Adding Actions to the Billing Accounts Summary
You can use VB Studio to add custom actions to the Actions menu on the Billing Accounts Summary screen. This screen is available in CX for Utilities Sales.
You can add these types of actions:
- Open URL action
- Navigate to page action
This example shows how to add either an open URL action or a navigate to page action to the menu.
This example assumes that the reader is familiar with Account 360 and understands how to use Visual Builder. For additional information, see:
Using Account 360 in the Using CX for Utilities Sales Guide
The Visual Builder Studio library in the Oracle Help Center
Customizing Variables and Constants in the Extending Oracle Cloud Applications with Visual Builder Studio Guide
Example: Adding an Action Menu Item to the Billing Account Summary
Log into CX for Utilities Sales as an administrator and navigate to Account 360.
- Select the Show Contacts action from the Search bar and click on Edit Linked Billing Accounts.
Click the menu at the top right of the page and select Edit Page in Visual Builder Studio.
Select your workspace and click Select. Note that you can also create a new workspace if needed.
In the App UIs panel, open billing-accounts-summary-start page.
- Select the e11y-user-action-template fragment and configure.
Select the Variables sub-tab to display the constants and variables.
Click on the USER_ACTION_CONTEXT_LIST constant.
On the right side of the screen, enter the following sample code in the Default Value field, making sure that any params that you include in your code sample are also included in your URL.
[ { "id": "CUSTOM_ACTION_NAME", "label": "Custom Menu Label", "active": true, "context": { "type": "Url", "url": "https://custommenuname.html?component=${component}&demo=${demo}&testId=${testId}", "params": [ { "name": "component", "value": "menu" }, { "name": "demo", "value": "overview" }, { "name": "testId", "scope": "ext" } ] } } ]Note:
You can also add a navigate to page action by replacing the above code sample with this code sample:[ { "id": "CUSTOM_ACTION_NAME", ... }, { "id": "NAVIGATE_ACTION_NAME", "label": "Navigate to activities page", "active": true, "context": { "type": "InAppNavigation", "appName": "cx-sales", "appPage": "application/container/accounts/accounts-detail", "windowName": "_blank", "params": [ { "name": "puid", "alias": "keyAccountPartyNumber" }, { "name": "view", "value": "activities" } ] } } ]Note:
You can also add a custom event by replacing the above code sample with this code sample:[ { "id": "ACTION_CUSTOM_EVENT", "label": "Test Custom Event", "active": true, "context": { "type": "CustomEvent", "eventId": "billingAccountSummaryActionsEvent", "eventData": { } } } ] -
If there are Visual Builder extension params that you want to use in action meta-data's context params, complete these steps to provide your Visual Builder extension params:
Return to the billing-accounts-summary-start tab and select the Variables sub-tab.
Click on the USER_ACTION_PARAMS_MENU_ACTIONS constant.
In the Default Value field, enter the value mapping for extension params:
[{ "name":"testId", "value":"[[$page.variables.testId]]" }]
Click on the JSON sub-tab to display a view where you can easily edit this sample code and update the code sample so it reflects your custom values.
Return to the Variables sub-tab and click on the USER_ACTION_UI_MENU_ACTIONS constant.
In the Default Value field, enter the ID you used in your code sample above. For example, enter ["CUSTOM_ACTION_NAME"] in this field.
Preview your changes to verify that they look as you expected. This will launch a new tab with the Account 360 in the billing account summary view. Validate that your new option is available, and that it navigates to the appropriate URL.
When your changes are ready for use, complete the steps to publish your changes to your production environment.
Parent topic: Use Cases for Customer Experience for Utilities
