Push the LED indicator module and cable through the LED housing on the
server front panel [1].
Install the LED indicator module cable by carefully pulling the cable
through the cable trough along the left side of the chassis.
To ease installation of
the LED indicator module cable, slightly lift the SAS or NVMe cable bundles
from the cable trough along the left side of the chassis.
Cable part number 7315469
is required for the LED indicator module.
Insert and tighten the two No. 2 Phillips screws to secure the LED
indicator module to the server front panel [1].
Install the FIM cable and Temperature Sensor Access cover to the
chassis by inserting it into the FIM cable and Temperature Sensor Access
cover slot [2].
Caution:
Be careful
not to damage the temperature sensor when installing the FIM cable and
Temperature Sensor Access cover to the chassis.
Install the three No. 2 Phillips screws to secure the FIM cable and
Temperature Sensor Access cover to the chassis [2].
Reconnect the LED indicator module cable to the motherboard.
You might need to disconnect the
SAS cable connections from the Oracle Storage 12 Gb SAS PCIe RAID HBA, Internal
card or NVMe cable connections from the Oracle Retimer card in PCIe slot 10 to
access the LED indicator module motherboard cable connection. See Servicing SAS
Cables or Servicing NVMe Cables.
