Introduction Module
The Introduction module provides a projection of how much the customer could spend on their utility bill if they continue their spending behavior through the end of the billing period.
Design
This image shows an example of the Introduction module with an energy costs experience:
The introduction module which displays a visual along with a projected bill amount.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Options Input Value
Budget Billing Language
A note regarding how high usage will affect the customer's bills in the future is included.
Default: As a budget billing consumer, your costs may increase in the future if you use more energy than usual.
Optional
Choose one of these options:
Use the default statement.
Use the following statement:
