget Configurations
If you are embedding widgets on your website using custom events, you must provide the full URLs of the test and production pages in which your widgets will be embedded. Your Oracle Utilities Delivery Team needs these URLs to configure the widgets and ensure that the custom events will work properly. Typically you will provide these URLs after you have worked with your Delivery Team to identify the pages where your widgets will be embedded.
For more information about embedding widgets with custom events, see Improving User Experience Scenarios with Custom Events in the Digital Self Service - Energy Management Embeddable Widgets Integration Guide.
Embedded Widget URLs
Provide the URLs of the pages for all of the widgets you choose to embed on your website. If you choose to embed the widgets on separate pages, provide all applicable URLs.
| Widget Name | URL of Page |
UAT Tier URL: Production Tier URL: |
Green Button - Download My Data
Note: This widget is often embedded on multiple pages. Ensure all applicable pages that embed the widget are listed. |
