Home Energy Analysis Call-to-Action
The Home Energy Analysis Call-to-Action widget encourages customers to complete the Home Energy Analysis in order to receive better tips.
Example screenshot with a prompt asking if the user wants better tips, inviting them to answer questions for a personalized energy breakdown, and a button labeled "Start now."
Embedding Guidelines
Widget Name: widget-hea-cta
Full Embedding Code: <opower-widget-hea-cta opower-instance="widget-hea-cta"></opower-widget-hea-cta>
  • It is recommend that you embed this widget at the top of the Ways to Save page so that customers see a natural connection between the tips and the Home Energy Analysis. You can also embed it near other widgets that display tips, such as Tips Light and Tips List.
  • Be aware that this widget is hidden for customers who have completed the Home Energy Analysis survey, so it must be embedded in a way that accounts for this behavior.
  • You can also consider embedding this widget on an account overview dashboard to use minimal screen space while also directing customers to complete the survey.
