EV Thanks Module
The EV Thanks module is used to tell the reader that driving an EV is impacting their community in a positive way. The module thanks the reader for driving an EV, and tells them that their community thanks them for helping to create a healthier environment, while also saving on fuel and maintenance costs.
Requirements
There are no module-specific requirements for this module.
Design
This is an example of the EV Thanks module:
This is an example of the EV Thanks module.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Table 6-9 Configuration Options
Configuration Option Input Value
Images
The image can be configured to use client-specific colors. Other than that, the image can not be changed.
Optional
Specify client branding colors.
To see how this module fits into the overall user experience, see Design and Configuration.
