Embedded Widget Configurations
If you are embedding widgets on your website using custom events, you must provide the full URLs of the web pages in which the widgets are embedded. For information on embedding widgets using custom events, see the Oracle Utilities Opower Embeddable Widgets Integration Guide.
Embedded Widget URLs
Provide the URLs for all of the widgets you choose to embed on your website. For rows that include multiple widgets the recommendation is to embed all widgets on the same page. If you choose to embed the widgets on separate pages, provide all applicable URLs and the corresponding widget. Ensure you provide the complete URL.
Feature and Widget Names URL
Rates Light
widget-rates-light
Rate Comparison
widget-rates
