Editing a Project (BUI) To modify project properties, use these steps. From the Shares menu, select Projects. Select a project in one of the following ways: Hover over the project and click the edit icon . Double-click the project name. Click the arrow icon next to Projects to expand the panel, then click on the project name. The project is selected, and tabs are displayed for editing the properties. Click one of the tabs to edit the project properties. Modify the project properties for the project as needed. Project properties are described in Project Properties. If file retention is set, review section File Retention Management. Retained projects and their files cannot be modified, even after their expiration. However, with the proper user role authorization, you can edit the file retention periods. Related Topics Snapshots and Clones Remote Replication File Retention Management
