Create the Oracle E-Business Suite Integration
This integration is triggered by the main integration, once for each record in the Oracle Taleo Enterprise Cloud Service export file. Each time the integration is triggered it imports information about a candidate into Oracle E-Business Suite, and returns an employee number. Later, this number is added to the candidate’s record in Oracle Taleo Enterprise Cloud Service.
Create an Integration Triggered by an Application Event
Create an integration that’s triggered by another integration.
Use the Oracle E-Business Suite Adapter to Import Data
Use the adapter to send information from each record that’s read from the export file to Oracle E-Business Suite.
- From the Invokes panel, click Oracle E-Business Suite, and drag the EBSImport adapter to the + after the EBS_CANDIDATE_CREATE endpoint on the integration canvas.
- Name your endpoint EBS-Import, and click Next.
- From the Product Family list, select Human Resources Suite, and from the Product list, select iRecruitment.
- From the API list, select Party, and click Next.
- From the Methods list, select Create Candidate Internal, and click Next. On the next screen, click Done.
- Configure the mapping for the EBS-Import endpoint:
- Configure the mapping for the Return action:
- Drag the P_EFFECTIVE_START_DATE element from the Source panel to the P_EFFECTIVE_START_DATE element in the Target panel.
- Drag the P_EFFECTIVE_END_DATE element from the Source panel, to the P_EFFECTIVE_END_DATE element in the Target panel.
- Drag the P_PERSON_ID element from the Source panel to the P_PERSON_ID element in the Target panel.
- Save your changes.
Assign a Business Identifier for the Oracle E-Business Suite Integration
At runtime, the status of business identifiers is visible on the Tracking page and (if integration errors have occurred) the Errors page.
- From the
menu, select Tracking.
- From the Source section, expand execute, request-wrapper, and CandidateData, and drag the EmailAddress field to the Drag a trigger field here section.
- Drag FirstName and LastName to the Drag a trigger field here section. Ensure that EmailAddress is marked as the primary identifier.
- Click Done, and click Save.
