Home Energy Analysis Light
The Home Energy Analysis (HEA) Light widget encourages customers to complete the HEA survey if they have not taken it already, and displays an energy use disaggregation for customers who have completed the survey. The widget is designed to be included in the Smart Dashboard or embedded on other utility-hosted webpages to promote the survey and lead customers to the full Home Energy Analysis experience.
There are two versions of Home Energy Analysis Light—version 1 and version 2—and there are significant differences in the user experience between them. The guidance on this page applies only to version 2 since only version 2 can be embedded. Contact your Delivery Team if you have questions about which version of the widget you have, and to discuss options for upgrading if necessary.
Survey Prompt
The HEA Light survey prompt is shown if a customer has not started or not completed the survey. The appearance of the prompt varies depending on the survey status. If the customer has not started the survey, the widget displays a prompt to start it. If the customer has started but not completed the survey, the widget shows a progress bar and prompts the customer to complete it.
Example: Survey Not Started
Image of a Survey Not Started for the home energy analysis light survey which gives an introduction of what the survey includes and a button that links to the survey
Example: Survey Started, Not Completed
Image of a survey started, but not completed for the home energy analysis survey which displays the percentage of the survey that has been completed so far and a link to the survey.
Disaggregation
The HEA Light disaggregation displays a breakdown of the customer's top three categories of energy use. There are two pathways to displaying the disaggregation in the HEA Light widget:
  • After the survey is completed, the HEA Light widget is updated to display the disaggregation.
  • Before the survey is completed, the HEA Light widget shows a disaggregation so that customers have quicker access to the results. In this case, the survey prompt described above is hidden, and customers can still take the survey to update their answers.
The HEA Light disaggregation, which displays a breakdown of the customer's top three categories of energy use and a button to see more details about their energy use.
Embedding Guidelines
Widget Name: widget-hea-cta
Full Embedding Code: <opower-widget-hea-cta opower-instance="widget-hea-cta"></opower-widget-hea-cta>
  • It is recommend that you embed this widget at the top of the Ways to Save page so that customers see a natural connection between the tips and the Home Energy Analysis. You can also embed it near other widgets that display tips, such as Tips Light and Tips List.
  • Be aware that this widget is hidden for customers who have completed the Home Energy Analysis survey, so it must be embedded in a way that accounts for this behavior.
  • You can also consider embedding this widget on an account overview dashboard to use minimal screen space while also directing customers to complete the survey.
