15 Servicing the Front LED Indicator Module
The following section describes how to service the front LED indicator module. The front LED indicator module is a replaceable component. For more information about replaceable components, see Illustrated Parts Breakdown and Replaceable Components.
Caution:
The front LED indicator modules should be removed and replaced only by authorized Oracle Service personnel.Caution:
Ensure that all power is removed from the server before removing or installing a front LED indicator module. You must disconnect the power cables before performing this procedure.Caution:
These procedures require that you handle components that are sensitive to electrostatic discharge. This sensitivity can cause the component to fail. To avoid damage, ensure that you follow electrostatic discharge safety measures and antistatic practices. See Electrostatic Discharge Safety.This section covers the following procedures:
