Deleting a signal comment type
You can delete signal comment types if you have the Manage Signal Configurations permission.
If you delete a comment that is applied to a drug-event combination, the comment remains visible when you view the signal history. However, you cannot use the comment as a filter on the Drug-Event Combinations and Drug Comments pages.
To retain the ability to use a comment as a filter, set the following properties to No for the comment instead of deleting the comment:
For more information, see the field descriptions in Adding a signal comment type.
1.         Click Settings.
The Settings page appears.
2.         In the Configure System section, click Manage Signal Configurations.
The Manage Signal Configurations page appears.
3.         Click the row menu (Row menu) for the signal configuration, and then click Edit Comment Types.
The Edit Comment Types window appears.
4.         In the table, locate the comment to delete.
5.         Click Delete for the comment.
6.         Click Close.
Related Topics
