PreviousNext
JavaScript must be enabled to correctly display this content
Editing a Project (CLI)
To modify project properties, use these steps.
Go to shares.
hostname:> shares
Enter select and a project name.
hostname:shares> select home
To list the project properties, use the get command.
To modify the project properties, use the set command. Project properties and values are described in Project Properties. For example, to enable vscan for this project, enter the following command:
hostname:shares home >set vscan=true
If file retention is set, review section File Retention Management. Retained projects and their files cannot be modified, even after their expiration. However, with the proper user role authorization, you can edit the file retention periods.
