Disconnect the LED indicator module cable from the motherboard.
You might need to disconnect the
SAS cable connections from the Oracle Storage 12 Gb SAS PCIe RAID HBA, Internal
card or the NVMe cable connections from the Oracle Retimer card in PCIe slot 10 to
access the LED indicator module motherboard cable connection. To ease removal of
the LED indicator module cable, slightly lift the SAS or NVMe cable bundles from
the cable trough along the left side of the chassis. See Servicing SAS
Cables or Servicing NVMe Cables.
Remove the three No. 2 Phillips screws that secure the FIM cable and
Temperature Sensor Access cover to the chassis [1].
Lift up and remove the FIM cable and Temperature Sensor Access cover from the
FIM cable and Temperature Sensor Access cover slot [1].
Set aside the FIM cable and Temp Sensor Access cover.
Remove the front LED indicator module [2].
Remove the two No. 2 Phillips screws that secure the LED indicator
module to the server front panel.
Remove the LED indicator module and cable from the server front
panel.
Remove the LED indicator module cable by carefully pulling the cable
through the cable trough along the left side of the chassis.
